Topic: [crashware] foo_input_mslive (Read 276568 times) previous topic - next topic
Reply #201
Hi, have a problem
mms://200.59.146.10/rockandpop-ba
Unable to open item for playback (Unsupported file format):
"mms://200.59.146.10/rockandpop-ba"
plays well in WMP 9, thanks in advance
Reply #202
404 http://acropolis.lokalen.org/2006/10/fooba...2000-components
what the hell....
you are the second people reporting this to me...
but I can access the page as normal.....
anybody can confirm this problem? anyone can open it?
Hi, have a problem
shit, it's a bug..., try using the default add location method for now.
Reply #203
what the hell....
Well, I get this
[a href="http://img400.imageshack.us/my.php?image=notfoundoa8.jpg" target="_blank"]
Reply #204
ok, my mistake, now it should be ok.
btw, updated.
Reply #205
Thx. But it doesn't work for me any more. After double clicking of whatever asx files nothing happens. The console gets flooded with "Unable to open item for playback (Unsupported file format)".
Reply #206
sorry, I created another bug while fixing the other bug...
fixed now.
Reply #207
Works fine, thanks!
Reply #209
I just installed the newest version of foo_input_mslive and foo_dsp_reverse and both are giving the error "Failed to load DLL: .....
Reason: This application has failed to start because the application configuration is incorrect. Reinstalling the application may fix this problem."
I have the new dll and my processor is a pentium M, which supports SSE and SSE 2. I also have the newest version of foobar. Any ideas?
Reply #210
I'm having trouble listening to Swedish national radio ("Sveriges Radio"). The link
mms://sr-wm.qbrick.com/02038_SR-P1-High
works fine in WMP11. Foobar result available here. The error message on the left does not occur every time. I have the latest version of foo_input_mslive and fulfil all other reqs.
Any suggestions? Can anyone reproduce or deny?
Reply #211
I think you put the libmmd.dll in a wrong place, must be either foobar root or SYSTEM32 dir.
I think you have some component or you try to edit the tag, it can't be modified.
Reply #213
there are only 3 reasons I can see if you can't load it:
1. no proper vc8 runtime installed (vc8sp1)
2. wrong place of the libmmd.dll
3. your CPU doesn't support SSE
Reply #214
that's strange...I just reinstalled the vc8 runtime and now it works. I guess I had a screwed up dll or something.
Reply #215
Culprit identified. foo_uie_lyrics tried to do something with the tags. After removing it, everything works fine. Thanks for your nice work Acropolis.
Reply #216
 I found a funny bug:
mslive plays back Video streams! Listening to the video is... interesting. Although quite repetitive. (Please don't fix this bug, it's funny.)
Version: 0.3.7
Reply #218
Both work with mslive. Tell more about your problem. What's happening? Which WMP do you have, which streams work etc...
BTW, I just recognized there's a "Paste location". This is excellent, thx!
Reply #219
For acropolis:
Hearing nothing sometimes is bad, sometimes is good. I'd like to give you the short feedback of me, that I am very happy with what you've created here!
Thank you!
Reply #220
I downloaded MSlive from your website.
but I get this error:
Failed to load DLL: foo_input_mslive.dll
I use Foobar2000 v.0.9.4.2
I searched on my computer because I used this plugin before.
I found version 0.3.3 this one let me load the .asx
I can listen to the file for maybe 0.5 sec. and then it shut down with this error:
Unable to resume decoding at 0:00.078 (Unsupported format or corrupted file):
"C:\Documents and Settings\Administrator\Desktop\stream.asx"
WMP do let me play this asx file.
I installed libmmd.dll
Reply #221
What about vc++8 runtimes, as described?
Reply #223
I suspect you have some kinds of components trying to tag the stream, so it can't resume.
Reply #224
you are right.
I removed foo_playback_custom.dll and it works.
is there anything you can do or should I report this at
Some Playcounter mods, For foobar 0.9
http://www.hydrogenaudio.org/forums/index....=55746&st=0
or just let it go because there's nothing to do except remove the plugin?
