Topic: Chronflow (Read 479917 times) previous topic - next topic
Chronflow
Reply #250
First of all, great work! This is the best plugin I've seen in a long time!
But is there a possibility to get rid of the "selection frame"? I'd like to switch it off or at least make the frame a bit thinner (it's too thick; it doesn't fit the visual style of my foobar), but there seems to be no possibility...
I also encountered a bug: when leave a completely blank "Album title" field, a white horizontal stripe appears across my chronflow panel. I can push it up and down by playing with the "Vertical Position" bar. The fault appears only if the field is empty: if I type any character in the field, everything seems to work as it is supposed to be.
foobar 0.9.5.1, panels 0.13.8 beta, chronflow 0.2.0d and Win XP SP2 (with latest Catalyst drivers)
Chronflow
Reply #251
Could you please try this:
http://chron.visiondesigns.de/foobar2000/f...low_v0.2.0d.zip
If there is still an unkown exception Message Box for the compile button, I don't know anymore...
I tried this version, and it didn't give me the usual error which I think is good. No crashes which I know is good . Now I get this string of text in the box beside the compile button: "Com Exception (outer): Class not registered"
Chronflow
Reply #252
Thank you Chronial, this is brilliant!
]btw, i could not reset it to 50%, how can i do this simply ??? it's jump from 49% to 51% [/size]
The easiest way I found was to move the slider to 10% or 30% (seems easier to get 30 than 50 for some reason), then click anywhere to the right of it and it should jump up by 20% each time.
Chronflow
Reply #253
Thanx mark, i got it!
Chronflow
Reply #254
1) How do I get rid of that white frame around the cover that is highlighted? (bg colour = black, text colour = white)
2) Is there a way to bind the Coverflow to Facets or the Playlist? If not than can we at least have the albums that are part of the currently active playlist be highlighted?
Chronflow
Reply #255
One question: how can I delete the highlight-frame around the center cover? Is there a way to do this in the script-area?
No, sorry - that's not possible yet - will be implemented in the future.
Com Exception (outer): Unknown error 0x800A017C
Great, you are getting different error messages ^^. Now it's getting compilcated. Anyway - at least I have an error number now. Will have a look into it tomorrow.
You can use the left and right arrow key.
also get the shutdown error : "Release OF RC Failed"
You are using the most recent foobar version?`I'm sorry - I can't support it, since it doesn't run on win2k.
still getting my c++ runtime error with changed image path (view last post)... T_T
My fix didn't work, sry. Will be fixed in the next version
Chronflow
Reply #256
What version should be used?
foobar has just crashed on startup. This was the first time I'd started foobar since installing chronflow.
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 011EA103h
Access violation, operation: read, address: 0000001Ch
Call path:
entry=>app_mainloop
Code bytes (011EA103h):
011EA0C3h:  C2 0C 00 33 C0 5E C2 0C 00 CC CC CC CC 56 8B F1
011EA0D3h:  80 7E 08 00 74 1E 53 8B DE E8 9F 02 00 00 8B 4E
011EA0E3h:  04 33 DB 3B CB 74 06 8B 01 8B 10 FF D2 89 5E 04
011EA0F3h:  88 5E 08 5B 5E C3 CC CC CC CC CC CC CC 8B 41 1C
011EA103h:  8B 40 1C C3 CC CC CC CC CC CC CC CC CC 8B 44 24
011EA113h:  08 50 E8 06 98 00 00 59 C2 08 00 CC CC 55 8B EC
011EA123h:  6A FF 68 31 70 21 01 64 A1 00 00 00 00 50 83 EC
