Topic: foo_ui_panels (Read 1318684 times) previous topic - next topic
0 Members and 22 Guests are viewing this topic.
foo_ui_panels
Reply #1425
I would like to ask if you could stock up the WINDOWSIZE command?
I would like to see something like:
WINDOWSIZE:x:y:LEFT:TOP:startX:startY
Which would do the same but position the 'fixed' corner at the desired position
example:
WINDOWSIZE:500:500:LEFT:TOP:5:5 would toggle the window to 500x500pixels and position the left top corner 5pixels from the left and 5 from the top (so in the top left screen)
WINDOWSIZE:500:500:RIGHT:TOP:1280:0 would position the window exactly in the right top corner of my screen (which has 1280x1024)
Additionally thanks terrestrial for this great plugin =)
foo_ui_panels
Reply #1426
Is there any way we could call for pvars to be set externally from outside the program?
Just the possibilites for that are endless.
hi
foo_ui_panels
Reply #1427
Thanks for the update, it solved the crashes
foo_ui_panels
Reply #1428
hmmm... are you sure? it seems to work fine here.
-Edited-
Nevermind, my mistake.
foo_ui_panels
Reply #1429
example:
I second that... I would love to see a dock function!
fb2k on OSX: flac q8 > rockboxed Sansa e280v1: Vorbis q5.0
foo_ui_panels
Reply #1430
delete the trackinfo_mod and scpl dlls. I've also uploaded 0.13.3 which should hopefully fix the crashes.
Looks like it's a part of background repeated.
what's your os? maybe you're using a slightly older version.... try updating to 0.13.3
Vista Home Premium, with Aero turned off.
Edit: it works now on version 0.13.3, thanks
foo_ui_panels
Reply #1431
Do you know if it's possible to do the same we could do with ColumnsUI
with the right-click thing on Foobar taskbar icon but with PanelsUI this time ?
I miss it a lot...
Also I can't rewind/ff by clicking on the my foobar playing progress bar, only by pressing right arrow on my keyboard... Kinda sucks :/
foo_ui_panels
Reply #1432
Also make it so you can define the SCPL group header count in px. Doing it in rows is ridiculous and annoying :C
hi
foo_ui_panels
Reply #1433
been messing around with panels_ui and it's very nice
but i have a problem, when i insert a SCPL panel, the group display portion doesn't show (though the item display works fine).
foo_ui_panels
Reply #1434
Have a small issue. For some reason when I switch between playlists using the playlist tree, I 'lose' my grouping for my SCPL. Ordinarily I have it sorted by artists, album (group) and then tracknumber for an album playlist. When I switch to another playlist though and then back to the original playlist for some reason it's sorted by type (group), album (group). I haven't the slightest clue why this happens or how to resolve it. Any help would be much appreciated.
foo_ui_panels
Reply #1435
Hello there,
Sorry if this has been asked before (searched in vain), I'm looking for a way to activate a button command by using the mouse scroll. Haven't found any documentation on this on the wiki page. Is this possible?
Also, I couldn't find a way to assign a shortcut to the "always on top" option in PanelsUI (looks like it overrides the option in foobar's general preferences).
Any clue?
Besides, is it possible to bypass/hide the group header when the track contains a specific tag? What I'm trying to do is displaying albums / single tracks in the same playlist. I'd like to get rid of group headers for single tracks.
Thx.
foo_ui_panels
Reply #1437
already back FofR, you must not have the latest version
foo_ui_panels
Reply #1438
Are you sure that the playlist is being sorted/grouped by album and not as a bunch of singles?  I think that singles are the default setting.  Have you tried right clicking on the playlist and going to settings and checking what the Sort / Group by is?
foo_ui_panels
Reply #1439
That's odd, reinstalled same version and now it works.
EDIT: Do you always have to right click > select add to playlist to send the items?
EDIT2: In Library Filter I'd like to put for instance in Artist, "Angelo Badalamenti" and "Angelo Badalamenti with some orchestra" in the same group.
I've also stripped out all artists from various albums / singles because I hate clicking on a group to see only one item and I've used $upper() to group correctly the terms that have case differences.
foo_ui_panels
Reply #1442
welcome back FofR when you releasing 0.8 of your panels
foo_ui_panels
Reply #1443
Hey Terrestrial,
I am still having problems with foobar crashing AFTER I close the it. It only happens when the Library Filter Panel is initialised in my layout.
