Topic: [CRASHWARE] updated foo_uie_albumart (Read 700004 times) previous topic - next topic
Reply #550
I'm stumped.  I must be missing something.  I even uninstalled foobar and reinstalled it with freshly downloaded components and rebooted.  Here's my config screens with components and Columns UI layout.  Note that when I used older versions of foo_uie_albumart I at least had the art panel show up but there was no provision in layout to add a panel.  Nothing like it shows in this thread or the wiki.
Reply #551
Right click a splitter/insert panels/panels/album art
A screenshot can be found here
foobar2000 + EAC + Burrrn = Happiness
Reply #552
Wow!  I finally got it
[a href="http://img120.imageshack.us/my.php?image=myfoobar2000albumartsuccess4rl.jpg" target="_blank"]
Reply #553
I know this has been brought up before, but now that foobar2000 does not remove image data from an MP3 tag, is their a possibility of adding support for embedded album art?
TIA
Reply #554
TIA
There's always a possibility, but the question is, who's going to do it?  I personally don't have any plans to add it as a feature.
Reply #555
That's completely understandable, hopefully someone else with coding knowledge could take a look at this and maybe add the support.  I wish I could do it, but I have no programming knowledge.
Thanks for the reply!
Reply #556
Using Foobar v0.9.2, albumart v0.2.1 and columns UI v0.1.3 beta 1v5!
I am having a big problem with the album art plugin which basically means I am unable to use it!  It slows my foobar down that much its just impossible to use it....when loading tracks esp it can take up to 30s to actually flick to the track and display the info etc...
At times it can even make foobar hang.
ANy ideas anyone?  Kinda desperate, one of the reasons I moved to Foobar was to have album art displayed and now I can't!
Reply #557
Maybe reinstall? delet foobar and install it again.
Or, if you haven´t done it allready, delet your albumart .dll, download it new and then put it again into the components directory, if then the problem still is there, i´m sorry that i couldn´t help you.
Reply #558
Keown: Try disabling the fading transition.  At least for me, that's the biggest resource-hog.  What OS/processor are you using?
Reply #559
one other bug ive noticed, and i apologize if this has been brought up, but when i play a game (ie NFSMW), the album panel goes gray when i exit out of the game and i have to restart foobar.
again, sorry if this is known.
Reply #560
Thanks for the suggestions guys...
I tried the fresh install of Foobar and no luck.  And I had tried replacing the .dll file recently to try and solve it also.
Also tried disabling the fading but again no help - it doesnt even seem to be just when changing tracks now, its like even when I am say for example just going into the album art preferences, the whole program just freezes up and stops responding for a bit.
On Windows XP with Athlon 64, 3500 Processor so should be no problem there right?
Reply #561
I think I have the same problem. If I for example filter something in "Browser" component, it freezes foobar2000 sometimes even for 1 minute. Sometimes fb2k freezes just by clicking on another song (not actually playing it). If I disable Album Art, all problems are gone.
My current workaround is disabling "follow cursor" option. Btw. I use version 0.1763 with Matroska support.
Reply #562
Since I didn't develop that version (or at least, I didn't add Matroska support), I can't officially offer any support.  The last version I released was 0.2.1.  However, I'll assume for now that keown is using one of my versions, so this is something I can and should address.  Could you both list what components you're using?  (or just take a screenshot of "Preferences -> Components")
evo3: I'll see if I can recreate that bug with the demo version.  I'll try to fix it, too, unless I get hooked on the game
Reply #563
Yup I am using 0.2.1!
Reply #564
Good job with the screenshot!
Exact version of columns ui is hidden. But Album list panel isn't the latest so it may be possible that columns ui isn't, too...
Reply #565
Nope just checked, am using v0.1.3 beta 1v5!
Reply #566
I just reproduced the problem with the latest official Album Art Panel. I knew I tried it before, but I wasn't really sure. Sometimes just clicking on another song means 10-20s delay and my HDD becomes very active. But if I disable "follow cursor" and a song is playing (so the album art doesen't change) the problem dissapears. Well not completely, but doesen't happen so often. If I disable Album Art completely, I have no more delays.
As for request for info on my components - I remember there was plugin which could list them. But I can't find it, can you help me?
Reply #567
Finally here it is, Components versions viewer.