011EA133h:  18 53 56 57 A1 34 11 23 01 33 C5 50 8D 45 F4 64
Stack (0012EB98h):
0012EB78h:  00000000 00000000 0000000C DC791250
0012EB88h:  0012FCD0 0000DE51 EE18DB64 EE18DD38
0012EB98h:  04F2E96B 0010057A 05016570 0012FB98
0012EBA8h:  050164A0 050163F0 05012470 04F238A2
0012EBB8h:  050163D8 2D7BBF0C 0010057A 050164A0
0012EBC8h:  00000000 00000200 00000000 01D100F6
0012EBD8h:  00000000 7E418BD9 7E470088 00000020
0012EBE8h:  0012EC24 7E41B3CC 7E41B3A7 01D100F6
0012EBF8h:  000000F6 050164A0 00000000 00000001
0012EC08h:  00000000 0012EBF4 0010057A 0012FBF4
0012EC18h:  7E440457 0000001D FFFFFFFF 7E41B3A7
0012EC28h:  04F22D94 0010057A 00000000 00000000
0012EC38h:  00000500 000003D1 00000000 050164A0
0012EC48h:  04F26906 0012EF80 7C80A9CC 050164A0
0012EC58h:  00000000 7C90E57C 04FCA5BC 00000000
0012EC68h:  00000000 00000000 00000053 000000BC
0012EC78h:  00AADF24 6D01139A 00000000 00CE0008
0012EC88h:  0012F21C 7C90E03C 04FCA5BC 00000000
0012EC98h:  00000000 00000000 000002A4 04FCA5BC
0012ECA8h:  00000000 00000000 00000000 00000000
Registers:
EAX: 00000000, EBX: 05012470, ECX: 01232E04, EDX: 01220594
ESI: 054F3E98, EDI: 050163F0, EBP: 05012470, ESP: 0012EB98
Crash location: "foo_chronflow", loaded at 011E0000h - 01242000h
Loaded modules:
foobar2000                      loaded at 00400000h - 00523000h
ntdll                            loaded at 7C900000h - 7C9B0000h
kernel32                        loaded at 7C800000h - 7C8F5000h
COMCTL32                        loaded at 773D0000h - 774D3000h
msvcrt                          loaded at 77C10000h - 77C68000h
ADVAPI32                        loaded at 77DD0000h - 77E6B000h
RPCRT4                          loaded at 77E70000h - 77F01000h
GDI32                            loaded at 77F10000h - 77F57000h
USER32                          loaded at 7E410000h - 7E4A0000h
SHLWAPI                          loaded at 77F60000h - 77FD6000h
SHELL32                          loaded at 7C9C0000h - 7D1D7000h
ole32                            loaded at 774E0000h - 7761D000h
shared                          loaded at 10000000h - 1002A000h
COMDLG32                        loaded at 763B0000h - 763F9000h
IMM32                            loaded at 76390000h - 763AD000h
LPK                              loaded at 629C0000h - 629C9000h
USP10                            loaded at 74D90000h - 74DFB000h
uxtheme                          loaded at 5AD70000h - 5ADA8000h
RocketDock                      loaded at 003D0000h - 003E2000h
PSAPI                            loaded at 76BF0000h - 76BFB000h
nview                            loaded at 00A60000h - 00BD3000h
OLEAUT32                        loaded at 77120000h - 771AB000h
WINMM                            loaded at 76B40000h - 76B6D000h
VERSION                          loaded at 77C00000h - 77C08000h
NTMARTA                          loaded at 77690000h - 776B1000h
WLDAP32                          loaded at 76F60000h - 76F8C000h
SAMLIB                          loaded at 71BF0000h - 71C03000h
MSCTF                            loaded at 74720000h - 7476B000h
RTSUltraMonHook                  loaded at 18800000h - 18836000h
msctfime                        loaded at 755C0000h - 755EE000h
foo_abx                          loaded at 00F00000h - 00F33000h
foo_albumlist                    loaded at 00F60000h - 00FC7000h
foo_audioscrobbler              loaded at 00FF0000h - 01020000h
WS2_32                          loaded at 71AB0000h - 71AC7000h
WS2HELP                          loaded at 71AA0000h - 71AA8000h
foo_autoplaylist                loaded at 01080000h - 010B0000h
