Topic: iPod manager (Read 2269468 times) previous topic - next topic
0 Members and 9 Guests are viewing this topic.
[seemingly abandonware] iPod manager
Reply #1200
Maybe your iPod connected in USB 1.1 mode. Mine likes to do that randomly..
Alternatively maybe the hard drive in the 160GB model is slow. I'd say to read the metadata from 130GBs of files would take roughly 20 minutes at the same speed as the 80GB model.
Anyway, the metadata is cached so it won't do that again unless you decide to change the entire contents of your iPod in one go.
Reply #1201
Hmm.. How do I tell when my Ipod has connected through usb 1.1? (I didn't know this was possible)
Reply #1202
Uh Oh....
Now I'm having a real problem.
Whenever I try to refresh ipod metadata or load library I'm now getting a "cache read was aborted" error.
Edit: Deleted the cache file and the fixed it.
Reply #1203
I don't know, I usually get strange messages from Windows or just notice it being so slow.. I think it's more to do with the (dodgy) USB chipset in my laptop, anyway.
You could check the read speed with some application, probably would be more telling, I get about 14MB/s read speed (26.5MB/s burst) on my 80GB classic - it doesn't vary much across the disk. I tried Sandra (physical disks benchmark) and some other random apps (not many seem to actually work..).
Slightly misleading error message sorry. It also triggers if there was an error reading the cache, the actual error should have been printed in the console.
Reply #1204
I have everything working flawlessly with my 80GB Classic now, and I'm loving it . I have a couple requests however:
1. Would it be possible to "Refresh Album Art" so any new album art would be updated on the iPod. My issue right now is that finding better quality art and remaking custom art wont update already sent art on the iPod. Also, I find that if I send songs to the iPod WITHOUT art, and then "Sync iPod" when art has been added to the folder, the new art is NOT sent to the iPod.
2. Will images ever be supported so they can be sent to the iPod with foobar?
3. Is it possible to "Check For Updates" for iPod firmware with foobar, or is that only possible with iTunes?
4. I almost always get an error when trying to eject my iPod. I get "Failed to eject iPod. Close any applications using the device and try again.". I have no apple software running, and the ONLY thing related to the iPod seems to be foobar (which obviously needs to be open to eject). I don't know what's going on with that .
Reply #1205
Hello, I don't know if this qualifies as a "bug" (it's more a misleading error message). I was trying to send an album to my ipod from an external hard-drive, but I kept getting an error message saying "File path too long". However the problem was that the drive letter assigned to the external drive wasn't the same I had configured in foobar library preferences. Once I changed it, it worked just fine.
So in short the "File path too long" message should have been something like "File not found" right?
I'm using 0.9.5 (foobar) + 0.5.7 (foo_dop)
Reply #1206
No. That error message should only trigger if the file is actually located on the iPod drive. The fact that it got past reading the iPod's database means it has the correct drive letter, as well. foo_dop doesn't care if the files are in your media library, or not.
So, I think the entries in your playlist probably pointed to paths that were on the external drive, but now on the iPod as the drive letter changed. I changed the driver letter of my iPod using disk management to W: and it has stuck since which helps avoid this kind of problem (Windows Vista here).
Reply #1207
1. You can update missing art by using the "Update metadata..." command in the context menu (directly on files on the iPod). You are correct though, you can't update changed art at the moment.
2. I don't plan to do this at the moment.
3. For a variety of reasons you should use iTunes for this.
4. Well, it could be some background application, you should see the same with "Safely remove hardware". I usually do a handle search with Process Explorer to find out what it is.
Reply #1208
Ah ok, If I understand correctly then since the path on my playlist had the drive letter that used to be associated with my external hard drive but was now my ipod drive letter, it gave the error "filename too long" because it assumed the path was associated with the ipod drive (it didn't even check if it was a valid path).
Thanks for the tip about the drive letter :-) I already did that to avoid this kind of thing (by manually changing the drive letter windows associates it with the specific device).
