Topic: foo_audioscrobbler 1.4.7 (Read 930021 times) previous topic - next topic
Reply #250
We could have the option for the new scrobbling style and the old scrobbling style with regards to the artist .
Just an idea.
It has been suggested before. I'd like to keep the number of options as minimal as possible in this component and prefer the right solution above any workarounds.
Reply #251
Just to contribute a weird VA scenario...
There is a compilation called Golden Apples of The Sun, which features various artists, but which was compiled by Devendra Banhart (who is not even featured on the compilation).  So for that album, I have "Devendra Banhart" under %ALBUM ARTIST%, and each individual artist under %ARTIST%.
And from the look of the tracklist on last.fm, it seems that %ARTIST% should be reported here, even though %ALBUM ARTIST% does not match "Various Artists" or "VA."
Thanks for your continued support of this component Florian, much appreciated
Reply #252
There is a compilation called Golden Apples of The Sun, which features various artists, but which was compiled by Devendra Banhart (who is not even featured on the compilation)...snip
There are quite a few albums like that out there. An example? Most trance compilations. Take "White Label Euphoria", the album was compiled by John '00' Fleming however all of the tracks are created by other people. Its situations like that which started this discussion.
Anyways, I thank Florian for taking a look at it
Reply #253
I've just released foo_audioscrobbler 1.3.9 which now uses %artist% instead of %album artist% again.
You can get it via the first post of this topic.
Kind regards,
Florian
Reply #254
Florian, and it will be hard to make an option what to scrobble? I mean - I want to scrobble %album artist% (so my profile won't get bad data), and others may want to scrobble %artist%. So, could you make an option for this?
Reply #255
It would be not hard to add.
But as I said above, I prefer a easy solution with as few possible problems caused by misuse of any options (just imagine users complaining about their tracks not being scrobbled because their over-complex title formatting for the artist field resulted in an empty artist).
Reply #256
So maybe something like option 'Scrobble %album artist% when possible' (turned off by default) and then check if the field is not empty, and if is not, then scrobble it?
Reply #257
I support Florian's decision. I helps to keep things clean. You "scrobble" tracks and not albums. Therefore if you have an album where an album artist is just someone who compiled some tracks into a sampler or mix album it would be wrong to have that person be associated with the track's title.
By the way, how does the official client do it?
Reply #258
Wait a minute. Album artist field is for main album composer, right? So f.e. Howard Shore. But Some track were made not only by him, so I tag thoes %album artist% - Howard Shore, %artist% - Howard Shore, Miranda Otto. And then - when I scrobble %artist%, last.fm don't recognize the track and don't know from wchich album it is. So it can't show mi simmilar tracks, and can't help me find more music I could possible like. And this it's most important feature.
Am I wrong?
Reply #259
The official client does it by reading the artist.
z-x: Yes you are wrong, because you are tagging your files incorrectly. Discog Last.fm.
Tag your files correctly!
The reason why last.fm doesn't recognise the track is because there's no artist named "Howard Shore, Miranda Otto" except for an entry in last.fm which is the result of bad data.
Please understand, you cant just list artists in the artist tag and expect last.fm to process each one, it reads it as a whole.
Thanks Florian, works fab.
z-x: Have you noticed your the only user listening to this artist
Like I stated previously, incorrectly tagged.
Reply #260
The official client reads the %artist% tag. It works like the previous few versions - where let's say you had multiple artists tagged as "Artist 1; Artist 2", it would only scrobble "Artist 1;" as the track artist. This is what I prefer actually - which is why I switched to using the last.fm client now to scrobble instead of using this plugin.
Reply #262
No. For Foobar - for songs with multiple artists (or actually I think this is a ID3 standard...not quite sure)
Last.fm only reads the first artist.
Such an example is "Something Stupid" by Robbie Williams and Nicole Kidman.
I have them tagged as such in the artist field: "Robbie Williams; Nicole Kidman". Last.fm only reads Robbie Williams and ignores Nicole Kidman..
