Topic: [Feature Request] Audio CD's open in their own playlist (Read 2920 times) previous topic - next topic
I play audio CD's a bit. When I put a CD in, it automatically opens up in Foobar2000, but however the tracks always goes to the playlist that is set in Preferences -> General -> Windows Shell Interaction -> Always send new files to playlist. Once that happens, I have to drag and drop the files into another playlist that I use solely for audio discs, then I have to go back to the 'file drop' playlist to remove the tracks that I copied over.
So my feature request for foobar2000 is a setting that if enabled, when a CD is put into the computer the tracks automatically go to the specified CD playlist instead of the playlist used for Windows Shell Integration.
main menu -> File -> Open Audio CD ... -> Play
The CD will be played in its own playlist
That works.
However, I want CD's to be automatically added to their own play list, and that was the subject of my feature request.
I have not tested it but as a solution for the present you can try the following:
Insert a CD, hold "shift" pressed until the CD drive is closed (this deactivates the AutoPlay function temporarily), create an autoplaylist named "CD-drive" with code
%path% HAS "d:\"
(replace d: with the letter of your CD drive).
Does this help?
%path% HAS "d:\"
Does this help?
I tried that, and it did not work. I even added my CD drive to the list of monitored folders.
