Topic: foo_discogs (Read 1387858 times) previous topic - next topic
0 Members and 9 Guests are viewing this topic.
foo_discogs
Reply #275
Great! Thanks for the update!!!
... have a little problem though. It doesn't fetch album art anymore. I set all the option correct i.e. show/fetch the album and it started to show in in its dialog but do not fetch any images. Any other option I missed?
Strange, are you sure you don't have a picture in the release directory ? By default they are named album_art_*.jpg. What happen if you update album art after tagging ? does it work ?
foo_discogs
Reply #276
Yep... I'm absolutely sure. I have checked it with no art / with different prefixes / with overwrite option etc. with no result  Will see if someone else has the same problem.
foo_discogs
Reply #277
Hi, im dying to try this plugin but have a really noob question. After installing the plugin and right clicking on a track to bring up the menu the only menu items enabled in the Discogs menu are "Write tags", "Edit tag mappings" and "Configuration". All the other items are greyed out. I have tried everything I can think of to enable the other menu items but nothing seems to work. Is there something really basic I am missing/misunderstanding? By the way I am using the FofR black reflection config.
thx
foo_discogs
Reply #278
Have you written tags for the item with discogs yet?
It's kinda hard for the plugin to update the tags or album art or view whatever page if you haven't written the %discogs release_id% tag yet to tell it which item in the discogs catalog it's dealing with.
elevatorladylevitateme
foo_discogs
Reply #279
I noticed when updating album and artist art that the overwrite box isn't there anymore :s isn't there a possibility to put it back. I always liked it because when a album was first released there where always low quality covers and after af few months when I looked again I mostly got high quality covers because after a time somebody ups them in high quality. So please put it back
and a little bug: when fetching art and the release id isn't found anymore the fetching of the art stops, it tags files again and stops....
foo_discogs
Reply #280
It's there in the configuration art tab
I'm not sure I understand what you mean, ca you explain more ?
foo_discogs
Reply #281
Oh, yes... I see now what happened. Used it previously and never written discogs ID tag since I don't really need it... but the album art fetching worked without that tag previously, right? What is the reason to write that tag in order to fetch the album art just once? I may be wrong but it is just a bit misleading to see the art in the dialog (i.e. seeing that it actually found the album art) but didn't write it properly with album art fetch option turned on.
Anyways, thanks for explaining and a great component.
Cheers!
foo_discogs
Reply #282
I'm sorry I think it had something to do with my connection, I'm not sure, will see if it happens again...
edit: it happend again, so when I choose update album /artist art in the context menu. It first searches for the art but it then bumps on a release id that isn't correct anymore
(because someone has moved the page or something like that, some releases of mine are not the same as in the beginning I tagged them with your plugin)
then it gives an errorbox where I have to click ok but instead of searching for the rest of the album./ artist art it begins to update tags very quickly and that's everything.
Hope I've made myself a little understandable...
foo_discogs
Reply #283
Well, this isn't primarily an album art fetching component, it's a discogs info fetching component with album art fetching built in.
foo_discogs
Reply #284
fetching art and  catalog numbers with "," and other things works fine!  i have no problems! yet . thank you!
stampgevaar  ... hmm... if page has moved to somewhere so and release_id changed, you can find it again in browser and change "release_id" tag.  then i assume fetching art will work fine.
foo_discogs
Reply #285
UPDATE:
OOPS IM SORRY THAT WAS MY FAULT =) ALL WORKS FINE =)  just i set errorous parameters for my proxy server ))) now i back my proxy config, and foo_discogs work fine... (i made some experimentation with gzip encoding in proxy...)
foo_discogs
Reply #286
After looking at the newer code you're right: before you could fetch art without the release id tag (when tagging a release, not updating art).
I'll correct this in the next version. Good find
Btw it's a good idea to leave the release id always written because a lot of functionality (update art/tag) cannot work without this. This also mean if I add newer tag in the future you'll be able to batch fetch them.
foo_discogs
Reply #287
yes I can do that but that's not happening till there's is a way to see which albums are wrong, cause else I have to update tags, see where it has gone wrong, fix id, redo this, etc etc and that all takes to much time. I don't know if the release id incorrect boxes appear for every release that isn't found but I got the feeling there acting a bit strange but I'm going to try it one of these days to see what it gives.
