Topic: foo_ui_panels (Read 1318815 times) previous topic - next topic
0 Members and 23 Guests are viewing this topic.
foo_ui_panels
Reply #2325
Is it as simple as just uploading the pui and the images?
Thanks for your help in advance.
Yup, that's all.
Presumably that would only save the panels components though. My interface uses a couple of columns_ui panels as well, and they dont seem to have their settings transfered with the pui file. (To be expected i guess) Is there any easy way to transfer these settings across with the theme?
foo_ui_panels
Reply #2326
2 Quick Questions,
Once upon a time I used Track Info Panel to show some basic song information. When all my info wouldnt fit into the panel I could use my scroll wheel to scroll down and few the rest of the info.  Is there any way I can reproduce the behavior for my new Panels UI version of track info panel?  At current all my info does not fit in my panel and the only way for me to view whats cut off is to make the panel bigger.
2nd Question, does anyone know if there is a collection of user submitted track info panel layouts thats written in code for the new panels UI?
(I am using columns UI and am only using Panels UI for the track info panel functionality)
Thankyou,
-vader897
foo_ui_panels
Reply #2327
I have a suggestion:
If the development is halted, we should create a page to save the versions of Panel ui and a description what features and bugs each version has(maybe syntax if someone knows?).
To be honest I myself have no idea which version has which features and bugs because the developement was so fast.
I don't even know if we could have such a topic in the upload section. I know terrestrial always said that you shouldn't upload old versions but if the developement stopped we should keep his creation because I am sure many people want to use panel ui.
This is just an idea. What do you think?
foo_ui_panels
Reply #2328
It's an incomplete (dead?) project and I see no reason too keep it alive. I think it's unfair to let new users to play with buggy, no longer developed foobar components.
foo_ui_panels
Reply #2329
I am not so interested in PanelUi but in Track Info Mod.
Can somebody recommend me a almost bugfree version that already works with foo_cwb_hooks?
foo_ui_panels
Reply #2330
I would like to know which known bugs are present. I'm using the latest version and has no obvious critical bugs. I've seen a few abnormalities but nothing that affects the use of it.
foo_ui_panels
Reply #2331
Do you have a specific problem? I have no problem with the latest PanelsUI beta as track display panel. (But I must say I'm not doing album art or button stuff).
foo_ui_panels
Reply #2332
Yup, that's all.
I use the playlists switcher and save its settings by going to MENU>PREFERENCES>COLUMNSUI-General Tab-Export, that will create the only other file you need to share your config
WHY?!?! There are other components that have not been updated in a much longer time than this one. To say its' dead is presumptuous and besides, I'm able to use it daily just fine so why should something like that be killed. You show me any piece of software that is entirely free of bugs. The things that this plug-in enables the user to do far out weighs the few bugs they might never come across
I personally prefer v13.6 but in that build as in EVERY single build a really bad bug is if you close foobar from the  tray(right click exit) it saves your pui in an unusable state
foo_ui_panels
Reply #2333
Much obliged my friend.
foo_ui_panels
Reply #2334
Question: IS it possible to add multiple objects into glass?
I would like to be able have Single Column Playlist and Playlists dropdown in my foobar skin (like Explorer in vista), but the glass effect can be set only for one object.
J
The Playlists dropdown looks weird. I can't find out how to disable the glass effect also on this element.
foo_ui_panels
Reply #2335
You can't disable glass in components. If something is on top of glass it won't draw black or dark fonts/backgrounds.
Like this:
foo_ui_panels
Reply #2336
Request: Could editor windows NOT be in parent-child relation? Having multiple windows opened for different panels, switching between them would be very convinient. Thanks.
foo_ui_panels
Reply #2337
I have a question about playlists. I wish activate a playlist with a button e.g => $button(.....,[activate:playlist-name],)
is there a way to do this ?
its very important so thanx for your answer in advance  (its for a new config)
Brett
Like this:
hi,
how do you make possible glass effect on Single Column Playlist ?
Thanx in advance.
Br3tt
foo_ui_panels
Reply #2339
hi,
Thanx in advance.
Br3tt
hi
Just put the SCPL on glass.  no need to do anything else.
Just make sure you choose the right colors for everything (font/background), or else it won't be visible.
bb10
foo_ui_panels
Reply #2340
hi,
Thanx in advance.
Br3tt
hi
bb10
Thanx,
could you explain me the syntax parameter of $glass(), i don't find it in the syntax reference of panelsui !
OK, syntax found in the txt file info joined with the panelsui dll !
$glass(left,right,top,bottom) -> vista only. extends the "glass" margin.
works fine
Br3tt
foo_ui_panels
Reply #2341
Brett
nobody ?
please, give me feed back,
Thanx
foo_ui_panels
Reply #2342
Yes there is a way as you can execute commands with panelsUI. You execute
foobar2000.exe /playlist-activate:playlistofyourchoice
The command is from foo_cmd_playlist. IIRC foo_menu_addons also has this, not sure though...
foo_ui_panels
Reply #2343
hi I seem to be having a problem with formatting the main window title.
My string for it in Display > PanelsUI > Title Formatting > Main window title
is $if(%isplaying%,[%album artist% - ][%title%],foobar2000)
But foobar only displays "PanelsUI" on the window title! Ive tried everything and searched but I can't figure it out! Help much appreciated!
this is what it looks like
foo_ui_panels
Reply #2344
[a href="http://img214.imageshack.us/my.php?image=untitledjs1.jpg" target="_blank"]
foo_ui_panels
Reply #2345
thanx but how to use this command line ?? using foo_run.dll ??
how do i code a button using foo_run command ?
i've just created a Run Service under foo_run named 'active_playlist' that execute the command line:
C:\Program Files\Foobar2000\foobar2000.exe /playlist-activate:$get(new_playlist_to_activate)
then assigned to a button but it doesn't work (nothing happened!)
any idea of what i'm doing wrong ?
Thanx in advance
Br3tt
foo_ui_panels
Reply #2346
If someone know, I'm interested too.
foo_ui_panels
Reply #2347
Thanx in advance
Br3tt
i also created a command in foo_run and then assigned it to a button. but it works perfectly for me.
here's the code for the button:
$imagebutton($eval(%_width%/2-87),604,%foobar_path%\buttons\cover.png,%foobar_path%\buttons\cover-hot.png,Run/Coverdownload,tooltip,Download Cover)
perhaps the command in foo_run isn't correct.
foo_ui_panels
Reply #2348
thank you so much! god what a simple stupid mistake teaches me to read over the documentation agian!
foo_ui_panels
Reply #2349
Thanx in advance
Br3tt
thanx for the example for foo_run, i've missed Run/ before the run service name !
using /playlist-activate works now with a button but the name of the playlist to activate must be coded in the foo_run Path !!! It's not what i want to do, i want to activate a playlist by using a var that contain the playlist name to activate...
any idea for how giving the playlist name to activate in parameters ?
thanx
Br3tt