Reply #263
I know this all, but it's not incorect method. The %artist% tag should be for the current artist (even when there are many of them), and the %album artist% is the one who is 'main' artist from current album. It's not my bad data. Or you are trying to tell me, that the %artist% and %album artist% should be the same?
I'm not expecting this - that is for why I am asking for possibility to select which tag i want to send to last.fm. I want to know with who Bjork made the Gling-Gló album, and I want to know that Miranda Otto sang on The Lord of the Rings soundtrack - the %artist% tag is great for it.
Yep, I've noticed. But the ', Trio...' part is in %artist% tag, because that is the actual artist. And the %album artist% is Bjork herself.
Reply #264
Gling-Gló
Tag correctly. There is a Performer tag, perhaps you can put Miranda Otto there. Whichever gets sent to last.fm, either %album artist% or %artist%, its incorrect with your current tagging scheme.
Reply #265
Nope. The %album artist% is just like that in Audioscrobbler and many others - just single 'main' artist, no comas and others performer's.
Maybe I should use another tag, who knows... Just - I don't see a reason %album artist% and %artist% should be the same.
Reply #266
Look at this release http://www.discogs.com/release/975325
I think a more logical to send "%album artist% = Tajmahal" instead of each artists.
Also: http://www.discogs.com/release/82535
"The Mystery Of The Yeti" should scrobbling with my "%album artist%  like the fist volume http://www.discogs.com/release/90964
I like %album artist% method with VA-checking.
So, I see no another way except to make scrobbling method optionaly..
And all will be happy..
Thinking Outside The Box
Reply #267
Nope. The %album artist% is just like that in Audioscrobbler and many others.
I dont understand, you have 2 halves of the artists name in 2 different tags.
Maybe its because I am obsessive about my tagging, but the Tajmahal example is wrong because there are about 3 remixes present. So it WILL get confused with the original and the remix by the additional artists. I also dont see how just because Tajmahal is common that the rest of artists disappear. Its misinformation.
Same applies to Mystery of the Yeti.
Reply #268
OK, so two examples: http://bayimg.com/BAHMLAAbB, http://bayimg.com/BahmmAabB
Like I said - I'm using %album artist% for main artist of the album (in most cases the onyly person that is mentioned in front of album art) and %artist% to mention all of the artist that are performing current song.
EDIT: Said what I wanted. EOT for me, cause we really start a war.
Reply #269
Looks like a new holy war..  Issue with Tajmahal is debatable, but "Mystery of the Yeti" identified themselves and it's really an alias, not VA. Just look at the first volume..
However, sorry for my flood.
Reply #270
I experienced a crash with this component (using 1.3.9; latest version):
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 7C93426Dh
Access violation, operation: read, address: 00000000h
Call path:
Code bytes (7C93426Dh):
7C93422Dh:  90 90 90 FF FF FF FF 00 00 00 00 62 CA 93 7C 90
7C93423Dh:  90 90 90 90 64 A1 18 00 00 00 53 6A 00 8B 40 30
7C93424Dh:  FF 70 18 E8 E8 C1 FD FF C3 88 4F 05 8D 48 08 8B
7C93425Dh:  11 89 95 64 FF FF FF 8B 40 0C 89 85 5C FF FF FF
7C93426Dh:  8B 00 3B 42 04 0F 85 13 01 00 00 3B C1 0F 85 0B
7C93427Dh:  01 00 00 FF 75 B0 8B 75 E4 56 E8 08 C9 FD FF 8B
7C93428Dh:  85 64 FF FF FF 8B 8D 5C FF FF FF 89 01 89 48 04
7C93429Dh:  3B C1 0F 84 E4 77 00 00 8B 45 B0 0F B7 08 29 4E
Stack (05E9FB5Ch):
05E9FB3Ch:  01170E45 011B0000 00000000 00000031
05E9FB4Ch:  00000031 011B46CC 00000020 011B46C8
