Topic: foobar sampling rate (Read 23659 times) previous topic - next topic
Hi!
Could somebody please help me out! I want to know what sample rate foobar gives out to external DAC without using resampler, for exaple, if i play 16bit/44.1khz audio than that would come out, but if i play 24bit/96khz will that be native output or will it be downsapled to 16/44.1 without using resampler? in other word will that what comes in goes out or do I have to specify sample rate?
That depends on your OS and output method, which version is your OS (Vista/7/XP) and what output set in Foobar Preferences -> Output?
Depends on input decoders too.
I use windows7 64bit. In foobar kernel streaming output.
With Kernel Streaming, WASAPI and ASIO the samplerate coming out of your sound card matches the input file. Bit depth is what you have configured in the output preferences. With DirectSound sample rate is what you have set Windows mixer to use.
In foobar preferences:advanced - decoding is tone/sweep saple rate:44.1 What is that?
That is the sample rate for virtual files added using the Add Location dialog, with the URL format:
tone://frequency,seconds
or
sweep://frequency-frequency,seconds
THANK YOU