Crash log:
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 01FFA146h
Access violation, operation: read, address: 03F89FB8h
Call path:
entry=>user_interface::shutdown
Code bytes (01FFA146h):
01FFA106h:  8B 38 8B F5 89 7C 24 1C 89 74 24 18 85 F6 8B 5D
01FFA116h:  04 74 04 3B F5 74 05 E8 D7 B4 04 00 3B FB 74 44
01FFA126h:  85 F6 75 05 E8 CA B4 04 00 3B 7E 04 75 05 E8 C0
01FFA136h:  B4 04 00 8B 77 28 85 F6 74 17 8B 0E 85 C9 74 08
01FFA146h:  8B 01 8B 10 6A 01 FF D2 56 E8 C4 BF 04 00 83 C4
01FFA156h:  04 8D 74 24 18 E8 60 34 FC FF 8B 7C 24 1C 8B 74
01FFA166h:  24 18 EB A8 8B C5 C7 44 24 2C FF FF FF FF E8 07
01FFA176h:  DB FB FF 8B 4C 24 24 64 89 0D 00 00 00 00 59 5F
Stack (0012F9D4h):
0012F9B4h:  00260688 7C9C93C0 00000312 7C9C93C0
0012F9C4h:  00000004 00260178 00001890 00000000
0012F9D4h:  7BFB614A 020B7594 0267C820 0267C870
0012F9E4h:  020B24F8 02650480 0267C820 026544B0
0012F9F4h:  7C911970 0012FA24 020605C8 00000000
0012FA04h:  01FB5D84 0267C820 7BFB6282 02650480
0012FA14h:  020B24F8 00000001 0012FA38 7C925EAC
0012FA24h:  0012FA44 02063E68 FFFFFFFF 01FCC980
0012FA34h:  7BFB62AA 02650480 020B24F8 0267C870
0012FA44h:  0012FA7C 0205FEA6 00000001 01FCCA93
0012FA54h:  0267C870 7BFB62CE 0267A398 020B24E0
0012FA64h:  00000000 020B5301 0012FA84 020B24F8
0012FA74h:  02650480 4EC76A42 0012FAB8 02060F08
0012FA84h:  00000001 01FBFE86 020B24E0 020BA598
0012FA94h:  020B5368 020B4490 020B5368 020B7330
0012FAA4h:  01FCC980 7BFB623E 020BA598 020B5368
0012FAB4h:  020B4490 0012FAF0 0205FEA6 00000001
0012FAC4h:  01FCCA93 020B4490 7BFB6242 020B6460
0012FAD4h:  020B5350 00000000 00000001 0012FACC
0012FAE4h:  020B5368 020BA598 4EC76A42 0012FB30
Registers:
EAX: 026504B8, EBX: 026504B8, ECX: 03F89FB8, EDX: 01FB5D50
ESI: 026927F8, EDI: 026544B0, EBP: 0267C820, ESP: 0012F9D4
Crash location: "foo_ui_panels", loaded at 01FB0000h - 0209C000h
Loaded modules:
foobar2000                      loaded at 00400000h - 004F3000h
ntdll                            loaded at 7C900000h - 7C9B0000h
kernel32                        loaded at 7C800000h - 7C8F4000h
COMCTL32                        loaded at 773D0000h - 774D3000h
msvcrt                          loaded at 77C10000h - 77C68000h
ADVAPI32                        loaded at 77DD0000h - 77E6B000h
RPCRT4                          loaded at 77E70000h - 77F01000h
GDI32                            loaded at 77F10000h - 77F57000h
USER32                          loaded at 7E410000h - 7E4A0000h
SHLWAPI                          loaded at 77F60000h - 77FD6000h
SHELL32                          loaded at 7C9C0000h - 7D1D5000h
ole32                            loaded at 774E0000h - 7761D000h
shared                          loaded at 10000000h - 10029000h
comdlg32                        loaded at 763B0000h - 763F9000h
IMM32                            loaded at 76390000h - 763AD000h
LPK                              loaded at 629C0000h - 629C9000h
USP10                            loaded at 74D90000h - 74DFB000h
uxtheme                          loaded at 5AD70000h - 5ADA8000h
MSCTF                            loaded at 74720000h - 7476B000h
AM27105                          loaded at 00A60000h - 00A9B000h
ws2_32                          loaded at 71AB0000h - 71AC7000h
WS2HELP                          loaded at 71AA0000h - 71AA8000h
msctfime                        loaded at 755C0000h - 755EE000h
foo_abx                          loaded at 00AE0000h - 00B13000h
foo_albumlist                    loaded at 00B40000h - 00B87000h
OLEAUT32                        loaded at 77120000h - 771AC000h
foo_albumlist_autoupdate        loaded at 00BB0000h - 00BC7000h
foo_audioscrobbler              loaded at 00BF0000h - 00C27000h
foo_autoplaylist                loaded at 00C50000h - 00C80000h
foo_burninate                    loaded at 00CA0000h - 00CD7000h
VERSION                          loaded at 77C00000h - 77C08000h
foo_cdda                        loaded at 00D00000h - 00D35000h
foo_converter                    loaded at 00D60000h - 00DC9000h