05E9FB5Ch:  000000BA 00000000 7C9105D4 00000100
05E9FB6Ch:  011B5F78 7C917BB0 0000003D 0000003D
05E9FB7Ch:  011BBCC8 00000001 00000001 011BB028
05E9FB8Ch:  00000008 011BB030 00000269 011B01C0
05E9FB9Ch:  0000000F 00000018 011B7E90 011BB3E0
05E9FBACh:  011B7E98 7C910F46 011BB778 011BB170
05E9FBBCh:  011BBCD8 05E9FBD0 011BC938 7C9105C8
05E9FBCCh:  011B7688 0000000F 7C910551 011B08F8
05E9FBDCh:  7C91056D 00000000 011B7690 00000000
05E9FBECh:  00000000 011BBCD0 7C90EE18 011BB768
05E9FBFCh:  FFFFFFFF 7C91056D 01170BEA 0000000B
05E9FC0Ch:  05E9FC1C 00000000 7C9105C8 09B269C8
05E9FC1Ch:  05E9FCE8 00000000 00160778 7C91056D
05E9FC2Ch:  011BBDE0 0000000F 001EE430 011B0338
05E9FC3Ch:  0000000C 011BAB18 011BC940 011BBCC0
05E9FC4Ch:  011BAFC8 011B4698 011BBCC0 0000000E
05E9FC5Ch:  011BC940 7C9105C8 00000178 05E9FD34
05E9FC6Ch:  7C910551 00160928 011BB778 00200E38
Registers:
EAX: 00000000, EBX: 00000257, ECX: 011B15F8, EDX: 00000000
ESI: 011B0270, EDI: 011B0338, EBP: 05E9FD7C, ESP: 05E9FB5C
Crash location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlInitializeContext" (+000001ECh)
Loaded modules:
foobar2000                      loaded at 00400000h - 004F3000h
ntdll                            loaded at 7C900000h - 7C9B0000h
kernel32                        loaded at 7C800000h - 7C8F5000h
COMCTL32                        loaded at 773D0000h - 774D3000h
msvcrt                          loaded at 77C10000h - 77C68000h
ADVAPI32                        loaded at 77DD0000h - 77E6B000h
RPCRT4                          loaded at 77E70000h - 77F01000h
GDI32                            loaded at 77F10000h - 77F57000h
USER32                          loaded at 7E410000h - 7E4A0000h
SHLWAPI                          loaded at 77F60000h - 77FD6000h
SHELL32                          loaded at 7C9C0000h - 7D1D5000h
ole32                            loaded at 774E0000h - 7761D000h
shared                          loaded at 10000000h - 10029000h
comdlg32                        loaded at 763B0000h - 763F9000h
ShimEng                          loaded at 5CB70000h - 5CB96000h
AcGenral                        loaded at 6F880000h - 6FA4A000h
WINMM                            loaded at 76B40000h - 76B6D000h
OLEAUT32                        loaded at 77120000h - 771AB000h
MSACM32                          loaded at 77BE0000h - 77BF5000h
VERSION                          loaded at 77C00000h - 77C08000h
USERENV                          loaded at 769C0000h - 76A73000h
UxTheme                          loaded at 5AD70000h - 5ADA8000h
IMM32                            loaded at 76390000h - 763AD000h
LPK                              loaded at 629C0000h - 629C9000h
USP10                            loaded at 74D90000h - 74DFB000h
wbsys                            loaded at 66500000h - 6650A000h
wbhelp                          loaded at 66600000h - 66617000h
DrvTrNTm                        loaded at 6BC00000h - 6BC1A000h
DrvTrNTl                        loaded at 6BC20000h - 6BC3D000h
serwvdrv                        loaded at 5CD70000h - 5CD77000h
umdmxfrm                        loaded at 5B0A0000h - 5B0A7000h
wblind                          loaded at 66000000h - 6607B000h
msimg32                          loaded at 76380000h - 76385000h
lgscroll                        loaded at 10100000h - 1010E000h
MSVCR71                          loaded at 7C340000h - 7C396000h
MSVCP71                          loaded at 7C3A0000h - 7C41B000h
apphelp                          loaded at 77B40000h - 77B62000h
msctfime                        loaded at 755C0000h - 755EE000h
foo_abx                          loaded at 01040000h - 01073000h
foo_albumlist                    loaded at 010A0000h - 010E7000h