Ooh it's normal that it can't find albumart where the release id is missing but it entirely stops there it doesn't go furter with the other albums which have a correct release id and are after this album in my playlist.
a printscreen to make myself clearer
http://img455.imageshack.us/my.php?image=naamlooskz4.jpg
It stops updating al the tags when a incorrect release id is found and starts updating the files.
I also have the problem with this artist and release
http://www.discogs.com/release/915439
http://www.discogs.com/artist/Dirk+DJ
, don't ask my why cause I have no idea it just gives the same error as in my example that it can't find the id but if I choose to view release or artist page this is done perfectly
EDIT: I think it has something to do when you have a multiple cd release, the tagger and album/artist art fetching works good with normal 1 cd releases and vinyl so maybe you should take a look at that (always disc 2)
foo_discogs
Reply #288
Brilliant plugin, but the UI might need a little tweaking.
It would be cool if the component could count how many files you have selected to tag and then check the discogs pages for albums that have the same number of tracks, just to narrow it down a bit.
This would'nt work if you want to tag an incomplete release (ie you don't have all the files), and you can already double click on a release to launch the www release page to do a quick check.
It's indeed a problem that you can't compare different releases. Why don't you imitate the freedb tagger interface? If you search artist+album it should not parse that many pages (especially not if you filter by CD's and albums only). This feature could eventually be deactivated, for some with slow internet connections (are people really still using modems anywhere?)
Also is it possible to retrieve additional track information, like remixer, producer and featuring artists? Also it would be nice, if it was able to retrieve multiple pages at a time, to compare the details (some releases fills more data then others).
foo_discogs
Reply #289
Now I'm updating tags and artist and album art and I have noticed al works perfectly except for multi disc releases, It's always cd 2 that gives an error so please fix this. thanks
foo_discogs
Reply #290
I'm not going to change the UI much at this point for the 5% of cases where it could be better. And I hate win32 UI programming foobar style with the 15 years old win32 common controls API! As for additional info I've thought doing it but by parsing html pages it's hard to get it right everytime. Discogs has some guidelines but there's a lot of corner cases. Now when I release the source if someone want to do it then great !
Maybe one day discogs will implement a proper Web service API to do that kind of stuff without having to parse ugly generated html. They've planned it but I wouldn't count on it anytime soon...
I guess you have disable the "Original Discog Track" tag aka DISCOG_ORIGINAL_TRACK, introduced by 0.98.
Without this tag, no tag update is performed for discs >= 2 for track specific tags (which tags were you updating?). That is because I have no way to link the local track to the remote track without this tag
foo_discogs
Reply #291
v0.99 out! <- scary number!
see first post for link
v 0.99
- add: "find deleted release ids" will scan all selected item and see if %DISCOG_RELEASE_ID% has been
deleted in discogs.com database. Those items are put in a new playlist.
- chg: when updating tags /art the only possible error now aborting the operation is if the connection
to discogs.com is lost. Other errors (deleted release id, bad url) will just cancel processing
for the current item and proceed to the next. Most of those errors are now logged in the foobar console.
If operation is stopped because of a connexion error, retrieved tag up to this point will be still written.
Also the abort button will stop the operation but still write all tags up to this point.
- chg: now it's possible again to retrieve art when tagging,  without having the release id tag enabled for writing
-chg: removed moving discogs track by draging the item as it messed quick selection (shift+click) usefull to remove items for multi-cd releases
- chg: clear cached data (releases, artists, ...) when the cache contains 50 releases.
- fix: crash if updating tags for tags write-enabled and DISCOGS_ORIGINAL_TRACK_NUMBER was write-enabled
Note: if artist art is checked or artist releated tag are enabled (anvs list, members, aliases, artist id) it can take bloody forever to retrieve all this info for a compilation and an eternity for a multi-cd compilation. Best is to batch update it later. For multi-cd this will be much quicker for discs >= 2
foo_discogs
Reply #292
But how about this?:
foo_discogs
Reply #294
I don't have it disabled but  problem is I already tagged my whole collection and updating tags doesn't work with "original discogs track" cause it's disabled. is there a way somehow to update those tracknumbers cause I'm not spending another week to completely retag all my double cds so they have the correct DISCOGS_ORIGINAL_TRACK...
