Topic: foo_audioscrobbler 1.4.7 (Read 928358 times) previous topic - next topic
Reply #901
Great plugin, I use it from longtime.
I have only a question, Is it possible to submit the song as "loved track"?
I don't find this feature, possibly for me inability, I have see that another player have this opportunity.
If it is not possible, no problem
Sandro
Reply #902
Sandro
You can do this with foo_softplaylists
http://www.hydrogenaudio.org/forums/index....showtopic=76133
Reply #903
Thank you very much it works fine :-D
Sandro
Reply #904
This plugin although great, is not syncing all my songs played in my iPod and iPhone. I always go to iPod/Rewrite database than i go to Preferences/Audiscrobler to scroble my iPod tracks and very often it says "you're cache contains 0 tracks" but i am sure i have songs that i just played in my iPod. This happens randomly, sometimes it works sometimes it doesn't. Any idea why?
I have the latest plugin of foo dop and audioscrobbler.
Reply #905
You can back up your settings by copying %appdata%\foobar2000\ to another location, or the directories configuration, user-components and (possibly) index-data from the foobar directory when using a portable install. That should make a reinstall less painful.
That didn't seem to do me any good at all. I installed foobar on a new machine, and tried copying the folder from my original computer over, but I still had a completely uncustomized foobar.
Reply #906
Did you use the same type of install?
e.g. If you had a normal installation on the old install using per-user preferences, then copied %appdata%\foobar2000\ to the new install you would have to also have installed normal with per-user preferences. If you do a normal -> portable/normal no per-user then the files would need to go into the foobar folder in Program Files. The best way to find the location to put the files is with Shift + File -> Browse Configuration Folder.
Hmm, looking at my own %appdata% and my post I forgot about theme.fth which stores the Default UI configuration (the UIElements Layout, but not things like media library locations etc). If that was the case I apologise as I'm a Columns UI user and forgot that you also need it. As such I might recommend the Autosave component which will zip up the important files and directories by default.
Reply #907
good plugin )
Reply #909
Scrobbling to last.fm from iPod does not seem to work anymore! I am pretty sad about this!
It used to work fine until recently - I use foo_audioscrobble and foo_dop with an iPod touch 2nd gen and the 4.0 software or whatever, which is supported yet when I sync my ipod my last.fm doesn't update, my cache contains 0 tracks, and playing a song in my library doesn't update last.fm with any of my plays.
I use my ipod more than my PC to listen to music, so this is pretty sad. I may have to go back to using itunes at this rate... or winamp... if I can't scrobble, I'm sad.
Reply #910
Hi Florian, when foo_audioscrobbler submits a song to last.fm the album title doesn't appear in this site. As example, I've submitted this song:
http://www.lastfm.com.br/music/Quinteto+Vi...r%C3%AAncias%29
the mp3 tag album title is "choveu Mantra no Sertão", but it doesn't appear in last.fm register. Is it correct? Is this information filled by scrobblers clients or by the artists?
I'm under win XP SP3, foobar v1.1.1 and foo_audioscrobbler v1.4.7
regards, Luis
singing the beauty of being an eternal learner (Gonzaguinha)
Reply #911
hi there,
i've read some topics noc concerning the audioscrobbler plug-in and everywhere it says you should enable it.
but when i go to preferences>tools, there's onliy "converter", no "audioscobbler". so i can't enable it.
i searched everywhere, what's the problem??
Reply #912
Tools> converter is no longer on the preferences page. What version of Foobar are you using?
I do not use, but I just downloaded and it shows up as expected under Tools > Autoscrobbler
This is with with foobar 1.1.1
terry
EDIT: The above assumes you have downloaded and installed the component before looking for it in preferences.
Reply #913
oh shit, what a fool's mistake: i still have an old version (v0.9.6.9)
another dumb question: how can i save all my settings? esspecially as i have tweaked the whole layout/design
EDIT: ha, the problem was really the version. "preferences" looks now like all the screenshots
thanks!
Reply #914
i need help with fieldremaping/formating.
the stream i hear use a suffix after the title licke 'white pulp – Just Like Me [onAir: Schwarze Welle]' an un my last.fm profil it shows the Titel as 'Just Like Me [onAir: Schwarze Welle]'.
How can i modify the title that it was send without the [onAir: Schwarze Welle]. all i try until now don't work
Reply #915
I want to get rid of a constant suffix " { SOFASPACE }" from online streaming.
Unfortunately, I couldn't find much info about field remapping options :/
Here's an example:
Vibrasphere – Fuzzy Vibes { SOFASPACE }
EDIT: solution found thanks to http://www.tinkafoo.com/log/foobar/titleformat_help.html
[$replace(%title%, { SOFASPACE },)]
It's not perfect but works fine.
Reply #916
@hellward: What you did is just changing what you see, the information got send to last.fm still has the suffix.
I made a new scrobbler based on wsh panel mod available at this thread. It supports user input title manipulation before sending the data off to last.fm. If you have any question regarding using the script ask me there.
Reply #917
I've recently changed my password in last.fm, but foo_audioscrobbler keeps telling me that my username/password is invalid.
I know it's not as I can login to the site with the new password and I have even resorted to using the last.fm app which I don't really like.
Is there something special I should be doing to "clear" the previous password?
Cheers
Del
Reply #918
Hi there!
Maybe someone else asked already, in this case ignore my post.
I wonder if it is possible to put folders in my media library, from wich audioscrobbler not scrobbles. For example: I have some Audiobooks and i'd like to have them in the library but i don't want to scrobble them to last.fm, because i want to use it for music only. Could you implement a blacklist or folder selection option? That would be aweseome!
Reply #919
Hello!
I've just installed the foobar 1.1.1 and the foo_audioscrobbler 1.4.7. The plugin does appear in the installed components list, but doesn't in the tools menu, so i cannot configure it.
Anyone knows how can i solve this?
Reply #920
Check foobar Preferences, it's in there.
Reply #921
A little feature request: I would love to see a feature to turn on/off scrobbling via menu (Playback menu e.g.), because it's a little bit uncomfortable to go always to the preferences menu to turn the audioscrobbler on/off.
Reply #922
It is possible to exclude certain songs of the library from scrobbling?
Reply #923
Sorry, double post.
Reply #924
It only appears in the "components" tab, doesn't appear in "tools", so how can i configure it?
take a look:
