Topic: Chronflow (Read 479938 times) previous topic - next topic
Chronflow
Reply #451
Thanks for this brilliant plugin
I have a problem here, most of my cover arts are randomly named (stolen from amazon), but $replace(%path%,%filename_ext%,)*.jpg doesn't work for me, is there anyway to make chronflow read the first image in the folder? I'd become bald in one night if I have to rename every image in each folder into folder.jpg....
Chronflow
Reply #454
since my tag has asian chars which stored in unicode/utf8, does chronflow support displaying unicode tag ?
Chronflow
Reply #455
Quite every foobar plugin does this by default, so you should rather try than ask. But yes, it does.
Chronflow
Reply #456
Hey, got a question. I can't seem to get Chronflow to work properly. I'm using Cepiperez's Dark config, and when I go to Chronflow, All that shows up is the loading.png, and No Covers Loaded under it. Should I add the covers manually? All my covers are in their album's folders named folder.jpg... What should i configure?
EDIT: Forgot to mention that the covers show up in the other parts of the config. They do not appear only in Chronflow.
Chronflow
Reply #457
How it works is that it retrieves the covers by establishing a source, which is your media library under your foobar preferences. Once you have added the folders for your media library, everything should work. - Add the directories that you want it to scan for covers and you're good to go.
Chronflow
Reply #458
Ahh, yes. now it works fine. Thank you very much, man!
Chronflow
Reply #459
Hey Chronial,
are you going to update your plugin at any time? Maybe adding some functions of bubble_coverflow or the suggested items on/around page 16... afaik wasn't there any development since v3.0, right?
regards, callisto
fb2k on OSX: flac q8 > rockboxed Sansa e280v1: Vorbis q5.0
Chronflow
Reply #460
hello
I also use the new version of Cepiperez Dark configuration and chronflow is supported
but I can't run it
I have immediately a failure text with illegal operation
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 69335A5Fh
Access violation, operation: read, address: 28174DA0h
Call path not available.
Code bytes (69335A5Fh):
69335A1Fh:  00 00 00 39 18 74 72 8B 96 0C 02 00 00 47 83 C0
69335A2Fh:  04 3B FA 72 EE 8B 54 24 1C 89 9C 8E 8C 00 00 00
69335A3Fh:  8B 8E 0C 02 00 00 89 94 8E 0C 01 00 00 8B 86 0C
69335A4Fh:  02 00 00 89 AC 86 8C 01 00 00 8B BE 0C 02 00 00
69335A5Fh:  8B 5C BE 08 6A 08 6A 01 E8 F4 71 13 00 83 C4 08
69335A6Fh:  85 C0 89 44 BE 08 74 0D 8B 4C 24 18 89 48 04 8B
69335A7Fh:  54 BE 08 89 1A 8B 86 0C 02 00 00 5F 40 89 86 0C
69335A8Fh:  02 00 00 5E 5D 5B C2 14 00 8B 5C BE 08 8B C3 85
Stack (103EFCE0h):
103EFCC0h:  7C929B3F 7C98C0D8 7C929AEB 00D09E84
103EFCD0h:  01818B08 0000FFFF 7FFDF000 00256B28
103EFCE0h:  1AB163B0 00000324 00000A38 002A0862
103EFCF0h:  693365F8 05380771 002A0862 1AB163B0
103EFD00h:  08180048 00000000 3D01224B 77D2FA16
103EFD10h:  00000000 693366DF 00000006 1A969530
103EFD20h:  69328FA4 3D01224B 001BB4E0 00000006
103EFD30h:  103EFE04 0DBB34D8 002A0862 00010028
103EFD40h:  00000025 10082000 00080808 10401808
103EFD50h:  18101010 00000208 00000000 00000000
103EFD60h:  00000000 00010028 00000025 10082000
103EFD70h:  00080808 10401808 18101010 00000208
103EFD80h:  00000000 00000000 00000000 00000000
103EFD90h:  00000000 00000000 00010001 00000000
103EFDA0h:  00000008 00000008 00000008 00000008
103EFDB0h:  00FF0000 0000FF00 000000FF FF000000
103EFDC0h:  00000020 00000020 00000010 00000010
103EFDD0h:  00000010 00000010 00000018 00000008
103EFDE0h:  00000002 00000000 00000000 00000000
103EFDF0h:  00000000 5F08C4AD 3D01224B 00000006
Registers:
EAX: 00000020, EBX: 00000A38, ECX: 00000020, EDX: 1AB163B0
ESI: 07B74C78, EDI: 08180048, EBP: 08180048, ESP: 103EFCE0
Crash location: "atioglxx", loaded at 69000000h - 6951D000h
Symbol: "atiPS" (+0000C96Fh)
Loaded modules:
foobar2000   loaded at 00400000h - 00522000h
ntdll loaded at 7C910000h - 7C9C7000h
kernel32 loaded at 7C800000h - 7C905000h
COMCTL32 loaded at 77390000h - 77493000h
msvcrt   loaded at 77BE0000h - 77C38000h
ADVAPI32 loaded at 77DA0000h - 77E4C000h
RPCRT4   loaded at 77E50000h - 77EE1000h
GDI32 loaded at 77EF0000h - 77F37000h
USER32   loaded at 77D10000h - 77D9E000h
SHLWAPI   loaded at 77F40000h - 77FDD000h
SHELL32   loaded at 7C9D0000h - 7EDB3000h
ole32 loaded at 774A0000h - 775DD000h
shared   loaded at 10000000h - 1002A000h
COMDLG32 loaded at 76340000h - 76399000h
IMM32 loaded at 76320000h - 7633D000h
sockspy   loaded at 00380000h - 003B6000h
uxtheme   loaded at 5B090000h - 5B0C8000h
MSCTF loaded at 74690000h - 746DC000h
UberIcon loaded at 00B10000h - 00B21000h
lgscroll loaded at 10100000h - 1010F000h
MSVCR80   loaded at 78130000h - 781CB000h
MSVCP80   loaded at 7C420000h - 7C4A7000h
NTMARTA   loaded at 77650000h - 77671000h
WLDAP32   loaded at 76F10000h - 76F3D000h
SAMLIB   loaded at 71B50000h - 71B63000h
msctfime loaded at 75140000h - 7516E000h
foo_albumlist loaded at 00B80000h - 00BE5000h
foo_browser   loaded at 00C10000h - 00C49000h
foo_cdda loaded at 00C70000h - 00CA8000h
foo_chronflow loaded at 00CD0000h - 00D31000h
WINMM loaded at 76AE0000h - 76B0F000h
gdiplus   loaded at 4EB80000h - 4ED23000h
OPENGL32 loaded at 5F070000h - 5F13C000h
GLU32 loaded at 6CEF0000h - 6CF11000h
DDRAW loaded at 736B0000h - 736F9000h
DCIMAN32 loaded at 73B10000h - 73B16000h
OLEAUT32 loaded at 770E0000h - 7716B000h
foo_converter loaded at 018F0000h - 01957000h
foo_cwbowron loaded at 01980000h - 019AA000h
foo_cwb_hooks loaded at 019D0000h - 01A06000h
foo_dsp_std   loaded at 01A30000h - 01A76000h
foo_fileops   loaded at 01AA0000h - 01AE5000h
foo_freedb2   loaded at 01B10000h - 01B50000h
foo_input_monkey loaded at 01B70000h - 01BBA000h
foo_input_std loaded at 01BE0000h - 01D08000h
foo_lyricsdb loaded at 01D30000h - 01D5F000h
WININET   loaded at 44080000h - 4427B000h
Normaliz loaded at 01D70000h - 01D79000h
iertutil loaded at 43E00000h - 43E45000h
foo_masstag   loaded at 01FA0000h - 01FF0000h
foo_playcount loaded at 02010000h - 02038000h
foo_playlist_tree loaded at 02060000h - 020D6000h
libmzsch360_000   loaded at 10400000h - 105D0000h
WSOCK32   loaded at 71A10000h - 71A1A000h
WS2_32   loaded at 719F0000h - 71A07000h
WS2HELP   loaded at 719E0000h - 719E8000h
libmzgc360_000   loaded at 02100000h - 021A4000h
foo_prettypop loaded at 021F0000h - 0223D000h
mscoree   loaded at 79000000h - 79045000h
msvcm80   loaded at 7C4C0000h - 7C53D000h
mscorwks loaded at 79E70000h - 7A3D1000h
mscorlib.ni   loaded at 790C0000h - 79BA6000h
mscorjit loaded at 79060000h - 790B3000h
rsaenh   loaded at 0FFD0000h - 0FFF8000h
foo_rgscan   loaded at 04790000h - 047EA000h
foo_run   loaded at 047F0000h - 0481B000h
foo_uie_albumart loaded at 04820000h - 0485C000h
foo_uie_albumlist loaded at 04880000h - 048BF000h
foo_uie_elplaylist   loaded at 048E0000h - 04924000h
foo_uie_graphical_browser loaded at 04950000h - 049E4000h
MSIMG32   loaded at 76310000h - 76315000h
foo_uie_lyrics   loaded at 04A00000h - 04A5D000h
foo_uie_playlists_dropdown   loaded at 04A80000h - 04AB9000h
foo_uie_powerpanels   loaded at 04AE0000h - 04B03000h
foo_uie_quicksearch   loaded at 04B30000h - 04B76000h
foo_ui_columns   loaded at 04BA0000h - 04C37000h
foo_ui_panels loaded at 04C60000h - 04D27000h
foo_ui_std   loaded at 04E70000h - 04F43000h
foo_unpack   loaded at 04F70000h - 04F9D000h
ctagent   loaded at 051E0000h - 051E6000h
System.ni loaded at 7A440000h - 7ABFE000h
System.Drawing.ni loaded at 7ADE0000h - 7AF74000h
System.Windows.Forms.ni   loaded at 7AFD0000h - 7BC56000h
CurXP0   loaded at 06300000h - 06308000h
mscms loaded at 73A80000h - 73A95000h
WINSPOOL loaded at 72F50000h - 72F76000h
icm32 loaded at 58A10000h - 58A51000h
netapi32 loaded at 6FEE0000h - 6FF34000h
appHelp   loaded at 77B50000h - 77B72000h
CLBCATQ   loaded at 76F80000h - 76FFF000h
COMRes   loaded at 77000000h - 770D4000h
VERSION   loaded at 77BD0000h - 77BD8000h
ieframe   loaded at 44360000h - 4492B000h
PSAPI loaded at 76BA0000h - 76BAB000h
urlmon   loaded at 075B0000h - 0774A000h
msscript loaded at 6B980000h - 6B999000h
vbscript loaded at 73300000h - 73365000h
jscript   loaded at 63380000h - 633F8000h
xpsp2res loaded at 20000000h - 20B02000h
SXS   loaded at 77210000h - 772C1000h
atioglxx loaded at 69000000h - 6951D000h
imagehlp loaded at 76C40000h - 76C68000h
DBGHELP   loaded at 5D3F0000h - 5D491000h
Stack dump analysis:
Address: 693365F8h, location: "atioglxx", loaded at 69000000h - 6951D000h
Symbol: "atiPS" (+0000D508h)
Address: 77D2FA16h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "WindowFromDC" (+00000000h)
Address: 693366DFh, location: "atioglxx", loaded at 69000000h - 6951D000h
Symbol: "atiPS" (+0000D5EFh)
Address: 69328FA4h, location: "atioglxx", loaded at 69000000h - 6951D000h
Symbol: "DrvSetPixelFormat" (+00000214h)
Address: 10401808h, location: "libmzsch360_000", loaded at 10400000h - 105D0000h
Symbol: "scheme_char_string_to_byte_string_locale" (+0000000Bh)
Address: 5F08C4ADh, location: "OPENGL32", loaded at 5F070000h - 5F13C000h
Symbol: "wglGetProcAddress" (+0000010Bh)
Address: 5F096CEDh, location: "OPENGL32", loaded at 5F070000h - 5F13C000h
Symbol: "wglSetPixelFormat" (+0000012Dh)
Address: 7C80A017h, location: "kernel32", loaded at 7C800000h - 7C905000h
Symbol: "SetEvent" (+00000000h)
Address: 7C91EE18h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "strchr" (+00000117h)
Address: 7C929AF0h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "towlower" (+00000384h)
Address: 7C929AEBh, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "towlower" (+0000037Fh)
Address: 7C929BA0h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "LdrGetProcedureAddress" (+00000018h)
Address: 5F070000h, location: "OPENGL32", loaded at 5F070000h - 5F13C000h
Address: 7C802520h, location: "kernel32", loaded at 7C800000h - 7C905000h
Symbol: "WaitForSingleObject" (+00000000h)
Address: 77F24F2Ah, location: "GDI32", loaded at 77EF0000h - 77F37000h
Symbol: "SetPixelFormat" (+00000037h)
Address: 00D0F078h, location: "foo_chronflow", loaded at 00CD0000h - 00D31000h
Address: 00CE43C7h, location: "foo_chronflow", loaded at 00CD0000h - 00D31000h
Address: 00D066A8h, location: "foo_chronflow", loaded at 00CD0000h - 00D31000h
Address: 00CE61F9h, location: "foo_chronflow", loaded at 00CD0000h - 00D31000h
Address: 00CE6889h, location: "foo_chronflow", loaded at 00CD0000h - 00D31000h
Address: 00CF37FBh, location: "foo_chronflow", loaded at 00CD0000h - 00D31000h
Address: 00CF52B0h, location: "foo_chronflow", loaded at 00CD0000h - 00D31000h
Address: 00CF38A0h, location: "foo_chronflow", loaded at 00CD0000h - 00D31000h
Address: 7C80B683h, location: "kernel32", loaded at 7C800000h - 7C905000h
Symbol: "GetModuleFileNameA" (+000001B4h)
Address: 7C839AA8h, location: "kernel32", loaded at 7C800000h - 7C905000h
Symbol: "ValidateLocale" (+000002B0h)
Address: 7C80B690h, location: "kernel32", loaded at 7C800000h - 7C905000h
Symbol: "GetModuleFileNameA" (+000001C1h)
Address: 00CF3821h, location: "foo_chronflow", loaded at 00CD0000h - 00D31000h
Version info:
foobar2000 v0.9.5.2
UNICODE
Windows 5.1
Additional info:
Converter 1.1.1  (foo_converter)
Album Art Panel 0.2.6  (foo_uie_albumart)
Graphical Browser rev015  (foo_uie_graphical_browser)
Playback Statistics 1.3.2  (foo_playcount)
Panels UI 0.14.12 beta [Jul 18 2007 - 13:39:30]  (foo_ui_panels)
File Operations 2.1  (foo_fileops)
Playlists Dropdown 0.6 alpha 3  (foo_uie_playlists_dropdown)
Startup Actions 0.0.2 [Jul 23 2007 - 08:27:55]  (foo_cwbowron)
Chronial's Coverflow 0.3.0  (foo_chronflow)
ZIP/GZIP reader 1.0  (foo_unpack)
ELPlaylist 0.2.9(alpha)  (foo_uie_elplaylist)
Album Art Browser 0.0.5 [Jul 23 2007 - 08:27:55]  (foo_cwbowron)
foobar2000 core 0.9.5.2  (Core)
Monkey's Audio decoder 2.1.2  (foo_input_monkey)
CD Audio Decoder 2.1.2  (foo_cdda)
Lyric Show Panels 0.3.3.0 [Apr 21 2008 - 11:24:16]  (foo_uie_lyrics)
Default User Interface 0.9.5  (foo_ui_std)
Standard DSP Array 1.0  (foo_dsp_std)
Columns UI 0.1.3 beta 1v7  (foo_ui_columns)
Playlist Tree Panel 3.0.4 [Aug  2 2007 - 10:16:21]  (foo_playlist_tree)
Run services 0.3.2  (foo_run)
Album list panel 0.2.1 beta 4  (foo_uie_albumlist)
Volume Panel 0.1  (foo_uie_powerpanels)
Music Browser 1.2.3b [Mar 23 2007 - 16:52:56]  (foo_browser)
Album List 4.2  (foo_albumlist)
freedb Tagger 0.6  (foo_freedb2)
RAR reader 1.1  (foo_unpack)
Seek Panel 0.1  (foo_uie_powerpanels)
ReplayGain Scanner 2.0.5  (foo_rgscan)
Quick Search Toolbar 2.8l  (foo_uie_quicksearch)
Masstagger 1.5  (foo_masstag)
Pretty Popup 1.2.3  (foo_prettypop)
cwbowron's title format hooks 1.1.1 [May  4 2007 - 12:39:47]  (foo_cwb_hooks)
foo_lyricsdb 0.0.7 beta 5  (foo_lyricsdb)
hope you can help
thank you
[!--sizeo:1--][span style=\"font-size:8pt;line-height:100%\"][!--/sizeo--]Moderation: codeboxed.[/size]
Chronflow
Reply #461
I can't help you
That means two things: 1. You are using an ATI graphics card  2. Your GPu drivers suck.
Try updating your GPU drivers - if that doesn't help this plugin won't run on your PC.
Chronflow
Reply #462
unfortunately I'm having a problem with chronflow on my new PC.
My GPU is a Geforce 9800GTX with the latest drivers. I hope you can help me with my problem since I really enjoyed using your plugin.
Chronflow
Reply #463
Hey Guys!
I am a brand new user of foobar2000 and im really loving it... But as you can imagine i am a complete noob at it! I tried installing skins with no success and the I found chronflow wich I would love to get up and running! I installed the modules in components folder but how the hell do I make it work in foobar????? Please help!
Chronflow
Reply #464
Hey guys i just finished another config for CHRONFLOW, heres the preview (fullview RECOMMENDED)
And heres the config:
// THE CIRCLE
// by subsonic
var num = 60;
// NUMBER OF COVERS DISPLAYED IN THE CIRCLE
// NO NEGATIVE VALUES!! SHOULD BE > 2
var r = 5;
// RADIUS OF THE CIRCLE
// ALSO AFFECTS THE CAMERA
var rotation = 90;
// ANGLE OF THE COVERS IN THE CIRCLE
// 90 = POINTING TO CENTER
var o = 1;
//AFFECTS THE SYMMETRY!
// THIS SHOULD BE 1 OR -1 ONLY!
// -1 = symmetric circle
// 1  = asymmetric
var width = 1.2;
//SIZE OF THE OUTER COVERS
var width_center = 5;
//SIZE OF THE CENTER COVER
//-------------  DONT EDIT BELOW
//----- only if you know what you're doing
var p = Math.ceil(num/2);
if(num/p != 2) { num++; }
function coverPosition(coverId){
var x, y, z; y = 0;
x = r*Math.sin(coverId*Math.PI/p);
  z = r*Math.cos(coverId*Math.PI/p);
if ((Math.abs(coverId) <= 0.5) && (Math.abs(coverId) >= 0)) {
  z = 0.2;
  x = 0;
  y = -Math.abs(coverId)*(width_center+2)*2;
  } else if ((Math.abs(coverId) <= 1) && (Math.abs(coverId) > 0.5)) {
  y = -(width+1.2) + (width+1.2)*Math.abs(coverId)*Math.abs(coverId);
} else if(Math.abs(coverId) > p) {
x = 0; y=0; z = -40;
  return new Array(x, y, z);
function coverRotation(coverId){
if (Math.abs(coverId) <= 0.5){
return new Array(-10, 1, 0, 0);
} else {
angle = coverId*(180/p) - rotation;
if(coverId < 0) {
angle = coverId*(180/p) - o*rotation;
return new Array(angle, 0, 1, 0);
function coverSizeLimits(coverId){
if (Math.abs(coverId) < 0.5) {
return new Array(width_center, width_center+1);
else {
  return new Array(width, width+1);
function coverAlign(coverId){
  return new Array(0, -1);
function drawCovers(){
  return new Array(-p, p);
function aspectBehaviour(){
  return new Array(1, 1);
/************************** CAMERA SETUP ****************/
function eyePos(coverId){
return new Array(0, r*2.3, r*3.3);
function lookAt(){
  return new Array(0, 0, 0);
// Used to rotate the view.
