Topic: foo_ui_panels (Read 1317986 times) previous topic - next topic
0 Members and 23 Guests are viewing this topic.
foo_ui_panels
Reply #250
Don't know if it has been reported already, or if I'm doing something wrong...
Seems like $buttons breaks the transparency of the png images I'm using, using the same images in a button panel or $imageabs/$imageabs2 works.
$button(0,$sub(%_height%,30),0,0,0,0,/images\Delta Futtons\Prev.png,/images\Delta Futtons\PrevHot.png,Previous,)
Picture showing the non-transparent buttons (and the current config I'm working on )
foo_ui_panels
Reply #251
i have a question, how can I do command in $button() to assign "a selected track".
My english is bad so that i cant describe it clearly.
Hmm for example i use 'Add to Playback Queue', then it just add "the playing track" into the queue,
but i want it add "the selected one " into queue, how should i do for this ?
Thanks alot .
foo_ui_panels
Reply #252
After replace PanelUI 0.6.1 beta, this sorting button does not work.
$puts(offsetX,$add($get(offsetX),$get(w),10))
$puts(w,$calcwidth($font(tahoma,8,,200-200-200)$put(str,$if(%sortstring%,ST:%sortstring%,Sort))))
$button2($get(offsetX),$get(offsetY),0,0,$get(w),$get(h),'$font(tahoma,8,,110-110-110)$if(%sortstring%,$rgb(250,250,250))'$get(str),'$font(tahoma,8,,200-250-63)'$get(str)
,'Sort:rating|%rating%:genre|%genre%:date|%date%:artist|%artist%:album|%album%',)
does the button not show up, or the menu doesn't work? if its the menu, change Sort->SORT. if its the button, then check your width/height.
I tried the old 0.45beta,0.50beta and now 0.61beta
All of them did crash when i hit "setting".
What is strange is that "sometimes" it wont crash...though i didnt change anything.
is there a reproducible sequence that always crashes?
Umm, no. That's not it.
Adding $drawrect(0,0,%_width%,%_height%,brushcolor-SYSCOL-15 pencolor-NULL) to the ui config doesn't change that color. See here.
album list seems to do the same thing in columns ui so I think thats album list behavior... it seems to be drawing an extra one pixel border in the window frame (?) color upon startup...
when I put a panel above my spectrum analyser the analyser is still visable, and my buttons keep appearing and dissapearing when I put them above a trackinfo panel. I choose to hide them with pvars maybe that has something to do with it...
overlaying panels is dependent on which ones you're overlaying. some will work, some won't
I tried
$button(0,$sub(%_height%,25),0,0,0,0,$get(browse),$get(browse2),'PVAR:SET:Tree:$ifequal($getpvar(Tree),0,1,0)',)
and this does not work, like you said it should work?
remove the single quotes around PVAR:SET
add "nobkgnd" as an option to the button when drawing on glass:
[code]$button(0,$sub(%_height%,30),0,0,0,0,/images\Delta Futtons\Prev.png,/images\Delta Futtons\PrevHot.png,Previous,nobkgnd)
you can't currently. it will be in a future version.
foo_ui_panels
Reply #253
Thank you .
I think you mean this
I start foobar2k -> do nothing -> hit right click and then choose setting -> crash
It always happened through these actions.
