hey marc, thanks for a great work...
unfortunately i'm having a problem =>
error message:
Scripting Engine Initialization Failed (Playcount Sync by marc2003, CODE: 0x80020101)
Check the console for more information (Always caused by unexcepted script error).
console:
WSH Panel Mod (Playcount Sync by marc2003): Parsing file "C:\Users\xxx\AppData\Roaming\foobar2000\marc2003\common.js"
WSH Panel Mod (Playcount Sync by marc2003): Parsing file "C:\Users\xxx\AppData\Roaming\foobar2000\marc2003\tooltip_buttons.js"
Error: WSH Panel Mod (Playcount Sync by marc2003): Microsoft JScript runtime error:
Automation server can't create object
Ln: 372, Col: 1
as you previously (and in the read me) said, i unchecked, rechecked and unchecked "safe mode" in wsh panel mode several times to no avail - error persists
any help, pls?
edit:
versions of required components i installed:
wsh panel mod 1.4.3
custom database 0.1.0_beta1
soft playlists 2011-02-05
