Topic: foo_DeleteCurrent (Read 41525 times) previous topic - next topic
foo_DeleteCurrent
How can I prevent that foobar is maximised everytime the confirmation window appears?
I don't want to disable the confirmation itself, though.
foo_DeleteCurrent
Unfortunately, the only way is to disable the confirmation. A message box must be attached to an existing window, otherwise it always appear behind other windows.
N.
foo_DeleteCurrent
Hey!
It's a great plugin. But it will be useful for me the folowing function:
Move the currently playing file to a specified folder.
Can you do that?
Thank you
foo_DeleteCurrent
Hey!
Can you do that?
Thank you
Hello.
This could be the purpose of another component, but it is very unlikely I will be the one who creates this function.
Regards
Nicolas Hatier
foo_DeleteCurrent
^^ it´s possible with foo_fileops
foo_DeleteCurrent
Reply #30
The component has been updated with an option to delete without confirmation.
http://www.niversoft.com/downloads/foo_DeleteCurrent.zip
Hey, where can I find this option?
Hello,
I just have downloaded and installed the tool. Unfortunately, I still have the message appearing:
"Do you want to delete current playing song? The file will be moved in the Recycle Bin if possible."
In the Assigned shortcuts I have selected: "Playback => Delete current song"
Any ideas how to turn off this message?
foo_DeleteCurrent
Just registered here to say thank you again for creating this. I've been using it four about 3 years
Re: foo_DeleteCurrent
Here's how to disable the confirmation window when deleting songs to Recycle Bin using foo_DeleteCurrent plugin:
Menu toolbar Playback - uncheck Ask for confirmation before deleting.
Reply #33
Hello Niver,
I just registered to thank you for making this plug-in. I like to listen to entire discographies and this function is incredibly useful.
Thank you!
Reply #34
Yeah, very useful.
I used this function in the good old foo_AdvancedControls, where it was integrated.
Great to see, there is a standalone version! Thanks Nicolas from Niversoft!
Just to put some more information to my "thanks":
Hugh Tash made a nice screenshot from the menu, where you find new options, and
you always can find new options/functions via the "Feature Watcher" component foo_whatsnew by foosion.
Reply #35
Is there any way to create a similar plugin that renames or moves the currently playing file?
foo_MoveCurrent
foo_RenameCurrent
One can make keyboard shortcuts to custom rename or move a file, but only when it is not currently playing. So one has to stop the playback first.
It would be so helpful for speedy sorting through large folders of mp3s, to do that with the push of a single button.
Reply #36
I use Autohotkey to do this. Basically it:
Makes sure the foobar window exists and is activated
Sends the shortcut to stop playback.
Sends the shortcut whatever "Context -> File Operations -> Move to" you want
Handles the dialog window for the move operation
Resumes playback
I then also have a similar hotkey to use foo_DeleteCurrent which works the same way, allowing you to delete/move the currently playing file, without foobar window currently in focus, resume playback. Optionally you could return focus to whatever program windows you previously had focused.
Here is a messy example that you would need to tweak for your configuation.
; ---- FOOBAR Move Playing Track to Library
^Numpad0::
SetKeyDelay, 10, 10
IfWinNotexist, %Foobar%
return
IfWinExist, %Foobar%
WinGet, current_ID, ID, A
previous_ID := current_ID
WinActivate
WinWaitActive, %Foobar%, , 2
if ErrorLevel
    MsgBox, WinWait timed out (Foobar).
    return
else
;BlockInput On
Send {NumpadDot}
Sleep,500
Send {Alt Down}
Send m
;Send {Numpad0}
Send {Alt Up}
WinWait, File Operation Preview, ,4
if ErrorLevel
    MsgBox, WinWait timed out (File Operation Preview).
;BlockInput Off
    return
Send {Space}
WinWaitClose
if ErrorLevel
    MsgBox, WinWaitClose timed out (File Operation Preview).
;BlockInput Off
    return
Sleep, 1000
SetKeyDelay, 10, 10
;ControlSend, , {Alt Down}{F11}{Alt Up}, ahk_class {97E27FAA-C0B3-4b8e-A693-ED7881E99FC1}
;Send {Delete}
Send {Numpad8}
;BlockInput Off
return
;BlockInp