sry again about my bad english
here is my error code just happened 3 mins ago:
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 7C967C37h
Access violation, operation: read, address: 00188000h
Call path:
entry=>app_mainloop
Code bytes (7C967C37h):
7C967BF7h:  CC CC CC CC CC 85 C0 74 25 8B 4D 0C 56 0F B6 31
7C967C07h:  48 41 66 83 3C 75 60 D0 99 7C 00 74 06 85 C0 74
7C967C17h:  0A 48 41 42 42 85 C0 75 E4 EB 02 42 42 5E 8B 45
7C967C27h:  08 89 10 E9 82 1B FE FF 85 C0 74 1D 8B 55 0C 57
7C967C37h:  0F B7 0A 8B 3D 60 E2 99 7C 66 8B 0C 4F 42 42 46
7C967C47h:  84 ED 74 01 46 48 75 E8 5F 8B 45 08 89 30 E9 97
7C967C57h:  BA FC FF 8B 7D 0C 8B 7F 04 66 8B 3C 4F 66 3B 3D
7C967C67h:  74 E4 99 7C 0F 84 28 52 FE FF C6 45 FF 00 E9 24
Stack (0012CD48h):
0012CD28h:  00000000 0012CF64 0012CF3C 00000000
0012CD38h:  8C9BA188 00000001 804DB3EE 8C9BA1C0
0012CD48h:  00184118 7C9336D2 0012CD74 77D6672D
0012CD58h:  0012CD88 00184118 00004A82 00717450
0012CD68h:  006FDB18 000000B1 00002541 0012CDAC
0012CD78h:  77D1D4E4 003904F6 000000B1 00000000
0012CD88h:  7FFFFFFF 00000000 000002B0 00000000
0012CD98h:  0073FB38 000000B1 006FDB18 003904F6
0012CDA8h:  0012CDA0 0012CDCC 77D1B903 00717450
0012CDB8h:  000000B1 00000000 7FFFFFFF 00000000
0012CDC8h:  00717450 0012CDE4 77D25D28 003904F6
0012CDD8h:  000000B1 00000000 7FFFFFFF 0012CE10
0012CDE8h:  77D4572F 003904F6 0012CE94 77D241E2
0012CDF8h:  00000000 0101F53C 0012CE68 77D18BD9
0012CE08h:  7FFDE000 004004EC 0012CE2C 77D24204
0012CE18h:  00000000 00000028 003904F6 00000001
0012CE28h:  00000000 0012CE58 77D18734 004004EC
0012CE38h:  00000028 003904F6 00000001 77D241E2
0012CE48h:  DCBAABCD 00000000 0012CE94 77D241E2
0012CE58h:  0012CEC0 77D18816 77D241E2 004004EC
Registers:
EAX: 000005CD, EBX: 00000000, ECX: 00000000, EDX: 00188000
ESI: 00001F74, EDI: 7FFB0022, EBP: 0012CD50, ESP: 0012CD48
Crash location: "ntdll", loaded at 7C920000h - 7C9B5000h
Symbol: "RtlInitializeSListHead" (+0000EC27h)
Loaded modules:
foobar2000                      loaded at 00400000h - 004F3000h
ntdll                            loaded at 7C920000h - 7C9B5000h
kernel32                        loaded at 7C800000h - 7C91D000h
COMCTL32                        loaded at 77180000h - 77283000h
msvcrt                          loaded at 77BE0000h - 77C38000h
ADVAPI32                        loaded at 77DA0000h - 77E47000h
RPCRT4                          loaded at 77E50000h - 77EE1000h
GDI32                            loaded at 77EF0000h - 77F37000h
USER32                          loaded at 77D10000h - 77D9E000h
SHLWAPI                          loaded at 77F40000h - 77FB6000h
SHELL32                          loaded at 7D590000h - 7DD83000h
ole32                            loaded at 76990000h - 76ACD000h
shared                          loaded at 10000000h - 10029000h
comdlg32                        loaded at 76320000h - 76367000h
IMM32                            loaded at 76300000h - 7631D000h
LPK                              loaded at 621F0000h - 621F9000h
USP10                            loaded at 73FA0000h - 7400B000h
uxtheme                          loaded at 5A410000h - 5A447000h
fgmgr                            loaded at 00A50000h - 00A58000h
MSCTF                            loaded at 74680000h - 746CB000h
YzToolBar                        loaded at 00AB0000h - 00ABF000h
msctfime                        loaded at 73640000h - 7366E000h
foo_cdda                        loaded at 00AE0000h - 00B16000h
foo_converter                    loaded at 00B40000h - 00BA9000h
foo_cwb_hooks                    loaded at 00BD0000h - 00C05000h
foo_dockable_panels              loaded at 00C30000h - 00C64000h
foo_dsp_std                      loaded at 00C90000h - 00CD1000h
