Topic: Lyrics Grabber Feedback & Discussion (Read 257032 times) previous topic - next topic
Reply #175
In foobar that's how we'd do the string simplification for common tag fields - easy (untested code, just to give an idea) :
$replace($lower($ascii(%album artist%)), ,,&,,",,'',,(,,-,,_,,),,=,,#,,{,,[,,\,,@,,],,°,,+,,},,$,,£,,%,,*,,',',,;,,:,,!,,?,,.,,/,,§,,)
$replace($lower($ascii(%album%)), ,,&,,",,'',,(,,-,,_,,),,=,,#,,{,,[,,\,,@,,],,°,,+,,},,$,,£,,%,,*,,',',,;,,:,,!,,?,,.,,/,,§,,)
$replace($lower($ascii(%title%)), ,,&,,",,'',,(,,-,,_,,),,=,,#,,{,,[,,\,,@,,],,°,,+,,},,$,,£,,%,,*,,',',,;,,:,,!,,?,,.,,/,,§,,)
Hope you get the idea. If we can do the same for the lyrics web sites data and compare the resulting strings, we'll have solved the problem, don't you think ?
BTW it would be nice if Lyrics Grabber could parse the %album artist% field BEFORE the %artist% field. I have the feeling that it only parses the %artist% field, which can lead to errors in many songs (e.g. all duets where %album artist% = name1 and %artist% = name1; name2)
Reply #176
By now you could have made same python scripts  so why not try it? It's easy.
i.e. if you want to experiment improving some script by above suggestions, look for something like this in the script:
[font= "Lucida Console"]artist = handle.Format("[%artist%]")[/font]
and then change it to:
[font= "Lucida Console"]artist = handle.Format("[%artist%]").lower().replace('#','').replace('!','')[/font]...
only be careful with indentation
[edit] grammar
Reply #177
def RemoveInvalidChars(field, replacing=['#','!' ETC]):
          field = handle.Format(field).lower()
          for n in replacing:
                  field = field.replace(n,'')
          return field
artist = Fields("[%artist%]")
Less code which is easier to maintain? It's probably some bugs or weird names in there, but the general idea...
EDIT: Forgot [code]s
Reply #178
@2E7AH : unfortunately I have absolutely no experience with Python.  But if it's as easy as you say, then I'm sure somebody will come soon with a solution. Nemphael for example, if he feels up to the challenge.  I'm just giving some good ideas, that's all, but it will be up to T.P Wang or any Python scripter to translate them into usable things.
However, I still think these improvements should be made directly at the Lyrics Grabber level, not at the scripts level. Here's how I see it :
- If Lyrics Grabber itself was able to understand that the song "Apprends-moi" from album artist "Superbus" from album "Lova Lova" is THE SAME as the song "Apprends moi" from the same album artist and album,
- If Lyrics Grabber itself was able to understand that the song "Key Hole" from album artist "Superbus" from album "Lova Lova" is THE SAME as the song "Keyhole" from the same album artist and album,
- etc.
... then I believe that all scripts based on Lyrics Grabber should be able to benefit from this. Don't you think so ?
Those improvements should ideally be made at the "core", not script by script.
Reply #179
Hmm... you are suggesting something like 3 custom input fields for artist-album-title somewhere in component's configuration. Not bad, but all scripts now will have to be changed (also the lyrics wiki and lyrics plugin).
Then also some (many I think) lyrics providers don't offer search with special chars, so you'll have to do the search for "Apprends-moi" and then again for "Apprends moi", or even worst case "Key Hole" and "Keyhole"
Reply #180
Let's take the LyricWiki example, and type in a search for "Superbus Apprends-moi" (correct orthograph). Here are the results : http://lyricwiki.org/Special:GoogleSearchR...p;sa=Search#229
As you can see, the song "Apprends moi" is retrieved anyway, even if its title is different ! Why ? Because the integrated Google search "knows" that "Apprends moi" is "close" to "Apprends-moi", so the result can be relevant.
The same result could be obtained by googling the following query : 'Superbus "Apprends-moi" inurl:lyricwiki'. The result would of course be the same : http://www.google.fr/search?hl=fr&q=Su...mp;aq=f&oq=
So I think we could put this to use into Lyric Grabber. If Lyrics Grabber can use the integrated LyricWiki Google search, the search motor will hopefully do the rest. Don't you think so ?
