Topic: [Not My Release] EsPlaylist (Read 339513 times) previous topic - next topic
Reply #375
Senna: Please make all mainmenu commands hidden by default (inclusiv View -> EsPlaylist -> ....) . Thanks
Reply #376
EsPlaylist v0.1.3.5 (2010/12/02) released.
Changelog:
  • fixed (perhaps): non-ASCII key didn't work in typing search (without using IME).
  • いい加減日本語の説明を追加。(保守するか不明)
Download EsPlaylist v0.1.3.5
For those who can't read Japanese, the google translation of the second bullet is: "Add a description of the Japanese already. (Unknown or maintenance)"
@ssenna, thank you very much for the pseudo-transparency option for the search toolbar, I don't know since which version it is implemented, as I 've just found it
Decalicatan Decalicatan
Reply #378
right click -> options -> configure
Reply #380
Feature request:
Either...
a.) The ability to define your own the typefind parameters. I am trying to achieve a layer where I can see all of my albums (album art only), but being able to typefind via album artist instead of album title (e.x. typing "Metallica" would take me to the first album in my library by Metallica, rather than the first album named "Metallica"). I can circumvent this by including the album artist in the Title field of the grouping, but that ends up cutting off the album titles. Which leads me to an alternative request...
b.) The ability to use $crlf() within the Title field of the album. This would allow me to include the album artist in the title, thus being able to typefind by album artist. I wouldn't have to worry about the album title being truncated, as it would be on a new line. I could also include more information under the album artwork should I choose to. Alternatively, it would be useful to be able to display the Side Info below the album artwork.
If there are any solutions to this problem that are already implemented, please post them!
Thanks ssenna for this awesome component!
Reply #381
How could i change the distance between two artworks ? There are too much pixels for me between each artwork, weight and height.
E.
Reply #382
Hi:
I have been using ELPlaylist for a long time and most of the time it works great.
But from time to time, album covers are not displayed in the playlist. To get covers back,
I have to exit foobar2000 and restart foobar2000 again. Any idea?
ftc
Reply #383
Sorry. I just put the above question under the wrong topic.
Reply #384
This plugin has pushed foobar2000 ten years forwards in terms of UI - thanks so much! It was truly the only thing missing
I wonder about two things:
  • Like asked before, what does the last item on the Artwork selection list ("icon") mean?
  • What difference does it make which item is crossed of (if any) under Preferences -> Preset setting??
I would also like to ask, if you might implement smooth scrolling in the up-level view? The scroll becomes kind of uneven, as the headers from even higher views make it jump in uneven intervals, changing between the height of the cover art and the height of the header. Also, I think it would give a more smooth experience.
You might consider reducing the white-space in the up-level view a bit as well. When the cover art column looks nice in the flat level, I get three items across in the up-level with a lot of white-space.
Reply #385
Here is another suggestion!
How about making the max height of the Group Info column match the max height of either the artwork or the group itself?
The way it is now, all text beneath the edge of the cover art gets cut off. This text could easily be displayed as long as the group was higher (i.e. had more items/lines).
With this plugin I aim for the DRY principle - don't repeat yourself. I have weeded out all columns that repeated the same info throughout the group. However, I am having a little trouble fitting some albums' multitude of genres in the side info column, as the info gets cut off (unless I make the artwork column very big)
Reply #386
Hey, I know you've been getting a lot of feature requests lately, but can you consider implementing one more?  I'd just like a main menu command to focus the search bar (similar to clear query and show/hide display).  This way I can map CTRL+F to playlist search.  Thanks.
Reply #387
F6 maybe ?
Reply #388
Thanks, I didn't know about that.  That more or less takes care of my need, but the ability to remap it to another key would be nice too.
Reply #389
I've got one problem I'd like to know how to fix:
The text next to the album art was black from the beginning so I wanted to change it. So I changed the color for "EsPlaylist" element first, I chose white.
Then I went on to change the color of the Group Titles to white as well (both selected and all the other), all the albums that are not selected, the text for them is white.
Though... the Group Title for the SELECTED item is black, even though I've chosen WHITE in the preferences.
Any one who knows anything about this and how to fix it?
Reply #390
Strange. Today when I started Foobar2000 again... this problem was gone. Ah well.
Reply #391
A few more corrections to the component:
  • When the playlist has been auto-filled by Facets the commands (go to up-layer/down-layer) don't work before something is selected
  • After applying tags (and downloading cover art) with the Discogs plugin the playlist should be refreshed
  • Sometimes it is a bit difficult dragging elements on the playlist. Maybe I ought to test more, but it is like one has to be very firm when clicking on the elements to drag them (after selecting them first) - sometimes nothing happens.
Reply #392
confirm.
Reply #393
I'd still really like to get these two answered:
Reply #394
* AFAIK, the "icon" is for an embedded icon for the codec but it may only implemented in FLAC
* AFAIK, the crossed item is the default grouping level when you select a preset grouping: for example if you have a preset with 2 grouping level: the upper one for the artist and the lower for the album. The latter is the one checked. Then the first time you select this grouping, the EsPlaylist will show the album grouping level
Reply #395
The last one is definitely true - thank you  With "embedded icon" do you mean embedded cover art? This is pretty normal with mp3 files as well.
Which leads me to another feature request: It would be great to be able to choose a special image like a "folder image" to display with groups that have no natural cover art (like "main genre")! Right now I have pointed my top level groups to the Artist art and have chosen a nice placeholder image for artist under Display preferences. But the moment one of my albums gets an image called artist.jpg in its folder, the group will of course display that image instead...
Reply #396
http://www.hydrogenaudio.org/forums/index....st&p=592289 : Icon would be used only when an image marked as "file icon" is embedded in file's metadata.
But I don't know what this exactly means
Reply #397
Thank you. My wish for setting a specific icon for groups at one layer still stands, then.
I have yet another feature request/correction: When all elements in a group are selected (manually) the group header should be selected automatically as well. The way it is now it is kind of random when the group header is selected, which may be confusing for some. Thanks for listening
Reply #398
Most important request:
Could you make typing in the Search bar overrule the keyboard shortcuts? I believe that is the only thing missing from being able to use the spacebar and arrow keys for playback control.
Reply #399
@Senna GREAT PLUGIN!!!
simple Feature request
Would be great if "hold left mouse button and move mouse down" would scroll down in library view (instead of selecting the albums as is the case now).
This would make it more compatible with windows 7 touchscreens
