Topic: foo_uie_bookmarks (Read 263243 times) previous topic - next topic
foo_uie_bookmarks
Hi all, here's a plugin to help you remember audio playback positions. Requires fb2k 1.3+.
Features:
  • Bookmark via playlist contextmenu/keyboard shortcut/toolbar button
  • Remove bookmark via contextmenu/Delete key
  • Inline editable Comment column
  • Time Capture: bookmark time is automatically updated on stop, user starting another, and on shutdown
  • Autoremove: bookmark is automatically deleted when playback reaches end of track
  • Autobookmark playing track on user starting another track in different/same playlist, and on shutdown
  • Capture playlist content when bookmarking
  • Field for global title formatting: %bookmarks%
  • Instant Save: save bookmarks data file whenever listview data changes except when a column is clicked
  • contextmenu Save: save bookmarks data file
  • Track Playlist: bookmark can be set to track playback in a playlist. If the user starts another track on the same playlist or fb2k advances to the next track while a bookmark is playing, then the bookmark will be updated with the new track's location/subsong and keep its playing status. Autoremoving only happens if playback order is set to Default and when playback has reached the end of the last track in the playlist.
Current version: 0.3.6
Changelog
foo_uie_bookmarks
thanx. it's work!
foo_uie_bookmarks
Nice idea
Minor suggestion: Please use Windows' date format settings or at least ISO 8601 (YYYY-MM-DD).
foo_uie_bookmarks
Very nice component, thanks a lot! But I have one problem: if I doubleclick a bookmarked item, it starts playing the song from the beginning and not from the saved time position. What am I doing wrong? I use foobar 0.9.3 beta 2
foo_uie_bookmarks
Cannot cnfirm that! It works fine!
It is nice that this new bookmark plugin uses a panel. Would just like to have settings for background and text color.
Thanks!!
foo_uie_bookmarks
Thanks!!
Sorry! I have 0.9.2 and 0.9.3beta installed and sometimes don't know what i am using.
It is a problem with the beta! Confirmed!
foo_uie_bookmarks
Nice feature to add to fb2k, but i have a "little issue"
When you doubleclick where there isn't any file, it pops up with a note saying "File not found".
i don't think it's necessary to inform the user when he doesn't click on a real file.. It should be enough just to let him/her experience that nothing is happening.
"Sometimes it's better to inform the user that he/she is an idiot, by not saying anything" as one of my school teachers once said..
It's ofcause a translation from danish, so something might have gone lost there..  but i hope that you understand the point of my "request"
Another thing i might be happy to do, is to cut down on the amount of data which is displayed.
I would like to remove some of the columns, but I haven't found any way to do this yet..
Am I requesting too much?.. plz, let me know..
foo_uie_bookmarks
Thanks!!
With the new foobar 0.9.3 beta 3 it works as it should - no more problems :-)
foo_uie_bookmarks
thank you very much for this plugin, dude!
foo_uie_bookmarks
Very nice and useful. Thank you tanka!
//edit: One suggestion, customizable/removable columns would be nice. For example i would like to remove "Location" and "Added on". They are stealing too much space.
foo_uie_bookmarks
- Hide/reset columns
Thank you.
But now i have the same problem as hayfi mentioned earlier in this thread, every song starts from beginning and not from bookmarked position.
foobar2000 v0.9.3 beta 3
foo_uie_bookmarks 0.0.1c
Win2K SP4
foo_uie_bookmarks
Thank you.
Win2K SP4
Can you reproduce it? I haven't encountered that problem and I've only tested it on WinXP.
foo_uie_bookmarks
Just tested it on my machine at home. Same problem.
