Topic: HowTo .dsf --> .flac (Read 5018 times) previous topic - next topic
Re: HowTo .dsf --> .flac
@Pocus
I haven't found a way to create a dsf with DST for me.
When I convert the dff to dsf format, it is unpacked and is back to its old size.
(By the way, simply renaming doesn't work either.)
@Pocus
Beats me, but for what it is worth: Tried the utility on the bottom of https://www.signalyst.com/professional.html ?
Is that really just the noise filter?
Yes.
Source was DSD64.
Here is example of spectrogram after ffmpeg -af "aresample=96000:resampler=soxr:precision=28, lowpass=f=30000":
sox rate -v 96000 sinc -30k
ffmpeg -f lavfi -i "sinc=r=96000:lp=30000, pan=stereo|c0=c0|c1=c0" -lavfi "aresample=96000:resampler=soxr:precision=28, afir=gtype=none"
@Porcus
OK. The conversion from .dff to .dsf only works with DSD data. DST packed .dff will not be accepted.
This doesn't shrink the file.
@Bogozo
Thanks for the presentation. Wow. I would not have thought that.
I have now converted the files to .flac.
2 variants are possible.
What is better ?
Version 1: 16bit 352800kHz --> generates a bitrate of 15.2Mb/s
Version 2: 24bit 192000khz --> generates a bitrate of 7728kb/s
Reply #30
Both are a waste of space. The conversion will never be lossless, so you should aim for a smaller size instead.
If you're still going to use FLAC, I suggest 16-bit 48 kHz.
Thanks Octocontrabass.
OK. I will do it in practice. But in theory. What would be better. Small bit depth, high sample rate and the resulting high bit rate, or the other version.
"Better" is a matter of opinion, as in most things audio.  The only way to find out is ABX (ie a blind listening test where you don't know what source you are listening to at the time and score it without psychological bias), and different listeners might well come up with a different answer.
It's your privilege to disagree, but that doesn't make you right and me wrong.
