Ooh. I don't know if this is Columns UI's fault or the panel's, but i got a crash. Here's what happened.
I have a single trackinfo panel, and it's in the side bar. I decided that i wanted to try putting another trackinfo panel in the main (non-side bar) area above the play list, so i went into Layouts tab and added a trackinfo panel and clicked apply. After a while it did that (put the trackinfo above the play list), but it also apparently removed the trackinfo panel from the side bar.
So i was like, f that, the side bar is more important than some lame panel above the play list, so i right-clicked in the empty area that was left in the side bar and re-added the trackinfo panel.
booooom, crash
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 01741DC3h
Access violation, operation: read, address: 00000008h
Call path:
entry=>app_mainloop
Code bytes (01741DC3h):
01741D83h: CC CC CC CC CC CC CC CC CC CC CC CC CC 56 8B F1
01741D93h: 8B 4E 04 85 C9 74 08 8B 01 8B 10 6A 01 FF D2 C7
01741DA3h: 46 04 00 00 00 00 8B 4E 0C 85 C9 C7 46 0C 00 00
01741DB3h: 00 00 5E 74 06 8B 01 8B 10 FF E2 C3 CC 8B 41 04
01741DC3h: 8B 40 08 C3 CC CC CC CC CC CC CC CC CC 8B 44 24
01741DD3h: 04 8B 0D 0C C6 76 01 6A 00 68 B0 1F 74 01 50 6A
01741DE3h: 66 51 FF 15 C0 E1 75 01 C2 04 00 CC CC B8 EC FC
01741DF3h: 75 01 C3 CC CC CC CC CC CC CC CC CC CC 8B 44 24
Stack (0012F5D0h):
0012F5B0h: 013FE64C 7C9C76F0 77F643DD 7C9C76F0
0012F5C0h: 00000004 00000000 013FDB58 00000000
0012F5D0h: 01741D6E BF94E7CF 0176B2EC 0185B0C8
0012F5E0h: 00000000 0176B2EC 0012F668 0175CDDB
0012F5F0h: FFFFFFFF 017CFF68 0DFB0296 0012F6BC
0012F600h: 018262BC BF609927 00000000 02415B68
0012F610h: 0185B0C8 00000000 00000000 000000B4
0012F620h: 000002A3 00000005 0012F664 0012F658
0012F630h: 01817324 01744F00 00000000 0040BF7B
0012F640h: 0040BF88 0012F6E0 00BAF00C 0012F690
0012F650h: 0049550F FFFFFFFF 017B9A97 0238A600
0012F660h: 00000001 0012F604 0012F768 01803A52
0012F670h: 00000009 01816DF4 00000000 00000000
0012F680h: 00000000 02469E00 0000000B 0012F678
0012F690h: 0012F768 018025BA FFFFFFFF 017BFF3F
0012F6A0h: 085F03D4 0185B0C8 01816DBC 0185D438
0012F6B0h: 0000001B 0000000A 018252C4 018252C4
0012F6C0h: 0DFB0296 00000000 0012F630 00000005
0012F6D0h: 01010004 0176B2EC 00000004 0012F774
0012F6E0h: 017D0D1E BF609827 01E30126 0185B0C8
Registers:
EAX: 00000000, EBX: 01825284, ECX: 0176B2EC, EDX: 01741DC0
ESI: 0176B2EC, EDI: 00000000, EBP: 0012F674, ESP: 0012F5D0
Crash location: "foo_uie_trackinfo", loaded at 01740000h - 01773000h
Loaded modules:
foobar2000 loaded at 00400000h - 004DC000h
ntdll loaded at 7C900000h - 7C9B0000h
kernel32 loaded at 7C800000h - 7C8F4000h
COMCTL32 loaded at 773D0000h - 774D2000h
msvcrt loaded at 77C10000h - 77C68000h
ADVAPI32 loaded at 77DD0000h - 77E6B000h
RPCRT4 loaded at 77E70000h - 77F01000h
GDI32 loaded at 77F10000h - 77F56000h
USER32 loaded at 77D40000h - 77DD0000h
SHLWAPI loaded at 77F60000h - 77FD6000h
SHELL32 loaded at 7C9C0000h - 7D1D3000h
ole32 loaded at 774E0000h - 7761C000h
shared loaded at 10000000h - 1002A000h
comdlg32 loaded at 763B0000h - 763F9000h
IMM32 loaded at 76390000h - 763AD000h
LPK loaded at 629C0000h - 629C9000h
USP10 loaded at 74D90000h - 74DFB000h
uxtheme loaded at 5AD70000h - 5ADA8000h
DockShellHook loaded at 003D0000h - 003DC000h
msctfime loaded at 755C0000h - 755EE000h
foo_abx loaded at 00A10000h - 00A43000h
foo_albumlist loaded at 00A70000h - 00AAF000h
foo_amipwrapper loaded at 00AD0000h - 00AF6000h
foo_autoplaylist loaded at 00B20000h - 00B52000h
foo_browser loaded at 00B80000h - 00BB7000h
foo_cdda loaded at 00BE0000h - 00C0D000h
foo_common loaded at 00C30000h - 00C6A000h
foo_converter loaded at 00C90000h - 00CF0000h
foo_dbsearch loaded at 00D10000h - 00D6C000h
foo_dsp_delta loaded at 00D90000h - 00DAE000h
foo_dsp_std loaded at 00DD0000h - 00E0F000h
foo_dumb loaded at 00E30000h - 00E8F000h