// The returned Vector points upwards in the viewport.
// This vector must not be parallel to the line of sight from the
// eyePos point to the lookAt point.
function upVector(){
  return new Array(0, 1, 0);
/************************** MIRROR SETUP *****************/
function showMirrorPlane(){
  return true; // return false to hide the mirror
// Any Point on the Mirror Plane
function mirrorPoint(){
// Normal of the Mirror Plane
function mirrorNormal(){
enjoy.
[!--sizeo:1--][span style=\"font-size:8pt;line-height:100%\"][!--/sizeo--]Moderation: Please do not inline images larger than roughly 800x600 and 80KB. Please use thumbnails and/or links for large pictures instead. Converted code to codebox as well.[/size]
Chronflow
Reply #465
Dude, the circle config is soooo awesome. I would recommend scalling your picture down so it doesn't stretch the page tho .
Good work, and thank you ^__^.
(btw offtopic but, I see you have "Good Health" by Pretty Girls Make Graves... never met anyone else who listened to them )
Chronflow
Reply #466
Hi Peter.
Is there a chance to add the Chrownflow component to the Default UI? I thins is an amazing component and a great addition to the visualizations in foobar default setup.
Chronflow
Reply #467
I can't help you
I updated my drivers and now....... it works perfectly
thank you
Chronflow
Reply #468
Hey Guys!
Chronflow
Reply #469
you can open it as a window in Default UI with dockable panels plugin
in columns UI, you add it in the layout page
in panelsUI you add it as a panel
Chronflow
Reply #470
Is there anyone who has managed successfully to update an ATI Mobility grahics card to enable Chronflow to work on Vista?
Pepito raised my hopes, but it seems the laptop/Vista combo is beyond my futile attempts (Dell M2010, ATI Mobility x1800, Vista Ultimate).
Thanks for any feedback!
Chronflow
Reply #471
Simple question: Is it possible to exclude folders from the media library being displayed in Chronflow?
Reason for this is that I have a folder of live recordings and such that doesn't have associated cover-art and I'd like to exclude this directory from being displayed as it leads to many "no cover" images amongst all my other proper coverart.
So is this possible? If not is there a chance of such a feature being added to this great component?
Chronflow
Reply #472
[a href="http://img3.imagebanana.com/view/515g4s6/chronflow_problem.jpg" target="_blank"]
the reason it didn't work was my dualmonitor setup. i noticed that the covers were displayed correctly on my other monitor so i switched the plugs of both monitors and now it works
Chronflow
Reply #473
ok i've just solved my own problem
To add to this, the majority of my own dual monitor problems (using an 8600GT) were cured when I upgraded to Nvidia's latest whql drivers, 175.16. I still get the occasional blank cover when flipping through my collection, but Chronflow works great otherwise.
Chronflow
Reply #474
Hi, great plugin. Love it.
Just wanted to ask, if it is possible to display more then one picture in the folder. I use the discogs plugin and album art ist usually more than one cover or label sticker. I could imagine drawing a slowly spinning cube with covers on each sides (spinning just round, you can't see the top or manipulate the cube). Does this work or is it impossible to do?