foo_burninate                    loaded at 010D0000h - 01107000h
foo_cdda                        loaded at 01130000h - 01165000h
foo_channel_mixer                loaded at 01190000h - 011CA000h
foo_chronflow                    loaded at 011E0000h - 01242000h
gdiplus                          loaded at 4EC50000h - 4EDF3000h
OPENGL32                        loaded at 5ED00000h - 5EDCC000h
GLU32                            loaded at 68B20000h - 68B40000h
DDRAW                            loaded at 73760000h - 737A9000h
DCIMAN32                        loaded at 73BC0000h - 73BC6000h
foo_converter                    loaded at 01280000h - 012E9000h
foo_custominfo                  loaded at 01310000h - 01395000h
foo_cwb_hooks                    loaded at 013C0000h - 0140C000h
foo_discogs                      loaded at 01430000h - 014D1000h
foo_dop                          loaded at 014F0000h - 0159B000h
SETUPAPI                        loaded at 77920000h - 77A13000h
foo_dsp_delta                    loaded at 015C0000h - 015DE000h
foo_dsp_soundtouch              loaded at 01600000h - 01626000h
foo_dsp_std                      loaded at 01650000h - 01698000h
foo_dts                          loaded at 016C0000h - 0170E000h
foo_facets                      loaded at 01730000h - 017B0000h
MSIMG32                          loaded at 76380000h - 76385000h
foo_fileops                      loaded at 017D0000h - 01816000h
foo_freedb2                      loaded at 01840000h - 01881000h
foo_input_monkey                loaded at 018B0000h - 018FA000h
foo_input_shorten                loaded at 01920000h - 0194D000h
foo_input_std                    loaded at 01970000h - 01A98000h
foo_lyricsdb                    loaded at 01AC0000h - 01AEF000h
WININET                          loaded at 42C10000h - 42CDF000h
Normaliz                        loaded at 01B00000h - 01B09000h
iertutil                        loaded at 42990000h - 429D5000h
foo_masstag                      loaded at 01D30000h - 01D80000h
foo_menu_addons                  loaded at 01DA0000h - 01DE5000h
foo_misc_addons                  loaded at 01E10000h - 01E3D000h
foo_out_asio                    loaded at 01E60000h - 01E97000h
foo_out_ks                      loaded at 01EC0000h - 01EEA000h
foo_playcount                    loaded at 01F10000h - 01F35000h
foo_quicktag                    loaded at 01F60000h - 01F9E000h
foo_rgscan                      loaded at 01FC0000h - 0201A000h
foo_scrobblecharts              loaded at 02040000h - 02073000h
foo_trackpos                    loaded at 020A0000h - 020BF000h
foo_uie_albumart                loaded at 020E0000h - 0211D000h
foo_uie_albumlist                loaded at 02140000h - 02183000h
foo_uie_bookmarks                loaded at 021B0000h - 02205000h
foo_uie_elplaylist              loaded at 02220000h - 0225C000h
foo_uie_explorer                loaded at 02280000h - 022BC000h
foo_uie_graphical_browser        loaded at 022E0000h - 02371000h
foo_uie_lyrics                  loaded at 02390000h - 023EF000h
foo_uie_peakmeter                loaded at 02410000h - 02443000h
foo_uie_playlists_dropdown      loaded at 02470000h - 024A9000h
foo_uie_queuemanager            loaded at 024D0000h - 02509000h
mscoree                          loaded at 79000000h - 79046000h
MSVCR80                          loaded at 78130000h - 781CB000h
msvcm80                          loaded at 7C4C0000h - 7C53D000h
mscorwks                        loaded at 79E70000h - 7A3FF000h
