Topic: kabuki's lastFOOdly config (Read 47370 times) previous topic - next topic
Reply #50
Propably not the best place to ask, but as I installed the fonts that came with this skin many webpages started to look strange and disturbing (with new fonts). Any way to revert this? (I don't use the skin, just tested it)
Reply #51
Like I said in a PM, brilliant theme. I can't see it getting any better than this when it comes to Foobar themes.
I would appreciate some help because I couldn't figure out how to
- Change month names to English (in "History")
- Set the path for the default "noartist.png" in all music->years/artists (or genres/artists)
Reply #52
Also (no edit button, sorry)
- Change the options in right click ELPlaylist -> Sort.
thank you
Reply #53
Hello,
First i would like to thank you for this great theme.
But i've got some problems with artist's images, they don't work.
I apologize for this noob question, but what is the code to use images which are located on artist's folder (images associated with albums)?
I try to use this line "$puts(art.path,$replace(%path%,%filename_ext%,)\%artist%.*)" as it is suggested by readme, but it doesn't work. (album's images work very well)
Thank you
(Sorry for my bad english)
Reply #54
This is what I have for artist images:
$puts(art.path,I:\Music\Artist Images\%artist%.*)
It's not going to work without defining your path.
Reply #55
Indeed, you have to right click on the image panel and choose settings. From there, define your path. Do it for albums panel too.
Reply #56
Have you find the solution?
Done for next release. It was an error in code/global value. Corrected now. Wait 'till september.
I will see that.
Could you be more specific?
This is different now, with next release. Using foo_covers, you only have to configure it once, in preferences.
Reply #57
Yep already found the error and corrected it.
When clicking an ELPlaylist panel (such as the right side of the main panel or the History panel) there's a Sort option, to sort by date, number of plays etc. The options are in French. But also I wanted to add another sort method and could not find how by myself/Google. (always nicer to know how to change it yourself.)
next release
Good to know  Though I haven't been studying too hard in the last few days, kept tweaking the theme and my music collection lol.
Reply #58
Maybe i misunderstand you, but are you talking about that ? :
edit: in next release, history sorting will change. It will be possible to sort by year, by month or by day.
Reply #59
Yes that's right... how did I miss that
Reply #60
I recently reisntalled my OS and everything else. Lastfoodly is fine but whenever I try to change something in the settings panel I get a "script error", also de group header doesn't show any images. I'm on XP sp3.
Reply #62
hello! thank you very much for lastFOOdly - i exited to use it and see all the music in my librarry which i have never seen before )
but i have issue about ArtworkView panel - albumart apeear too big there and i set padding 150px in Layout settings. but this in now enough for me - is it possible to make such a simple border around albumart picture? (5px white + 20px gray)
Reply #63
Hello.
Please refer to the first post if you are interested by using last version of LastFoodly config.
I've been inactive since july 2010, but following the forum, actively in july/august. Not much from September, due to another activity.
So in august, i've changed some little things, following other user/developper's works.
This new version is dated from that time... so sorry if some of those works/codes have changed since.
You can test it if you want.
@Kkamion: sorry to have been so long to consider your request. As you can see, your last reminder mail have convinced me to take this necessary time
Here is a very quick changes Log, if needed:
-Muzack's Charts (v1.0 b5) section added, and twicked.
-Infos panel was "littlely" modified, with Marc2003's work integrated (not updated in my skin since august)
-Properties panel added to the Tags section
-The config includes now "track's fingerprint system" (foo_biometric) for determining a unique track's signature
-Other things that I can't remember well
-Cover's path are simpler to manage, using foo_cover2 component.
Maybe some "other user's part of code" are out of date, at least, components are (normally all, at least those watched by AutoUpdate system) updated in the package.
As for the first version, please consider those step first:
1-Download the zip
2-Download last version of foobar2000
3-FULL options available, Install foobar2000 in portable mode in C:\
DON'T RUN after install (uncheck the option, before quiting installation window)
4-drop the zip in C:\foobar2000\
5-then "extract here" once, then "extract here" the zip included so all folders will be in there good place
6-read the readmefirst included, if not done before or to refresh your mind about the step by step configuration
7-enjoy it if you still like it.