Great plugin by the way
Reply #1209
So apparently right clicking one album in your media library and clicking "sync with ipod" actually................. Re-syncs the entire library with the ipod with just those songs....
Damnit.
Reply #1210
Sorry to bother you with this again Musicmusic, but I was just wondering if the following is ever going to happen:
Musicmusic,
Would it be possible for you to make some variables to get the following information:
%ipod_size% = The size of the iPod (80 GB, 160 GB, etc)
%ipod_space_used% = The amount of GB used up on the iPod (returned in bytes)
%ipod_space_left% = The amount of space left for storage on the iPod (returned in bytes)
The variable codes can be different, those were just examples. I would find this information very useful for something I am making, and if you could implement this, that would be amazing .
Thanks for your hard work on this component .
Reply #1211
Just to add to that, the blocking application may also be listed in the system event log. Sometimes I have this...: "The application System with process id 4 stopped the removal or ejection for the device USB\VID_05AC&PID_1261 [...]".
Sorry to bother you with this again Musicmusic, but I was just wondering if the following is ever going to happen: [...]
Sorry, no plans.
Reply #1212
Two things
Often (not all of the time) when I add files to my iPod it lowers the amount of available space but the songs can't be found on the playlist... it seems like they're going into a neverland somewhere on the drive (5g Nano)
Also, any chance of adding an autofill function with the options of 1) delete and refill or 2) fill free space.  That would be great, especially 2 since Winamp can't do that.
Reply #1213
They should show up provided the database it updated correctly. If foo_dop failed to do that it would complain. The other possibility is that something else is reverting it, but that shouldn't happen if you don't run other iPod apps at the same time, and also you should set your iPod in manual music management mode in iTunes.
I will likely add some command to recover orphaned files at some point, however you can accomplish the same thing manually if you drag the iPod_Control\Music folder into foobar2000 and run the Send to iPod command on the loaded files.
Unfortunately there are many things that still remain to be done, and I'm not trying to compete with Winamp, so these are on the back burner.
Reply #1214
Ok, hi musicmusic and thank you for your plug-in.
Also I have a question and one bug.
Yesterday somehow all my album artworks in iPod Touch  8gb suddenly dissapeared. The strange thing is, that disappeared only "big versions", that are displayed whey you are playing exact track, and those, displayed in the the horizontal "cover-flow" browsing. But those artworks, that were embedded into the mp3-file with id3v2 tegs are ok - they are still displaying.
Also, all small icons of artworks, displayed in classical vertical album listing all stayed untouched - they are still displaying. The error appeared only with "big versions" and only "soft artworks" (those that where in the album folders, not in the files). And previously I noticed, that such artworks where displayed slightly transparent.
When did it happened? Can't say exactly, but have several variants:
1) when I uploaded video-files to my iPod via iTunes.
2) When Last.fm scrobbler updated itunes plugin. (it still doesn't support Tuch, but now recognizes him).
3) Something else, caused by launching iTunes. However, i don't remember doing anything else there yesterday....
Reply #1215
The problem is that iTunes enjoys reloading the artwork when you use it - as I recall this is related to when it does its "determining gapless playback information..". As iTunes only sees the embedded artwork, the tracks without embedded artwork will lose their artwork. It should also leave the tracks with gapless data set by foo_dop alone. I cannot explain however why only some artwork formats are lost, that part of this behaviour is specific to the iPod touch / iPhone.
Regarding transparent artwork, this is known. I was hoping it was fixed in 0.5.8.8 TEST but if not I do not have a solution.
Reply #1216
On the topic of artwork, I seem to have lost some of mine off my iPod also. I run an 80 GB iPod Classic, and since the newest firmware update (1.1.2) from Apple, I seem to have lost a bit of my artwork. It happened on random albums it seems, and foo_dop still says the artwork is ON the iPod (using the Browse iPod feature).