foo_amipwrapper                  loaded at 01110000h - 0113C000h
foo_audioscrobbler              loaded at 01160000h - 01199000h
WS2_32                          loaded at 71AB0000h - 71AC7000h
WS2HELP                          loaded at 71AA0000h - 71AA8000h
foo_autoplaylist                loaded at 011C0000h - 011F0000h
foo_browser                      loaded at 01210000h - 01249000h
foo_cdda                        loaded at 01270000h - 012A5000h
foo_common                      loaded at 012D0000h - 01303000h
foo_converter                    loaded at 01330000h - 01399000h
foo_custominfo                  loaded at 013C0000h - 01445000h
foo_cwbowron                    loaded at 01470000h - 0149A000h
gdiplus                          loaded at 4EC50000h - 4EDF3000h
foo_cwb_hooks                    loaded at 014D0000h - 0151D000h
foo_default_videoplayer          loaded at 01540000h - 0154D000h
MSVCR80                          loaded at 78130000h - 781CB000h
foo_dockable_panels              loaded at 01570000h - 015A3000h
foo_dop                          loaded at 015D0000h - 0163C000h
SETUPAPI                        loaded at 77920000h - 77A13000h
foo_dsp_delta                    loaded at 01660000h - 0167E000h
foo_dsp_std                      loaded at 016A0000h - 016E1000h
foo_freedb2                      loaded at 01710000h - 01750000h
foo_ftpput                      loaded at 01770000h - 017EF000h
WINSPOOL                        loaded at 73000000h - 73026000h
WININET                          loaded at 42C10000h - 42CDF000h
Normaliz                        loaded at 01800000h - 01809000h
iertutil                        loaded at 42990000h - 429D5000h
foo_history                      loaded at 01A50000h - 01A6C000h
foo_input_std                    loaded at 01A90000h - 01BA2000h
foo_joystick_control            loaded at 01BD0000h - 01BEE000h
DINPUT8                          loaded at 6CE10000h - 6CE48000h
foo_lyricsdb                    loaded at 01C10000h - 01C3F000h
foo_masstag                      loaded at 01C60000h - 01CB0000h
foo_playback_custom              loaded at 01CD0000h - 01D15000h
foo_playlist_bind                loaded at 01D50000h - 01D75000h
foo_playlist_manager            loaded at 01D90000h - 01DD4000h
foo_playlist_tree                loaded at 01E00000h - 01E76000h
libmzsch360_000                  loaded at 10400000h - 105D0000h
WSOCK32                          loaded at 71AD0000h - 71AD9000h
libmzgc360_000                  loaded at 01EA0000h - 01F44000h
foo_pqview                      loaded at 01F90000h - 01FAB000h
foo_preview                      loaded at 01FD0000h - 01FF1000h
foo_rgscan                      loaded at 02010000h - 02058000h
foo_run                          loaded at 02080000h - 020AB000h
foo_runcmd                      loaded at 020D0000h - 020FF000h
foo_tlbRC                        loaded at 02120000h - 02140000h
foo_uie_albumart                loaded at 02160000h - 0219C000h
foo_uie_albumart_msn            loaded at 021C0000h - 021DC000h
foo_uie_lyrics                  loaded at 021F0000h - 02251000h
foo_uie_lyrics_panel            loaded at 02280000h - 022E9000h
foo_uie_peakmeter                loaded at 02310000h - 0233D000h
foo_uie_playlists_dropdown      loaded at 02360000h - 0239C000h
foo_uie_powerpanels              loaded at 023C0000h - 023E3000h
foo_uie_pvt                      loaded at 02410000h - 02442000h
foo_uie_queuemanager            loaded at 02470000h - 024A9000h
mscoree                          loaded at 79000000h - 79045000h
msvcm80                          loaded at 7C4C0000h - 7C53D000h
mscorwks                        loaded at 79E70000h - 7A3D6000h