But it doesn't matter that much but I think that's the problem
foo_discogs
Reply #295
Release 778632 gives a foobar crash. I had the ID tagged before but the release got rejected at discogs in the meantime. It is also not recognized as deleted release.
Pretty rare case i guess, but it just happened to me...
http://www.discogs.com/release/778632
Thanks again for this plug-in.
foo_discogs
Reply #296
I got a crash when updating a large amount of tags
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 00CD2AEAh
Access violation, operation: read, address: 00000030h
Call path:
threaded_process thread
Code bytes (00CD2AEAh):
00CD2AAAh:  34 0F 00 00 00 89 5E 30 88 5E 20 83 7E 18 10 72
00CD2ABAh:  0C 8B 4E 04 51 E8 31 F3 03 00 83 C4 04 89 5E 14
00CD2ACAh:  C7 46 18 0F 00 00 00 88 5E 04 5E 5B C3 CC CC CC
00CD2ADAh:  CC CC CC CC CC CC 53 8B 5C 24 08 55 8B 6C 24 10
00CD2AEAh:  39 6B 14 56 57 8B F1 73 05 E8 0F EC 03 00 8B 7B
00CD2AFAh:  14 8B 44 24 1C 2B FD 3B C7 73 02 8B F8 3B F3 75
00CD2B0Ah:  1F 6A FF 03 FD 57 8B CE E8 F9 03 00 00 55 6A 00
00CD2B1Ah:  8B CE E8 EF 03 00 00 5F 8B C6 5E 5D 5B C2 0C 00
Stack (0B4EF840h):
0B4EF820h:  0012F498 7E3A37BC 00000000 0000000C
0B4EF830h:  00000000 08B123B0 00000000 0012F4C4
0B4EF840h:  0B4EF8A4 0B4EF97C 00CE2792 0000001C
0B4EF850h:  00000000 FFFFFFFF F7EDC97F 00000000
0B4EF860h:  0B4EF97C 0B4EF97C 0B4EF87C F7EDC9AB
0B4EF870h:  0B4EF97C 14D75380 00CF6400 00000000
0B4EF880h:  00000000 00000000 00000000 0000000F
0B4EF890h:  F7EDC97F 0B4EF858 0B4EF920 00D28EA8
0B4EF8A0h:  FFFFFFFF 00000000 00CE1EE5 0000001C
0B4EF8B0h:  0B4EF97C 00000000 00000000 0B4EF97C
0B4EF8C0h:  0B4EF8F0 00000000 0B4EF8E8 00CE160E
0B4EF8D0h:  0B4EF8E8 0000001C 0B4EF97C 00000000
0B4EF8E0h:  00000068 00000000 00438A0A 004E2ABC
0B4EF8F0h:  0F2203A8 00CDE639 0000001C F7EDC8DB
0B4EF900h:  0F220370 0000001D 0F28C5E4 0F28C608
0B4EF910h:  0B4EFA34 00000000 00000001 00000000
0B4EF920h:  0B4EFA54 00D29589 00000000 00CDEE5D
0B4EF930h:  0B4EF97C 0F2203A8 00000000 F7EDC89B
0B4EF940h:  021E2968 0000001D 00D40018 00D4048F
0B4EF950h:  00462070 00000000 00000000 00000000
Registers:
EAX: 0000001C, EBX: 0000001C, ECX: 0B4EF874, EDX: 00000001
ESI: 00000000, EDI: 00000000, EBP: 00000000, ESP: 0B4EF840
Crash location: "foo_discogs", loaded at 00CD0000h - 00D4C000h
Loaded modules:
foobar2000                      loaded at 00400000h - 004F3000h
ntdll                            loaded at 7C900000h - 7C9B6000h
kernel32                        loaded at 7C800000h - 7C8FE000h
COMCTL32                        loaded at 77390000h - 77493000h
msvcrt                          loaded at 77BE0000h - 77C38000h
ADVAPI32                        loaded at 77F40000h - 77FEB000h
RPCRT4                          loaded at 77DA0000h - 77E31000h
GDI32                            loaded at 77E40000h - 77E87000h
USER32                          loaded at 7E390000h - 7E420000h
SHLWAPI                          loaded at 77E90000h - 77F06000h
SHELL32                          loaded at 7C9C0000h - 7D1E0000h
ole32                            loaded at 774A0000h - 775DD000h
shared                          loaded at 10000000h - 10029000h
comdlg32                        loaded at 76350000h - 7639A000h
IMM32                            loaded at 76330000h - 7634D000h
uxtheme                          loaded at 5B190000h - 5B1C8000h