foo_cwb_hooks                    loaded at 00DF0000h - 00E25000h
foo_dop                          loaded at 00E50000h - 00EAD000h
SETUPAPI                        loaded at 77920000h - 77A13000h
foo_dsp_bs2b                    loaded at 00ED0000h - 00EEC000h
foo_dsp_crossfader              loaded at 00F10000h - 00F2D000h
libmmd                          loaded at 00F40000h - 011F1000h
MSVCR80                          loaded at 78130000h - 781CB000h
foo_dsp_skip_silence            loaded at 01220000h - 01233000h
foo_dsp_std                      loaded at 01250000h - 01291000h
foo_freedb2                      loaded at 012C0000h - 01300000h
foo_input_std                    loaded at 01320000h - 01433000h
foo_lyricsdb                    loaded at 01460000h - 0148F000h
WININET                          loaded at 42C10000h - 42CDF000h
Normaliz                        loaded at 014A0000h - 014A9000h
iertutil                        loaded at 42990000h - 429D5000h
foo_masstag                      loaded at 016D0000h - 0171F000h
foo_msnalt                      loaded at 01740000h - 01759000h
foo_out_ks                      loaded at 01780000h - 017AA000h
foo_playcount                    loaded at 017D0000h - 017F8000h
foo_playlist_bind                loaded at 01820000h - 01845000h
foo_playlist_tree                loaded at 01860000h - 018D5000h
libmzsch360_000                  loaded at 10400000h - 105D0000h
WSOCK32                          loaded at 71AD0000h - 71AD9000h
libmzgc360_000                  loaded at 01900000h - 019A4000h
foo_rgscan                      loaded at 019F0000h - 01A38000h
foo_run                          loaded at 01A60000h - 01A8B000h
foo_scheduler                    loaded at 01AB0000h - 01B1F000h
POWRPROF                        loaded at 74AD0000h - 74AD8000h
WINMM                            loaded at 76B40000h - 76B6D000h
serwvdrv                        loaded at 5CD70000h - 5CD77000h
umdmxfrm                        loaded at 5B0A0000h - 5B0A7000h
foo_scrobblecharts              loaded at 01BC0000h - 01BF3000h
foo_uie_albumart                loaded at 01C20000h - 01C52000h
gdiplus                          loaded at 4EC50000h - 4EDF3000h
foo_uie_albumlist                loaded at 01C90000h - 01CCD000h
foo_uie_lyrics_panel            loaded at 01CF0000h - 01D58000h
foo_uie_playlists_dropdown      loaded at 01D80000h - 01DBA000h
foo_uie_quicksearch              loaded at 01DE0000h - 01E26000h
foo_uie_tabs                    loaded at 01E50000h - 01E76000h
foo_uie_wmpvis                  loaded at 01EA0000h - 01EDB000h
MSVCP80                          loaded at 7C420000h - 7C4A7000h
foo_ui_columns                  loaded at 01EF0000h - 01F87000h
foo_ui_panels                    loaded at 01FB0000h - 0209C000h
foo_ui_std                      loaded at 020C0000h - 02117000h
foo_unpack                      loaded at 02140000h - 0216E000h
foo_utils                        loaded at 02190000h - 021C8000h
foo_winamp_spam                  loaded at 021F0000h - 02220000h
Msimg32                          loaded at 76380000h - 76385000h
mswsock                          loaded at 71A50000h - 71A8F000h
DNSAPI                          loaded at 76F20000h - 76F47000h
rasadhlp                        loaded at 76FC0000h - 76FC6000h
WINTRUST                        loaded at 76C30000h - 76C5E000h
CRYPT32                          loaded at 77A80000h - 77B14000h
MSASN1                          loaded at 77B20000h - 77B32000h
IMAGEHLP                        loaded at 76C90000h - 76CB8000h
Aqua Dock                        loaded at 04210000h - 0421D000h
YzDock                          loaded at 04230000h - 0423D000h
SHDOCLC                          loaded at 20000000h - 20088000h
DBGHELP                          loaded at 59A60000h - 59B01000h
Stack dump analysis:
Address: 7C911970h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlDeleteCriticalSection" (+000000E6h)