foo_freedb2 loaded at 00EB0000h - 00EF0000h
foo_gep loaded at 00F10000h - 00FA8000h
MSIMG32 loaded at 76380000h - 76385000h
OLEAUT32 loaded at 77120000h - 771AC000h
foo_input_monkey loaded at 00FD0000h - 01013000h
foo_input_shorten loaded at 01040000h - 0106E000h
foo_input_std loaded at 01090000h - 0119C000h
foo_lnk loaded at 011C0000h - 011D9000h
foo_masstag loaded at 01200000h - 0124E000h
foo_midi loaded at 01270000h - 01318000h
foo_osd loaded at 01340000h - 01376000h
gdiplus loaded at 4EC50000h - 4EDF3000h
foo_playcount loaded at 013B0000h - 013D8000h
foo_playlist_manager loaded at 01400000h - 01446000h
foo_pqview loaded at 01470000h - 0148C000h
foo_psf loaded at 014B0000h - 01593000h
foo_rgscan loaded at 015C0000h - 01603000h
foo_uie_albumart loaded at 01630000h - 01659000h
foo_uie_albumlist loaded at 01680000h - 016BF000h
foo_uie_explorer loaded at 016E0000h - 0171D000h
foo_uie_trackinfo loaded at 01740000h - 01773000h
foo_ui_columns loaded at 017A0000h - 0183A000h
foo_ui_std loaded at 01860000h - 018B7000h
foo_unpack loaded at 018E0000h - 0190E000h
foo_utils loaded at 01930000h - 01969000h
CLBCATQ loaded at 76FD0000h - 7704F000h
COMRes loaded at 77050000h - 77115000h
VERSION loaded at 77C00000h - 77C08000h
dciman32 loaded at 73BC0000h - 73BC6000h
amip loaded at 074C0000h - 0766A000h
WS2_32 loaded at 71AB0000h - 71AC7000h
WS2HELP loaded at 71AA0000h - 71AA8000h
DSOUND loaded at 73F10000h - 73F6C000h
WINMM loaded at 76B40000h - 76B6D000h
wdmaud loaded at 72D20000h - 72D29000h
WINTRUST loaded at 76C30000h - 76C5E000h
CRYPT32 loaded at 77A80000h - 77B14000h
MSASN1 loaded at 77B20000h - 77B32000h
IMAGEHLP loaded at 76C90000h - 76CB8000h
msacm32 loaded at 72D10000h - 72D18000h
MSACM32 loaded at 77BE0000h - 77BF5000h
midimap loaded at 77BD0000h - 77BD7000h
KsUser loaded at 73EE0000h - 73EE4000h
asycfilt loaded at 708F0000h - 70903000h
DBGHELP loaded at 59A60000h - 59B01000h
Stack dump analysis:
Address: 01741D6Eh, location: "foo_uie_trackinfo", loaded at 01740000h - 01773000h
Address: 0176B2ECh, location: "foo_uie_trackinfo", loaded at 01740000h - 01773000h
Address: 0175CDDBh, location: "foo_uie_trackinfo", loaded at 01740000h - 01773000h
Address: 017CFF68h, location: "foo_ui_columns", loaded at 017A0000h - 0183A000h
Address: 01817324h, location: "foo_ui_columns", loaded at 017A0000h - 0183A000h
Address: 01744F00h, location: "foo_uie_trackinfo", loaded at 01740000h - 01773000h
Address: 0040BF7Bh, location: "foobar2000", loaded at 00400000h - 004DC000h
Address: 0040BF88h, location: "foobar2000", loaded at 00400000h - 004DC000h
Address: 00BAF00Ch, location: "foo_browser", loaded at 00B80000h - 00BB7000h
Address: 0049550Fh, location: "foobar2000", loaded at 00400000h - 004DC000h
Address: 017B9A97h, location: "foo_ui_columns", loaded at 017A0000h - 0183A000h
Address: 01803A52h, location: "foo_ui_columns", loaded at 017A0000h - 0183A000h
Address: 01816DF4h, location: "foo_ui_columns", loaded at 017A0000h - 0183A000h
Address: 018025BAh, location: "foo_ui_columns", loaded at 017A0000h - 0183A000h
Address: 017BFF3Fh, location: "foo_ui_columns", loaded at 017A0000h - 0183A000h
Address: 01816DBCh, location: "foo_ui_columns", loaded at 017A0000h - 0183A000h
Address: 018252C4h, location: "foo_ui_columns", loaded at 017A0000h - 0183A000h
Address: 01010004h, location: "foo_input_monkey", loaded at 00FD0000h - 01013000h
Address: 017D0D1Eh, location: "foo_ui_columns", loaded at 017A0000h - 0183A000h
Address: 017C5F67h, location: "foo_ui_columns", loaded at 017A0000h - 0183A000h
Address: 77D48BB1h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowThreadProcessId" (+00000159h)
Address: 0180D064h, location: "foo_ui_columns", loaded at 017A0000h - 0183A000h
Address: 00E30126h, location: "foo_dumb", loaded at 00E30000h - 00E8F000h
Address: 01803AF4h, location: "foo_ui_columns", loaded at 017A0000h - 0183A000h
