Topic: Notepad++ Languange file (Read 3047 times) previous topic - next topic
does any one have a language file for the foobar tagz that they are willing to share?
This is my UserDefineLang.xml
Hope it works for you.
<NotepadPlus>
<UserLang name="foobar2000" ext="foo TAGZ fcs">
<Settings>
<Global caseIgnored="yes" />
<TreatAsSymbol comment="no" commentLine="yes" />
<Prefix words1="no" words2="no" words3="no" words4="no" />
</Settings>
<KeywordLists>
<Keywords name="Delimiters">'00'00</Keywords>
<Keywords name="Folder+">BlockBegin</Keywords>
<Keywords name="Folder-">BlockEnd</Keywords>
<Keywords name="Operators">' ( ) , [ ] | =</Keywords>
<Keywords name="Comment">1 1 2 2 0//</Keywords>
<Keywords name="Words1">%album artist% %album% %date% %artist% %title% %tracknumber% %genre% %subgenre%  %performer% %instrument% %composer% %conductor% %orchestra% %publisher% %work% %cat#% %tempo% %situation% %rating% %emyfav% %bpm% %check sm% %score% %check ly% %lyrics%  %check tad% %check q% %check gs% %check pi% %check lc% %added% %downloaded% %length% %cwb_systemdate% </Keywords>
<Keywords name="Words2">%isplaying% %_ispaused% %_composer% %_comment% %__channels% %_date% %_directoryname% %disc% %_diskwriter_index% %_foobar2000_version% %_filename% %_filename_ext% %_genre% %_isplaying% %ispaused% %_length% %_length_seconds% %_path% %_path_raw% %_playlist_number% %_subsong% %__bitrate% %__extrainfo% %__replaygain_album_gain% %__replaygain_album_peak% %__replaygain_track_gain% %__replaygain_track_peak% %__samplerate% %playback_time% %length% %length_seconds% %_time_elapsed% %_time_elapsed_seconds% %_time_remaining% %_time_remaining_seconds% %play_count% %codec% %codec_profile% %filename% %filename_ext% %directoryname% %path% %subsong% %path_sort% %length_seconds% %filesize% %bitrate% %channels% %samplerate% %__mp3_stereo_mode% %added% %_system_year% %_system_month% %_system_day% %_system_hour% %last_played% %_selected_back% %_back% %_selected_back_no_focus% %_selected_text% %_time_total% %_time_total_seconds%</Keywords>
<Keywords name="Words3">$if $if2 $if3 $ifequal $ifgreater $iflonger $select $repeat</Keywords>
<Keywords name="Words4">$put $puts $get $abbr $lower $upper $num $caps $caps2 $len $pad $pad_right $cut $padcut $padcut_right $insert $add $sub $mul $div $muldiv $mod $min $max $left $right $and $or $xor $not $fix_eol $fix_eol2 $meta $meta_sep $mets_num $mets_test $info $char $strcmp $stricmp $directory $greater $longer $strchr $strrchr $strstr $progress $progress2 $replace $ext $substr $rgb $transition $blend $rand $trim $tab $crlf $longest $shortest $set_style $calculate_blend_target $offset_colour</Keywords>
</KeywordLists>
<Styles>
<WordsStyle name="DEFAULT" styleID="11" fgColor="000000" bgColor="FFFFFF" fontName="Courier New" fontStyle="0" fontSize="10" />
<WordsStyle name="FOLDEROPEN" styleID="12" fgColor="FF8000" bgColor="FFFF80" fontName="" fontStyle="0" />
<WordsStyle name="FOLDERCLOSE" styleID="13" fgColor="FF8040" bgColor="FFFF80" fontName="" fontStyle="0" />
<WordsStyle name="KEYWORD1" styleID="5" fgColor="0000FF" bgColor="FFFFFF" fontName="Arial" fontStyle="0" fontSize="10" />
<WordsStyle name="KEYWORD2" styleID="6" fgColor="4646FF" bgColor="FFFFFF" fontName="Arial" fontStyle="0" fontSize="10" />
<WordsStyle name="KEYWORD3" styleID="7" fgColor="FF0000" bgColor="FFFFFF" fontName="Courier New" fontStyle="0" fontSize="11" />
<WordsStyle name="KEYWORD4" styleID="8" fgColor="FF4646" bgColor="FFFFFF" fontName="Courier New" fontStyle="0" fontSize="11" />
<WordsStyle name="COMMENT" styleID="1" fgColor="FFFF00" bgColor="FFFFFF" fontName="" fontStyle="0" />
<WordsStyle name="COMMENT LINE" styleID="2" fgColor="008000" bgColor="FFFFFF" fontName="Arial" fontStyle="2" fontSize="10" />
<WordsStyle name="NUMBER" styleID="4" fgColor="FF0080" bgColor="FFFFFF" fontName="Arial" fontStyle="0" fontSize="10" />
<WordsStyle name="OPERATOR" styleID="10" fgColor="000000" bgColor="FFFFFF" fontName="Courier New" fontStyle="0" />
<WordsStyle name="DELIMINER1" styleID="14" fgColor="A25151" bgColor="FFFFFF" fontName="Arial" fontStyle="0" />
<WordsStyle name="DELIMINER2" styleID="15" fgColor="FFFFFF" bgColor="FFFFFF" fontName="" fontStyle="0" />
</Styles>
</UserLang>
</NotepadPlus>
[!--sizeo:1--][span style=\"font-size:8pt;line-height:100%\"][!--/sizeo--]Moderation: added codebox.[/size]
thanks. seems to work for most things.