mscorlib.ni                      loaded at 790C0000h - 79BF6000h
mscorjit                        loaded at 79060000h - 790B6000h
rsaenh                          loaded at 0FFD0000h - 0FFF8000h
System.ni                        loaded at 7A440000h - 7AC2A000h
System.Drawing.ni                loaded at 7ADE0000h - 7AF7C000h
foo_uie_quicksearch              loaded at 04C70000h - 04CB6000h
foo_uie_tabs                    loaded at 04CC0000h - 04CE6000h
foo_uie_vis_channel_spectrum    loaded at 04D10000h - 04D4A000h
foo_uie_vis_peakmeter_spectrum  loaded at 04D70000h - 04DAF000h
foo_ui_columns                  loaded at 04DD0000h - 04EE9000h
foo_ui_panels                    loaded at 04F10000h - 04FF9000h
foo_ui_std                      loaded at 05020000h - 050E1000h
foo_unpack                      loaded at 05110000h - 0513D000h
foo_utils                        loaded at 05160000h - 05198000h
RTSUltraMonHookRes              loaded at 18900000h - 18903000h
nvwddi                          loaded at 055D0000h - 055E5000h
ctagent                          loaded at 05600000h - 05607000h
mswsock                          loaded at 71A50000h - 71A8F000h
DNSAPI                          loaded at 76F20000h - 76F47000h
WINTRUST                        loaded at 76C30000h - 76C5E000h
CRYPT32                          loaded at 77A80000h - 77B14000h
MSASN1                          loaded at 77B20000h - 77B32000h
IMAGEHLP                        loaded at 76C90000h - 76CB8000h
mdnsNSP                          loaded at 16080000h - 160A5000h
CoreFoundation                  loaded at 18000000h - 18110000h
WSOCK32                          loaded at 71AD0000h - 71AD9000h
YSFileShim                      loaded at 05C80000h - 05C8A000h
icuuc36                          loaded at 05C90000h - 05D58000h
icudt36                          loaded at 09E20000h - 0A527000h
icuin36                          loaded at 05D60000h - 05DED000h
pthreadGC2                      loaded at 05DF0000h - 05DFF000h
libobjc.i386.A                  loaded at 22200000h - 2229D000h
Iphlpapi                        loaded at 76D60000h - 76D79000h
iTunesMobileDevice              loaded at 0A530000h - 0A644000h
QuickTime                        loaded at 66800000h - 6766D000h
DSOUND                          loaded at 73F10000h - 73F6C000h
hnetcfg                          loaded at 662B0000h - 66308000h
wshtcpip                        loaded at 71A90000h - 71A98000h
rasadhlp                        loaded at 76FC0000h - 76FC6000h
CLBCATQ                          loaded at 76FD0000h - 7704F000h
COMRes                          loaded at 77050000h - 77115000h
xpsp2res                        loaded at 20000000h - 202C5000h
DBGHELP                          loaded at 59A60000h - 59B01000h
Stack dump analysis:
Address: 04F2E96Bh, location: "foo_ui_panels", loaded at 04F10000h - 04FF9000h
Address: 04F238A2h, location: "foo_ui_panels", loaded at 04F10000h - 04FF9000h
Address: 7E418BD9h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetWindowThreadProcessId" (+00000159h)
Address: 7E470088h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 7E41B3CCh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "DefWindowProcW" (+00000090h)
Address: 7E41B3A7h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "DefWindowProcW" (+0000006Bh)
Address: 7E440457h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 04F22D94h, location: "foo_ui_panels", loaded at 04F10000h - 04FF9000h
Address: 04F26906h, location: "foo_ui_panels", loaded at 04F10000h - 04FF9000h
