is there a way to 'turn off' panels that you call up earlier? what i have is 2 buttons. one button brings up the library and another button brings up the track display. what keeps happening is whenever i click a button it just overlays the panel over the old panel without first clearing the space.
$button2(0,0,0,0,16,14,button,button,
PVAR:SET:display:$select($getpvar(display),2),)
PVAR:SET:display2:$select($getpvar(display2),2),)
//Panel One codes
//Panel Two codes
//Panel Three codes
//Panel Four codes
as you can see from the code theres no clearing issue between panel1&2 or panel3&4 since the code will only render one from each set. the problem arises between the sets because the code is rendering one from each set and this is why i am having the overlaying panels issue.
i have tried several dummy variables but my programming skills are obviously too noob to get it to work. any ideas would be appreciated. thanks
ps. dont mind the syntaxing of the spacing on the buttons. they are on distinct locations in the real code