Address: 020605C8h, location: "foo_ui_panels", loaded at 01FB0000h - 0209C000h
Address: 01FB5D84h, location: "foo_ui_panels", loaded at 01FB0000h - 0209C000h
Address: 7C925EACh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlDestroyHeap" (+00000116h)
Address: 02063E68h, location: "foo_ui_panels", loaded at 01FB0000h - 0209C000h
Address: 01FCC980h, location: "foo_ui_panels", loaded at 01FB0000h - 0209C000h
Address: 0205FEA6h, location: "foo_ui_panels", loaded at 01FB0000h - 0209C000h
Address: 01FCCA93h, location: "foo_ui_panels", loaded at 01FB0000h - 0209C000h
Address: 4EC76A42h, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Symbol: "GdiplusShutdown" (+0000004Dh)
Address: 02060F08h, location: "foo_ui_panels", loaded at 01FB0000h - 0209C000h
Address: 01FBFE86h, location: "foo_ui_panels", loaded at 01FB0000h - 0209C000h
Address: 0208B154h, location: "foo_ui_panels", loaded at 01FB0000h - 0209C000h
Address: 0208B15Ch, location: "foo_ui_panels", loaded at 01FB0000h - 0209C000h
Address: 01FCFC9Bh, location: "foo_ui_panels", loaded at 01FB0000h - 0209C000h
Address: 7E41DAEAh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "DestroyWindow" (+00000000h)
Address: 004DED54h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004DF178h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 02063700h, location: "foo_ui_panels", loaded at 01FB0000h - 0209C000h
Address: 00466224h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004A87E6h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00430A0Eh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 013C0640h, location: "foo_input_std", loaded at 01320000h - 01433000h
Address: 004C07D0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004BC438h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C910732h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+0000015Eh)
Address: 00400000h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C70E0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C911538h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "wcsncpy" (+00000AA9h)
Address: 7C90EE18h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "strchr" (+00000117h)
Address: 7C911596h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "wcsncpy" (+00000B07h)
Address: 7C9106EBh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 004E4198h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004B49CCh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C917BF5h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlReAllocateHeap" (+000001F8h)
Address: 1000C021h, location: "shared", loaded at 10000000h - 10029000h
Address: 004E3E68h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C9106F0h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+0000011Ch)
Address: 00491E58h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E4218h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00447AE7h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0043D4DDh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004991DDh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 01000000h, location: "libmmd", loaded at 00F40000h - 011F1000h
Symbol: "_csqrtq_f90" (+000BD6C4h)
Address: 00497110h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C0540h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 10002D87h, location: "shared", loaded at 10000000h - 10029000h
Symbol: "uPrintCrashInfo_SetDumpPath" (+000000A7h)
Address: 004AF4F4h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00430B6Eh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E0928h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004973CAh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004936FCh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004936F6h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004B49E0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004B33D0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E4210h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004AF8E8h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00496284h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C816FD7h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "RegisterWaitForInputIdle" (+00000049h)