msctfime                        loaded at 75250000h - 7527E000h
foo_abx                          loaded at 00A30000h - 00A64000h
foo_albumlist                    loaded at 00A70000h - 00AB7000h
OLEAUT32                        loaded at 770E0000h - 7716C000h
foo_cdda                        loaded at 00AD0000h - 00B06000h
foo_converter                    loaded at 00B30000h - 00B99000h
foo_custominfo                  loaded at 00BC0000h - 00C45000h
foo_cwb_hooks                    loaded at 00C70000h - 00CA5000h
foo_discogs                      loaded at 00CD0000h - 00D4C000h
gdiplus                          loaded at 4EB80000h - 4ED23000h
WS2_32                          loaded at 71A30000h - 71A47000h
WS2HELP                          loaded at 71A20000h - 71A28000h
WINMM                            loaded at 76AF0000h - 76B1E000h
foo_dsp_std                      loaded at 00DF0000h - 00E31000h
foo_input_std                    loaded at 00E60000h - 00F74000h
foo_masstag                      loaded at 00FA0000h - 00FF0000h
foo_masstag_addons              loaded at 01010000h - 0101E000h
MSVCR80                          loaded at 78130000h - 781CB000h
foo_menu_addons                  loaded at 01040000h - 01065000h
foo_msnalt                      loaded at 01080000h - 01099000h
foo_playcount                    loaded at 010C0000h - 010E8000h
foo_playlist_tree                loaded at 01110000h - 01182000h
libmzsch360_000                  loaded at 10400000h - 105D0000h
WSOCK32                          loaded at 71A50000h - 71A5A000h
libmzgc360_000                  loaded at 011B0000h - 01254000h
foo_rgscan                      loaded at 012A0000h - 012E8000h
foo_run                          loaded at 01310000h - 0133B000h
foo_uie_console                  loaded at 01360000h - 0137B000h
foo_uie_quicksearch              loaded at 013A0000h - 013E6000h
foo_ui_columns                  loaded at 01410000h - 014A7000h
foo_ui_panels                    loaded at 014D0000h - 015A3000h
foo_ui_std                      loaded at 015D0000h - 01627000h
foo_unpack                      loaded at 01650000h - 0167E000h
foo_utils                        loaded at 016A0000h - 016D9000h
foo_whatsnew                    loaded at 01700000h - 01730000h
Msimg32                          loaded at 76320000h - 76325000h
DSOUND                          loaded at 73E80000h - 73EDC000h
VERSION                          loaded at 77BD0000h - 77BD8000h
WINTRUST                        loaded at 76BF0000h - 76C1E000h
CRYPT32                          loaded at 77A40000h - 77AD5000h
MSASN1                          loaded at 77AE0000h - 77AF2000h
IMAGEHLP                        loaded at 76C50000h - 76C78000h
wdmaud                          loaded at 72C90000h - 72C99000h
msacm32                          loaded at 72C80000h - 72C88000h
MSACM32                          loaded at 77BB0000h - 77BC5000h
midimap                          loaded at 77BA0000h - 77BA7000h
KsUser                          loaded at 73E50000h - 73E54000h
netapi32                        loaded at 6FF20000h - 6FF74000h
SETUPAPI                        loaded at 778E0000h - 779D7000h
appHelp                          loaded at 77B00000h - 77B22000h
CLBCATQ                          loaded at 76F90000h - 7700F000h