Address: 017D0DD0h, location: "foo_ui_columns", loaded at 017A0000h - 0183A000h
Address: 017D0D8Eh, location: "foo_ui_columns", loaded at 017A0000h - 0183A000h
Address: 77D48709h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDC" (+00000072h)
Address: 77D487EBh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDC" (+00000154h)
Address: 00AD4790h, location: "foo_amipwrapper", loaded at 00AD0000h - 00AF6000h
Address: 77D70494h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetClipboardFormatNameA" (+0000014Fh)
Address: 77D48808h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDC" (+00000171h)
Address: 77D4D3BBh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetTopWindow" (+0000024Ch)
Address: 77D484BCh, location: "USER32", loaded at 77D40000h - 77DD0000h
Address: 77D48564h, location: "USER32", loaded at 77D40000h - 77DD0000h
Address: 77D4B2A1h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+000000BCh)
Address: 77D4B23Ch, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+00000057h)
Address: 014C006Fh, location: "foo_psf", loaded at 014B0000h - 01593000h
Address: 77D4B258h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+00000073h)
Address: 017D0746h, location: "foo_ui_columns", loaded at 017A0000h - 0183A000h
Address: 77D4B378h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+00000193h)
Address: 77D488A9h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowLongW" (+0000002Bh)
Address: 77D488B2h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowLongW" (+00000034h)
Address: 77D489A5h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowLongW" (+00000127h)
Address: 004C87F8h, location: "foobar2000", loaded at 00400000h - 004DC000h
Address: 004AD668h, location: "foobar2000", loaded at 00400000h - 004DC000h
Address: 77D489C8h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowLongW" (+0000014Ah)
Address: 77D489E8h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DispatchMessageW" (+0000000Fh)
Address: 0042A497h, location: "foobar2000", loaded at 00400000h - 004DC000h
Address: 77D4E666h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DestroyWindow" (+00000000h)
Address: 00D4E666h, location: "foo_dbsearch", loaded at 00D10000h - 00D6C000h
Address: 0042AF1Ah, location: "foobar2000", loaded at 00400000h - 004DC000h
Address: 7C9106ABh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+000000D7h)
Address: 004AD734h, location: "foobar2000", loaded at 00400000h - 004DC000h
Address: 004AC600h, location: "foobar2000", loaded at 00400000h - 004DC000h
Address: 00400000h, location: "foobar2000", loaded at 00400000h - 004DC000h
Address: 004AE828h, location: "foobar2000", loaded at 00400000h - 004DC000h
Address: 004CD1A0h, location: "foobar2000", loaded at 00400000h - 004DC000h
Address: 7C910732h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+0000015Eh)
Address: 7C90EE18h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "strchr" (+00000117h)
Address: 7C911538h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "wcsncpy" (+00000AA9h)
Address: 7C911596h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "wcsncpy" (+00000B07h)
Address: 7C9106EBh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 004CD280h, location: "foobar2000", loaded at 00400000h - 004DC000h
Address: 004A18E4h, location: "foobar2000", loaded at 00400000h - 004DC000h
Address: 7C910570h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+00000133h)
Address: 7C91056Dh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+00000130h)
Address: 7C917CB7h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlReAllocateHeap" (+000002BAh)
Address: 7C917BF5h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlReAllocateHeap" (+000001F8h)
Address: 7C917BB0h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlReAllocateHeap" (+000001B3h)
Address: 1000D533h, location: "shared", loaded at 10000000h - 1002A000h
