Topic: Case config (Read 24755 times) previous topic - next topic
Case config
Case Skin
This is a no title bar skin based on Case VS.
It has the same features that my skin twitter.
The font used are included in the package
See the readme file for infos
Moderation: Removed attachment because it contained a commercial font (Swiss 721 Light Condensed).
Case config
Update 1 : size corrections, modifications after understanding layout and groups
the readme file has been updated too
Case config
looks nice, i'm surprised there are no comments
Case config
All this together (the foo and theme) looks great. Great work mate!
Case config
Hello,
I really like your config but I have some questions :
1- How can I disable because library panel and playlist switcher panel I don't use this panel ?
2- Is there a mean to have a mini player without the top bar that you have when you use the close button of the panel ?
3- How can i switch to single playlist mode because when i use the button there is nothing that happen.?
4- A suggestion is to add a button to close foobar
Thanks by advance for all your answer
bowen
Case config
Hello,
bowen
1- all the configuraiton is done from the layout globals
There you will find the line when you configure the order of the panels. Just put -1 for the ones you dont want
2- no not really because each panel is made to look like a window itself, so it always have the top bar
3- if nothing happens it is that your sort/group are not well configured:
playlist layout selector :
$if($strcmp(%playlistname%,Divers),
$ifgreater($getpvar(SCPSingleart),0,
$scplsetlayout(Singles),
$scplsetlayout(SinglesNoArt)
$if($isgrouped(album),
$scplsetlayout(Album),
Then you must have an "Album" criteria and a "Singles" criteria.
If it still doesnt work could you verify if you have Album, Singles, SinglesNoArt layouts in the SCPL config
EDIT I dont think i understood the 2, could you explain
Case config
Hello,
bowen
1- Thanks it works well
2- Ok but i don't want to hide the top bar of all window but only to keep only the nowplaying panel like on the fourth picture (i don't want to see the other panel)
3- I don't see where i must verify. And when i click on the button to switch the button doesn't change
4- I have no seek bar on the now playing panel and no album art in this panel and the playlist panel
Thanks by advance
bowen
Case config
Thanks by advance
bowen
1 - cool
2- to do so just put all the other panel positions to -1 from the layout globals(if i understood correctly)
3- ok i am not sure you have the last version. to be am gonna send you my conf if you want. It is already on sendspace. http://www.sendspace.com/file/d2vsg1
4- try with the version i sent you. As for the album art in the NP panel and the scpl panel you have to set CoverPath and artistPath in Preferences->PanelsUI->user globals.
I have something like that
$setpvar(coverPath,$replace(%path%,%filename_ext%,folder.jpg))
$setpvar(artistPath,F:\Artists\%artist%.jpg)
be careful the * wont work because i test if the file exists
Case config
2- For the this point isn't there a button to switch to this mode and we are not obliged to go to the layout ?
3- & 4- Seek bar are here but as you can see i have no cover in nowplaying and playlist panel and when i press  the button to switch to single mode playlist nothing happen.
Do you know where it come from?
Case config
2- currently no button for that but i can easily make one. I was already thinking about doing it.
3-4- about the art as i told you you have to set CoverPath and artistPath in Preferences->PanelsUI->Globals but be careful you cant use *. About the button th
ats really strange, could you send me your conf like i sent you.
5- yes it is background in layout globals
For the error while closing i have it too only with case. There is something wrong with WSH Panel but i didnt figure out what.
Now about foo_uie_wmpvis.dll i might now, be careful this plugin need another dll http://acropolis.lokalen.org/wp-content/pl...nload.php?id=20
extract it to either the SYSTEM32 or foobar directory.
Case config
Thanks for your answer.
Here is my config as you want. In the zip file there is some other configuration and files/folders that I use but there is yours too.