Reply #181
Here is simple python script for fetching time-stamped lyrics from the site I found today (lrcDB). It has 26252 records as now, not much, but they are time-stamped
@foorious I left input fields as is, so you can improve them
lrcDB.py
import encodings.utf_8
import urllib
from grabber import LyricProviderBase
class lrcDB(LyricProviderBase):
    def GetName(self):
        return "lrcDB"
    def GetVersion(self):
        return "0.1"
    def GetURL(self):
        return "http://www.lrcdb.org/search.php"
    def Query(self, handles, status, abort):
        result = []
        lid = ''
        for handle in handles:
            status.Advance()
            if abort.Aborting():
                return result
            album = handle.Format("[%album%]")
            title = handle.Format("[%title%]")
            try:
                string = urllib.urlopen("http://www.lrcdb.org/search.php?artist=%s&album=%s&title=%s&query=plugin&type=plugin" % (urllib.quote(artist), urllib.quote(album), urllib.quote(title))).read()
                lid = string.split(': ')[1]
                if lid > '' and len(lid) < 10:
                    lyric = urllib.urlopen("http://www.lrcdb.org/lyric.php?lid=%s&astext=yes" % lid).read()
                    result.append(lyric)
            except Exception, e:
                traceback.print_exc(file=sys.stdout)
                result.append('')
                continue
        return result
if __name__ == "__main__":
    LyricProviderInstance = lrcDB()
[!--sizeo:1--][span style=\"font-size:8pt;line-height:100%\"][!--/sizeo--][edit] last minute correction[/size]
Reply #182
Some one can help and make script for http://www.plyrics.com please? thanks in advance
Reply #183
The LrcDB.org main page says this :
Please don't use bots to search the site.
Posted by tonyc on 2008-08-08 18:50:05
I got an automated email today telling me the web server's CPU usage had spiked to 100%. It looks like someone was running a search bot through their entire MP3 collection and trying to download the lyrics for all of them from the site.
This type of activity brings the server to a crawl, so I have no choice but to block IP addresses that are doing this. This is the only way I can ensure the site is available for all of the other users.
One query per second is the maximum I will allow. Anyone sending queries faster than this on a regular basis will be blocked from the site.
Have things improved since then or not ? (it's been almost a year). I'm saying this because the site seemed to be under heavy load this morning...
Oh, and another thing : what about a Lyrics Grabber option (checkbox) that would allow timestamped lyrics to be downloaded, even if non-timestamped lyrics are already present in the %lyrics% tag ? (automatic replacement of non-timestamped lyrics by timestamped ones, optional of course).
Reply #184
PLyrics is almost the same as AZ Lyrics, so changing the AZ Lyrics script a little will get you there. Anyway I made that another way using reg.exp and here it is:
pLyrics.py
import urllib
import re
class pLyrics(LyricProviderBase):
    def GetName(self):
        return "pLyrics (Punk)"
    def GetURL(self):
        return "http://www.plyrics.com"
        return "0.1"
        rx_lrc = re.compile(r"(^(?!All lyrics)^\w.+|^\(.+)|^\w.+<br>",re.M)
        rx_str = re.compile(r"\W+")
        result = []
        lyric = []
            status.Advance()
                return result
            artist = handle.Format('[%artist%]')
            title = handle.Format('[%title%]')
            artist = rx_str.sub('',artist.lower())
            title = rx_str.sub('',title.lower())
            try:
                string = urllib.urlopen('http://www.plyrics.com/lyrics/'+artist+'/'+title+'.html').read()
                if string.find('Page Not Found') == -1:
                        for match in rx_lrc.finditer(string.replace('<br>','')):
                                lyric.append(match.group())
                else:
                        result.append('')
                        continue
                lyric = '\r\n'.join(lyric)
                result.append('')
                continue
        return result
if __name__ == '__main__':
    LyricProviderInstance = pLyrics()
This is modified version for lrcDB script, which now looks for artist-title if artist-album-title fails:
lrcDB.py
import urllib
    def GetName(self):
        return 'lrcDB (LRC)'
        return '0.2'
    def GetURL(self):
        return 'http://www.lrcdb.org/search.php'
        result = []
        lid = ''
            status.Advance()
                return result
            album = handle.Format('[%album%]')
            try:
                string = urllib.urlopen('http://www.lrcdb.org/search.php?artist=%s&album=%s&title=%s&query=plugin&type=plugin' % (urllib.quote(artist), urllib.quote(album), urllib.quote(title))).read()
                if string == 'no match':
                    string = urllib.urlopen('http://www.lrcdb.org/search.php?artist=%s&title=%s&query=plugin&type=plugin' % (urllib.quote(artist), urllib.quote(title))).read()
                        result.append('')
                        continue
                string = string.split('\t')[0]
                if lid != '':
                    lyric = urllib.urlopen('http://www.lrcdb.org/lyric.php?lid=%s&astext=yes' % lid).read()
                result.append('')
                continue
        return result
Reply #185
i try, but no results
many thanks for script!
hmm, its work only for single track :/ if i choose full album only first track success
http://plyrics.com/a/alexisonfire.html
Reply #186
I tested it only on one track  , try this:
import urllib
import re
    def GetName(self):
    def GetURL(self):
        return "0.1"
        result = []
        lrc = []
            status.Advance()
                return result
            try:
                                lrc.append(match.group())
                else:
                        result.append('')
                        continue
                lyric = '\r\n'.join(lrc)
                result.append('')
                continue
        return result
Reply #187
Here is another script, with the same reg.ex method for Lyrics.net.ua (184912 records as now)
lyricsNET.py
import urllib
import re
class LyricsNET(LyricProviderBase):
    def GetName(self):
        return "Lyrics.NET"
    def GetURL(self):
        return "http://lyrics.net.ua"
        return "0.1"
        rx_lrc = re.compile(r"^\w.*<br />$|<p class=text>\w.*<br />",re.M)
        rx_str = re.compile(r"(?!\w+?)\W+?")