mscorlib.ni                      loaded at 790C0000h - 79B90000h
mscorjit                        loaded at 79060000h - 790B3000h
rsaenh                          loaded at 0FFD0000h - 0FFF8000h
System.ni                        loaded at 7A440000h - 7AC06000h
System.Drawing.ni                loaded at 7ADE0000h - 7AF6C000h
foo_uie_quicksearch              loaded at 04C20000h - 04C66000h
foo_uie_tabs                    loaded at 04C70000h - 04C9A000h
foo_uie_typefind                loaded at 04CB0000h - 04CE0000h
foo_uie_vis_channel_spectrum    loaded at 04D00000h - 04D28000h
foo_uie_vis_egoh                loaded at 04D50000h - 04D6D000h
foo_ui_columns                  loaded at 04D80000h - 04E25000h
foo_ui_panels                    loaded at 04E50000h - 04F17000h
foo_ui_std                      loaded at 04F40000h - 04F97000h
foo_unpack                      loaded at 04FC0000h - 04FEE000h
foo_winamp_spam                  loaded at 05010000h - 0502F000h
HookDll                          loaded at 05460000h - 05467000h
mswsock                          loaded at 71A50000h - 71A8F000h
DNSAPI                          loaded at 76F20000h - 76F47000h
mdnsNSP                          loaded at 16080000h - 16099000h
Iphlpapi                        loaded at 76D60000h - 76D79000h
WINTRUST                        loaded at 76C30000h - 76C5E000h
CRYPT32                          loaded at 77A80000h - 77B14000h
MSASN1                          loaded at 77B20000h - 77B32000h
IMAGEHLP                        loaded at 76C90000h - 76CB8000h
amip                            loaded at 06830000h - 069EA000h
hnetcfg                          loaded at 662B0000h - 66308000h
wshtcpip                        loaded at 71A90000h - 71A98000h
DSOUND                          loaded at 73F10000h - 73F6C000h
wdmaud                          loaded at 72D20000h - 72D29000h
HID                              loaded at 688F0000h - 688F9000h
msacm32                          loaded at 72D10000h - 72D18000h
midimap                          loaded at 77BD0000h - 77BD7000h
rasadhlp                        loaded at 76FC0000h - 76FC6000h
KsUser                          loaded at 73EE0000h - 73EE4000h
System.Windows.Forms.ni          loaded at 7AFD0000h - 7BC54000h
netapi32                        loaded at 5B860000h - 5B8B4000h
CLBCATQ                          loaded at 76FD0000h - 7704F000h
COMRes                          loaded at 77050000h - 77115000h
GRA8E1~1                        loaded at 09240000h - 0945D000h
GrooveUtil                      loaded at 68EF0000h - 68FE1000h
GrooveNew                        loaded at 68FF0000h - 68FF7000h
ATL80                            loaded at 7C630000h - 7C64B000h
GR99D3~1                        loaded at 65E30000h - 65E67000h
urlmon                          loaded at 42CF0000h - 42E14000h
Msxml3                          loaded at 74980000h - 74A93000h
Secur32                          loaded at 77FE0000h - 77FF1000h
winrnr                          loaded at 76FB0000h - 76FB8000h
WLDAP32                          loaded at 76F60000h - 76F8C000h
sensapi                          loaded at 722B0000h - 722B5000h
MPRAPI                          loaded at 76D40000h - 76D58000h
ACTIVEDS                        loaded at 77CC0000h - 77CF2000h
adsldpc                          loaded at 76E10000h - 76E35000h
ATL                              loaded at 76B20000h - 76B31000h
rtutils                          loaded at 76E80000h - 76E8E000h
SAMLIB                          loaded at 71BF0000h - 71C03000h
RASAPI32                        loaded at 76EE0000h - 76F1C000h
rasman                          loaded at 76E90000h - 76EA2000h
