TomBarlow, can you help me inserting your wheel-scrolling function in my progress bar script?
// Flags, used with GdiDrawText
// For more information, see: [url=http://msdn.microsoft.com/en-us/library/dd162498(VS.85).aspx]http://msdn.microsoft.com/en-us/library/dd162498(VS.85).aspx[/url]
var DT_TOP = 0x00000000;
var DT_LEFT = 0x00000000;
var DT_CENTER = 0x00000001;
var DT_RIGHT = 0x00000002;
var DT_VCENTER = 0x00000004;
var DT_BOTTOM = 0x00000008;
var DT_WORDBREAK = 0x00000010;
var DT_SINGLELINE = 0x00000020;
var DT_EXPANDTABS = 0x00000040;
var DT_TABSTOP = 0x00000080;
var DT_NOCLIP = 0x00000100;
var DT_EXTERNALLEADING = 0x00000200;
var DT_CALCRECT = 0x00000400;
var DT_NOPREFIX = 0x00000800;
var DT_INTERNAL = 0x00001000;
var DT_EDITCONTROL = 0x00002000;
var DT_PATH_ELLIPSIS = 0x00004000;
var DT_END_ELLIPSIS = 0x00008000;
var DT_MODIFYSTRING = 0x00010000;
var DT_RTLREADING = 0x00020000;
var DT_WORD_ELLIPSIS = 0x00040000;
var DT_NOFULLWIDTHCHARBREAK = 0x00080000;
var DT_HIDEPREFIX = 0x00100000;
var DT_PREFIXONLY = 0x00200000;
function RGB(r,g,b){ return (0xff000000|(r<<16)|(g<<8)|(b)); }
var g_font = gdi.Font("LCD", 18, 1);
var g_drag = 0;
var g_drag_seek = 0;
var tfo = fb.TitleFormat("POS: %playback_time%/%length% '('$max(0,$left($muldiv(%playback_time_seconds%,1000,%length_seconds%),$sub($len($muldiv(%playback_time_seconds%,1000,%length_seconds%)),1)))'.'$right($muldiv(%playback_time_seconds%,1000,%length_seconds%),1)'%)' REM: %playback_time_remaining%");
function TimeFmt(t){
var zpad = function(n){
var str = n.toString();
return (str.length<2) ? "0"+str : str;
var h = Math.floor(t/3600); t-=h*3600;
var m = Math.floor(t/60); t-=m*60;
var s = Math.floor(t);
if(h>0) return h.toString()+":"+zpad(m)+":"+zpad(s);
return m.toString()+":"+zpad(s);
function on_paint(gr){
var txt = "";
var pos =0;
if(fb.PlaybackTime > 0){
if(g_drag){
pos = window.Width * g_drag_seek;
txt = "Seek " + TimeFmt(g_drag_seek * fb.PlaybackLength) + " / " + TimeFmt(fb.PlaybackLength);
else{
pos = window.Width * (fb.PlaybackTime / fb.PlaybackLength);
txt = tfo.Eval();
}else
txt = "Playback Stopped";
gr.FillGradRect( 0, 0, pos, window.Height, 90, RGB(240,240,240), RGB(46,48,63));
gr.FillGradRect(pos, 0, window.Width-pos, window.Height, 90, RGB(240,240,240), RGB(190,190,190));
gr.GdiDrawText(txt, g_font, RGB(50,50,50), 0, 0, window.Width, window.Height, DT_CENTER | DT_VCENTER | DT_SINGLELINE);
gr.DrawRect(0,0, window.Width-1, window.Height-1, 1.0, RGB(150,150,150));
function on_mouse_lbtn_down(x,y){
g_drag = 1;
if(g_drag){
g_drag = 0;
g_drag_seek = x / window.Width;
g_drag_seek = (g_drag_seek<0) ? 0 : (g_drag_seek<1) ? g_drag_seek : 1;
fb.PlaybackTime = fb.PlaybackLength * g_drag_seek;
function on_mouse_move(x,y){
if(g_drag){
window.Repaint();
function on_playback_time(time){
window.Repaint();
function on_playback_stop(){
window.Repaint();
function on_playback_starting(cmd, paused){
function on_playback_new_track(info){
window.Repaint();
//EOF