foo_input_monkey                loaded at 00D00000h - 00D49000h
foo_input_std                    loaded at 00D70000h - 00E84000h
foo_out_asio                    loaded at 00EB0000h - 00EDE000h
foo_ui_columns                  loaded at 00F00000h - 00F97000h
foo_ui_panels                    loaded at 00FC0000h - 01085000h
gdiplus                          loaded at 4AEF0000h - 4B093000h
Msimg32                          loaded at 762F0000h - 762F5000h
foo_ui_std                      loaded at 010C0000h - 01117000h
ctagent                          loaded at 02000000h - 02006000h
CLBCATQ                          loaded at 76FA0000h - 7701F000h
COMRes                          loaded at 77020000h - 770BB000h
OLEAUT32                        loaded at 770F0000h - 7717C000h
VERSION                          loaded at 77BD0000h - 77BD8000h
ctasio                          loaded at 02540000h - 02556000h
WINMM                            loaded at 76B10000h - 76B3A000h
ctosuser                        loaded at 02560000h - 02586000h
CTEDASIO                        loaded at 026B0000h - 026C0000h
xpsp2res                        loaded at 20000000h - 2054B000h
EmuPatchMixDSP_ps                loaded at 029D0000h - 029F3000h
imagehlp                        loaded at 76C60000h - 76C88000h
DBGHELP                          loaded at 68CC0000h - 68D61000h
Stack dump analysis:
Address: 7C9336D2h, location: "ntdll", loaded at 7C920000h - 7C9B5000h
Symbol: "RtlUnicodeToMultiByteSize" (+00000000h)
Address: 77D6672Dh, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "keybd_event" (+000003ECh)
Address: 77D1D4E4h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "SetPropW" (+000000BBh)
Address: 77D1B903h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "SendMessageW" (+00000049h)
Address: 77D25D28h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "SendDlgItemMessageW" (+0000004Eh)
Address: 77D4572Fh, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "DeregisterShellHookWindow" (+00005497h)
Address: 77D241E2h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "DefDlgProcW" (+00000000h)
Address: 0101F53Ch, location: "foo_ui_panels", loaded at 00FC0000h - 01085000h
Address: 77D18BD9h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "GetWindowThreadProcessId" (+00000159h)
Address: 77D24204h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "DefDlgProcW" (+00000022h)
Address: 77D18734h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "GetDC" (+0000006Dh)
Address: 77D18816h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "GetDC" (+0000014Fh)
Address: 77D40467h, location: "USER32", loaded at 77D10000h - 77D9E000h
Address: 77D18830h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "GetDC" (+00000169h)
Address: 77D1B4C0h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "DefWindowProcW" (+00000184h)
Address: 77D1B4D0h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "DefWindowProcW" (+00000194h)
Address: 77D1B50Ch, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "DefWindowProcW" (+000001D0h)
Address: 7C92EAE3h, location: "ntdll", loaded at 7C920000h - 7C9B5000h
Symbol: "KiUserCallbackDispatcher" (+00000013h)
Address: 77D1B473h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "DefWindowProcW" (+00000137h)
Address: 77D194BEh, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "GetWindowLongA" (+00000061h)
Address: 77D1B8BAh, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "SendMessageW" (+00000000h)
Address: 00FE77D3h, location: "foo_ui_panels", loaded at 00FC0000h - 01085000h
Address: 77BE2070h, location: "msvcrt", loaded at 77BE0000h - 77C38000h
Symbol: "__non_rtti_object::`vftable'" (+00000C78h)
Address: 01061730h, location: "foo_ui_panels", loaded at 00FC0000h - 01085000h