Address: 7C80A9CCh, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "lstrcmpW" (+00000000h)
Address: 7C90E57Ch, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "NtSetEvent" (+0000000Ch)
Address: 04FCA5BCh, location: "foo_ui_panels", loaded at 04F10000h - 04FF9000h
Address: 00AADF24h, location: "nview", loaded at 00A60000h - 00BD3000h
Symbol: "PMLoadPresentation" (+00003D14h)
Address: 7C90E03Ch, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "NtQueryInformationThread" (+0000000Ch)
Address: 00AADF4Fh, location: "nview", loaded at 00A60000h - 00BD3000h
Symbol: "PMLoadPresentation" (+00003D3Fh)
Address: 01000000h, location: "foo_audioscrobbler", loaded at 00FF0000h - 01020000h
Address: 7C80CE35h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "LCMapStringW" (+0000018Dh)
Address: 7E419E80h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "CharLowerBuffW" (+00000029h)
Address: 7E41DBE5h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "CharLowerW" (+0000004Bh)
Address: 00AAC81Eh, location: "nview", loaded at 00A60000h - 00BD3000h
Symbol: "PMLoadPresentation" (+0000260Eh)
Address: 7C90E1FEh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "ZwQueryValueKey" (+00000000h)
Address: 7C90FB6Ch, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlNtStatusToDosError" (+0000002Fh)
Address: 7C80A7AEh, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "GetThreadPriority" (+0000001Bh)
Address: 00AAD56Fh, location: "nview", loaded at 00A60000h - 00BD3000h
Symbol: "PMLoadPresentation" (+0000335Fh)
Address: 7C80BA80h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "lstrcpyW" (+0000001Ch)
Address: 7C80A9ECh, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "lstrcmpW" (+00000020h)
Address: 7C80A027h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "SetEvent" (+00000010h)
Address: 00AB0B11h, location: "nview", loaded at 00A60000h - 00BD3000h
Symbol: "PMLoadPresentation" (+00006901h)
Address: 00490055h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 00AB1059h, location: "nview", loaded at 00A60000h - 00BD3000h
Symbol: "PMLoadPresentation" (+00006E49h)
Address: 00490000h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 7A310000h, location: "mscorwks", loaded at 79E70000h - 7A3FF000h
Address: 79E71BCDh, location: "mscorwks", loaded at 79E70000h - 7A3FF000h
Address: 79F124A1h, location: "mscorwks", loaded at 79E70000h - 7A3FF000h
Symbol: "GetCLRFunction" (+0002F3EDh)
Address: 7A345948h, location: "mscorwks", loaded at 79E70000h - 7A3FF000h
Address: 00B38A48h, location: "nview", loaded at 00A60000h - 00BD3000h
Address: 79F0FA12h, location: "mscorwks", loaded at 79E70000h - 7A3FF000h
Symbol: "GetCLRFunction" (+0002C95Eh)
Address: 74730455h, location: "MSCTF", loaded at 74720000h - 7476B000h
Symbol: "TF_DllDetachInOther" (+00001625h)
Address: 00AD147Fh, location: "nview", loaded at 00A60000h - 00BD3000h
Symbol: "PMLoadPresentation" (+0002726Fh)
Address: 7E41F7F6h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "EnableMenuItem" (+0000006Fh)
Address: 7E41F805h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "EnableMenuItem" (+0000007Eh)
Address: 7E41F808h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "EnableMenuItem" (+00000081h)
Address: 7E431688h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetOpenClipboardWindow" (+00000037h)
Address: 7E431698h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetOpenClipboardWindow" (+00000047h)
Address: 7C90EAE3h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "KiUserCallbackDispatcher" (+00000013h)