Would it be possible to have the option of whipping the artwork database, and resending artwork for all songs? I imagine it would be hard to find changes in artwork unless you used some kind of checksum or whatever to determine if the artwork has changed or not.
If this can't be done, I am just gonna erase my iPod (using iTunes) and resend everything with foo_dop again. I don't know what caused the artwork loss (probably the update?) but external artwork capabilities is one of the main reasons I enjoy using foo_dop .
EDIT: If it matters, ALL my artwork is located in a single folder, with the naming scheme being %album%.jpg.
Reply #1217
So if I check "Disable automatic synching for all iPods and iPhones" - would iTunes stop doing that?
Reply #1218
I'm not sure what goes on with your iPod  How many songs are on it? It shouldn't just lose artwork for existing tracks, unless some other app has been interfering. I will make some changes to make artwork management a bit easier at some point, yes, but for now it would probably be easier to just restore.
No, it will still do it whenever you make a manual change (add files etc.). Your options are:
1. Embed artwork into all of your files, using tags that iTunes likes.
2. Only use files with gapless data (Lame MP3 / Nero AAC) and enable gapless scanning in foo_dop.
3. Keep iTunes in manual mode and avoid using it. It's possible to send videos using foo_dop, but you don't get the thumbnails (but you can manually create them like artwork). You can scrobble you plays to last.fm with foo_dop by using foo_audioscrobbler.
Reply #1219
Your options are:
Oh, there is no any problems with scrobbling plays on touch, since it has it's own scrobbler-application (even little bit better, then PC-verison, I should say ))). That plug-in update was done by iTunes without my will and I thought it might be a reason for artwork loss, since it started recognizing the player. The only reason I'm still with iTunes installed are podcasts.
I will take second option and enable gapless scanning, probably.
Reply #1220
OK
I will also add an option to set dummy gapless data for tracks which foo_dop doesn't find gapless data, which will prevent iTunes from scanning them which in turn should stop iTunes mangling their artwork.
Reply #1221
* foo_dop doesn't support any date added [to foobar2000 media library] field. The problems here are: Where do I get this from? foobar2000 doesn't track it automatically. Do I assume the user has set a metadata field for this? What is the name of the field? What format is it in? I guess I can workaround these problems as well, anyway.
...Although, there is an official component which does, now. Playback Statistics 2.1 was just updated.
elevatorladylevitateme
Reply #1222
I know this.
Reply #1223
Hi musicmusic, I've got a bunch of requests/bugs to report:
I've noticed that foo_dop doesn't seem to check whether songs of the same artist/album/name already exist, such that it's perfectly possible to send stuff to the iPod that is already there without any sort of warning. Do you think it would be possible to implement some sort of measure to prevent/be informed of this in a future version?
On another matter, I have been noticing some odd conversion fails when sending tracks to the iPod from a lossless source. It sometimes happens when sending whole albums, that one or two tracks, usually the second and/or third last, fail to convert. Sending the failed tracks independently afterwards seems to work, so it's nothing wrong with the file itself. I am not sure if foo_dop is using multi-threaded conversion like foobar2000 itself does, as it's not obvious from its info box, but if that is the case and given the pattern, I have the hypothesis that it might fail whenever the last file in the set finishes converting before the second or third last do, or something along those lines. You might want to have a look at that.
Finally, I've also noticed that stopping any operation at the "Waiting for file info read to complete" stage renders foo_dop useless for any sort of operation with a "Cache read was aborted" error until one manually deletes the 0 KB metadata_cache.fpl file on the root folder of the iPod drive. Perhaps this is a potential problem you'd like to patch up in the future.
Anyway, again, thanks for maintaining this excellent plugin!
Reply #1224
Yes, this is planned.
What version of foo_dop are you using? Only the recent 0.5.8.x versions have multi-threaded conversion. In some rare cases with those versions, it was possible that the conversion would fail, that has been corrected for next build. Can you tell me the exact message you see, so I know if it's the same problem?
Ah, you worked out where this came from, thanks, I'll check what's going on.
