Topic: foo_ui_panels (Read 1318098 times) previous topic - next topic
0 Members and 21 Guests are viewing this topic.
foo_ui_panels
Reply #2200
I just remembered how I resolved the issue I was having. It was because of the sort code I had in my Preferences.
Go to Preferences - General and see what sort code you have for 'Sort incoming files by'. Edit it accordingly and I think that may resolve your issue.
I think that looks like it might work.  I have only been using panels ui for a day or two so I am still getting used to how it works.  I will fiddle around with that later.  If anyone knows of any configs of a library filter that does open different trees depending on tag structure that doesnt  have this problem, please point me towards them so i can have a look to work out how it all works.  THanks
foo_ui_panels
Reply #2201
I really hope terrestrial hasn't stopped developing the component cause of bad feedback from older foobar community people.
foo_ui_panels
Reply #2202
I donlt know if this has been brought up already, but in SCPL, the only way to arrange tracks is to hold alt, then drag and drop. This is really annoying and kind of odd. Is there any plans to redesign this feature? I'm using foobar and panels_ui under wine in Linux, and the alt-drag method doesn't even work, as gnome and KDE both have alt-drag reserved for moving the window.
What version of Panels are you using? In the latest betas you can drag and drop by first selecting the track/tracks and letting go of the mouse button. Then click on the selection and drag as you wish.
I'm using 0.13.8 beta (June 12, 2007) Thats the one linked from the post in the OP. Is there a newer version? Also, how can I tell which version is the latest? In the past the only way I could tell was by downloading the link,  overwriting the old component in my foobar directory, restarting foobar, loading the preferences, and seeing if the number is greater. Seriously, nowhere in the OP, nor on the download page does it say which version is current. At some point I just kind of gave up on updating the thing.
foo_ui_panels
Reply #2203
I think this is possible. Or he may be just in holidays? If anyone knows more, let us know.
foo_ui_panels
Reply #2204
Some of the criticism in that thread while not positive was at least constructive (such as foosion's), but some of the latter from a certain member was utter verbal flatulence. I too hope it didn't turn him off or discourage him. There's obviously a lot of us who appreciate the time and work he's put into this component.
You can download the latest version released here (version 0.14.2 beta [Jul 18 2007]), but keep in mind there are many new changes, some things work differently, or may be buggy, so make backups of your PUI files, and refer to the wiki; the new changes (syntax and deprecated functions) are all documented, the latest version number is usually documented on the wiki as well.
foo_ui_panels
Reply #2205
i hope he is in holidays.. meritated holidays.
foo_ui_panels
Reply #2206
Indeed. Come back terrestrial!
Btw, does 'always on top' work for anyone or is that still a feature to be implemented?
foo_ui_panels
Reply #2207
That's exactly what i wondered today. Guess it's still on ToDo (not only the command via PanelsUI code but also the one accessable via menu)
At least I enabled it and nothing happened...
I so hope terrestrial is fine.
foo_ui_panels
Reply #2208
The !null! function in Library filter doesn't work for me anymore... I'm using 0.13.8, and this code:
$if(%favourite%,%favourite%,!null!)
also tried
$if2(%favourite%,!null!)
I'm pretty sure it has worked before, but not anymore. I get the questionmark in LF on all those tracks that don't have the %favourite% tag..
Anyone know what the problem might be?
foo_ui_panels
Reply #2209
Have you checked this with the latest version?
foo_ui_panels
Reply #2210
No, I don't want the latest version, yet... My whole config is written in the former language, and I dont want to rewrite everything as I just wrote it. It should work with !null! but it doesnt :S
foo_ui_panels
Reply #2211
The old syntax still works in the latest beta. Just back up your PUI if you want to downgrade later.
foo_ui_panels
Reply #2212
Is there a bug with %_trackinfo_notrack% in 0.14.12 beta ?
Its output seems broken.
foo_ui_panels
Reply #2213
I also hope terrestial keeps the development for this great plugin, but I thank him so much for the work he's done so far.
foo_ui_panels
Reply #2216
is there a way to embed all album covers of a particular artist? wanna make something like apple's coverflow... all my covers are stored in one directory and named like that: %artist%.%album%.folder.jpg
foo_ui_panels
Reply #2217
Thats not been my experience. The latest panels throws my alignments off and some of my fonts lose their colour
foo_ui_panels
Reply #2218
There might have been some changes, as long as you don't enable $newsyntax() there should only be small annoyances?! My config worked fine (and it was coded when panels-ui wasn't existent at all), but it's a rather simple layout. Anyways, it worked.
foo_ui_panels
Reply #2219
I'm using the newest version of panelsUI available, but I still got the same problem with playlist switcher. In every panelsUI-based config, it's not transparent. Someone wrote that it depends on columnsUI - I also updated that component, but it didn't help. Any suggestions?
foo_ui_panels
Reply #2220
The only way that the playlist switcher can be transparent is if your using ColumnsUI as your default display not panelsUI
foo_ui_panels
Reply #2221
Has found a bug!
In "Single Column Playlist"-> "Item Display" if to write $calcwidth(%length%) and to play song that after 10-30 seconds begins outflow of memory in 4 KB every second, that is visible in windows tasks dispatcher.
foo_ui_panels
Reply #2222
I've tried the $rand() function in Group Display in SCP and it seems that it's not working properly. The function itself works but it doesn't display the result properly; visual glitch.
for example, it displays the top of "8" with the botton of "4". it's always the first half of a number and a bottom of another number.
could anyone try it out to see if it's just me?
PanelsUI v0.14.14beta
foo_ui_panels
Reply #2223
Works fine here. May depend on your font/size settings and/or the "environment" (alignabs and so on)?
Where'd you get that one from, wasnt 0.14.12 the latest released beta?
foo_ui_panels
Reply #2224
Tell please as works "FILTER:name|value:name2|value2" and what is "name" and "value"?