Address: 747308B6h, location: "MSCTF", loaded at 74720000h - 7476B000h
Symbol: "TF_UninitSystem" (+0000044Dh)
Address: 7E431891h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "UnhookWinEvent" (+00000025h)
Address: 7E43E175h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "User32InitializeImmEntryTable" (+00000E18h)
Address: 7E43E152h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "User32InitializeImmEntryTable" (+00000DF5h)
Address: 00AD3C25h, location: "nview", loaded at 00A60000h - 00BD3000h
Symbol: "PMLoadPresentation" (+00029A15h)
Address: 7E41F84Ah, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "EnableMenuItem" (+000000C3h)
Address: 7C80261Ah, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "WaitForSingleObjectEx" (+000000DAh)
Address: 7C8025F0h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "WaitForSingleObjectEx" (+000000B0h)
Address: 7C839AA8h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "ValidateLocale" (+000002B0h)
Address: 7C8025F8h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "WaitForSingleObjectEx" (+000000B8h)
Address: 7C802532h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "WaitForSingleObject" (+00000012h)
Address: 7C90E2F1h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "NtReleaseMutant" (+0000000Ch)
Address: 7C8024B7h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "ReleaseMutex" (+00000010h)
Address: 74754C96h, location: "MSCTF", loaded at 74720000h - 7476B000h
Symbol: "TF_RunInputCPL" (+000045E7h)
Address: 74755352h, location: "MSCTF", loaded at 74720000h - 7476B000h
Symbol: "TF_GetThreadFlags" (+00000361h)
Address: 74755358h, location: "MSCTF", loaded at 74720000h - 7476B000h
Symbol: "TF_GetThreadFlags" (+00000367h)
Address: 7473EFF2h, location: "MSCTF", loaded at 74720000h - 7476B000h
Symbol: "TF_CreateCicLoadMutex" (+0000858Fh)
Address: 7473EFFFh, location: "MSCTF", loaded at 74720000h - 7476B000h
Symbol: "TF_CreateCicLoadMutex" (+0000859Ch)
Address: 7E41F896h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "CallNextHookEx" (+0000003Bh)
Address: 18808007h, location: "RTSUltraMonHook", loaded at 18800000h - 18836000h
Address: 1880800Ch, location: "RTSUltraMonHook", loaded at 18800000h - 18836000h
Address: 1881F454h, location: "RTSUltraMonHook", loaded at 18800000h - 18836000h
Address: 18824E58h, location: "RTSUltraMonHook", loaded at 18800000h - 18836000h
Address: 7E41F94Bh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "CallNextHookEx" (+000000F0h)
Address: 7E41F95Bh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "CallNextHookEx" (+00000100h)
Address: 18807E46h, location: "RTSUltraMonHook", loaded at 18800000h - 18836000h
Address: 7E41F819h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "EnableMenuItem" (+00000092h)
Address: 01FCEFE7h, location: "foo_rgscan", loaded at 01FC0000h - 0201A000h
Address: 74730E6Ch, location: "MSCTF", loaded at 74720000h - 7476B000h
Symbol: "TF_UninitSystem" (+00000A03h)
Address: 74730E71h, location: "MSCTF", loaded at 74720000h - 7476B000h
Symbol: "TF_UninitSystem" (+00000A08h)
Address: 7475E548h, location: "MSCTF", loaded at 74720000h - 7476B000h
Address: 74730E78h, location: "MSCTF", loaded at 74720000h - 7476B000h
Symbol: "TF_UninitSystem" (+00000A0Fh)
Address: 74730DE9h, location: "MSCTF", loaded at 74720000h - 7476B000h
Symbol: "TF_UninitSystem" (+00000980h)
Address: 7E418B26h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetWindowThreadProcessId" (+000000A6h)
