Topic: Prerelease of Cdparanoia 10.0 (Read 24058 times) previous topic - next topic
A new prerelease of cdparanoia, the CD-ripping backend for *nix, is now out.
http://lists.xiph.org/pipermail/paranoia-a...ust/000006.html
Hello all,
Cdparanoia 10pre0 is now up at xiph.org as a test release of the
upcoming 10.0, the first official release of cdparanoia in five years.
This release marks a return of cdparanoia to active development here
at xiph.org.
The 10.0 release brings cdparanoia up to date with bugfixes, submitted
patches and kernel interface changes over the period since the release
of 9.8 back in 2001.  Most importantly, cdparanoia adds official
support for SG_IO.  There are no new features in this release; it's
intended to bring the project up to date before resuming development.
<snip>
For now, please build from the build system
(configure/make), not your distributions package tools.
Happy hacking!
Monty
Monty urges people to test the new version. Its SG_IO routines are different from Red Hat's or Fedora's.
Source downloads: http://www.xiph.org/paranoia/
In SVN: http://svn.xiph.org/tags/paranoia-III-10pre0/
Thats good news  All the updates and possible new features
Lets hope in the near futre Spoon and Monty, or whoever is developing can get AccurateRip intergrated somehow, that would be a fantastic move...not sure how it would work with licenses though?
Kristian
Great news! Shouldn't this be in News Submissions?
Very welcome news indeed. A big thank you to Monty and co. for taking the time to do this.
Kristian
AccurateRip is not open-source though?
at xiph.org.
That's always great news. I wonder what ideas he has in store for release 10.0?
budding I.T professional
AccurateRip is closed source, CDParanoia is GPLd.
Read: won't happen.
Edit: that's also the reason why you won't see AccurateRip in CDex (unless Faber decides to ignore the GPL again)
ah, for whatever reason i thought it was under bsd, which would have been ok.
can a gpl app not link to a closed source dll then?
kristian
ah, for whatever reason I thought it was under BSD, which would have been ok.
can a GPL app not link to a closed source dll then?
kristian
Their can be a hybrid license like Foobar2000 partial BSD. Most people who develop software though sway in one direction or another. I like AccurateRip, but I won't discuss how ridiculous their motto is  . Most of the time Windows developers won't GPL their code for whatever reason, while Linux and OS/X developers will make it cross-platform so that it can run on Windows, OS/X, and Linux.
OK, I'm using Fedora... I've downloaded sources, compiled them, but didn't made make or make install, because I'm unsure what to do with it... and on site explanation isn't very clear.
TAPE LOADING ERROR
Well, you should probably install it to your ~/bin/ directory. I use ./configure --prefix=/home/kjoonlee for that.
If you have a SCSI CD-ROM, or if you still use IDE-SCSI emulation, try ripping CDs with the new ~/bin/cdparanoia with /dev/scd0 or /dev/sg0 or whatever your device is.
edit: wording
Speaking of license troubles... the never-ending fight between Schily (Jörg Schilling) and the rest of the world has recently escalated again. For those who don't know him, he's the one who created libsg, mkisofs, cdrtools and so on...
How does Schilling's decision to use the CDDL for some parts of his releases affected the cdparanoia profect? Since the CDDL is very likely to be incompliant with the GPL.
These programmers need to stop coming up with their own licenses. It's the kind of thing that should be left up to a patent attorney who is skilled in the field  . They think they can do it all
How's the cache-issue coming along? Will it be updated to deal with modern drives with large caches?
"ONLY THOSE WHO ATTEMPT THE IMPOSSIBLE WILL ACHIEVE THE ABSURD"
        - Oceania Association of Autonomous Astronauts
Only if the developer of the GPL app adds a special exception to his license. And most choose not to, because that opens a big licensing can of worms.
I honestly gave up trying to understand Schilling's reasons to keep juggling around licenses, and filed it off as a bad case of attention whoreism (yeah, I just made that up).
Does cdparanoia use code from Schilling's tools?
Even if that's the case, it wouldn't be a problem, since it would be using code that was originally licensed under the GPL.
These programmers need to stop coming up with their own licenses. It's the kind of thing that should be left up to a patent attorney who is skilled in the field.
For the last time: copyright (which is what these licenses deal with) has nothing to do with patents!
HotshotGG probably just meant "intellectual property lawyers."
Kristian
cdparanoia is a back-end, and AccurateRip is a database. It would be possible for a separate closed-source app to use cdparanoia as a separate back-end and use AccurateRip.
But no AccurateRip support will be in cdparanoia, because cdparanoia is just a back-end.
OK, I will backup my old CDparanoia libs and use new ones. But one thing troubles me... I've ripped one CD with SoundJuicer, and as I understood that program works with paranoia libs... or is it not? I'm fairly new to Linux, but I am trying to conquer it  so, if you'd tell me an app for extracting with paranoia libs, I'd gladly replace libraries and begin testing ripping... because this Sound Juicer has ripped perfectly clean disc with a lot of glitches.
I have Liteon DVDRW, it caches audio, so If I replace it, it should be better?
(edit)
OK, I've found GRip, so I'm using it - it uses for sure paranoia library... will test it for a while.
TAPE LOADING ERROR
Oops, sorry about that. I didn't know about libcdparanoia. You'd have to take extra care if you use programs that use the cdparanoia library without using the cdparanoia binary executable.
But if you can point GRip to the /path/to/new/cdparanoia, then you should be all set.
I think the standard KDE audio extraction uses cdparanoia as well.
Thats correct, which is KAudioCreator.
An eye for eye will make the whole world blind
Yes thank you for clarifying that. That is what I meant, but I just shortened it.
[deleted]
No, my error there... I ment library as in "external program"... I used windows since 3.11, I'm used to libraries...
/usr/bin/cdparanoia
cdparanoia III release 10pre0 (August 29, 2006)
© 2006 Monty <monty@xiph.org> and Xiph.Org
That's it.
TAPE LOADING ERROR