Address: 1000D469h, location: "shared", loaded at 10000000h - 1002A000h
Address: 10003AB0h, location: "shared", loaded at 10000000h - 1002A000h
Symbol: "t_font_description::g_from_font" (+00000030h)
Address: 10003ABEh, location: "shared", loaded at 10000000h - 1002A000h
Symbol: "t_font_description::g_from_font" (+0000003Eh)
Address: 7C911B09h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlLogStackBackTrace" (+00000025h)
Address: 004CD210h, location: "foobar2000", loaded at 00400000h - 004DC000h
Address: 004813A4h, location: "foobar2000", loaded at 00400000h - 004DC000h
Address: 7C9106F0h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+0000011Ch)
Address: 00480EB5h, location: "foobar2000", loaded at 00400000h - 004DC000h
Address: 004AD480h, location: "foobar2000", loaded at 00400000h - 004DC000h
Address: 10002D77h, location: "shared", loaded at 10000000h - 1002A000h
Symbol: "uPrintCrashInfo_SetDumpPath" (+000000B7h)
Address: 0049D48Bh, location: "foobar2000", loaded at 00400000h - 004DC000h
Address: 0042B0F4h, location: "foobar2000", loaded at 00400000h - 004DC000h
Address: 004CA288h, location: "foobar2000", loaded at 00400000h - 004DC000h
Address: 00486E75h, location: "foobar2000", loaded at 00400000h - 004DC000h
Address: 00481239h, location: "foobar2000", loaded at 00400000h - 004DC000h
Address: 00481233h, location: "foobar2000", loaded at 00400000h - 004DC000h
Address: 004A18E8h, location: "foobar2000", loaded at 00400000h - 004DC000h
Address: 004A0CE5h, location: "foobar2000", loaded at 00400000h - 004DC000h
Address: 00486560h, location: "foobar2000", loaded at 00400000h - 004DC000h
Address: 0049D66Dh, location: "foobar2000", loaded at 00400000h - 004DC000h
Address: 00485445h, location: "foobar2000", loaded at 00400000h - 004DC000h
Address: 7C816D4Fh, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "RegisterWaitForInputIdle" (+00000049h)
Address: 7C8399F3h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "FindAtomW" (+00000094h)
Address: 7C816D58h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "RegisterWaitForInputIdle" (+00000052h)
Address: 004854AEh, location: "foobar2000", loaded at 00400000h - 004DC000h
Address: 004B0063h, location: "foobar2000", loaded at 00400000h - 004DC000h
Address: 003D006Eh, location: "DockShellHook", loaded at 003D0000h - 003DC000h
Address: 003D0065h, location: "DockShellHook", loaded at 003D0000h - 003DC000h
Address: 00410072h, location: "foobar2000", loaded at 00400000h - 004DC000h
Version info:
foobar2000 v0.9
UNICODE
Additional info:
Shorten decoder 0.4.2a (foo_input_shorten)
Monkey's Audio decoder 2.0 (foo_input_monkey)
Track info panel 0.1 (foo_uie_trackinfo)
Converter 1.0 (foo_converter)
Game Emu Player 1.3 (foo_gep)
freedb tagger v0.5.1 (foo_freedb2)
Explorer Tree 1.04.6 (foo_uie_explorer)
Database search 1.3.1 beta 11 (foo_dbsearch)
Album list panel 0.2.1 beta 3 (foo_uie_albumlist)
MPEG-4 AAC decoder 2.1 (foo_input_std)
DUMB module decoder 0.9.7 (foo_dumb)
Columns UI 0.1.3 pre-alpha 17v6 (foo_ui_columns)
Default User Interface 0.9acc (foo_ui_std)
ZIP/GZIP reader 1.0 (foo_unpack)
RAR reader 1.1 (foo_unpack)
Album Art Panel 0.150 (foo_uie_albumart)
Common services 0.1 (foo_common)
ReplayGain Scanner 2.0 (foo_rgscan)
Standard input array 1.0 (foo_input_std)
Highly Experimental 2.0.5 (foo_psf)
Playlist Manager 1.0 (foo_playlist_manager)
LPCM <--> delta-PCM converter 0.1.1 (foo_dsp_delta)
Playback statistics 1.0 (foo_playcount)
CD Audio decoder 2.0 (foo_cdda)
Music Browser 1.0.9 [Mar 30 2006 - 19:07:07] (foo_browser)
On-Screen Display GDI+ 1.52 (foo_osd)
Playlist tools 0.5.6 (foo_utils)
Standard DSP array 1.0 (foo_dsp_std)
MIDI synthesizer host 1.6 (foo_midi)
Masstagger 1.5 (foo_masstag)
Shell link resolver 1.1 (foo_lnk)
FLAC decoder 1.1.0 (foo_input_std)
ABX comparator 1.3 (foo_abx)
Album List 3.1.0 (foo_albumlist)
AMIP Wrapper 0.90 (foo_amipwrapper)