Kind Regards.
Reply #64
Thanks for sharing once again
I had trouble starting it for the first time because foo_uie_explorer crashed it upon start. Removing foo_uie_explorer.dll.cfg in configuration folder solved the problem.
Reply #65
Thanks to you again kkamion. For the report too.
I've upload a version with the foo_uie_explorer.dll.cfg removed.
I hope it will fix the problem for next downloads.
Reply #66
Same here
YS
Rozzo
Reply #67
thanks once again! been using it since the first time
Reply #68
Hello.
1-Download the zip
Kind Regards.
How i put that shadow under the album cover thumb or artists thumb?
Reply #69
first: sorry for my anglish
now: i am a new coder in foobar2k, and i show you my mod for kabuki lastfoodly:
http://dox.bg/files/dw?a=30a569582b
http://dox.bg/files/dw?a=863d2db457
http://dox.bg/files/dw?a=e312b70232
this is not my idea, i just moding the FooXb script (http://browse.deviantart.com/customization/skins/media/foobar2000/?order=9&offset=216#/d2q6pjz).
script (replace artwork panel/create new and put the code):
1. to splitter settings:
$if($and($isvisible_c(PS1),$isvisible_c(PS0)),
$showpanel(5,1)
$showpanel(0,1)
$showpanel(1,1)
$showpanel(3,1)
$showpanel(4,1)
$showpanel_c(Volume1,0)
$showpanel_c(Volume,1)
$showpanel_c(WSeek,0)
$showpanel_c(Lyric2,0)
$showpanel_c(Rating2,0)
$showpanel_c(Love2,0)
////BackGround////
$imageabs(,,,,Skins/FooX/Images/,backgradk.png,n,255)
$imageabs(-25,-5,,,Skins/FooX/Images/,over.png,6,70)
$drawrect(,,782,496,,100-100-100-255,RESERVED)
$drawrect(315,,1,496,100-100-100-255,,RESERVED)
////Background Channel Spectrum////
$imageabs(60,327,,,Skins/FooX/Images/barw.png,,,10)
////Artist/Title///
$font(Levenim MT,8)
$drawstring(%artist%,33,250,250,20,155-155-155-255,hcenter center nowrap
elipchar,)
$font(Levenim MT,12)
$drawstring(%title%,33,230,250,20,200-25-85-255,hcenter center nowrap elipchar,)
$font(Levenim MT,8)
$if(%ps_isplaying%,,$font(Calibri,50)
$drawstring(0:00,165,$sub(%_height%,80),W,H,0-0-0-30,aa))
///Cover+Rect///
$if($findfile($replace(%path%,%filename_ext%,folder-front.jpg)),
$imageabs(58,15,200,200,%path%,artreader,n,,hcenter)
$drawrect($sub($getlastpos(x),5),$sub($getlastpos(y),5),$add($getlastpos(w),10),$
add($getlastpos(h),10),,150-150-150-255,RESERVED)
$drawrect($getlastpos(x),$getlastpos(y),$getlastpos(w),$div($getlastpos(h),2),255
-255-255-55,,RESERVED)
$drawrect(53,10,210,210,,150-150-150-255,RESERVED)
$drawrect(58,15,200,100,255-255-255-55,,RESERVED)
///MP3 Info////
$imageabs(,425,60,60,icons\%codec%.png,,n,255)
$font(calibri,8)
$drawstring(%bitrate%kbps$char(10)%codec%$char(10)%length%,60,430,,,155-155-155-2
55,left nowrap elipchar,))
$if($not($isvisible_c(PS0)),
$showpanel(0,0)
$showpanel_c(Volume1,1)
$showpanel_c(Volume,0)
$showpanel(5,0)
$showpanel(1,0)
$showpanel(3,0)
$showpanel(4,0)
$showpanel_c(Lyric2,1)
$showpanel_c(WSeek,1)
$showpanel_c(Rating2,1)
$showpanel_c(Love2,1)
//$showpanel_c(ELP2,1)
////BackGround////
$imageabs(,,,,Skins/FooX/Images/backgradk.png,,n,255)
$imageabs(-25,-5,,,Skins/FooX/Images/over.png,,6,70)
$imageabs(560,-5,,,Skins/FooX/Images/over.png,,2,70)
$drawrect(,,782,496,,150-150-150-255,RESERVED)