CPU: AMD Athlon™  [x86 Family 6 Model 6 Stepping 2]
Operating System: Microsoft Windows XP [version: 5.1.2600 Service Pack 2]
Installed RAM: 1024 MBytes
Free disk space on foobar2000 partition: 2683 MBytes
foobar2000 path: C:\Program Files\Multimedia\Audio\foobar2000\
Core version: foobar2000 v0.9.2
Build time: 17:54:58 on 07 June 2006
Active components (49):
foo_abx.dll v1.3 [07 June 2006] - ABX comparator
foo_ac3.dll v0.7 [23 March 2006] - AC3 decoder
foo_albumlist.dll v3.2.0 [07 June 2006] - Album List
foo_bitcompare.dll v1.0 [19 March 2006] - Binary comparator
foo_browser.dll v1.2.0b [Jun 14 2006 - 08:28:57] [14 June 2006] - Music Browser
foo_cdda.dll v2.1 [07 June 2006] - CD Audio decoder
foo_channel_mixer.dll v0.9.4 [12 April 2006] - Channel Mixer
foo_common.dll v0.1 [11 March 2006] - Common services
foo_converter.dll v1.0.1 [07 June 2006] - Converter
foo_cuesheet_creator.dll v0.4.5 [22 June 2006] - Cuesheet Creator
foo_dbsearch.dll v1.3.1 beta 11 [13 March 2006] - Database search
foo_dsp_continuator.dll v0.4.0 [11 April 2006] - Continuator
foo_dsp_std.dll v1.0 [07 June 2006] - Standard DSP array
foo_dsp_vlevel.dll v20060324.0 [24 March 2006] - VLevel
foo_dts.dll v0.1 [25 May 2006] - DTS decoder
foo_freedb2.dll vv0.5.1 [14 March 2006] - freedb tagger
foo_history.dll v0.2 [31 March 2006] - History
foo_input_matroska.dll v0.9.0.8 [10 May 2006] - Matroska Plugin
foo_input_shorten.dll v0.4.2a [11 March 2006] - Shorten decoder
foo_input_std.dll v1.0 [07 June 2006] - Standard input array
foo_input_std.dll v1.1.0 [07 June 2006] - FLAC decoder
foo_input_tta.dll v2.4.1 [14 April 2006] - TTA Audio Decoder (unofficial)
foo_lnk.dll v1.1 [11 March 2006] - Shell link resolver
foo_lyricsdb.dll v0.0.7 beta 3 [09 May 2006] - foo_lyricsdb
foo_masstag.dll v1.5 [07 June 2006] - Masstagger
foo_packet_decoder_ac3.dll v0.9 [30 April 2006] - ATSC A/52 (AC3) Packet Decoder
foo_packet_decoder_wavpack.dll v0.9.0 [10 May 2006] - WavPack Packet Decoder
foo_playcount.dll v1.9.2 [12 April 2006] - Play Count
foo_playlist_bind.dll v2.2 [06 April 2006] - Playlist Bind
foo_playlist_manager.dll v1.0 [13 March 2006] - Playlist Manager
foo_playlist_tree.dll v2.2.beta1 [Jun 16 2006 - 14:42:32] [16 June 2006] - Playlist Tree Panel
foo_prettypop.dll v1.2.2 [13 April 2006] - Pretty Popup
foo_random.dll v1.2.3 [13 March 2006] - Randomized playlist entry
foo_rgscan.dll v2.0.1 [07 June 2006] - ReplayGain Scanner
foo_tradersfriend.dll v0.6.1 [13 March 2006] - Live show tagger
foo_ui_columns.dll v0.1.3 beta 1v5 [29 April 2006] - Columns UI
foo_ui_std.dll v0.9acc [07 June 2006] - Default User Interface
foo_uie_albumart.dll v0.2.1 [21 June 2006] - Album Art Panel
foo_uie_albumlist.dll v0.2.1 beta 1 [20 March 2006] - Album list panel
foo_uie_explorer.dll v1.04.6 [23 March 2006] - Explorer Tree
foo_uie_lyrics.dll v0.3.0.0 [02 June 2006] - Lyric Show Panels
foo_uie_quicksearch.dll v2.0 [27 May 2006] - Quick Search Toolbar
foo_uie_tabs.dll v0.2.1 [07 July 2006] - Tabbed panel modifyed
foo_uie_trackinfo.dll v0.8 [03 May 2006] - Track info panel
foo_unpack.dll v1.0 [07 June 2006] - ZIP/GZIP reader
foo_unpack.dll v1.1 [07 June 2006] - RAR reader
foo_utils.dll v0.5.6 [13 March 2006] - Playlist tools
foo_version.dll v0.1 [15 July 2006] - Components versions viewer
foo_vis_projectM.dll v1.97.6.2 [16 April 2006] - projectM visualization
I'll ty a clear fb2k install with just a few components (Columns UI, Album Art and Browser if necessary) and let you know the results.
