Topic: Peakmeter for Columns UI (Read 210993 times) previous topic - next topic
Reply #225
What about transparent window background?
either that or a background image would be a nice addition. would also be nice to make the peak indicator a bit wider. this is a pretty sweet component, i've always wanted a peakmeter for foobar.
Reply #226
gradients look great, can't wait to test this out.
keep up the good work!!!
foo_pm, can you give us another preview version, please?
Your plugin is one of the most useful ui plugins.
Thank you.
Thank you for the motivation  The next version (0.0.4.1 alpha) will include color-gradient-mode (mentioned before) and a mode in which you can use your own textures (images). For the most part it's implemented, but not tested. So please wait until the next version is presentable.
Hmmm..., i told in this post that i implement this in version 0.0.5. But i think i'll wait until panels ui development proceeds.
Thank you! Good idea. I will think about a background image and a customizable size for the peak indicator.
Reply #227
There is one ting i would like to see implemented in a future release is a possibility to disable the tooltip for channels peek and RMS.
And thanks for a great plug-in
Reply #228
Thanks! This will be part of the next version (0.0.4.1 alpha).
Reply #229
any updates? really looking forward to more features
btw great plugin
Reply #230
btw great plugin
Thanks! The new version 0.0.4.1 alpha will be released In a few days. The version will include, among other things:
- customizable range (-100 ... +27 dB)
- color-gradient-mode for the main bar
- image-mode with foreground and background image for the main bar
Reply #231
btw great plugin
can't wait for it
thanks
Reply #232
foo_pm
please, can you add bpm counter too?
Reply #233
first of all, i really love this plug-in.
my request, it would be nice if the channel textbox can be positioned on either left, right, top or bottom.
thanks for the great  plug-in!
Reply #234
Wohooooo!
We are waiting! ;-)
Sorry, but i really want to try out the new functions.
Does peakmeter support transparency in the next version?
Reply #235
foo_pm
nice idea, but i'm sorry to say that something like that is not planned.
Thanks! I'll try to implement this in one of the next versions.
Wohooooo!
We are waiting! ;-)
Thanks! A customizable background image will be part of the next version (0.0.5.x). When i got the time, transparency will be released too. EDIT: now you can try it out
Reply #236
A new version is released (0.0.4.1 alpha).
Some of the new features are:
- optional reset on track change
- zoom factor will be saved now (optional)
You can get it here: Peakmeter 0.0.4.1 alpha. Please backup your previous version!
Please notice a new requirement for W2K: GDI+.
Reply #237
Finaly!  Thanks a lot, going to test it
Thinking Outside The Box
Reply #238
The new features are great!
But I miss one thing. Main bar background is always displayed solid, and in previous version it used the same texture as the foreground, so it looked as on/off LEDs. Can this be fixed?
If age or weaknes doe prohibyte bloudletting you must use boxing
Reply #239
I noticed this as well. I was trying to find an option for it, but ended up using an image for right now. It would be great if this were fixed so I didn't have to use an image however .
Great progress so far, and I am looking forward to transparent mode so I can keep this viewable in in config ^___^.
Reply #240
Wow, I didn't like the new color scheme and wanted to revert to 0.4.0 alpha but using 0.4.1 messed up my foobar.cfg and the color scheme didn't go back to the default for 0.4.0.  The "Reset All" button in 0.4.0 alpha doesn't reset the colors, well now I know!
Reply #241
Is great that this new version supports easier tweaking of the ranges, but is still kinda  slow to change every range 1 by 1... maybe a checkbox or something like that would be nice.
Thanks again for this component!
Reply #242
When i use image-mode with foreground and background image for the main bar, i can not change the image.
I hope you will fix this for the next release
And thanks for the great component
Edit, i found a useful piece of software, so you can make your own color-gradient images  http://www.devenezia.com/downloads/gradient/index.html
Reply #244
+1  Also the relative path to images will be great..
Reply #245
Thanks both! It's fixed. You can get the new version here: Peakmeter 0.0.4.2 beta
Thanks. Yes, you are right. I will remember this for a future version.
Thanks. It's fixed in the current version 0.0.4.2 beta.
Thanks for this suggestion. Relative paths would be nice, particularly for shared configs.
Reply #246
Thanx for your reactivity foo_pm
waiting for relatives path too
bye
Br3tt
Reply #247
Hi, foo_pm!
Thanks a LOT for the plugin. This is how one should go about writing ones. No resource hog and highly customizable. Nearly perfect for me. To make it absolutely perfect, could u pls look at:
1. Additional bars: now they can only be _both_ on top or to the left of the main bars (depending on the meter orientation). Could u add an option for _each_ additional bar just like for labels: bottom/right & top/left?
2. Another request for peak value text boxes and smoother falling of peaks.
3. Customizable main bar peak height for vertical (width for horisontal orientation) or some other way to see them easily.
4. In vertical orientation the label is right or left justified. Could you make it also center justified (for 2 vertical main bars with one instance of lables between them)?
Thanks again.
Reply #248
bye
Br3tt
Hi, foo_pm!
  Thank you very much!
Nice suggestion and easy to implement. I think this will be part of the next release.
At this time the implemention of peak value text boxes is not planned.    I think an option to modify the falling of peaks is necessary and will be realized in a future version.
Ok, i'll think about it.
Good idea!    I'll try to implement this.
Reply #249
ahm, peakmeter not compatible atm with latest foobar v0.9.5b3, right?