Address: 04F21910h, location: "foo_ui_panels", loaded at 04F10000h - 04FF9000h
Address: 7E4188D1h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetWindowLongW" (+0000002Bh)
Address: 04FC1B62h, location: "foo_ui_panels", loaded at 04F10000h - 04FF9000h
Address: 04F21961h, location: "foo_ui_panels", loaded at 04F10000h - 04FF9000h
Version info:
foobar2000 v0.9.5.1
UNICODE
Windows 5.1
Additional info:
Bookmarks 0.2.5.2  (foo_uie_bookmarks)
Playlists Dropdown 0.6 alpha 4  (foo_uie_playlists_dropdown)
Audio CD Writer 2.0.1  (foo_burninate)
Graphical Browser rev014  (foo_uie_graphical_browser)
Explorer Tree 1.04.6b  (foo_uie_explorer)
Monkey's Audio decoder 2.1.2  (foo_input_monkey)
Quick Search Toolbar 2.8l  (foo_uie_quicksearch)
Masstagger 1.6  (foo_masstag)
Channel Spectrum panel 0.16  (foo_uie_vis_channel_spectrum)
Kernel Streaming Output 1.2.2  (foo_out_ks)
cwbowron's title format hooks 1.2.6 [Jan  2 2008 - 15:50:05]  (foo_cwb_hooks)
Queue manager panel 0.2.3  (foo_uie_queuemanager)
Standard DSP Array 1.0  (foo_dsp_std)
Discogs Tagger 1.12  (foo_discogs)
Track Positioner 1.0  (foo_trackpos)
ASIO support 1.2.6  (foo_out_asio)
Album Art Panel 0.2.7.1  (foo_uie_albumart)
ReplayGain Scanner 2.0.3  (foo_rgscan)
File Operations 2.1  (foo_fileops)
Tagger Panel Window 1.0.6 [Jan  2 2008 - 15:50:49]  (foo_cwb_hooks)
Panels UI 0.13.8 beta [Jun 12 2007 - 12:28:00]  (foo_ui_panels)
CD Audio Decoder 2.1.2  (foo_cdda)
foobar2000 core 0.9.5.1  (Core)
Playlist Tools 0.5.9  (foo_utils)
Facets 2008-01-25  (foo_facets)
Peakmeter Panel 0.0.4.2 beta  (foo_uie_peakmeter)
foo_custominfo 0.1.2  (foo_custominfo)
LPCM <--> delta-PCM converter 0.1.1  (foo_dsp_delta)
Quick Tagger 1.0  (foo_quicktag)
Menu Addons 0.4 (SSE)  (foo_menu_addons)
Default User Interface 0.9.5  (foo_ui_std)
Last.fm Chart Player 0.2.3  (foo_scrobblecharts)
Playback Statistics 2.0  (foo_playcount)
Shorten decoder 0.4.2.1  (foo_input_shorten)
Audioscrobbler 1.3.16  (foo_audioscrobbler)
ELPlaylist 0.2.4.2(alpha)  (foo_uie_elplaylist)
Channel Mixer 0.9.6.4  (foo_channel_mixer)
Coverflow pannel 0.2.0d  (foo_chronflow)
iPod manager 0.5.6.36 TEST  (foo_dop)
SoundTouch DSP 0.1 (SSE)  (foo_dsp_soundtouch)
Album List 4.2  (foo_albumlist)
Converter 1.1  (foo_converter)
Tabbed panel modifyed 0.2.1  (foo_uie_tabs)
ZIP/GZIP reader 1.0  (foo_unpack)
DTS decoder 0.1.1 (SSE)  (foo_dts)
Autoplaylist Manager 1.0  (foo_autoplaylist)
freedb Tagger 0.5.2.1  (foo_freedb2)
Columns UI 0.3 beta 1 preview 4  (foo_ui_columns)
Lyric Show Panels 0.3.1.1  (foo_uie_lyrics)
RAR reader 1.1  (foo_unpack)
foo_lyricsdb 0.0.7 beta 5  (foo_lyricsdb)
Peakmeter Spectrum Visualisation 0.1.0.1 beta  (foo_uie_vis_peakmeter_spectrum)
Misc. Addons 0.1.1 (SSE)  (foo_misc_addons)
Album list panel 0.2.3 beta  (foo_uie_albumlist)
ABX Comparator 1.3.1  (foo_abx)
Chronflow
Reply #257
There is the worth that waited
it's really great component...so good
Chronflow
Reply #258
@Chronial: Thank you for this component, it does not support wild cards currently, am I right? When I try to use wild cards, it crashes with C runtime error. It also crashes with the same error when I try $files function from foo_func.
Chronflow
Reply #260
Wow! Great component. It's almost perfect for my needs.
To be perfect, is it possible to add an extra cover in the cover flow for every track which is not in the database or filtered out by a database filter. It's in order to have "displayed cover follows playing track" working for each track of the playlist.
Chronflow
Reply #261
So, done with all the bugfixing, I think.