Address: 7C9305C8h, location: "ntdll", loaded at 7C920000h - 7C9B5000h
Symbol: "RtlFreeHeap" (+0000018Bh)
Address: 7C930551h, location: "ntdll", loaded at 7C920000h - 7C9B5000h
Symbol: "RtlFreeHeap" (+00000114h)
Address: 7C93056Dh, location: "ntdll", loaded at 7C920000h - 7C9B5000h
Symbol: "RtlFreeHeap" (+00000130h)
Address: 7C809A09h, location: "kernel32", loaded at 7C800000h - 7C91D000h
Symbol: "lstrlenW" (+00000000h)
Address: 5A415413h, location: "uxtheme", loaded at 5A410000h - 5A447000h
Symbol: "Ordinal44" (+000007F3h)
Address: 5A41542Fh, location: "uxtheme", loaded at 5A410000h - 5A447000h
Symbol: "Ordinal44" (+0000080Fh)
Address: 7C9306EBh, location: "ntdll", loaded at 7C920000h - 7C9B5000h
Address: 7C92EE18h, location: "ntdll", loaded at 7C920000h - 7C9B5000h
Symbol: "strchr" (+00000117h)
Address: 7C930570h, location: "ntdll", loaded at 7C920000h - 7C9B5000h
Symbol: "RtlFreeHeap" (+00000133h)
Address: 77BFC2DEh, location: "msvcrt", loaded at 77BE0000h - 77C38000h
Symbol: "free" (+000000C3h)
Address: 77BFC2E3h, location: "msvcrt", loaded at 77BE0000h - 77C38000h
Symbol: "free" (+000000C8h)
Address: 5A4178E9h, location: "uxtheme", loaded at 5A410000h - 5A447000h
Symbol: "GetThemeSysColor" (+0000072Fh)
Address: 77181840h, location: "COMCTL32", loaded at 77180000h - 77283000h
Symbol: "Ordinal249" (+00001840h)
Address: 77C05C94h, location: "msvcrt", loaded at 77BE0000h - 77C38000h
Symbol: "except_handler3" (+00000000h)
Address: 5A417A3Fh, location: "uxtheme", loaded at 5A410000h - 5A447000h
Symbol: "GetThemeSysColor" (+00000885h)
Address: 7C930340h, location: "ntdll", loaded at 7C920000h - 7C9B5000h
Symbol: "RtlRestoreLastWin32Error" (+00000000h)
Address: 5A417A4Dh, location: "uxtheme", loaded at 5A410000h - 5A447000h
Symbol: "GetThemeSysColor" (+00000893h)
Address: 77D1B3D2h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "DefWindowProcW" (+00000096h)
Address: 5A411B3Dh, location: "uxtheme", loaded at 5A410000h - 5A447000h
Address: 5A416C1Bh, location: "uxtheme", loaded at 5A410000h - 5A447000h
Symbol: "DrawThemeBackgroundEx" (+00001696h)
Address: 77D70088h, location: "USER32", loaded at 77D10000h - 77D9E000h
Address: 77D1B3CCh, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "DefWindowProcW" (+00000090h)
Address: 77EF991Bh, location: "GDI32", loaded at 77EF0000h - 77F37000h
Symbol: "CreateFontIndirectExW" (+00000084h)
Address: 77EF98F6h, location: "GDI32", loaded at 77EF0000h - 77F37000h
Symbol: "CreateFontIndirectExW" (+0000005Fh)
Address: 77D188A6h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "GetWindowLongW" (+00000000h)
Address: 77EF99DFh, location: "GDI32", loaded at 77EF0000h - 77F37000h
Symbol: "CreateFontIndirectW" (+00000046h)
Address: 77EF99E7h, location: "GDI32", loaded at 77EF0000h - 77F37000h
Symbol: "CreateFontIndirectW" (+0000004Eh)
Address: 01000000h, location: "foo_ui_panels", loaded at 00FC0000h - 01085000h
Symbol: "foobar2000_get_interface" (+00016B20h)
Address: 77D1D038h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "EnumDisplayMonitors" (+000000D5h)
Address: 77D1885Ah, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "GetDC" (+00000193h)
Address: 77D1882Ah, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "GetDC" (+00000163h)
Address: 77D18B26h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "GetWindowThreadProcessId" (+000000A6h)
Address: 00FE5FD0h, location: "foo_ui_panels", loaded at 00FC0000h - 01085000h
Address: 77D188D1h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "GetWindowLongW" (+0000002Bh)
Address: 77D188DAh, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "GetWindowLongW" (+00000034h)
Address: 77D188E0h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "GetWindowLongW" (+0000003Ah)