Technical information:
CPU: AMD Athlon(tm) 64 Processor 3200+ [x86 Family 15 Model 47 Stepping 2] [DEP enabled]
Operating System: Microsoft Windows XP [version: 5.1.2600 Service Pack 2]
Installed RAM: 1024 MBytes
Free disk space on foobar2000 partition: 6430 MBytes
foobar2000 path: D:\Applikationen\foobar2000\
Core version: foobar2000 v0.9.3 beta 3
Build time: 22:23:32 on 22 July 2006
Active components (22):
foo_albumlist.dll v3.2.0 [22 July 2006] - Album List
foo_burninate.dll v2.0.1 [27 June 2006] - Audio CD Writer
foo_cdda.dll v2.1.1 [22 July 2006] - CD Audio Decoder
foo_common.dll v0.1 [11 March 2006] - Common services
foo_converter.dll v1.0.1 [22 July 2006] - Converter
foo_dbsearch.dll v1.3.1 beta 11 [13 March 2006] - Database search
foo_dsp_std.dll v1.0 [22 July 2006] - Standard DSP array
foo_freedb2.dll v0.5.2 [12 July 2006] - freedb tagger
foo_input_monkey.dll v2.1.1 [04 July 2006] - Monkey's Audio decoder
foo_input_std.dll v1.0 [22 July 2006] - Standard Input Array
foo_input_std.dll v1.1.0 [22 July 2006] - FLAC decoder
foo_locktest.dll v1.0 [13 March 2006] - Playlist Lock Test
foo_masstag.dll v1.6 [22 July 2006] - Masstagger
foo_playlist_bind.dll v2.2 [06 April 2006] - Playlist Bind
foo_rgscan.dll v2.0.2 [22 July 2006] - ReplayGain Scanner
foo_run.dll v0.3.2 [15 June 2006] - Run services
foo_ui_columns.dll v0.1.3 beta 1v5 [29 April 2006] - Columns UI
foo_ui_std.dll v0.9acc [22 July 2006] - Default User Interface
foo_uie_bookmarks.dll v0.0.1c [26 July 2006] - Bookmarks
foo_uie_explorer.dll v1.04.6b [06 July 2006] - Explorer Tree
foo_uie_quicksearch.dll v2.8a [16 June 2006] - Quick Search Toolbar
foo_version.dll v0.3 [18 July 2006] - Components versions viewer
foo_uie_bookmarks
I think that i've detected the problem and found out the solution. After updating the component it doesn't work with old playlist-entries. If I clear the playlist(s) and reload the tracks, it works fine again
Is this a bug? Can you explain this behaviour?
Thank you
foo_uie_bookmarks
After terminating my problem here's the next suggestion
An extra column for adding comments manually would be very useful. For example, if you set multiple bookmarks in a song or dj-set, it would be very cool, to comment the bookmarks, like "song x", "guitar solo" or something else.
Thank you
foo_uie_bookmarks
First of all thanks for the plugin, I was really missing that one.
I've had the problem as well and can confirm, the workaround works.
Some suggestions:
1. Allow background color change
2. Allow keyboard shortcuts inside the panel (del, strg+a)
3. "Delete all" function + make this available as an fb2k command.
foo_uie_bookmarks
Update: 0.0.2
To update, just overwrite the dll.
- Improved bookmarking while bookmarks window is closed
- Contextmenu Clear removes all items
- Delete key removes items
- Text/background colors
- Clear Bookmarks keyboard shortcut
- Bugfix: contextmenu location when contextmenu key is pressed
- Bugfix: wrote file twice on window creation
- Bugfix: focused item played instead of bookmarked item
- Inline editable Comment column
Thank you for bugfixing and the new features, especially the comment field
It seems, that i've detected another bug. I doesn't work with cuesheets. The bookmark doesn't point to the correct position. For expamle, if i bookmark one minute after beginning of the third song, the playback starts after one minute from beginning of the first track (one minute after beginning of the whole imagefile)
Once more, thank you for your work
foo_uie_bookmarks
Nice work with the latest version..! It's really neat and very easy to use
But I can confirm the bug with cue sheets.
It reads the song name fine and also the time into the song, where the bookmark were set, but when playing, it resumes from the specified time, but instead of the selected track, it starts from the first track number.
Edit: cleared the text up a bit to give some sence..
foo_uie_bookmarks
Many thanks for the update. 2 Problems:
1. The plugin seems to forget it's columns widths after an fb2k restart (definitely in time column)
2. Please make all commands available:
[blockquote]a) (example) foobar2000.exe /command:"Bookmark" (does not work at the moment)
b) for foosions foo_runcmd[/blockquote]
Why don't you promote you plugin in 3rdparty-plugin forum?
foo_uie_bookmarks
Great updates. Thank you very much and keep it coming.
foo_uie_bookmarks
Found a bug:
If you wants to play a bookmarked song wich path points to a CD/DVD device that doesn't contain the Cd anymore Foobar closes with a error message
foo_uie_bookmarks
Small feature request: Sorting by clicking on columns header
foo_uie_bookmarks
Very nice plugin! but multi-lines name format will be better
foo_uie_bookmarks
Thanks for the update! But. Hmmm. I don't see any change and I don't see "- Keyboard shortcuts can now be processed through the Bookmarks window"
