Topic: Discussion of "Default UI Gallery" (Read 388337 times) previous topic - next topic
Reply #425
would you mind sharing your config  Hitchhiker427 or at least the scripts for WSH Panels
Reply #426
Just a quickie...how do you disable the menu bar and the status bar?
That's a very good question...you'd think it would be simple but after looking for a way for awhile last night, I can't find anything in the main menu or Preferences either. I'm sure there's an answer by editing a cfg file or something, but I'm new to foo and still finding my way around. Man, what a plethora of styles can be had with this app, and it seems that just about anything is possible in a way, but the initial learning curve can be daunting for the non savvy users. Fortunately I'm a loooong time tech help/security forum expert so I can learn fairly quickly, but it's still quite the task....and also allot of fun too!
I'm gonna have some questions for y'all soon, hope you don't mind a new foo newb poking around the dark recesses of your brains for awhile
Take care!
Dave
Reply #427
There is no way to disable main menu and status bar in the Default User Interface.
They can be disabled in the alternative Columns UI, though.
Reply #428
There ya go...
Thanx Yirkha. Not that I'm looking to do this, but I don't like to see little questions like this go unanswered, so I just wanted to help it along.
BTW, does anyone know of a thread anywhere where people have exchanged different EQ presets for others to try? I like to experiment with other folks settings.
Also, couldn't help but notice your sig note too...how true! In some poorly moderated forums you see thread after thread of huge posts quoted and requoted, without any trimming, and it just makes reading that thread a horrific PITA! I mean...how hard is it to delete excess cruft before you reply to a quoted post?
Damn I'm having fun learning FB2K!
Dave
Reply #429
Hit me up with some good color schemes. I got bored with 75% dark background, white text and pastel color of choice highlight : / Now using total white with black text.
Reply #430
Reply #431
Your image did not show for me. Maybe too large?
Nevertheless:
1. do you mean window title?
You can not get rid of foobar notation. However, you could add something like $repeat(' ',70) to the end of your string and it will push foobar towards the right. Replace number with whatever works for you and your window size.
2. Can not hide column heading in Default User Interface
3. No idea. Hacking an executable for such a small thing seems a bit pointless - good luck
terry
PS: image now showing
Reply #432
@tflogic:
2) To remove the column headings, try using EsPlaylist instead of the Default UI playlist.  It allows this.
3) I believe that the arrow icon is located in foo_ui_std.dll.  Try hacking that.
Reply #433
Nevertheless:
terry
1) yeah, the window title. i tried adding that piece of code to the end of the string but since it exceeds the character limit on my taskbar, it just adds "..." at the end.
2) really? seems like a simple option.
3) well, reshacking an icon or bmp usually takes less than 30 seconds if you know where it can be found. it has to be somewhere! someone must have tried this before me.
Reply #434
Hitchhiker, thanks so much for the help! However, there is one problem I encountered with using EsPlaylist versus the regular playlist viewer. Since I don't need album art, I disabled it in the group settings, trying to emulate my playlist in that screenshot above. However, where the albumart displays, there's an extra column taking up space on the left side of the playlist viewer. Right clicking on it doesn't allow me to remove it but instead only allows me to insert other columns to the right of it. How do I delete that column?
Reply #435
just resize it so it doesn't take any space.
Reply #436
Silly question that doesn't deserve it's own thread: Is there a titleformatting string that can return the installation path of foobar?
Reply #437
ok, i got a question and i can't find the answer anywhere (or maybe overlook it)
here's my DUI
Uploaded with ImageShack.us
I want to change "Library Search" with "Playlist Search", in other words, is there a way to use Playlist Search as UI Element?
or maybe change the playlist search window behaviour to behave like winamp, use a (global) hotkey then the playlist search window pop up (on top of other window) regardless foobar window is active/not
any help is much appreciate, thanks before D:
Reply #438
i've just added EsPlaylist to my layout as well. it's coming along nicely now.
I really like you're configuration  , do you still have it ? and do you mind sharing ?
Edit : OOps, Wrong thread.. I thought I moved to the discussion one.
Sorry for the bad english, I'm french .
Reply #439
Really liking this configuration.
How do I get the Images part? Is it part of the latest foo_uie_biography? And are the playback buttons self made or from an icon pack that is, right now, elusive to me?
Reply #440
My current layout with buttons changed...
Maybe I'm just stupid, but how do you get that simple info area that's in the bottom of this config? The one under the "Now Playing" tab I mean...
Reply #442
anyone knows where i can find some default UI buttons ? i know i need ico or png 16x16 only.. but i'm getting frustrated because i cannot find any  maybe is there a way to convert fcb files to png or ico ?
i don't want to install any other UI, just to keep it plain simple but with other buttons because the default ones are just too white and hard to find in a hurry. thanks.
Reply #445
Run Services
http://www.foobar2000.org/components/view/foo_run
Wikipedia
http://en.wikipedia.org/wiki/Special:Search?search=$replace(%album artist%, ,_)
YouTube
http://www.youtube.com/results?search_query=$replace(%artist%+%title%, ,+)&aq=f&ie=utf-8
Discogs
http://www.discogs.com/search?q=$replace(%album artist%, ,+)
Last.fm
http://www.last.fm/music/$replace(%album artist%, ,+)
Reply #448
Thank you so much.