Address: 00FE5FFFh, location: "foo_ui_panels", loaded at 00FC0000h - 01085000h
Address: 77D1B3F9h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "DefWindowProcW" (+000000BDh)
Address: 77D1B3A7h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "DefWindowProcW" (+0000006Bh)
Address: 77D1B3B0h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "DefWindowProcW" (+00000074h)
Address: 771A9954h, location: "COMCTL32", loaded at 77180000h - 77283000h
Symbol: "Ordinal384" (+0000DAB4h)
Address: 771A8EA4h, location: "COMCTL32", loaded at 77180000h - 77283000h
Symbol: "Ordinal384" (+0000D004h)
Address: 771A99B0h, location: "COMCTL32", loaded at 77180000h - 77283000h
Symbol: "Ordinal384" (+0000DB10h)
Address: 00AB2A5Dh, location: "YzToolBar", loaded at 00AB0000h - 00ABF000h
Symbol: "restoreAllLogo_EXPIE" (+0000071Dh)
Address: 77D1EB3Eh, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "CallNextHookEx" (+0000003Bh)
Address: 00AB2B00h, location: "YzToolBar", loaded at 00AB0000h - 00ABF000h
Symbol: "restoreAllLogo_EXPIE" (+000007C0h)
Address: 77D318F4h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "UnhookWinEvent" (+00000077h)
Address: 77D6ABECh, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "GetRawInputDeviceInfoA" (+0000011Fh)
Address: 00AB2A90h, location: "YzToolBar", loaded at 00AB0000h - 00ABF000h
Symbol: "restoreAllLogo_EXPIE" (+00000750h)
Address: 77D1B51Ch, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "DefWindowProcW" (+000001E0h)
Address: 77D6AB8Eh, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "GetRawInputDeviceInfoA" (+000000C1h)
Address: 7C80BDE6h, location: "kernel32", loaded at 7C800000h - 7C91D000h
Symbol: "lstrlen" (+00000030h)
Address: 77D1D074h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "EnumDisplayMonitors" (+00000111h)
Address: 77D2013Eh, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "CreateWindowExW" (+000001EEh)
Address: 77D20104h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "CreateWindowExW" (+000001B4h)
Address: 00FC0000h, location: "foo_ui_panels", loaded at 00FC0000h - 01085000h
Address: 77D20129h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "CreateWindowExW" (+000001D9h)
Address: 771A106Eh, location: "COMCTL32", loaded at 77180000h - 77283000h
Symbol: "Ordinal384" (+000051CEh)
Address: 77D1BAA4h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "IsWindow" (+00000171h)
Address: 5A414434h, location: "uxtheme", loaded at 5A410000h - 5A447000h
Symbol: "GetThemeBackgroundContentRect" (+00000495h)
Address: 5A4168EFh, location: "uxtheme", loaded at 5A410000h - 5A447000h
Symbol: "DrawThemeBackgroundEx" (+0000136Ah)
Address: 5A413995h, location: "uxtheme", loaded at 5A410000h - 5A447000h
Symbol: "DrawThemeText" (+00000964h)
Address: 771A0D5Dh, location: "COMCTL32", loaded at 77180000h - 77283000h
Symbol: "Ordinal384" (+00004EBDh)
Address: 5A413AA7h, location: "uxtheme", loaded at 5A410000h - 5A447000h
Symbol: "DrawThemeText" (+00000A76h)
Address: 00440462h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 73FB49F4h, location: "USP10", loaded at 73FA0000h - 7400B000h
Symbol: "ScriptIsComplex" (+00000036h)
Address: 73FB4A1Ah, location: "USP10", loaded at 73FA0000h - 7400B000h
Symbol: "ScriptIsComplex" (+0000005Ch)
Address: 77212198h, location: "COMCTL32", loaded at 77180000h - 77283000h
Address: 77F30EB0h, location: "GDI32", loaded at 77EF0000h - 77F37000h
Symbol: "GetGlyphIndicesW" (+000000C0h)
Address: 77F1DBA8h, location: "GDI32", loaded at 77EF0000h - 77F37000h
Symbol: "GetETM" (+00000099h)
Address: 77F33020h, location: "GDI32", loaded at 77EF0000h - 77F37000h
Address: 77F1DC62h, location: "GDI32", loaded at 77EF0000h - 77F37000h
Symbol: "GdiRealizationInfo" (+00000071h)