COMRes                          loaded at 77010000h - 770DD000h
cscui                            loaded at 779E0000h - 77A36000h
CSCDLL                          loaded at 765A0000h - 765BD000h
mlang                            loaded at 75D40000h - 75DD1000h
mswsock                          loaded at 719D0000h - 71A10000h
DNSAPI                          loaded at 76EE0000h - 76F07000h
hnetcfg                          loaded at 61200000h - 61259000h
wshtcpip                        loaded at 71A10000h - 71A18000h
winrnr                          loaded at 76F70000h - 76F78000h
WLDAP32                          loaded at 76F20000h - 76F4D000h
rasadhlp                        loaded at 76F80000h - 76F86000h
ieframe                          loaded at 105D0000h - 10B9A000h
PSAPI                            loaded at 76BB0000h - 76BBB000h
iertutil                        loaded at 6E850000h - 6E895000h
urlmon                          loaded at 61410000h - 61534000h
Secur32                          loaded at 77F10000h - 77F21000h
xpsp2res                        loaded at 20000000h - 202D5000h
DBGHELP                          loaded at 59E70000h - 59F11000h
Stack dump analysis:
Address: 00CE2792h, location: "foo_discogs", loaded at 00CD0000h - 00D4C000h
Address: 00CF6400h, location: "foo_discogs", loaded at 00CD0000h - 00D4C000h
Symbol: "foobar2000_get_interface" (+00001BC0h)
Address: 00D28EA8h, location: "foo_discogs", loaded at 00CD0000h - 00D4C000h
Address: 00CE1EE5h, location: "foo_discogs", loaded at 00CD0000h - 00D4C000h
Address: 00CE160Eh, location: "foo_discogs", loaded at 00CD0000h - 00D4C000h
Address: 00438A0Ah, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E2ABCh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00CDE639h, location: "foo_discogs", loaded at 00CD0000h - 00D4C000h
Address: 00D29589h, location: "foo_discogs", loaded at 00CD0000h - 00D4C000h
Address: 00CDEE5Dh, location: "foo_discogs", loaded at 00CD0000h - 00D4C000h
Address: 00D40018h, location: "foo_discogs", loaded at 00CD0000h - 00D4C000h
Address: 00D4048Fh, location: "foo_discogs", loaded at 00CD0000h - 00D4C000h
Address: 00462070h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C47F4h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00D11E42h, location: "foo_discogs", loaded at 00CD0000h - 00D4C000h
Address: 00CD2EE6h, location: "foo_discogs", loaded at 00CD0000h - 00D4C000h
Address: 00D14598h, location: "foo_discogs", loaded at 00CD0000h - 00D4C000h
Address: 00D3CDD0h, location: "foo_discogs", loaded at 00CD0000h - 00D4C000h
Address: 00D3C8A0h, location: "foo_discogs", loaded at 00CD0000h - 00D4C000h
Address: 00D147D4h, location: "foo_discogs", loaded at 00CD0000h - 00D4C000h
Address: 00D3CEB0h, location: "foo_discogs", loaded at 00CD0000h - 00D4C000h
Address: 00D2990Ah, location: "foo_discogs", loaded at 00CD0000h - 00D4C000h
Address: 00CDE166h, location: "foo_discogs", loaded at 00CD0000h - 00D4C000h
Address: 00D29948h, location: "foo_discogs", loaded at 00CD0000h - 00D4C000h
Address: 00CE0F67h, location: "foo_discogs", loaded at 00CD0000h - 00D4C000h
Address: 00D31AF0h, location: "foo_discogs", loaded at 00CD0000h - 00D4C000h
Address: 7C919AF0h, location: "ntdll", loaded at 7C900000h - 7C9B6000h
Symbol: "towlower" (+00000384h)
