Topic: Wanted v0.9 plugin ports (Read 750914 times) previous topic - next topic
Reply #250
No Farinhir that's not what it means. But I don't use any lyrics plugin so I didn't know what the differences were and I put the "try minilyrics" to give some people an alternative, now if you think it's not enough feel free to contact the developer to have news from him and see if he's planning to port the plugin. I can't do it for every plugin but I will add any info you can provide me with to the list.
Reply #251
An update of foo_vis_stereo would be nice
foobar2000 + EAC + Burrrn = Happiness
Reply #254
OK just thought I'd mention, if it's useful, that kode54 said that he might try porting foo_dsp_soundtouch sometime later eventually (he said that nobody remembers that it exists, but from what I've seen a lot of people miss it).
Also it's been bugging me for a while, but "foo_soundtouch" is redundant and erroneous.
Reply #255
You can take foo_uie_console out of the wanted list.
Its in the ported list but still exists in the wanted list.
Just something I noticed.
Cheers, keep up the good work.
Reply #256
I didn't say nobody remembered the component, merely that some people were unclear on its origin after so much time since they last needed to update it. The fact that I did away with my 0.8.3 components page does not help matters.
I will get around to it eventually.
Reply #257
I some how my panels and teh ability to create new panels after upgrading to Column UI v1.3 7v6.  Any ideas?
UPDATE:  looks like it all has to be done in the preference menus...but I can't add Album Art or track info panels?
Nevermind, updated to latest versions that they show up.
Reply #258
trance, I'm not sure what you mean but I think you should make sure you have the last version of Albumart/trackinfo (redownload them from the first post) and then try to add them through the layout configuration of ColumnsUI
Reply #260
Where did you get this version? On musicmusic's page the current version is 0.1.3 beta 1v5.
Reply #261
You have the last one Lycox, I think he was referring to the pre-alpha 17v6.
Reply #263
Hey guys, I'm having troubles navigated these forums.
Is there a link to download kernel streaming component for 0.9?
Reply #265
sorry for n00b question, do components from v 9.0 work with 9.1 ?
Reply #266
Yep, all the 0.9.x are compatible between versions.
Reply #267
thank you again
Reply #269
There was a new version of the ASIO plugin released today.  It now works with the Emu cards.
Reply #271
Yep, some copy/paste mistake, fixed. Thanks.
Reply #274
I miss foo_quicktag.