Address: 77F07375h, location: "GDI32", loaded at 77EF0000h - 77F37000h
Symbol: "SetMetaFileBitsEx" (+000000A9h)
Address: 77F1D554h, location: "GDI32", loaded at 77EF0000h - 77F37000h
Symbol: "GetTextExtentExPointWPri" (+00000021h)
Address: 621F32F8h, location: "LPK", loaded at 621F0000h - 621F9000h
Symbol: "LpkGetTextExtentExPoint" (+000000C3h)
Address: 77EF7632h, location: "GDI32", loaded at 77EF0000h - 77F37000h
Symbol: "CreateCompatibleBitmap" (+000005EFh)
Address: 77D1D5BEh, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "DefWindowProcA" (+000000D0h)
Address: 77D1D601h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "DefWindowProcA" (+00000113h)
Address: 01058B79h, location: "foo_ui_panels", loaded at 00FC0000h - 01085000h
Address: 00FE6013h, location: "foo_ui_panels", loaded at 00FC0000h - 01085000h
Address: 77D245E4h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "DefDlgProcW" (+00000402h)
Address: 77D241B0h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "PrivateExtractIconExW" (+000002D5h)
Address: 77D23FD9h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "PrivateExtractIconExW" (+000000FEh)
Address: 0107A7C8h, location: "foo_ui_panels", loaded at 00FC0000h - 01085000h
Address: 77D24E28h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "GetWindowTextLengthW" (+00000547h)
Address: 0107A580h, location: "foo_ui_panels", loaded at 00FC0000h - 01085000h
Address: 0107A7B8h, location: "foo_ui_panels", loaded at 00FC0000h - 01085000h
Version info:
foobar2000 v0.9.4.2
UNICODE
Additional info:
PanelsUI 0.6.1 beta [Feb 16 2007 - 15:57:11]  (foo_ui_panels)
WMA Decoder 1.1  (foo_input_std)
Dockable Panels 1.0.5 [Dec  4 2006 - 09:04:00]  (foo_dockable_panels)
ASIO support 1.2.4  (foo_out_asio)
foobar2000 core 0.9.4.2  (Core)
Converter 1.0.1  (foo_converter)
FLAC Decoder 1.1.0  (foo_input_std)
Monkey's Audio decoder 2.1.1  (foo_input_monkey)
Default User Interface 0.9acc  (foo_ui_std)
Columns UI 0.1.3 beta 1v7  (foo_ui_columns)
Standard DSP array 1.0  (foo_dsp_std)
CD Audio Decoder 2.1.1  (foo_cdda)
cwbowron's title format hooks 1.1.0beta [Dec  1 2006 - 13:47:34]  (foo_cwb_hooks)
foo_ui_panels
Reply #254
Oh, thanks
after change Sort->SORT, when clicking button It shows sub menu correctly.
read the code several times but I couldn't find capital problem.
It's like hide and seek for me.
Thanks~
foo_ui_panels
Reply #255
Another request:
Is it possible that, in the active playlist, %_isplaying% returns true if a track is playing, even if the current playing playlist is not the active playlist. I suppose it would be best to have this an option, since some layouts would not want this.
Thanks again Terrestrial.
foo_ui_panels
Reply #256
Another request:
I, too, would really like this feature - it is very confusing to have a track listed on screen, which is actually playing but which does not look as if it is because it is running from the queue manager or some other playlist!
foo_ui_panels
Reply #257
Great Plugin, yes, the future of foobar...
-> If I delete the title bar and I try minimize with click in the taskbar, don't minimize (yes with the tray icon)...
(sorry my english)
foo_ui_panels
Reply #258
Ditto.
foo_ui_panels
Reply #259
Yet another request:
An extension to TitleFormatting, something like %is_in_playing_playlist%. This would allow those layouts which distinguish a "browsing" playlist from a "playing" playlist to highlight the tracks currently added to their playing playlist in their browser playlist. Alternately, %is_in_queue%, which is probably more universally appropriate, but I don't use "add to queue" because of the fact that it permanently changes the playing playlist, so I am not familiar with layouts that add tracks to the queue from multiple playlists.