Address: 7C800000h, location: "kernel32", loaded at 7C800000h - 7C8FE000h
Address: 6120676Eh, location: "hnetcfg", loaded at 61200000h - 61259000h
Address: 61410000h, location: "urlmon", loaded at 61410000h - 61534000h
Symbol: "Ordinal230" (+00000000h)
Address: 61411AA6h, location: "urlmon", loaded at 61410000h - 61534000h
Symbol: "Ordinal230" (+00001AA6h)
Address: 76F21341h, location: "WLDAP32", loaded at 76F20000h - 76F4D000h
Symbol: "Ordinal325" (+00001341h)
Address: 76F411B0h, location: "WLDAP32", loaded at 76F20000h - 76F4D000h
Address: 76F211CEh, location: "WLDAP32", loaded at 76F20000h - 76F4D000h
Symbol: "Ordinal325" (+000011CEh)
Address: 614A3FDFh, location: "urlmon", loaded at 61410000h - 61534000h
Address: 7C9011A7h, location: "ntdll", loaded at 7C900000h - 7C9B6000h
Symbol: "LdrInitializeThunk" (+00000029h)
Address: 7C918E94h, location: "ntdll", loaded at 7C900000h - 7C9B6000h
Symbol: "CsrNewThread" (+0000001Ah)
Address: 7C918F87h, location: "ntdll", loaded at 7C900000h - 7C9B6000h
Symbol: "CsrNewThread" (+0000010Dh)
Address: 7C90EE18h, location: "ntdll", loaded at 7C900000h - 7C9B6000h
Symbol: "strchr" (+00000117h)
Address: 7C918ED0h, location: "ntdll", loaded at 7C900000h - 7C9B6000h
Symbol: "CsrNewThread" (+00000056h)
Address: 7C918E74h, location: "ntdll", loaded at 7C900000h - 7C9B6000h
Symbol: "RtlUnicodeStringToInteger" (+00000213h)
Address: 7C90E8C4h, location: "ntdll", loaded at 7C900000h - 7C9B6000h
Symbol: "ZwTestAlert" (+0000000Ch)
Address: 7C918DFAh, location: "ntdll", loaded at 7C900000h - 7C9B6000h
Symbol: "RtlUnicodeStringToInteger" (+00000199h)
Address: 7E39BB74h, location: "USER32", loaded at 7E390000h - 7E420000h
Symbol: "MapWindowPoints" (+00000045h)
Address: 7C918E00h, location: "ntdll", loaded at 7C900000h - 7C9B6000h
Symbol: "RtlUnicodeStringToInteger" (+0000019Fh)
Address: 7C90D625h, location: "ntdll", loaded at 7C900000h - 7C9B6000h
Symbol: "ZwContinue" (+0000000Ch)
Address: 7C90EACFh, location: "ntdll", loaded at 7C900000h - 7C9B6000h
Symbol: "KiUserApcDispatcher" (+0000000Fh)
Address: 0045D3EFh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C810659h, location: "kernel32", loaded at 7C800000h - 7C8FE000h
Symbol: "CreateThread" (+00000022h)
Address: 00D29E7Ch, location: "foo_discogs", loaded at 00CD0000h - 00D4C000h
Address: 0045D460h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C42A8h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 10002D87h, location: "shared", loaded at 10000000h - 10029000h
Symbol: "uPrintCrashInfo_SetDumpPath" (+000000A7h)
Address: 004A86ACh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0045D414h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004A6459h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C80B683h, location: "kernel32", loaded at 7C800000h - 7C8FE000h
Symbol: "GetModuleFileNameA" (+000001B4h)
Address: 7C839AA8h, location: "kernel32", loaded at 7C800000h - 7C8FE000h
Symbol: "ValidateLocale" (+000002B0h)
Address: 7C80B690h, location: "kernel32", loaded at 7C800000h - 7C8FE000h
Symbol: "GetModuleFileNameA" (+000001C1h)
Version info:
foobar2000 v0.9.4.2
UNICODE
Additional info:
Quick Search Toolbar 2.8k  (foo_uie_quicksearch)
Playback Statistics 1.3.2  (foo_playcount)
ABX Comparator 1.3.1  (foo_abx)
Playlist tools 0.5.7  (foo_utils)
