Topic: Musepack (MPC) SV8 beta is out (Read 73904 times) previous topic - next topic
Reply #75
Decode to stdout still not working with the latest binaries.
Is there a special command for stdout or can I use - ?
http://r2d.musepack.net/files/musepack_bin_20071123.zip
It works fine for me. Yes, you should use - for stdout.
D:\Util\MusePack\sv8>mpcdec.exe -h
mpcdec - Musepack (MPC) decoder v0.9.2 (C) 2006-2007 MDT
Built Nov 23 2007 16:27:47
Usage: mpcdec.exe [-i] [-h] <infile.mpc> [<outfile.wav>]
-i : print file information on stdout
-c : check the file for stream errors
     (doesn't fully decode, outfile will be ignored)
-h : print this help
you can use stdin and stdout as resp. <infile.mpc> and
<outfile.wav> replacing the file name by "-"
Reply #76
E:\Console\codec>mpcdec input.mpc - | lame -V5 --vbr-new --quiet - output.mp3
2446080 samples decoded in 342 ms (162.18x)
This wil create a mp3 file with very much noise.
Decoding directly to a wav file is working without any problem.
Also decoding without transcoding creates a wav file with very much noise.
E:\Console\codec>mpcdec input.mpc - > output.wav
mpcdec - Musepack (MPC) decoder v0.9.2 © 2006-2007 MDT
2446080 samples decoded in 405 ms (136.95x)
Reply #77
stdout works for me on debian - both output to file and to pipe.
and since others on windows have verified this there must be something wrong with your situation specifically.
later
Reply #78
When trying decoding to stdout on another system it gave me the error message that msvcr71.dll was missing.
After copying msvcr71.dll to the same directory as mpcdec.exe it gives the same disturbed output as on my other computer.
PS
Decoding to file works perfectly on both systems.
Reply #79
Now I see.
Verified here with 3 versions of lame as well as with Ogg Vorbis. Same results (noise).
Reply #80
I haven't looked at it yet and might do it later this evening, but what's the output format of mpcdec when writing to stdout? wave or raw pcm? What LAME version are you using?
Reply #82
Years of wait... thanks, now it nearly dream will be ture...
( missing Hydrogenaudio.. )
Guitarist with Tinnitus, i wish to hear the pure silent again.
Reply #83
i just noticed - r2d fixed the stdin/out for y'all windows folks in SVN.
later
Reply #85
later
Confirmed
mpcdec (build 20071201)
Thanks for the updated binaries.
The first tests are looking promising.
Also the terminate bug (link below) from the previous 1.95e decode is fixed.
http://www.hydrogenaudio.org/forums/index....showtopic=54889
