Topic: .Ogg Vorbis aotuv (Read 503207 times) previous topic - next topic
.Ogg Vorbis aotuv
Reply #350
Hi there vorbis fans
Aoyumi seems little quiet lately, does anyone of you has any news about the upcoming release?
.Ogg Vorbis aotuv
Reply #351
With news or without It looks like vorbis is dead anyway. At least in regard of actively improvement the quality of the codec.
.Ogg Vorbis aotuv
Reply #352
AoTuV is too mature to be "actively improved" IMHO.
.Ogg Vorbis aotuv
Reply #353
The best measure of the maturity degree  is tests like these ;-)
.Ogg Vorbis aotuv
Reply #354
Everything in the AoTuV tunings will be merged into the main line source for the next major release of libvorbis 1.3.0. That's about it. On top of that an HA forum member compiled an SSE Optimized version of AoTuV tunings and created a 32-bit x86 Linux compile that's about 3x faster then the standard build.
This test does not appear to be a very good indication of anything? This "added noise" everyone talks about is called "Noise Normalization". It's trivial for the lower quality values. It's not used beyond a -q 6. I am not of the impression that one should just keep tuning the encoder consistently as it may cause regressions especially if everything is not double checked and implemented in the mainline after further testing. I am not stating that AoTuV tunings are not very good, because they are. I am just stating there is possibility that might happen with some samples sometimes.
budding I.T professional
.Ogg Vorbis aotuv
Reply #355
Any idea when libvorbis 1.3.0 will be released?
.Ogg Vorbis aotuv
Reply #356
It depends on what projects Xiph is working on and what coincides with their schedule. I would think Monty would be the only one merging the tunings into the main branch, but he is still busy working on Theora. Unless the job is left up to someone else now or another contributor I am really not sure. I wouldn't put a time stamp on anything though!
.Ogg Vorbis aotuv
Reply #357
aoTuV post-beta5.7 [20100314] (wip) released
*Probably "wip" mean "Work In Progress".
This is a test version including an important change of a plan included in in a next version.
[ Limit Quality -2/-1/0 ]
With fixed bug of "-ignore_length" in venc.
And, don't use less or equal -q-1 on 32kHz, libvorbis is buggy
download: http://www.geocities.jp/aoyoume/aotuv/test.html
<name>madoka</name>
.Ogg Vorbis aotuv
Reply #358
Great ! Very happy to see progress however slight!!
Can't wait until this is properly released with source code and all.
.Ogg Vorbis aotuv
Reply #359
For various reasons,  a number of bug fixes and coupled surround support bumped their way way to the head of the line ahead of the AoTuV merge work.  I'm pointing this out here just so no one will think that the work isn't happening— it just hasn't happened yet.
.Ogg Vorbis aotuv
Reply #360
Xiph's and aotuv's work is always appreciated, and is always good to hear positive news about aotuv's .ogg project
I hope that day won't be far away
We all looking forward for the next release
.Ogg Vorbis aotuv
Reply #361
New version of aoTuV released. Click
Download from here.
Woot! 5.1 aotuv!
EDIT: Is anyone else getting problems trying to encode at any quality setting above q0? It just defaults to q0, no matter what you tell it to do!
EDIT2: Apparently it's already been answered. I have to say I find this ridiculous!
.Ogg Vorbis aotuv
Reply #362
will wait for john33
.Ogg Vorbis aotuv
Reply #363
How do you know Xanikseo that it just defaults to q0?
Is it mentioned anywhere?
lets hold on and wait to see what other guys would say
.Ogg Vorbis aotuv
Reply #364
From aoTuV 20100516.txt
[ Limit Quality -2/-1/0/1 ]
If you try to encode with some other quality, it defaults to 0.
.Ogg Vorbis aotuv
Reply #365
Hmmm guess we need to wait longer for the proper version then
.Ogg Vorbis aotuv
Reply #366
from Monty blog, aoTuv is getting merge to the Vorbis main trunk soon
also the new WebM announcement from Google is a really good news to Vorbis, maybe more hardware player will support it now  , things are getting excited again
wow my last visit was: Jan 16 2008, 12:47, it has been awhile, kinda quiet in the audio front lately.
still LAME 3.96.1 --preset extreme -q 0 -V 0 -m s at least until 2005.
.Ogg Vorbis aotuv
Reply #367
give us links
you got any links to the websites you are refering to so we can read also?
.Ogg Vorbis aotuv
Reply #370
Good good keep the updates coming, I'm looking forward to a full release with source code and all . I see slowly more q values are being accepted, now we're up to q2. Hopefully it won't take too long to accept all values of q up to 10...
.Ogg Vorbis aotuv
Reply #371
I ABX tested this latest test build against the killer samples found at the following thread started by sauvage78:
Multi-Codec Listening Tests
At q2 I could still easily ABX the Autechre, Abfahrt and Kraftwerk samples. Especially Autechre I could ABX at every try.
.Ogg Vorbis aotuv
Reply #373
aoTuV post-beta5.7 [20100718] (for tester)
aoTuV [20100718] (r510) [ Limit Quality -2/-1/0/1/2 ]
Sorry for my English.
.Ogg Vorbis aotuv
Reply #374
Unfortunately I do not make those samples a target this time.
Therefore, I may not anticipate the so big improvement with those samples.
Cranberries___zombie_partial2 is also easy at -q2.
In comparison with the former (beta) version, how?
You please tell me about it if you feel that it is bad than before.
This is a bugfix version of "20100711".
The new problem by the specific pattern in the previous version was fixed.