        rx_htm = re.compile(r"<.*?>")
        result = []
        lrc = []
            status.Advance()
                return result
            artist = rx_str.sub('_',artist.lower().replace('&','_amp_'))
            album = rx_str.sub('_',album.lower().replace('&','_amp_'))
            title = rx_str.sub('_',title.lower().replace('&','_amp_'))
            try:
                string = urllib.urlopen('http://lyrics.net.ua/lyrics/'+artist+'/'+album+'/'+title+'.html').read()
                if string.find('failed to open stream') == -1:
                        for match in rx_lrc.finditer(string):
                                lrc.append(rx_htm.sub('',match.group()))
                else:
                        result.append('')
                        continue
                result.append('')
                continue
        return result
    LyricProviderInstance = LyricsNET()
Reply #189
IMO we're all talking much about the scripts and not enough about Lyrics Grabber.
Maybe there should be a separate topic for all Lyrics Grabber scripts, so that we can keep discussing about Lyrics Grabber development and improvements.
Reply #190
I've made couple of new scripts which I posted here
Don't want to trash this thread and also to avoid possible indentation error when user manages script
@T.P.Wang: I was trying to convert HTML enteties to unicode with "htmlentitydefs" and then with "BeautifulSoup", but always get this same message:
foo_grabber_python: TypeError: No registered converter was able to produce a C++ rvalue of type class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > from this Python object of type NavigableString
[edit] If someone knows of LRC (time-stamped) lyrics site or service, please post
Reply #191
I got an error:
foo_grabber_python: Traceback (most recent call last):
  File "C:\Program Files\foobar2000\pygrabber\scripts\LyricsTXT.py", line 35, in Query
    url = 'http://www.lyricstxt.com/lyrics/'+artist[0]+'/'+artist+'/'+title+'_lyrics.html'
IndexError: string index out of range
Is it the script or the plugin?
Reply #192
Is that error for some particular artist/album?
There is (mistype) error in the script at line 42:
[font= "Lucida Console"]if link == None:[/font]
should be:
[font= "Lucida Console"]if lyric == None:[/font]
Also read request will stop at " ’ " - char(8217) - that is fixed and can be downloaded from here
If you notice any other anomaly, please report.
Reply #193
Python script for fetching AMG review (album) here
Allmusic has some limitation on number of accesses per IP. I don't know the number but it shouldn't worry us too much because in this case access is per album not per track. Of course use it with common sense.
For any error please post.
Reply #194
Is there some way to use python debugger? I mean where is module grabber? Is it wrapped in foo_grabber_python.dll?
Reply #195
Sorry for my late reply.
You should use str(instance of NavigableString, 'utf_8') in order to convert it to utf-8 first.
Yes, module grabber is embedded into foo_grabber_python.dll. It's always a headache to debug scripts.
I'd suggest write common scripts in a python IDE which contains debugging, then migrate them in foo_grabber_python env.
PS: I don't forget this project, there's a lot of inner changes in my current developing version (not compatable with previous versions), and changed frequently, and I'll consider a better configuration dialog (I mean I'm not good at designing a GUI, It always takes me a lot of time...  )
Reply #196
I don't remember what I was doing back then, because I left the code. Trying now they both work fine
I guess passed string(?) was not in utf-8
OK
I got this very nice PyScripter and feel uncomfortable tracing strange behaviours with SciTE and foobar console
And looking forward to next python_grabber release  (especially "custom meta field-value pair")
Reply #197
@T.P.Wang: I was testing Gracenote grabber script, and thought to suggest something regarding multiple tag value pairs:
- possibility to call simple dialog within the script so user can select which tags to be written and option for custom tag mapping
For example, AMG script can fetch at least: AMG REVIEW, GENRE, STYLE, MOOD, THEME, PUBLISHER, DATE, COMPOSER, RELEASES... from url respond.
So if I call this suggested dialog function from script, it will pop dialog box at user request with all defined tags contained in the script and some tick box for selecting/deselecting which tags to be written (and maybe input box aside tags for custom tag mapping defaulting to tag defined in script)
Reply #198
...or that can be appended on existing querying result dialog, which is probably better, but with losing option for choosing tag before script search starts
Reply #199
hi i have been using foo_uie_lyrics, but sometimes its online search does not find the song i am playing. i like how foo_uie_lyrics does not change the tag.
is there anyway to make lyrics grabber download the  lyrics instead of putting it into the tag like how foo_uie_lyrics lets you save to config folder?
thanks!
