Topic: iPod manager (Read 2269429 times) previous topic - next topic
0 Members and 20 Guests are viewing this topic.
[seemingly abandonware] iPod manager
Reply #3550
hey,
i'm not sure if this has recently been mentioned (as a search bought up old threads) but there appears to be a problem again with importing Playback Statistics from the ipod into foobar.
i've only just noticed this & tried rolling back to 0.6.9.6 but to no avail, so i'm not 100% sure when it started.
using foobar2000 v1.1.7, foo_dop 0.6.9.7 & playcount 3.0.2
any suggestions whould be greatly appreciated
Reply #3551
Since the latest update to Quicktime (7.7) a couple of days ago, I get a crash every time foobar is closed. Removing foo_dop fixes these crashes. I'm using foobar v1.1.7 and foo_dop 0.6.9.7 on Windows 7 Pro 64. I also confirmed this by doing a system restore to before the update and all worked fine again until the update was re-applied.
(snip)
I can confirm this on Win7 x64 SP1.
Reply #3553
Same crash problems here with win7-64sp1 and latest itunes/quicktime
Reply #3554
Sorry to be one of these people, but I'm having issues with running this awesome plugin.
It used to work fine, however for some reason I can't get it to work again.
System is 13" macbook pro 2010 model
OS is Windows Server 2008r2 (same as when I previously was using it)
Device is iPhone 4, running a jailbroken 4.3.3 iOS
Pre reqs are installed (iphonecalc and the two apple packages).
I just have no device showing in foobar ("no ipod found") My device is set to sync manually for music and I'm flat out stumped
Any help would be greatly appreciated thanks
Reply #3555
I've run into a snag with the plugin. Every playlist I've made since I started using ipod manager exclusively gets deleted whenever I plug in my ipod. To test it I made a playlist on my ipod, then updated a preexisting playlist. The one I updated is still there, but the new one was gone. This happens with genius playlists too. I know I can make a new playlist in foobar through manage contents, but I don't plug in my ipod often and its frustrating to see my playlists constantly disappear. Is there anything I can do about this? I have a 4g touch.
Reply #3556
foo_dop plug in works great except some titles show "libgpod"
What is causing this error with the metadata? I have about 50 titles showing this, cannot seem to figure out which tracks it is. Tried in Music Bee, displays fine, and of course it does in iTunes.  I really want to leave iTunes far behind, after this iPod wears out, it's another brand of player.
Reply #3557
First of all, i love the plugin, its great and worked perfectly for me the last months, but all of a sudden new Tracks get added without titles, but only tracknumbers as title tag...
I tried different versions, but all do the same...
not sure where the problem is, so i would appreciate every hint i can get
W7/iPod Classic 120GB
Reply #3558
I've been using the plugin for my iPod and it has worked wonderfully. I'm trying to do the same with my iPhone 4, but I'm not having as much luck.
When trying to sync music, I receive this error:
"DB Version 5 requires iPhoneCalc.dll. Write operations are disabled."
However, I have what I believe is the most up-to-date version of iPhoneCalc.dll in my components folder. I also have Apple Application Support and Apple Mobile Device Support.
Windows 7
foobar2000 v1.1.7
iOS 4.3.5 (8L1)
Please let me know if you need more information. Thank you for your help!
Reply #3559
I have it in my foobar2000 home folder, i'm not sure if it works in components
Reply #3560
I moved it to the home folder and syncing works perfectly. Thanks!
However, I have run into another problem, and this time I'm not sure if there's a simple fix. I use Audioscrobbler as well, and when archiving the tracks from my iPhone I ran into some issues with garbled text in the tags. However, it seems playing songs straight from fb2k does not result in incorrect tags.
I'm not sure if this is a problem with the iPod manager or Audioscrobbler. I can ask this question somewhere else if it isn't appropriate here.
Again, thanks for all your help!
Reply #3561
So, I have all my album artwork saved in my album folder and named "folder.jpg". The foobar2000 album art viewer is able to pick everything up.
However, when I use foo_dop it only sends album art info for about half of my library. In the preferences I have the source script specified as "folder" and specify it to "additionally use foobar2000 built-in artwork reader".
Does anybody know what preferences I need to change to get it to pick up the album artwork.
Reply #3562
Hello, I'm using foobar2000 v1.1.8 beta 6, audioscrobbler, and foo_dop.
When I Rewrite the database and submit tracks for scrobbling, if I have played a track multiple times on my ipod, it's only count for once. Is there any solution for this? Thanks
Reply #3563
I have a question to your component. I am using a iPhone3GS and foobar 1.XXXX. I am synchronizing it and it works perfect, but I dont have any Covers on my iphone after synchronization. I marked the "save cover to file", but the problem is, i dont have the covers in folder, I already saved them to mp3tag with program "mp3tag". So the cover is already in file.
So what do i have to do, to get the covers to the iphone?
Thanks for you help!
Reply #3564
Hey everyone,
I tried the synchronization "ipod manager" tool with foobar and it works really great. The only problem is, that I already have the covers of the albums (mp3) in tag. And now, after synchronizing with foobar no album covers are shown on the ipod.
In the ipod manager i can choose "copy cover to the tag", but they are already in the tag and I dont have then in a folder. So what can I do, to see the covers on the iPod too?
Thanks for your help!
Reply #3565
Hey everyone,
So I have figured it out: Just click on "Write cover to Tag" and it will take the covers in tag!
Reply #3566
Hey!
I've got a iPhone 4 (4.3.3) and a iPod Classic 120GB. There's some music on my iPhone and now I want to change it. So I turn on Foobar2000 as usual, plug in my iPhone and then go to File -> iPod -> Load library. Then it tells me "No iPod found". I then try the same with my iPod, no issue with that one.
I've installed iphonecalc.dll, Mobile Device Support and Application Support, I also installed the whole iTunes package just to be on the safe side. No luck. On my other computer, where I added the music to my iPhone, it works just as it's supposed to and I did exactly the same thing on that one. So... I need some help over here.
Reply #3567
I keep getting an error message saying "Failed to query SQL post process commands. Write operations are disabled." whenever I try to put anything on my ipod.
And I have no idea how to take stuff OFF of my ipod.
Reply #3568
New to this forum and would appreciate help. Installed Foobar 2000, foo_dop etc but foobar doesn't recognise iPod ('no iPod found'). Can't get past this.
Reply #3571
Which iPod do you have?
Does the Console in foobar2000 say anything?
Reply #3573
Help! My iPhone / iPod touch is not detected!
Make sure you enabled mobile devices support in preferences.
Make sure you have iTunes (or at least Apple Mobile Device Support and Quicktime) installed
If you receive a “Could not locate matching USB device for Apple Mobile Device” message, this can normally be fixed by uninstalling/reinstalling Apple Mobile Device Support. It can be uninstalled from the control panel. To reinstall, extract the installer from the iTunes installer using 7-Zip and run it.
If you receive a “Failed to pair device” message, this means that for some reason the component was not be able to pair the device with your OS/computer. If the device is locked with a passcode, you will need to unlock it and then restart foobar2000 to try again. If all else fails, you can try connecting the device to iTunes once on the same OS install. Alternatively, you may be able to copy the encryption keys, normally located in %allusersprofile%\Apple\Lockdown\ OR %appdata%\Apple Computer\Lockdown\, from another OS install.
Also check what messages are displayed in the foobar2000 console.
Tried all that?
Reply #3574
Tried all that?
1. Tunes is installed but not running as I read there may be clashes if Foobar is running as well.
2. No 'failed to pair device message.
3. Where is the foobar 2000 console to be found?
