Topic: Peakmeter for Columns UI (Read 210991 times) previous topic - next topic
Reply #150
wow nice plugin!
can't wait to see new options.
I'd like to see the the things that go up and down fall down when pause of stop the song.
is this possible and realistic?
Thank you! I don't know exactly what you mean. When playback is paused the peak falls down if the fall down time is reached. For me it's a "bug". It's fixed and will released in 0.0.3.1.
and just to be sure, will 'reset all' reset the plugin settings or everything?
not the first time I delete my foobar settings :/
If you are in the peakmeter Preferences dialog the reset button will only reset the plugin settings. guaranteed
Reply #151
wow nice plugin!
Thank you! I don't know exactly what you mean. When playback is paused the peak falls down if the fall down time is reached. For me it's a "bug". It's fixed and will released in 0.0.3 alpha.
I dont mean the red peak.
what I mean is the green lines.
the green lines go op and down, as always.
but when I pause they freeze, but I'd like to see them slowly fall down.
so like this from high to low.
for me It will be a nice future, anyway I look forward to any new futures.
Reply #152
wow nice plugin!
Thank you, now I know what you mean. It's a nice idea but this will be implemented at a later date when all the major features are implemented.
Reply #153
This is a wonderful component, thank you very much for implementing it for everybody to enjoy.
Two requests:
1.  I believe this has already been requested, but I'd really like to remove the bars for levels beyond 0 from my display.  I thought hiding them in the new version would do this, but apparently it does not (maybe it just hides the labels?).
2.  It would be great if there were some color blending so that the differences between the different colors assigned to the various levels were not so obvious in the display (particular for wide or tall peakmeters).
Reply #154
Two requests:
Thank you! Yes, the complete scale will be customizable by adding and deleting ranges with "add" and "delete" buttons below the range listview. Code and dialog are currently prepared for this.
Good idea, but i think color gradients could be better done with user defined bitmaps. I will test both before i make a decision.
Reply #155
I've released a new version (0.0.3.1) with two minor fixes:
- when set vertical and horizonal padding to 0 and all bars customized without labels there will be no space between the bars and the border. (link)
- when playback is paused the peak will not fall down (link)
You can get the new version here: foo_uie_peakmeter_003.zip
Reply #156
Do you only see a short max peak on startup or will it stay until you play a song.
Yes, it stays until I press the 'play' button. But, for now I can't reproduce it too.
About peaks behaviour. 'Disappear' option is not what I meant  (but you shouldn't remove it - just change the name, e.g. to 'Disabled').  I want old peaks level to be replaced with a new one after some seconds. It's the same as 'fall down' option but peaks are hiding instead of falling down.
The past  was yesterday...
Reply #157
For a future version it would be cool if it was possible to reverse orientation. I mean right to left, top to bottom meters. Could be used to create a mirror effect.
Reply #158
Yeah that would be cool.
Reply #159
ive just installed foobar, and thought id try this out, i unzipped the file to the foobar directory, now how do i use it? i dont see any menu for it or anything (so far i have installed only columns ui)
Reply #160
You want to make yourself familiar with the basic columns ui layout concept.
Preferences - Display - Columns UI (click) - Layout [tab]
Reply #161
Also, make sure any components that you download (named foo_***.dll or similar) go in the folder called components in the foobar directory, not the directory that contains foobar itself  .
Reply #162
under which sub menu do you guys see your settings for the meter?
Reply #164
foobar2000 will load components in any directory within ".\foobar2000" and probably with any name.
Reply #166
this version is great! lot's of new customization options, thanks a lot!
Reply #167
Ok, thanks. This would be the fourth behaviour option for the peaks  .  I will remember it for a future version.
It's planned with a lot of other features (zoom function, RMS-display, additional analysis-bar ... ) for the next version.
Reply #168
I got it, it just took some exploring through columns ui- thanks guys for the help
Reply #169
edit: nm my question was answered already, I should read before I post.
Reply #170
wow nice plugin!
Reply #171
really nice plugin. i like the option to change the colors, i will make it look lik an allen & heath xone 92
Reply #172
Mmm be interesting to see what the colours and appearance of this is...
Reply #173
Another request:
At the moment, setting colors is quite a work. Not so much that I have to set 12 colors one by one (although setting a color range would be nice), but that every change requires to 1)click on the color 2)click edit 3)click on the "..." button next to the color 4)change the color 5)click "OK" and 6)click "OK" again. It would be much nicer if:
-One click would take you right to the change color screen OR
-There was a hex-box next to every color; hex-colors IMHO are easier than RGB, expecially if you know HTML.
Just my $0.02 on this excellent plugin!
Les mots d'amour...
Reply #174
wow nice plugin!
Thank you! I hope it's possible to integrate this or a similar option in one of the next versions. Maybe the one after next.
Another request:
Thank you! You're right. In the next version right click on the range listview can be used to get directly into the color dialog box.