TAPI32                          loaded at 76EB0000h - 76EDF000h
msv1_0                          loaded at 77C70000h - 77C93000h
ieframe                          loaded at 42EF0000h - 434BB000h
PSAPI                            loaded at 76BF0000h - 76BFB000h
cscui                            loaded at 77A20000h - 77A74000h
CSCDLL                          loaded at 76600000h - 7661D000h
browseui                        loaded at 75F80000h - 7607D000h
ntshrui                          loaded at 76990000h - 769B5000h
SHDOCVW                          loaded at 77760000h - 778D0000h
CRYPTUI                          loaded at 754D0000h - 75550000h
xpsp2res                        loaded at 20000000h - 202C5000h
DBGHELP                          loaded at 59A60000h - 59B01000h
Stack dump analysis:
Address: 7C9105D4h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+00000000h)
Address: 7C917BB0h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlReAllocateHeap" (+000001B3h)
Address: 7C910F46h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "wcsncpy" (+000004B7h)
Address: 7C9105C8h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+0000018Bh)
Address: 7C910551h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+00000114h)
Address: 7C91056Dh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+00000130h)
Address: 7C90EE18h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "strchr" (+00000117h)
Address: 01170BEAh, location: "foo_audioscrobbler", loaded at 01160000h - 01199000h
Address: 7C911962h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlDeleteCriticalSection" (+000000D8h)
Address: 0201FFFFh, location: "foo_rgscan", loaded at 02010000h - 02058000h
Address: 7C9106F0h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+0000011Ch)
Address: 01170E45h, location: "foo_audioscrobbler", loaded at 01160000h - 01199000h
Address: 01161534h, location: "foo_audioscrobbler", loaded at 01160000h - 01199000h
Address: 011614A6h, location: "foo_audioscrobbler", loaded at 01160000h - 01199000h
Address: 01161502h, location: "foo_audioscrobbler", loaded at 01160000h - 01199000h
Address: 01161B7Dh, location: "foo_audioscrobbler", loaded at 01160000h - 01199000h
Address: 01161992h, location: "foo_audioscrobbler", loaded at 01160000h - 01199000h
Address: 7C8025F0h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "WaitForSingleObjectEx" (+000000B0h)
Address: 7C802532h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "WaitForSingleObject" (+00000012h)
Address: 01182738h, location: "foo_audioscrobbler", loaded at 01160000h - 01199000h
Address: 0116B530h, location: "foo_audioscrobbler", loaded at 01160000h - 01199000h
Address: 01190940h, location: "foo_audioscrobbler", loaded at 01160000h - 01199000h
Address: 011847A0h, location: "foo_audioscrobbler", loaded at 01160000h - 01199000h
Address: 01184784h, location: "foo_audioscrobbler", loaded at 01160000h - 01199000h
Address: 01184458h, location: "foo_audioscrobbler", loaded at 01160000h - 01199000h
Address: 0118297Bh, location: "foo_audioscrobbler", loaded at 01160000h - 01199000h
Address: 01184438h, location: "foo_audioscrobbler", loaded at 01160000h - 01199000h
Address: 0116BAB9h, location: "foo_audioscrobbler", loaded at 01160000h - 01199000h
Address: 7C80B683h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "GetModuleFileNameA" (+000001B4h)
Address: 7C839AA8h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "ValidateLocale" (+000002B0h)
Address: 7C80B690h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "GetModuleFileNameA" (+000001C1h)
Address: 0116BAB0h, location: "foo_audioscrobbler", loaded at 01160000h - 01199000h