////Biography$imageabs/////
///Cover+Rect///
$drawimage(216,15,350,350,%path%,artreader,n,,hcenter)
///MP3 Info////
$font(calibri,8)
$if($not($isvisible_c(PS1)),
$showpanel(0,0)
$showpanel(5,0)
$showpanel(1,0)
$showpanel(3,0)
$showpanel(4,0)
////BackGround////
$if($findfile(lastfm\artist/%artist%.jpg),
$drawimage(,-20,,,lastfm\artist/%artist%.jpg,,n,)
//$drawrect(,,782,496,,150-150-150-255,RESERVED)
$imageabs(,,,,Skins/FooX/Images/overh.png,,n,50)
$imageabs(,,,,Skins/FooX/Images/backgrad.png,,n,255)
$imageabs(356,-10,,,Skins/FooX/Images/over.png,,8,50)
//$drawrect(211,150,1,500,150-150-150-255,,RESERVED)
//$drawrect($sub(%_width%,212),150,1,500,150-150-150-255,,RESERVED)
//$drawrect(1,390,310,1,150-150-150-255,,RESERVED)
//$drawrect($sub(%_width%,311),392,310,1,150-150-150-255,,RESERVED)
//$drawrect($sub(315,26),,1,496,150-150-150-255,,RESERVED)
//$drawrect(26,,1,496,150-150-150-255,,RESERVED)
////Artist/Title///
$drawrect(0,310,796,80,0-0-0-155,,RESERVED)
$font(Segoe UI,14)
$drawstring(%artist%,187,323,%width%,%height%,155-155-155-255,left center nowrap
elipchar,)
$font(Segoe UI,14)
$drawstring(%title%,187,345,%width%,%height%,139-190-0-255,left center nowrap
elipchar,)
$font(Levenim MT,8)
$drawstring(%album%,189,369,%width%,%height%,155-155-155-255,left center nowrap
elipchar,)
///Cover+Rect///
$drawimage(60,330,50,50,%path%,artreader,n,,hcenter)
//$drawroundrect(293,17,194,16,2,2,0-0-0-30,R2-G2-B2-A2,)
//$drawstring(,10,10,,,155-155-155-255,left nowrap elipchar,)
///MP3 Info////
$imageabs(2,348,40,40,icons\%codec%.png,,n,255)
$font(calibri,8)
///$imageabs(120,348,50,50,skins\Kabuki\Images\White\Genres\%genre%.png,,n,255)
///$font(calibri,8)
$imageabs(2,310,40,40,skins\Kabuki\Images\White\Flags\%country%.png,,n,255)
$font(calibri,8)
$imageabs(162,260,,,skins\Kabuki\Images\White\Sighn\%music%.png,,n,255)
$font(calibri,8)
for per second:
///Time///
$font(Calibri,50)
$drawstring(%playback_time%,165,414,W,H,255-255-255-30,aa))
$font(Calibri,50)
$drawstring(%playback_time%,$sub(%_width%,140),414,W,H,255-255-255-30,aa))
$font(Segoe UI,18)
$drawstring(%playback_time%,$sub(%_width%,55),322,W,H,150-150-150-180,aa))
And my question: how to switch %genre% with %music%. When i just replace the picture.png (genre dir) is resizing to small one  .
and in new version on script kabuki i can't put/replace the script in art work panel.
Enjoy
Reply #70
and this is the link for my f2k (portable version):http://dox.bg/files/dw?a=fda2ed5889
extract archive  in c:\
Reply #71
What the hell are you linking to that is 135 megs?
Reply #73
Why would someone want images of artists in YOUR library?
If this is an entire installation of foobar, you may want to review the following.
from license to use foobar
Only unmodified installers can be redistributed; redistribution of foobar2000 binaries in any other form is not permitted.
Neither the name of the author nor the names of its contributors may be used to endorse or promote products derived from this software without specific prior written permission.
Reply #74
     i am so sorry to post anything in this forum. this is not happen again.
