Topic: Default UI Gallery (Read 748303 times) previous topic - next topic
Re: Default UI Gallery
Reply #601
I probably should distribute a bottom panel like that with JSP3 itself. I've been too lazy to incorporate a volume slider in the current track info/seekbar/buttons scripts.
Yes, that would be an interesting addition. Of course, you can complete anything as basic as this in no time.
But if you don't have the time, here is the script I use. As you know, I'm a newbie, and there must have been a joke line code in the script.
eurekagliese, looks good!
Thank you, and thank you for your Flags script, which I could learn from along with the JSP samples.
Thanks for the tip seperating shuffle/repeat buttons!
Reply #602
Thank you so much that's perfect eurekagliese
Updated my layout and its perfect now minus album art viewer from Refacets instead of coverflow obviously
PC - Teac UD-505 - Adam Audio A4V - DCA ÆON Open X
Samsung S23 Ultra 512GB - Fiio UTWS5 - TinHifi P1 Max.
Reply #603
@eurekagliese
JSPlaylist:
Enable Dynamic is valid only during playback
Enable Dynamic only when Now Playing:
Can you add an enable/disable option?
Now Playing
Stop
SHURE SRH1840, SENNHEISER HD660S2, SENNHEISER HD 490 PRO, DT 1990 PRO, HiFiMAN Edition XS, Bowers & Wilkins P7, FiiO FT5, 水月雨 (MOONDROP) 空鳴 - VOID, Nakamichi Elite FIVE ANC, SONY WH-ULT900N (ULT WEAR) (made a Upgrade/Balanced Cable by myself)
Re: Re: Default UI Gallery
Reply #604
Thank you; in fact, I was inspired by the Elia theme, which resembles Spotify.
By the way, your Vibe theme is also really good, clean and elegant.
Reply #605
@eurekagliese
JSPlaylist:
Now Playing
Stop
Actually you can just simply switch the uncomment line 966 to
	// var metadb = fb.GetFocusItem();
var metadb = fb.GetNowPlaying();
Reply #606
Great.
Reply #607
X
Reply #608
X
Reply #609
So my theme end up as below (with JScript Panel 3)
Reply #610
Here is my humble DUI configuration (v2.1 preview 2023-08-28 32-bit).
Reply #612
Nice and clean, mate.
Is that the default playlist view? How do you colour that love icon?
Yup, it's default playlist view, and the 'Love' icon is from unicode character. The following is my custom column.
$ifequal(%rating%,5,>>>$char(10084)<<< , )
Reply #613
Sorry for the late reply.
I had no idea that >>> could modify the highlight colour of a field.
It increased visibility and allowed me to experiment with some of the custom column patterns, no matter how long I've used fb2k, it feels like I'm always getting an easter egg.
Thank you very much!
Reply #614
This the current version 3.0 of my Foobar2000 UltraWide DUI Dark Theme, to achieve the total black I patched and then installed a Windows Theme (as in this sub adviced to do) called "Fluent" by Niivu. I searched a lot for a theme that match with the "dark & blue" palette that I have for a long time.
Components shown:
- Album Art
- Deskband Controls
- JScript Panel 3 + JS Playlist
- Library Tree with 3 panels with support for Last.fm "love button"
- On-Screen Display
- OpenLyrics
- Shpeck with MilkDrop 2 for Visualizations
- Spectrum Analyzer
- Spider Monkey Panel with Biography script
- Text Display
- Waveform Minibar (mod)
I can share the presets to use 3 columns with JScript Panel or the slight modifications I made in JS Playlist.
Have you tried turning it off and on again??
Reply #615
For those who are interested, you can download each script config here 😉👍‍
Reply #616
Reply #618
Made the switch to 64-bit and I'm back to default UI elements only. A bit of status bar abuse going on to display metadata that I would have placed on a second grouping level in SimPlaylist, which I finally decided to let go of.
Reply #619
This is my layout for foobar2000 v2.0 x64:
X
This above have foo_enhanced_spectrum_analyzer (which I have waiting for an update on this spectrum analyzer component that adds octave bands mode like in foo_vis_spectrum_analyzer) on it that I have installed on a Windows 10 laptop
Reply #620
It is simply AMAZING the amount of flexibility f2k provides. I've used it for years, but haven't even remotely tried some of the more customized layouts that many have. My DUI config is still stuck (for now) on v1.6. I've been messing around with Georgia-ReBorn which is, of course, not a DUI theme.
Anyway, here's what my daily driver has looked like for a while . . .
Reply #622
December's here and I'd like to share this theme. I've added some more features to the custom track script.
If you want to try it out, simply import the.fth layout or just copy and paste the updated Custom Track script below into your existing panel.
Components used:
- JScript Panel 3
- Playback Statistics
- OpenLyrics (Optional)
- Last.fm Playcount Sync (Optional)
Required fonts:
- Material Icons Round font
https://github.com/google/material-design-icons/blob/master/font/MaterialIconsRound-Regular.otf?raw=true
- Segoe Fluent Icons font
https://download.microsoft.com/download/8/f/c/8fc7cbc3-177e-4a22-af48-2a85e1c5bffb/Segoe-Fluent-Icons.zip
Reply #623
@eurekagliese
Track Info + Seekbar + Buttons (Custom Track 3.0.js)
Nice!
You still have good taste.
Time passes quickly when you get absorbed in editing.