Address: 7C800000h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Version info:
foobar2000 v0.9.4.4
UNICODE
Additional info:
Volume Panel 0.1  (foo_uie_powerpanels)
Album Art Panel 0.2.6  (foo_uie_albumart)
ReplayGain Scanner 2.0.2  (foo_rgscan)
Joystick Control 0.1.1  (foo_joystick_control)
Album List 3.2.0  (foo_albumlist)
History 0.2  (foo_history)
ZIP/GZIP reader 1.0  (foo_unpack)
Run Command 1.0 beta 2  (foo_runcmd)
Album Art Panel Mod (MSN) 0.2.1_8  (foo_uie_albumart_msn)
Lyric Show Panels 0.3.1.1b8 DEV [Sep 16 2007 - 08:44:03]  (foo_uie_lyrics)
Playlist Tree Panel 3.0.4 [Aug  2 2007 - 10:16:21]  (foo_playlist_tree)
Startup Actions 0.0.2 [Jul 23 2007 - 08:27:55]  (foo_cwbowron)
Playlists Dropdown 0.6 alpha 3  (foo_uie_playlists_dropdown)
Panels UI 0.14.12 beta [Jul 18 2007 - 13:39:30]  (foo_ui_panels)
Typefind 0.2 beta 1  (foo_uie_typefind)
Quick Search Toolbar 2.8k  (foo_uie_quicksearch)
Seek Panel 0.1  (foo_uie_powerpanels)
CD Audio Decoder 2.1.1  (foo_cdda)
WMA Decoder 1.1  (foo_input_std)
FTP Uploader 0.4.9  (foo_ftpput)
Converter 1.0.1  (foo_converter)
Autoplaylist Manager 1.0  (foo_autoplaylist)
Standard DSP array 1.0  (foo_dsp_std)
Masstagger 1.6  (foo_masstag)
NGPV Preview 0.0.2 B  (foo_uie_pvt)
Default video player 0.1.3  (foo_default_videoplayer)
Common services 0.1  (foo_common)
Playlist Manager 1.0.2  (foo_playlist_manager)
Preview 1.2  (foo_preview)
foobar2000 core 0.9.4.4  (Core)
FLAC Decoder 1.1.0  (foo_input_std)
ABX Comparator 1.3.1  (foo_abx)
cwbowron's title format hooks 1.2.5 [Jun  8 2007 - 08:49:42]  (foo_cwb_hooks)
Lyrics panel 0.35  (foo_uie_lyrics_panel)
foo_custominfo 0.1.2  (foo_custominfo)
Columns UI 0.2.0 alpha 3  (foo_ui_columns)
AMIP Wrapper 0.90  (foo_amipwrapper)
Music Browser 1.2.3b [Mar 23 2007 - 16:52:56]  (foo_browser)
Egoh Spectrum analyser (uie) 1.1.2  (foo_uie_vis_egoh)
Playback Statistics Custom 1.4.2  (foo_playback_custom)
TLB Remote Control 2.1  (foo_tlbRC)
Album Art Browser 0.0.5 [Jul 23 2007 - 08:27:55]  (foo_cwbowron)
LPCM <--> delta-PCM converter 0.1.1  (foo_dsp_delta)
Audioscrobbler 1.3.9  (foo_audioscrobbler)
Playlist Bind 3.1  (foo_playlist_bind)
Peakmeter Panel 0.0.4.0 alpha preview  (foo_uie_peakmeter)
Queue manager panel 0.2.3  (foo_uie_queuemanager)
Channel Spectrum panel 0.07  (foo_uie_vis_channel_spectrum)
iPod manager 0.4.3 TEST  (foo_dop)
Dockable Panels 1.0.7b [Mar 28 2007 - 09:18:48]  (foo_dockable_panels)
Run services 0.3.2  (foo_run)
RAR reader 1.1  (foo_unpack)
Tabbed panel modified 0.2.5  (foo_uie_tabs)
Winamp API Emulator 0.90  (foo_winamp_spam)
foo_lyricsdb 0.0.7 beta 5  (foo_lyricsdb)
freedb Tagger 0.5.2a  (foo_freedb2)
Default User Interface 0.9acc  (foo_ui_std)
Tagger Panel Window 1.0.5 [Jun 12 2007 - 15:14:00]  (foo_cwb_hooks)
Reply #271
Did this crash happen at a specific point (end of track / start of track) or can you reproduce it?
Has anyone experienced similar problems with the v1.3.9?
Reply #272
like z-x, i would prefer the using of %album artist%.
if you can add an option so each user can choose which artist to prefer it would be great. or at least if there's a situation of "artist 1; artist 2" submitting only the first artist.
i don't think x-y and me tagging our files incorrectly.
thank you
edit: how can i get 1.3.8 version?
edit2: nevermind, got it
Reply #273
It happened 3 times. It was random each time (except I was working on track info code each time). I haven't had a crash after those 3 however.
Reply #274
Since it happend three times when dealing with the track info component and the crash didn't occur in foo_audioscrobbler's code (according to the log you've supplied) I suggest you to post more logs - maybe they'll put more light in that dark.