Address: 7C839AA8h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "ValidateLocale" (+000002B0h)
Address: 7C816FE0h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "RegisterWaitForInputIdle" (+00000052h)
Address: 004962EDh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E0049h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004F0044h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004B0063h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00410072h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004D002Eh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0044002Eh, location: "foobar2000", loaded at 00400000h - 004F3000h
Version info:
foobar2000 v0.9.4.3
UNICODE
Additional info:
Album List 3.2.0  (foo_albumlist)
Default User Interface 0.9acc  (foo_ui_std)
Album Art Panel 0.175  (foo_uie_albumart)
Masstagger 1.6  (foo_masstag)
Columns UI 0.1.3 beta 1v7  (foo_ui_columns)
cwbowron's title format hooks 1.1.0beta [Dec  1 2006 - 13:47:34]  (foo_cwb_hooks)
CD Audio Decoder 2.1.1  (foo_cdda)
Lyrics panel 0.34.1  (foo_uie_lyrics_panel)
Gapless Crossfader 0.2.6 (Intel SSE)  (foo_dsp_crossfader)
foo_lyricsdb 0.0.7 beta 5  (foo_lyricsdb)
ReplayGain Scanner 2.0.2  (foo_rgscan)
MSN Now Playing (alt) 2.4  (foo_msnalt)
iPod manager 0.3.9 TEST  (foo_dop)
Playlist Bind 3.1  (foo_playlist_bind)
Audio CD Writer 2.0.1  (foo_burninate)
Converter 1.0.1  (foo_converter)
Playlist Tree Panel 3.0.BETA_3 [Apr  3 2007 - 11:39:32]  (foo_playlist_tree)
Autoplaylist Manager 1.0  (foo_autoplaylist)
Last.fm Chart Player 0.2.3  (foo_scrobblecharts)
FLAC Decoder 1.1.0  (foo_input_std)
Standard DSP array 1.0  (foo_dsp_std)
Scheduler 3.53  (foo_scheduler)
freedb Tagger 0.5.2a  (foo_freedb2)
Albumlist autoupdate 0.1  (foo_albumlist_autoupdate)
ZIP/GZIP reader 1.0  (foo_unpack)
Playlists Dropdown 0.5.7.5  (foo_uie_playlists_dropdown)
Kernel Streaming Output 1.2.2  (foo_out_ks)
Skip silence 0.1 (Intel SSE)  (foo_dsp_skip_silence)
Winamp API Emulator 0.96  (foo_winamp_spam)
WMA Decoder 1.1  (foo_input_std)
RAR reader 1.1  (foo_unpack)
Run services 0.3.2  (foo_run)
Album list panel 0.2.1  (foo_uie_albumlist)
Panels UI 0.13.3 beta [May 23 2007 - 02:07:20]  (foo_ui_panels)
bs2b 2.1.0  (foo_dsp_bs2b)
Audioscrobbler 1.3.5  (foo_audioscrobbler)
Playback Statistics 1.3.2  (foo_playcount)
WMP Visualizations 0.1.2 (Intel SSE)  (foo_uie_wmpvis)
ABX Comparator 1.3.1  (foo_abx)
Quick Search Toolbar 2.8k  (foo_uie_quicksearch)
Playlist Tools 0.5.9  (foo_utils)
foobar2000 core 0.9.4.3  (Core)
Tabbed panel modifyed 0.2.1  (foo_uie_tabs)
foo_ui_panels
Reply #1445
What about sub groups?
Just having a day off from work today, I'm snowed under until June 13th, at which point I am done.
Request: Start typing to jump to that letter
Request 2: The ability to border an entire sub group
foo_ui_panels
Reply #1446
Dunno if there is a sub groups one.
foo_ui_panels
Reply #1447
EDIT: Any group/item count options yet?
%_subidx% -> "level" of the node
%_maxidx% -> number of levels
%_itemindex% -> index of the current item
%_itemcount% -> number of items at the same level
%trackcount% -> number of tracks under the selected node
%childcount% -> number of child nodes (will only be valid if the parent node has been expanded once)
Hey Terrestrial,
fixed. download 0.13.4
foo_ui_panels
Reply #1448
oh, i didn't know i had to turn on album grouping. well i got it to work, but it seems i can't create a new preset, i can only edit and delete the ones that came with it.
foo_ui_panels
Reply #1449
I'm not happy with the 0.13, now, screen is flashing when swapping pictures on Tracks Displays ...
and a latency when changing panels that previouly containt a pictures before refresh with a new one (cover)...
fix this bugg please, it render foobar not very nice
Bye
Br3tt