Reply #568
Exactly this is my problem, too - but even worse, since all my music is stored on a network server. That said, if I have "follow cursor" activated and try to select another song from the list I have to wait up to 30 seconds before foobar comes back to me again. With "AlbumArt" deactivated the problems will also vanish, so I think this is the main source of the problem. Here is my configuration:
CPU: Intel® Pentium® 4 CPU 3.00GHz [x86 Family 15 Model 4 Stepping 3]
Installed RAM: 2048 MBytes
Free disk space on foobar2000 partition: 4009 MBytes
foobar2000 path: C:\Programme\foobar2000\
Active components (34):
foo_browser.dll v1.2.2c [Jul  6 2006 - 09:42:02] [06 July 2006] - Music Browser
foo_burninate.dll v2.0.1 [27 June 2006] - Audio CD Writer
foo_infobox.dll v2.0.3 [25 June 2006] - Special file info box
foo_notaskbar.dll v0.1 [16 April 2006] - Taskbar Button Remover
foo_run.dll v0.3.2 [15 June 2006] - Run services
foo_uie_albumlist.dll v0.2.1 beta 4 [28 April 2006] - Album list panel
foo_uie_playlists_dropdown.dll v0.5.7.5 [09 June 2006] - Playlists Dropdown
foo_uie_quicksearch.dll v2.8f [20 June 2006] - Quick Search Toolbar
foo_utils.dll v0.5.7 [27 April 2006] - Playlist tools
"If there 's no soul in the computer's music, it's because nobody put it there." - Björk.
Reply #569
I just reproduced the problem with this configuration (everything set to default):
Free disk space on foobar2000 partition: 2533 MBytes
foobar2000 path: c:\Program Files\Multimedia\Audio\fb2k\
Core version: foobar2000 v0.9.3 beta 1
Build time: 21:20:42 on 11 July 2006
Active components (7):
foo_albumlist.dll v3.2.0 [11 July 2006] - Album List
foo_input_std.dll v1.1.0 [11 July 2006] - FLAC decoder
foo_input_std.dll v1.0 [11 July 2006] - Standard input array
foo_ui_std.dll v0.9acc [11 July 2006] - Default User Interface
But it doesen't happen so often. It might depend on playlist size, I don't know. I'll try to explain more deeply what happens. If I click on different songs, the album art usually changes with a few seconds delay. That's O.K., my machine is rather slow. But sometimes (I would say randomly) fb2k hangs for quite a long time (20-30 seconds I'd guess) and I hear a lot of HDD activity. I think it might be a bug when Album Art searches for images on defined paths.
Reply #570
This lag would be foo_uie_albumart searching for images. Unfortunately, it does so in a way that blocks the user interface. The problem is especially pronounced, if your sources list ist large, has many wildcards, or references files on a slow drive (for example a network drive).
Reply #571
foosion> But my files are on a local drive (quite fast 200 GB SATA drive). I left all the source paths on default, so there were only 3 directories where to look for an album art. And furthermore, it hangs up randomly. So sometimes the ablum art is displayed within a few (2-3) seconds, but sometimes it takes up to 30 seconds. So I'm not really satisfied with your explanation, I think the problem must be elsewhere.
Reply #572
Is your music all in one big directory?
Try manually adding the sources, initially, just use this one:
"$replace(%path%,%filename_ext%,)*"
and have your album art in the same directory as an album.
hi
Reply #573
This is definately not the cause, since older versions (at least the original AlbumArt panel) didn't produced this kind of odd behaviour. My sources list is exactly two entries "large" looking for "no cover art" and "cover art", the second one in the manner "folder.jpg", so I think this rules out the sources-idea...
Another thing is that my network is based on a linux NFS share system which is blazing fast with all other things than album art.
What I will try now is to delete all references of album art, reinstall it using standard sources. I will report back if this has helped...
Reply #574
I also experienced this behaviour. Will examine this beeing back in my "studying-place".
