Topic: foo_ui_panels (Read 1318148 times) previous topic - next topic
0 Members and 16 Guests are viewing this topic.
foo_ui_panels
Reply #2375
Is it (im)possible to make PanelsUI completely transparent to the desktop, while keeping the layout (not alpha)???
foo_ui_panels
Reply #2376
Can I hide the window title? In the news versions i can't, ins't available setting in the preferences window...
foo_ui_panels
Reply #2377
Yann:
You can do so by adding $windowstyle(hidetitlebar) to the // Background section of your layout's settings.
foo_ui_panels
Reply #2379
thanks!!
other question: in a POPUP, which is the option for a button for close it?
i read the wiki for panels_ui and only find open it (POPUP:name), but in the popup (or the main window) which is the option for close it?
thanks again.
foo_ui_panels
Reply #2380
something like that ?
of course you can, with $glass() under Vista
Br3tt
(OT) That looks...... very nice
I'm not currently using Vista. Is the glass effect completely transparant, when the titlebar is hidden?
foo_ui_panels
Reply #2382
A return to PanelsUI 0.13.8 version, 0.14.12 too much bugged
0.14.2 cause bugging displays in SCPL (overlay display with offsets !! then black screen)
and it doesn't handle correctly the $alignabs() function
wait & see a more stable version.
Br3tt
foo_ui_panels
Reply #2383
I can't get the glass effect working properly.
@falstaff: Can you share your config? how do you get black graphic elements to show up without becoming transparent?
foo_ui_panels
Reply #2384
As far as I know, only black text doesn't work, but I could be wrong.
foo_ui_panels
Reply #2385
question: when transparency is set in the group display of SCPL, some of the text seems to be messed up:
how do i fix this?
thanks
foo_ui_panels
Reply #2386
Instead of forcing the glass element to disappear, be smart and just use a background image that is the same as your wallpaper
foo_ui_panels
Reply #2387
Hi! I'm having problems with sorting&grouping. I can't seem to sort by group by folder. I don't have "folder" in my sort/group-by criteria menu. Anyone out there who could help me out a little  ?
foo_ui_panels
Reply #2388
Hi, has anybody got the CONTEXT-SELECTED option for buttons working with 0.14?
$button2(800,100,0,0,23,23,'xxx','XXX',TAG:SET:rating:1,CONTEXT-SELECTED)
does only tag the playing track, not the selected ones.  I also tried other code from the forum.
Some other pui-configs use this option and don't work here (i.e. rating buttons in FofR configuration).
Any ideas? Seems to be a bug or 0.14 to me...  (0.14.12beta)
foo_ui_panels
Reply #2389
The configuration I downloaded (the latest Fofr one) is very nice but I've come to a problem. It has it set so that the Library Filter seperates bands with commas in the name (for instance,  Akron / Family or Meanwhile, Back in Communist Russia) into two different artist entries for each bit either side of the comma. Is there anyway I can change this, or some bit of code I need to have a look for in the configuration?
foo_ui_panels
Reply #2390
Don't exist a option for close the POPUP?
foo_ui_panels
Reply #2392
thanks.
foo_ui_panels
Reply #2393
I was waiting for terestrial to release the next version, but unfortunately for the foobar community it's starting to look like that might not happen anytime soon if at all.  What is the last "stable"-ish version of Panels UI?  The two I have are 13.7, which runs perfectly fine, and 14.12, which is ridiculously buggy - it crashes frequently and the image functions can't do what I want them to do, to align vertically.  Did any of the 14.xx versions run okay?
foo_ui_panels
Reply #2394
I hadn't any problem with 0.13.8 (since release) until now! Works excellent for me!
I will also release a config with 0.13.8 soon (maybe in a week)
foo_ui_panels
Reply #2395
Does anyone know if $meta_sum() or $info_sum() could be used to get the playing time of an album?  I've tried $info_sum(length_seconds) in the group section of SCPL, but it always returns 0, as does $meta_info(length_seconds).
I have been wondering the same thing but haven't seen any replies.  Any ideas?
Thanks,
John S.
foo_ui_panels
Reply #2396
I'm on the latest beta and it's never crashed for me. :/
foo_ui_panels
Reply #2397
In the changelog of version 14.12, I see no mention of 13.8 (not in the changelog linked in the wiki either).  Perhapse you mean 14.8?  Also you said "until now".  Why, what problem do you have now?  Is there someplace I can go to get specific versions of Panels UI?  There is only one version on the official site of terestrial's, and it's 13.7.
foo_ui_panels
Reply #2398
13.8 was a beta too.
14.12 was perfectly stable for me. Slightly odd alignment but easily rectifiable. I found that all my crashes were caused by tiny omissions in my code. All image paths had to start with / when relative to the Panels folder or else it crashed.
foo_ui_panels
Reply #2399
14.12 works fine for me too. Never had an issue with it. Sure there are some unfinished things, but my config doesn't use them. I am not to sure why lots of people get crashes and bugs, I haven't encountered anything like that. And I can't code in Panels UI to well lol.
