Topic: foo_httpcontrol (Read 950542 times) previous topic - next topic
foo_httpcontrol
Reply #225
idk if this is supposed to allow this, but whenever i try and access the ip i supply in the program from another computter, i always get a "Forbidden" page
foo_httpcontrol
Reply #226
did you set any value to "Remote IP" field in plugin configuration page?
foo_httpcontrol
Reply #228
yup, as the outbound ip of the computer
check "Enable logging" in preferences, try to access remotely, and then post screenshot of plugin preferences window and contents of foobar2000 console.
foo_httpcontrol
Reply #229
http://quasi.schererzoo.com/screenshot.jpg
and yes that is with me trying to remote access, it doesnt show up at all, which leads me to believe its something wrong with vista
foo_httpcontrol
Reply #230
I think you misunderstood something. your "bind to interface" field equals to "remote ip". why is that? you said you are trying to connect to machine running foobar2000 remotely.
foo_httpcontrol
Reply #231
yes i am, so should bind to be local host? and if so, what should remote be?
foo_httpcontrol
Reply #232
once again, remote ip defines the one and only ip you're allowing connection _from_.
foo_httpcontrol
Reply #234
so technically, if im trying to connect remotely from a computer that has the IP 192.168.1.4, this should work?
no it wont. your http listener service is bound to localhost ip which is unreachable from the remote machine unless you set up the routing
change it to whatever ip has the network card connected with the remote machine (192.168.1.5 iirc judging by your previous screenshot)
ps I hope you are not trolling
foo_httpcontrol
Reply #235
it has been possible from almost the very beginning with EnqueueDirSubdirs cmd.
Ahh, I stand corrected.  I posted in haste without checking the available commands.  Now to find room for another button on the template...
may I ask why you didn't go in the way suggested by stock template, where the page is being refreshed only on track changes or in case of insufficient playing track data? requesting data every five seconds might be a bit consumptive batterywise.
I would need to read the track length and set up a timer to request the data at the presumed end of the track.  Certainly doable; I just haven't had time yet.
foo_httpcontrol
Reply #236
My problem is that when using your template, the playlist page is not scrollable. I tried with fusion and firefox and it s not scrollable. Maybe it s something you want on iphone but do you know how to change that?
It has to do with how the iPhone handles scrolling.  To restore the scroll bar, open up the CSS file and remove the "overflow: hidden" attribute from the BODY element.
Thanks but i would like my page to be scrollable with mouse wheel but still hide the scrollbar. Is it possible?
foo_httpcontrol
Reply #237
ok i got it, thanks, and no im not trolling lol
foo_httpcontrol
Reply #240
When any tag is updated, foobar2000 freezes for up to 15 seconds (at least when a large playlist is active, >30000 entrys).
foo_httpcontrol
Reply #241
Patient: Doctor, it hurts when I do this...
Doctor: Then stop doing it...
foo_httpcontrol
Reply #242
If there an option to make http control "read-only"? I want other users in LAN to be able to see what is playing now but I don't want to let them change anything. Is it possible?
foo_httpcontrol
Reply #243
Oblikoamorale,
I have a couple of questions, I think I already know the answer to the first.
So can your plugin be loaded on a Nokia 770? Assuming the answer is no, then could you recommend any device (or style of device) on which it could be loaded? All that I am looking for is to create a remote whose primary purpose is to control Foobar on my pc - nothing more. A screen the size of the Nokia is sufficient and I would not be wanting to use said device as a phone / pda etc.
A newbie.
foo_httpcontrol
Reply #244
nope, there is no such option. but you can somewhat simulate one by cutting out all playback control knobs from the template.
and the answer is: I simply don't know. there is a possibility that control page would work fine, but there also is a non-zero chance that nokian browser considers template javascript too hard to swallow. in other words, you wouldn't know until you try. but even if your attempt fails, you can always get rid of all troublesome javascript moments by fiddling with the template.
if you want template to be adopted for your device - send me one and I'll do the dirty work
foo_httpcontrol
Reply #245
That is a most generous offer  - I will first try it on the Nokia - just to see - there is nothing to lose!
I am going to have to find out how to quote - so first it is off to the help area!!
foo_httpcontrol
Reply #246
Well I tried - but the Nokia does not even see the file never mind use it!! So I will have to try another tack.
Thanks again.
Alan
foo_httpcontrol
Reply #248
Are there any clever people here who use the G1 phone? This plugin works perfectly for me - but I wonder if someone would like to design a really beautiful interface that uses the right screen size etc..
The other thing that I'm desperate for is some form of keyword search - I have so much music over so many hard drives and searching works so well on foobar itself..
any hope?
cheers
ooops,
i meant to post this in the
foo_httpcontrol, control foobar via http
thread. Can someone move it for me? thanks!
any hope?
cheers
foo_httpcontrol
Reply #249
I'd stuck by myself upon the need of simple search yesterday, so I admit, it might be useful.
    v0.81 17 Feb
        add: CreateSimpleAutoplaylist command, turning currently active
             playlist into autoplaylist with query pattern specified in param1
             value. Calling it with empty param1 value removes autoplaylist.