Get the version 0.2.1 here:
http://chron.visiondesigns.de/foobar2000/f...flow_v0.2.1.zip
Please remember: you need Windows Script Control - get it here: http://www.microsoft.com/downloads/details...;displaylang=en
Changes:
Implemented. See Display Tab in options. Set the with to 0 to remove the highlight-frame.
Fixed.
Chronflow
Reply #263
The new version can't load the cover images. I only get this:
Chronflow
Reply #264
Damn - uploaded wrong version.
Please download again
Chronflow
Reply #266
OK, all is working fine. Thanks a lot! This really is my favourite plugin now!
Only the bug I mentioned a few posts before (see top of page 11) is still there: a white stripe across the panel when I leave an empty album title field:
Doesn't bother me because when I doesn't want do display any text I simply type "." and push it down out of the visible space, but I think I should mention it nevertheless...
Chronflow
Reply #267
Yay the newest version (2.1) works perfectly! No crashes, speedy, and works on XP . Thanks for allll your hard work man . Good job .
One request: Would it be possible to have the coverflow bind to a playlist?
Chronflow
Reply #268
I can only second it, both!! Works very good here now. NO C++ ERROR!!!!!! *yay*
just two more things:
1: If I bind double click to "play" nothing happens...
2: If the image's aspect-ratio isn't 1:1 when scrolling it pops out a little bit (hard to describe), I think b/c the boundaries of the selected image to resize are up/down... maybe this won't happen if it were left/right.
fb2k on OSX: flac q8 > rockboxed Sansa e280v1: Vorbis q5.0
Chronflow
Reply #269
Looks great, but even the new version is very slow with my library. After any click the panel waits 2 to 4 seconds before moving the covers.
And it eats 200 Mb of RAM.
I have around 3000 albums in the library, though, so the lockups are understandable.
Chronflow
Reply #270
Thanks for mentioning again - I had already forgotten that one. This is fixed now - will be fixed in the next release. You can btw. just use " " (a space) as the formating string.
On the todo list.
Chronflow
Reply #271
This happens because "play" is only available on the playlist. I can't check this while listin the available commands. But I added this single item as an exception (this means it won't be selectable as an action any more). I would generally advice you to use foo_trackpos, as it provides a very useful command to use as default action for plugins like chronflow.
no, it's not . This is "desired" - it's a side affect of the Jscript code that makes very wide covers beeing displayed larger when they come to front. If you don't like this side-effect, just change the coverSizeLimits() function to:
function coverSizeLimits(coverId){
   if (Math.abs(coverId) < 1){ // The centered cover
      var w, h;
      w = 1;
      h = 1.2 + Math.abs(coverId) * 0.8;
      return new Array(w, h);
   } else { // The covers on the side
      return new Array(1, 2);
No - that's not acceptable. I have the same amount of albums and the panel should always be 100% responsive (it will even by with 30000 albums). When do you experience this delay? Only when you click on a cover, or also when you use the keyboard?
Or are you talking about track-changes? This is not my fault. Other components are blocking foobar. One of the candidates for that is uie_albumart. If you remove all other components, the panel should react instantly to track-changes.
Chronflow
Reply #272
Chronial, every time I exit foobar, I get a shutdown error msg. (I am fairly certain I have isolated this error to your chronflow plugin)
It reads:  Release of RC failed. (mainWin)
Chronflow
Reply #273
Yes, this is my plugin. The titlebar of the message should also say so .
Which version of foobar are you using?
Chronflow
Reply #274
I've got one more:
When double-click an album which contains more than one discs (numbered by "discnumber" tag), the playlist lists all the #1-tracks first, then all the #2-tracks and so on.
A sorting as following would make much more sense:
disc 1 / track 1
disc 1 / track 2
disc 1 / track 3
disc 2 / track 1
disc 2 / track 2
I don't want to put the discnumbers into my sorting routine since I still want ONE cover for each album in the chronflow window.
Would it be possible to change this behaviour?
EDIT: Shame on me. Found it myself. Sorry!
