Topic: Foobar Gallery (Read 1809259 times) previous topic - next topic
Foobar Gallery
Reply #2000
how did you manage to get this horizontal blend effect, especially in the top (or bottom) frame? Thanks
Foobar Gallery
Reply #2001
my foobar theme
screenshot
download theme
[span style='font-size:8pt;line-height:100%']moderation: please refrain from inlining images larger than roughly 800x600 and 80KB. please use thumbnails and/or links for large pictures instead.[/span]
Foobar Gallery
Reply #2002
whoa.
is that for foo_looks?
Foobar Gallery
Reply #2003
whoa.
[a href="index.php?act=findpost&pid=358268"][{POST_SNAPBACK}][/a]
yes
Foobar Gallery
Reply #2004
Top or bottom frame?
Blending was basically done using transition with the █ character before and after the text.
Here's an example of where the various artists column is used. I don't have a CD cover for it yet:
[a href="http://img502.imageshack.us/my.php?image=untitled3mf.jpg][/url]
Foobar Gallery
Reply #2005
With top or bottom frame I mean the green line that turns into a black line in the end of the column (see screenshot)
Foobar Gallery
Reply #2006
my foobar theme
screenshot
download theme
Great work!
Would it be possible to add support for track info from stream radio? Works in foobar: not sure if it's a foo_looks problem or something that can be fixed in your code...
Alessandro
Foobar Gallery
Reply #2007
[a href="index.php?act=findpost&pid=358316"][{POST_SNAPBACK}][/a]
Oh, that! Heh heh, I'm very pleased with how that turned out. See, it doesn't change colors. It's one solid color (same as the background behind the text). It just appears to change color because of the surrounding colors. Just like in the below picture. The left is black, the middle is 50% gray (128,128,128) and the right is white. The dots are all the same shade of blue and you can see that they are by the lines that connect them:
Foobar Gallery
Reply #2008
Alessandro
I think it`s possible but now i`d how =)
i solved this task
Foobar Gallery
Reply #2009
my foobar theme
screenshot
download theme
[a href="index.php?act=findpost&pid=358257"][{POST_SNAPBACK}][/a]
WOW! NOW That is unique! Everyone else is busy with the main foobar window, but here is someone who kicked the main window out of the stage! Great job!
Only problem that the bar is not expandable horizontally. Also the playlist must expand horizontally according to how much the bar is expanded. The user should be able to expand the playlist vertically.
An additional ability to show lyrics (from LYRICS tag) will be appreciable.
It will be really helpful to someone like me with large playlists and huge laptop resolution. It would also be helpful if I could edit the way playlist items are displayed, and turn off seeking in the seek bar. That is. it should always show how much a song is played, but user shall be able to choose where clicking/dragging on it will let him seek through the song. (I get so irritated by accidental clicks and restarting of song in between)
(signed)
ADTC
send2adtc AT gmail DOT com
Foobar Gallery
Reply #2010
my slightly modified old set-up to go with hl2 visual style (heavily modded by me):
[span style='font-size:8pt;line-height:100%']animated gif, 292kB
resolution 1920 x 1200[/span]
Foobar Gallery
Reply #2011
...back again...I pretty much only changed my VS (from Luna Element to self-modded Royale Vista) and the buttons to a self-modded "Smoke Special Mini" (the colors change on hover).  The sidebar is hidden (as shown in the pics).
hidden sidebar:
sidebar showing:
Foobar Gallery
Reply #2012
[a href="index.php?act=findpost&pid=358777"][{POST_SNAPBACK}][/a]
oh my god! plz share your .fcs!
Foobar Gallery
Reply #2013
hidden sidebar:
sidebar showing:
[a href="index.php?act=findpost&pid=358780"][{POST_SNAPBACK}][/a]
That's a nice background pic. Nice foobar design, too. Nice and simple.
Foobar Gallery
Reply #2014
resolution 1920 x 1200[/span][a href="index.php?act=findpost&pid=358777"][{POST_SNAPBACK}][/a]
oh my god! plz share your .fcs![a href="index.php?act=findpost&pid=358820"][{POST_SNAPBACK}][/a]
it's Lyx's Navigator suite, version 1.00 with some stuff from version 1.02 and little changes to suit some of my needs.
Foobar Gallery
Reply #2015
hidden sidebar:
sidebar showing:
Care to share your fcs? Looks fab.
Foobar Gallery
Reply #2016
My foobar2000 0.83
[a href="index.php?act=findpost&pid=357530"][{POST_SNAPBACK}][/a]
Could you share the fcs? And what font is that?
Foobar Gallery
Reply #2017
hidden sidebar:
  [a href="http://s21.yousendit.com/d.aspx?id=1DE7NNQGSZY730W0P2RJN1UTGW" target="_blank"]http://s21.yousendit.com/d.aspx?id=1DE7NNQ...730W0P2RJN1UTGW
Foobar Gallery
Reply #2018
[a href="http://mazy.johanka.cz/my_pics/temp/foobar/foobar-mazy-2006-01-21-animated.gif" target="_blank"]
Foobar Gallery
Reply #2019
my foobar theme
screenshot
download theme
[a href="index.php?act=findpost&pid=358717"][{POST_SNAPBACK}][/a]
foo_looks has been around for a while, and is all about that which you're talking about. But sure, it's a nice skin.
Foobar Gallery
Reply #2020
Here is my foobar2000
Foobar Gallery
Reply #2021
[a href="index.php?act=findpost&pid=358988"][{POST_SNAPBACK}][/a]
Nice setup. I love that album! My friend let me borrow it and my favorite song is Float On, and then The World At Large. I found out that I live about 10 miles from where Modest Mouse started.
Foobar Gallery
Reply #2022
Idec Sdawkminn: you have some very good tastes.
I have a question, when a file is not well tagged, i have a black color like in this picture. Does someone knows where to change it???
Foobar Gallery
Reply #2023
Hi, Now these are awesome skins you have made! I am all new to foobar and am overwhelmed by all the docs and the wiki and so on. Did any of you make, or consider make a step by step guide how to make some similar looks for newbies like me?
Foobar Gallery
Reply #2024
front243: I suppose it is quite a bit of work to get columns_ui to look like some of the ones shown in this thread.  The best first place to get a quick set-up is the columns_ui FAQs.  Read that and play around, then ask more specific questions and play around some more.