Here my config
Two other suggestion :
A button to close foobar and a button to choose what type of order you want (shuffle, repeat, default)
Thanks for your help
Case config
Here my config
OK i ll take a look at it. About your suggestions:
I dont think i ll put a close button because as you can choose each panel you want it would have to be on each panel and i dont like that. Personnaly i use the contextual menu on the systray(actually i never close foobar )
As for the order i ll put it right away. Should have done it sooner
EDIT: trying to find the best way to add the changing order button, i dont really like the idea to add a button especially for that. Case is pure, i dont want my skin to be crouded with buttons. Do you think a button to get to the menu(from where you can easily change the order) would be ok?
Case config
Yes you can make a button to the menu instead of the option button because you can go in option from the menu
For the close button I understand the idea and i am ok
I hope you'll find from where the problem come from because I really like your config and i want to use it
Case config
OK, it s really weird, i just used your cfg file and the button for changing between singles and albums worked correctly. So what i did is make the modifications for the mini mode and the menu button, and then i made a package of my foobar with only what you need for case(it is your cfg in the package). So try by taking the cfg and the ui file for the archive and lets hope it will work. If it doesnt it must be something with your components. Are you sure you have the latest versions?
http://www.sendspace.com/file/5u3lrv
EDIT : tell me if you like the new features. If so i ll upload it on my first post and on customize.org
Case config
It seems that the button to switch the playlist mode doesn't work
But all the new features works well
I d'on't understand I have no cover in the two panel :nowplaying, playlist
Thanks for you help
Case config
Thanks for you help
About the button i dont understand really, this is crazy.
About the arts now, where are your covers, what is there name?
Case config
About the art : my cover are in the same directory as the mp3 file and are name cover. I have the ggod thing in the panel ui option :
$puts(coverPath,$replace(%path%,%filename_ext%,cover.jpg))
$puts(isSingle,$if(%tracknumber%,0,1))
Can you give me the version of your component to check if i have the good one
I think you can delete the preference button because you have the Menu button
bowen
Case config
bowen
Oh i see now try with setpvar instead of puts and it should be fine. You are right about the preferences button
Case config
Sorry but I don't understand : "try with setpvar instead of puts"
Could you explain please
Edit : I understand and it works well thanks
Now that i succeed to solve this problem i look for the playlist mode switcher ...
For your configuration I would like to say that she is amazing and if i have suggestion i give you them
Case config
for the button, try to put that in your SCPL layout selector
Now thanks for you compliment and share any suggestion you have. I would love to improve it
Case config
What do you heard by SCPL layout selector .? the global layout or the scpl layout with group and item display ?
Case config
i mean Preferences->PanelsUI->Sort/Group->SCPL layout selector
Case config
Ok thanks so it seems that it changes nothing
I'll continue to look after the reason
I have a suggestion :
In normal mode the cover doesn't appear in the nowplaying panel but only on the albumart panel and in the mini mode the cover appears in the nowplaying panel
I have a question : is there a way to have different source of cover if one have no cover in
For example : If there is no cover.jpg he look for an other source like a folder
I need this fonctionnality because i have a lot of single in the same folder
Case config
i like your idea about art in minimode. In fact i will force the art in minimode while not in normal mode. Is that ok for you?
for the art with difference sources its possible to do what you want. In fact you can put *.jpg for example in your user globals. The problem is that i there is no art in the directory, the text will still have an xoffset as if there was an image. That s why i test if the file exists and that s why currently it doesnt work with *
So there is 2 possibilties. Either we create a2nd choice art like coverPath2 and i still test if the first one exists, if not i test the 2nd.
Or you use an * in coverPath but if no art you ll have the xoffset.
Tell me what you prefer.
EDIT: about your problem with the button for singles and album, do a right click on the SCPL go to Sort/Group by. Singles must be the third one and Album the fourth one
Case config
For the albumart in mini mode i am ok with your suggestion
For the different path i like the idea of a cover path two if it doesn't exist en coverpath
For the button problem and when i go to sort/group by i have :
-Edit
-Rating/Artist/title
-Artist/title/Rating
-Title/Rating/artist
I don't have single or album even in edit
