Topic: foo_vis_spectrum_analyzer (Read 106015 times) previous topic - next topic
Re: foo_vis_spectrum_analyzer
Reply #475
With 2-channel stereo, no peak indicator is displayed in the right channel.
Thanks for your great work!
Reply #476
Confirmed. But only when vertically stacked. I'll investigate.
Reply #477
Testing rc3. Upgraded from beta 2 to rc3. It had issues with the beta2 layout it inherited. In my best laymans guess, it looked like it wasn't correctly rendering elements that had opacity less than 100% 🤷 I used the reset button, the issues persisted. I removed the component's UI element and readded it, which seemed to resolve the issue.
There does seem to be a bug with the reset button. To reproduce: context menu > configure > Styles > Click reset button. The configure modal window will flash, then if you go back to the styles section you'll see the list of styles has a duplicate list of entries. You can keep doing this behavior and the list of styles will keep incrementing a duplicate list indefinitely.
Reply #478
v0.7.1.0, 2024-02-29
* Changed: To avoid confusion color source None for the background has been disabled until it can be properly implemented.
* Fixed: Reversing the colors of a gradient did not recalculate the position of the colors. Instead it spread out the colors evenly.
* Fixed (Regression): The peak indicators on the bar graph weren't rendered.
You can download it from Components repository or upgrade from within foobar2000.
Reply #479
As you can see, I just released 0.7.1.0. I'll look into it.
Reply #480
It's just a bug in the dialog. The listbox is not cleared before it's filled again. The style entries are still uniquely defined. I'll release a point release after the inevitable release bug reports have come in.
Any more details on the opacity problem: which element? Which opacity value?
Reply #481
Unfortunately no, and those assertions were just my best guess, I could be wrong about what aspect of the rendering was dysfunctional. In retrospect I should have recorded a short clip which I will do going forward if I encounter issues like that.
Reply #482
Thank you for v7.1.0.
Unfortunately the Xaxis text is broken.
Reply #483
I'm unable to reproduce this. I tried different settings and different scaling functions, even with linear scaling like you seem to use.
Reply #484
I have just noticed that the text is OK with a separate Spectrum for the right and left channels, but not with a Spectrum that contains both stereo channels!
After resetting and setting up the settings again, the problem occurs again...
Reply #485
Your right picture: if the settings are:
- Distribution: Linear
- Scaling: Linear
- X-axis: Decades
then everything is working as designed.
Reply #486
Testing 0710 release after having stuck with 0600.  I noticed a bug in 0710's bar spectrum color scheme display--when Prism 1 is selected, although the gradient in the dialog shows red on top and dark blue on bottom, as it does in version 0600, during actual playback red is on the bottom of the bars and dark blue at the top.  See attached images.
You could say "well just hit the "Reverse" button in 0710 to correct it," but this produces a display visually unlike the correct rendition in 0600 (blue range becomes too indistinct towards the bottom).
Hopefully this was just an oversight and would be an easy fix?
Reply #487
You're right. That's because the graph is now rendered upside down and then flipped, unless the user selects "Flip Vertically". Sounds confusing but mathematically it makes sense.
I'll reverse the colors before creating the brush. That way the GUI stays consistent.
Reply #488
- Scaling: Linear
- X-axis: Decades
Unfortunately, it doesn't look any better for me with this setting...
Maybe it's because of CUI , or because I have two instances installed? I'm at a loss...
Reply #489
- Scaling: Linear
- X-axis: Decades
You understood me wrong: why are you using linear Scaling mode? Most spectrum analyzers use Logarithmic by default.
Reply #490
Yes, I misunderstood that, sorry. If I set Scaling to Linear, the text scale is displayed correctly. Thank you!
I had used the same settings for both Spectrums. Strangely enough, this led to a completely different result for the Spectrum with both stereo channels.
Reply #491
great, the freezing has been fixed... for non-fullscreen mode... sorry to say this, but this component is a bugfest
Reply #492
You know ... It's beta. And it is called beta for a reason. Nobody requires you to install it and expose yourself to bugs.
Reply #493
Great! Looking forward to your bug reports so that I can fix them. Oh, wait,... you're just whining...
Reply #494
Unfortunately I have another bug report for 0710.  When the X-axis frequency scale (distribution linear, scaling logarithmic) is set for an upper limit past about 24 kHz, instead of an expected fall-off before that point, a space/"notch" appears and frequency bars start appearing again where none should be.  In version 0600, this does not happen--a fall-off occurs and then no more activity is shown.  This is with normal music, not a test wave, etc.  The images below aren't from the the same exact moment but are representative of an entire song.  They show the X-axis set for 26 kHz max, first from 0600 and then 0710:
Reply #495
Did you disable the "Common / Suppress mirror image" flag? It was a feature request to show the amplitudes of frequencies above the Nyquist frequency. Default is to suppress the mirror image.
Reply #496
That was it, thank you!  BTW, on my install of 0710 the option to "Suppress mirror image" was un-checked by default.
Edit:  the reversed gradient color bars with Prism 1 issue is indeed fixed with github release 0720-alpha 1, great.  Just installed it on top of 0710 and so far all is well.
Reply #497
for @pqyt does it make sense to have default settings of this component having the same color gradient, foreground and background colors as fb2k's built-in spectrum visualization something like this(this YT video shows the colorscheme matching the fb2k built-in Spectrum in dark mode, but this color scheme depends on the current DUI/CUI colorschemes just like built-in visualizations in foobar2000) instead of a custom gradient one like the original foo_musical_spectrum?
Reply #498
The color schemes are in there but I'm not a fan of making them the default.
Reply #499
^When the color scheme is "Artwork" and a track does not have an album cover, the color scheme of the graph will be different from the color scheme of other layout elements.
In this case, I think it makes sense to define a default color scheme (i.e. when there is no cover).