Feature Watcher 1.0.2  (foo_whatsnew)
ZIP/GZIP reader 1.0  (foo_unpack)
Playlist Tree Panel 3.0.BETA_2 [Mar 23 2007 - 16:44:16]  (foo_playlist_tree)
Masstagger Addons 0.3.3  (foo_masstag_addons)
Columns UI 0.1.3 beta 1v7  (foo_ui_columns)
FLAC Decoder 1.1.0  (foo_input_std)
Discogs Tagger 0.99  (foo_discogs)
Converter 1.0.1  (foo_converter)
Masstagger 1.6  (foo_masstag)
Default User Interface 0.9acc  (foo_ui_std)
Album List 3.2.0  (foo_albumlist)
RAR reader 1.1  (foo_unpack)
Run services 0.3.2  (foo_run)
cwbowron's title format hooks 1.1.0beta [Dec  1 2006 - 13:47:34]  (foo_cwb_hooks)
foo_custominfo 0.1.2  (foo_custominfo)
Console panel 0.2.1  (foo_uie_console)
foobar2000 core 0.9.4.2  (Core)
WMA Decoder 1.1  (foo_input_std)
MSN Now Playing (alt) 2.4  (foo_msnalt)
CD Audio Decoder 2.1.1  (foo_cdda)
ReplayGain Scanner 2.0.2  (foo_rgscan)
Standard DSP array 1.0  (foo_dsp_std)
Panels UI 0.9.1 beta [Mar 27 2007 - 23:07:16]  (foo_ui_panels)
Menu Addons 0.3.9  (foo_menu_addons)
and other one (same reason)
Illegal operation:
Call path:
Stack (06F1F840h):
06F1F820h:  0012F498 7E3A37BC 00000000 0000000C
06F1F830h:  00000000 003A3F58 00000000 0012F4C4
06F1F840h:  06F1F8A4 06F1F97C 00CE2792 0000001C
06F1F850h:  00000000 FFFFFFFF CCB9C8BD 00000000
06F1F860h:  06F1F97C 06F1F97C 06F1F87C CCB9C869
06F1F870h:  06F1F97C 0CCA5380 00CF6400 00000000
06F1F880h:  00000000 00000000 00000000 0000000F
06F1F890h:  CCB9C8BD 06F1F858 06F1F920 00D28EA8
06F1F8A0h:  FFFFFFFF 00000000 00CE1EE5 0000001C
06F1F8B0h:  06F1F97C 00000000 00000000 06F1F97C
06F1F8C0h:  06F1F8F0 00000000 06F1F8E8 00CE160E
06F1F8D0h:  06F1F8E8 0000001C 06F1F97C 00000000
06F1F8E0h:  00000068 00000000 00438A0A 004E2ABC
06F1F8F0h:  10C52860 00CDE639 0000001C CCB9C919
06F1F900h:  10C52828 0000001D 11268A8C 11268AB0
06F1F910h:  06F1FA34 00000000 00000001 00000000
06F1F920h:  06F1FA54 00D29589 00000000 00CDEE5D
06F1F930h:  06F1F97C 10C52860 00000000 CCB9C959
06F1F940h:  022F61E8 0000001D 00D40018 00D4048F
06F1F950h:  00462070 00000000 00000000 00000000
Registers:
EAX: 0000001C, EBX: 0000001C, ECX: 06F1F874, EDX: 00000001
ESI: 00000000, EDI: 00000000, EBP: 00000000, ESP: 06F1F840
Loaded modules:
Address: 7C919BA0h, location: "ntdll", loaded at 7C900000h - 7C9B6000h
Symbol: "LdrGetProcedureAddress" (+00000018h)
Address: 7C9106EBh, location: "ntdll", loaded at 7C900000h - 7C9B6000h
Address: 76F21382h, location: "WLDAP32", loaded at 76F20000h - 76F4D000h
Symbol: "Ordinal325" (+00001382h)
Address: 76F21178h, location: "WLDAP32", loaded at 76F20000h - 76F4D000h
Symbol: "Ordinal325" (+00001178h)
Address: 76F20000h, location: "WLDAP32", loaded at 76F20000h - 76F4D000h
Symbol: "Ordinal325" (+00000000h)
Address: 76F21130h, location: "WLDAP32", loaded at 76F20000h - 76F4D000h
Symbol: "Ordinal325" (+00001130h)
Version info:
foobar2000 v0.9.4.2
UNICODE
Additional info:
foo_discogs
Reply #297
Wow, another update. Works flawlessly here.
The only thing i'm missing is a back button from the 'release' to 'find release' dialog.
foo_discogs
Reply #298
I agree; a back button would be great.
foo_discogs
Reply #299
Awesome plugin, although I'm having a problem where it adds in the tracks in a seemingly random order, and there's no quick way to sort them by the existing track number or filename (as would be logical).
Guinness for strength!
