Topic: [CRASHWARE] updated foo_uie_albumart (Read 700282 times) previous topic - next topic
0 Members and 10 Guests are viewing this topic.
Reply #525
Version 2.1 is reported in preferences/components as 2.0!
Nothing serious, but I can confirm that.  Another odd thing is that I didn't lose my settings for the panel when upgrading too.  Compile date is right, version number is not.  I can't tell if anything is different though.
Reply #526
Just a tiny suggestion: Could you make the default "Inactive selection background (no focus)" color in the "Playlist switcher" R=228, G=228, B=235, which is the corresponding default color for the regular playlist and looks much better than using the same gray as the UI elements.
EDIT: Sorry, wrong thread, this was supposed to go to foo_ui_columns:
http://www.hydrogenaudio.org/forums/index....ndpost&p=405292
Reply #527
Is it possible to tile an albumart image (and if not would you consider looking into making it possible)?  We can already view the images normally or apply different methods of stretching and scaling. It seems only natural we would eventually want to tile them.
Yeah, that doesn't sound like a bad idea.
Thank you for all your work modifying one of the most popular and useful components for foobar.
-- don't forget that it was rexy who initially created this plugin, and (*deep breath*) david_dl, WigBaM, G-Lite, and foosion who made contributions before I even touched it.
Also, %ispaused% doesn't seem to work at all (it would be nice if it worked),
Make sure you're using version 0.2.0 or higher.
One additional thing to note, I dont know if this is a bug or not but I've noticed that sometimes if you add a new variable to a source (as in, a %variable% that isnt anywhere else in the panel config) that it wont get processed properly until you restart foobar. If you spend the time to come up with a good block of code but you think a new variable is not working you may want to restart foobar before giving up on the approach.
  Can you give me an example of this?  I would qualify that as a bug....
Has anyone tried splitting the frames of an animated GIF and then have albumart cycle through them at maximum speed, for faux animation?  I wonder if it would be fast enough.  (Does 0 mean no delay, or no cycling?)  I guess it would depend on the original animation.  Obviously, you'd have to disable transitions.
0 means no cycling (analagous to 0 disabling animation).  I should probably have made that clearer.  Also, the units are in seconds, so you wouldn't be able to get it to cycle quickly enough.  Plus, it'd probably use a lot of CPU to do that.  But it is a fun idea.  Maybe I'll change the units to milliseconds some time in the future and people can play with the animation idea.
D'oh!  silly me!  Thanks for letting me know.
  wrong thread?
Okay, you can downloaded the updated 0.2.1 here.  The only difference should be the version number actually shows 0.2.1 and the compile date is today's date.  I did upload the correct version before, just forgot to bump the number.
Also, you'll only lose your settings if you upgrade from a version before 0.2.0, like 0.176 -> 0.2.1.  I left the warning just in case anyone didn't see it earlier.
Reply #528
I may have found a bug. If i am listening to a song and that i change the cover while playing, i cant refresh it, it does nothing. I need to load a track with another cover then go back to the cover i changed to see the change.
Reply #529
how to insert albumart panel ?
before 0.9.2, it's only do a right click and insert the panel, but now how can i do it ?
Reply #532
When you say "change the cover", do you mean you actually replace the .jpg file on your disk?  Did you try doing a "Refresh" (right-click on the panel, then select "Refresh")?  Which version are you using?  The "refresh" function was one of the "minor tweaks and fixes" I made in version 0.2.0, so make sure you're using the latest version and let me know if it's still a problem.
Reply #533
Edit: Nevermind, I tried a few more things and X:\My Music\MP3 Albums\00 Covers\[%Artist% ~ %Album%]*.* is working.
I'm sorry, this is a rather basic question, but I've spent a fair amount of time browsing the thread and playing around and can't seem to figure it out.  I have all of my album art saved to X:\My Music\MP3 Albums\00 Covers, with the filenames in the format Artist ~ Album ~ Cover.jpg.  How do I tell albumart to look in this folder and select the correct image?
Reply #534
Yeah i am using the last version, and by changing the cover i mean replacing the folder.jpg by another one (better quality). I tried the refresh it did nothing. I am not really sure but i think i already had that problem on older versions.
Reply #535
i have a question: i installed albumart and choose a picture if the albumart isnt available, but if i shift to an album where the cover is available, i have to right click -> next source, is there a way to let album art search for the next source automaitcally?
Reply #536
Are you using 0.2.1?  This was one of the bugs I thought I addressed between 0.2.0 and 0.2.1.
Reply #537
What order are your sources in albumart? Is the line for you no-cover image BELOW the line that finds the album's cover? Here is my sources list:
$replace(%path%,%filename_ext%,)cover.*
$replace(%path%,%filename_ext%,)*
-$if($strcmp($left(%path%,7),http$char(58)$char(47)$char(47)),components\online-radio.*,components\no-cover.*)
First it looks for a file named cover.* in the song's directory. Then it looks for any image in the song's directory. Then it checks to see if the song is online or local and displays an appropriate no-cover image.
Reply #538
Are there any plans to display Neroaactag embedded cover art?
Reply #540
Am I the only one getting a non-solid color in the album art background?
Describing screenshot (sorry about the compression on the jpg)
I've chosen the same background color on the trackinfo and the albumart panel but they end up as shown on the picture above; the album art has a dotted background and the dots have the correct color.
This concerns: fb2k v0.9.2 b.5 and foo_uie_albumart 0.2.1
Edit: Nevermind, it's all good.
Reply #541
I tried to update to 0.2.1, but when I do it doesn't display in preferences, the latest version that does is 0.176a, but that one doesn't display in the layout window so I can't use that either
Am I missing some dll or what else could be the problem?
The previous version I used was something around 0.15 and that worked fine.
Reply #542
After you add the panel to your layout, right click to open up the preferences.  Since you can add multiple album art panels now, each one has its own preferences....just like the Track Info panel.
Reply #543
Is it possible to add HTTP support to this plugin? I have a little PHP script running on localhost that uses AWS to download album art. It'd be pretty sweet if I could use it.
Reply #544
But it isn't an option in my layout tab so I can't add it
This is what I have
Reply #545
What version of ColumnsUI are you using?  Yours looks different than mine.  Mine shows "Horizontal Splitter" or "Vertical Splitter", while yours just shows "Splitter".  You might be using an incompatible version.
Reply #546
Is it possible to add HTTP support to this plugin? I have a little PHP script running on localhost that uses AWS to download album art. It'd be pretty sweet if I could use it.  :P
Please see posts 481, 482, 486, and 488. This has recently been discussed in this same thread and I got the impression gfngfgf is working on it's implementation.
Please search the forum before asking questions or making suggestions.
Reply #547
This is what I have
Under Preferences go to the Components section and find Columns UI in the list (foo_ui_columns). What is the version number? The latest version, which has been out for awhile and is what most of us use, is v0.1.3 beta 1v5 and can be obtained here. As KarnEvil indicated you appear to be running an older version due to the lack of splitter types.
Reply #548
My bad.
Sounds great, though. Hope they add it soon as I have maybe 2 albums with correct art in the folders.
EDIT: 4 albums.
Reply #549
Ok, it's fixed now, so thanks for your help
I was sure that I had checked Columns UI, but I must have cancelled the download, since the new one was the exact same size as the dll I had plus same last modified date and time
