Not sure if im putting this is the right place, but here goes;
I'm having a wierd problem with images not showing up. I'm trying to modify the Liqourice thingie.
Everything is working smooth, but for some reason the some of the album art is not showing up. Most of it works perfect, but some won't show up. They're named correctly (folder.jpg) and all that, tried removing the files, refreshing the library, everything, but for some artists it wont show up.
Is this even a problem within panels or is it something wierd going on with the files?
I'm very new to this, although most of the code is making sense, some stuff is still confusing.
Here is the code for the album art;
Sources:
// --- Image sources
//$puts(nocover,$getpvar(dir)/noart.png)
$puts(imgsrc,$replace(%path%,%filename_ext%,folder.*))
//$puts(artoverlay,$getpvar(dir)/overlay.png)
$puts(border,$getpvar(dir)/corners.png)
Displaying:
// --- Album Art Display
$if($and($fileexists($get(imgsrc)),$greater(%_itemcount%,5)),
//$imageabs2($get(imgw),89,,$eval($get(rowheight)*{%_itemindex%-1}),$get(imgw),$get(rowheight),$get(leftpad),,$get(nocover),NOKEEPASPECT)
$imageabs2($get(imgw),89,,$eval($get(rowheight)*{%_itemindex%-1}),$get(imgw),$get(rowheight),$get(leftpad),,$get(imgsrc),)
//$imageabs2($get(imgw),89,,$eval($get(rowheight)*{%_itemindex%-1}),$get(imgw),$get(rowheight),$get(leftpad),,$get(artoverlay),NOKEEPASPECT alpha-150)
$imageabs2($get(imgw),89,,$eval($get(rowheight)*{%_itemindex%-1}),$get(imgw),$get(rowheight),$get(leftpad),,$get(border),NOKEEPASPECT)
EDIT
Solved!
Seems as if the directory with the folder.jpg is named with a "#" in it, it wont load the images. Is this a known bug? Anyway to work around it than to rename the folder?