Thanks again.
foo_ui_panels
Reply #260
Seeing as how "This is beta", it's probably not such a grand idea to have every other post be another feature request. For the love of god, there's 5 new requests on this thread each day as it is.
I mean, I'm not terrestrial, and I don't want to act as if I was, but come on people.
naaa na na naaaaaa na na NAAAAAAA na na naaaaaaaaa
foo_ui_panels
Reply #261
cwb_foo_hooks has a function that does that.  Something like %queue_index%, I can't remember.
I can't speak for Terrestrial, but as someone who has programmed, the worst thing is silence from users.  We want feedback.
Panels UI itself only exists because someone posted a feature request in the Text info mod thread asking for a $newpanel() function.
foo_ui_panels
Reply #262
That is the point of beta. terrestrial doesn't have a spec to work from. I don't have any bugs to report, so some input from user requests is also important. File them away, if they don't get implemented, it's no big deal. Suggestions are always a good thing.
foo_ui_panels
Reply #263
Now that the SCPL config window doesn't have it's own default font selector, is  the one in the panels configuration dialog supposed to set it?
Because if so, mine isn't.
elevatorladylevitateme
foo_ui_panels
Reply #265
I wanted to report that I'm having better luck than many, it seems, as far as not having crashes, etc.  What I do have (surprised no one else has reported this) (and wondering if it must be something crazy I'm doing!) is a complete desktop refresh, whenever a track-change occurs.  That's not just Fb2k, it is my complete desktop.  I believe it is related to the Track Display and possibly having something in the wrong section of code (// PerTrack, etc).  However, I've moved things all around, and it seems to occur no matter what.  I believe I saw this occur in Columns UI as well, using the same (or similar) Track Display.
I am very interested to know whether it will ever happen that say, a Track Display, can host any other panel?  By 'any other' I mean, any panel which follows specific guidelines.  I don't know how much component developers watch these types of things.  Some more than others, I guess.  One really nice thing, would be for all potentially-scrolling panels to have the option to turn off both horizontal and vertical scroll bars.  Otherwise, my design appears very seamless.  I have been attempting to overlay a Playlist Tree Panel on the Track Display, as it would be very nice to dynamically see the 'more by this artist' or a PTP showing the tracks in the currently playing album.  However, apparently Track Display redraws on many events (as necessary).
Still have much experimenting to do, as I'm relatively new to FB2K altogether, anyway.  Thanks again!
foo_ui_panels
Reply #266
Well, I think at last I've found out the main aspects about using this really wonderful extension ! Keep on developing this project ! definately one of the best eva ! But I've two bugs to report. My Seekbar and my Volume bar show up, but are not useable, und I can't find anything other that could cause this ... Mhm maybe it is because something is above them, but I can't find it ... Because of this I've got a feature request. Ya could implement, that if you push a certain button, all elements of the panelsUI are highlighetd in a defferent color, so you can see whether one is above another one ... This would be very useful I think.
greetings elemakil
foo_ui_panels
Reply #267
I don't know if it had been mentioned before, but Pretty Popup doesn't seem to work with Panels UI, at least with my foobar config.
Anyone has tried Pretty Popup with Panels UI?
foo_ui_panels
Reply #269
quick question - i would test for myself but i am at work. Can SCPL use buttons yet?
foo_ui_panels
Reply #271
Yes this seems to be right I haven't a font selector too.
So just use some code...
Thanks, but that doesn't resolve this issue.
I was wanting to know what now sets the font default.
Because if it is supposed to be inherited from panels (which I think would seem to be most logical), it isn't, which would be a bug.
foo_ui_panels
Reply #273
I can't export my settings.  In the settings window Export is always greyed out.  I'm using 0.6.1 beta.
foo_ui_panels
Reply #274
You answered it yourself, its a beta  From few pages back:
it's currently disabled because with the next version the import/export format will be different. just for this version, the import uses the older format to allow people to easily import their old settings.
