Topic: FooNight FooDay (Read 162345 times) previous topic - next topic
FooNight FooDay
Reply #175
I tried the solution posted earlier in this thread to get the icons for the Links section of the Utils tab to show up, but they still don't.  I looked at the config window again, and it has the correct paths to the images, but they're not showing up.  Any ideas?
FooNight FooDay
Reply #176
hey i read the installation file on the needed components,where do i get those? I googled them and got nothing much =/
foo_exvar.dll
foo_ui_columns.dll
foo_uie_biography.dll
foo_uie_elplaylist.dll
foo_uie_library_tree.dll
foo_uie_lyrics.dll
foo_uie_panel_splitter.dll
foo_uie_quicksearch.dll
foo_uie_textbox.dll
foo_uie_vis_channel_spectrum.dll
foo_uie_wsh_panel_mod.dll
foo_vis_shpeck.dll
FooNight FooDay
Reply #177
foo_exvar.dll
foo_ui_columns.dll
foo_uie_lyrics.dll
foo_uie_textbox.dll
foo_vis_shpeck.dll
http://foo2k.chottu.net/
http://yuo.be/columns.php
http://wiki.hydrogenaudio.org/index.php?ti...:Components_0.9
You should be able to find what you need with these sites.
FooNight FooDay
Reply #178
Hey,thanks but after i downloaded all of them and try importing the theme,it says that the layout import was aborted because the following required panels are not installed.
Lyrics Show
WSH panel mod
But i installed them already but maybe mine was a different one?
Mine was
foo_uie_lyrics_panel.dll
foo_uie_wsh_panel.dll
FooNight FooDay
Reply #180
libgpng and zlib libraries libraries are installed?
FooNight FooDay
Reply #181
You need this two components:
http://foo-wsh-panel-mod.googlecode.com/fi...el_mod-1.1.9.7z (wsh panel mod)
http://www.hydrogenaudio.org/forums/index....ost&id=4810 (lyrics show)
Thanks for the help man  I got one more question,in the read me,it says The following variables can be set in foo exvar (optional): i can't find this foo exvar thing on the preference tab where do i find it?
FooNight FooDay
Reply #182
Nope, they weren't, that fixed it.  Now it seems that only the Google button works, though.  Is there something else I have to change?
FooNight FooDay
Reply #183
I got a little tired of not having icons for the utils, and since qwertz's link was dead, I've created icons for the run services he has in his links section.
You can get it here.
There's an .fcb which you can import or you can just use load the icons individually. I have two versions of allmusic's, the one they use, and one where I added a border that I think looks slightly better. Yes, I am that anal
FooNight FooDay
Reply #184
In the read me,it says The following variables can be set in foo exvar (optional): i can't find this foo exvar thing on the preference tab where do i find it?
Why does mine look different compared to yours,and why are the album covers for all the artists the same?
FooNight FooDay
Reply #185
Anyone have a good alternative to the playlist switcher tabs, or know how to skin them so that they fit in with foonight? As they are, they stick out and look kind of ugly when you turn them on.
FooNight FooDay
Reply #186
@StrangeProgram
Do you have foo_exvar.dll installed? If so, look closer. Nobody is going to help you, if you don't provide further information.
@MioTheGreat
Preferences -> Playlist Switcher -> uncheck Multiline Tabs
The tabs are optional anyway, there is a "normal" playlist switcher plus Library Tree in foonight, check the readme.
FooNight FooDay
Reply #187
Yeah i have installed the theme already and under preference i can't find it,sorry for sounding noobish.
FooNight FooDay
Reply #188
exvar = Extended Variables
FooNight FooDay
Reply #189
Exvar stands for "Extended Variables" that you can find in the Preferences menu that you indicate, under "Tools"
You've got everything you need mate!
FooNight FooDay
Reply #190
hello all.. im new in here..
i just want to ask what the function PL button that in the bottom left.. is that playlist ??
FooNight FooDay
Reply #191
Hello Nitez,
indeed PL stands for Playlist, it enables you to manage your playlists thanks to this menu with the usual right and lef clicks. Do you have the grey PLtask bar that appears (with Default and Libray view) when you click on this PL button? Otherwise check all your components are updated and well installed.
See you
FooNight FooDay
Reply #192
Hello Nitez,
See you
yes in the PL task that appears default but no library view.....
so if i want when click that PL task all my song list are appears what i have to do ??
FooNight FooDay
Reply #193
Hello Nitez,
See you
Hey!
Not sure I understand all you meant to say but it seems that you're looking for the link to have all your music to appear and that will be the "Al" buttom at the top left that will do it. The PL button enables you to create your own playlists from the albums you have and switch between them during music playing..
Hope that it answers your question, otherwise maybe try to reformulate your question!!! )
Cheerio
FooNight FooDay
Reply #194
Hey,thanks for the help all  but if u look at the screenshot i posted above,i'm still wondering why all my album art looks the same.
FooNight FooDay
Reply #195
Hey!
Cheerio
i mean if i drag all my music then right click then enqueque in foobar2000 then all my music are listed in PL button ..
btw how to creat my own playlist ??
FooNight FooDay
Reply #196
Hey!
Cheerio
- First click on Al button so that you have your Library in the left window of Foobar
- Then Left click on PL button to have the Playlist menu
- Right click on the grey bar
- Left Click on "New" and name it as you want
- Then go in your library, find the song you want to add to your PL and simply drag it on your new PL tab!
And that's it, repeat the operation for all the songs you want to add to the PL!!
Not a tough job really!!
FooNight FooDay
Reply #197
Hello!
I instaled the 'skin' and now my album list got all messy.
On the Fil tab songs from one album are all together, but on the Al tab, some the albums got separated, it looks like there is a different album for every ( or every few songs), but the album name is the same.
And the tags are all right.
------------- Toll 1999 Aenima------------
Track 1
Track 2
Track 3
--------------Tool 1999 Aenima
Track 4
Track 5....
Does anyone know why?? How to fix it? Tried reinstaling, didnt work.
FooNight FooDay
Reply #198
Hello!
Track 1
Track 2
Track 3
Track 4
Track 5....
Fixed it by clicking sort by date command, but i need to do it specially for each artist, is there any way to click sort by date desc for all playlists???
I figured out media library scaner wont add some of the files(albums), he just keeps ignoring them like the albums arent in the folder... weird ...and annoying. Anyone had this problem??
Is there any way to turn off the right left scroll bar on the album list tab??
FooNight FooDay
Reply #199
Where do they get separated? The playlist or the Library Tree?
