Topic: LA NOIRE 64-bit Columns UI theme (Read 10302 times) previous topic - next topic - Topic derived from Columns UI appearance
Re: LA NOIRE 64-bit Columns UI theme
Hi :)
wrong folder name.
Standard installation
Profile → foobar2000-v2
Rename it to "profile" yourself if you want to use it in a Portable installation.
Or rewrite Read me.txt for portable installation.
Also, the version of Read me.txt
#   La Noire     #     F2K Theme 64bits  #  Version 0.2
#   La Noire     #     F2K Theme 64bits  #  Version 0.45
SHURE SRH1840, SENNHEISER HD660S2, SENNHEISER HD 490 PRO, DT 1990 PRO, HiFiMAN Edition XS, Bowers & Wilkins P7, FiiO FT5, 水月雨 (MOONDROP) 空鳴 - VOID, Nakamichi Elite FIVE ANC, SONY WH-ULT900N (ULT WEAR) (made a Upgrade/Balanced Cable by myself)
LA NOIRE V0.5 64-bits FB2k : https://mega.nz/file/ad9kxDoS#2891GFZyBpUNs9p_UfVA8MoUZuLesILH2YuU3TO7Qvo
- Read me small correction .
- Add Guide.jpg missing . ( Instruction for adding new Radio Station ) .
I don't see any icons or buttons.
Is it possible that something is missing, like an images folder or specific fonts?
maybe You need the  Font Awesome (ttf version): https://fontawesome.com
I think the samples folder with the .js scripts is also missing
In fact I have a whole series of errors.
I have the fonts fontawesome.com for my skin:
Font:
https://foobar2000.xrea.jp/up/files/up1526.zip
MaterialIconsRound-Regular
Segoe Fluent Icons
https://foobar2000.xrea.jp/?Skins+%2864bit+compatible%29#u67baf32
[/quote
Yes yes . I have to add this to the read me .
Thanks you
Made line 31 inactive 31 topbar.js
profile\user-components-x64\foo_jscript_panel3\samples\jsplaylist\
//         gr.DrawImage(this.logo, this.x, this.y, this.h, this.h, 0, 0, this.logo.Width, this.logo.Height);
LA NOIRE V0.52 for F2K 64-bits : https://mega.nz/file/bZMAWCZY#e9IgqPiUJ1AUU77KAwB6wHlW3rr6PA6CIQWUbJ9mf2A
- Add Button for Radio Search  ( left panel ) .
- Add Button for quick add location ( left panel ) .
- Add Button for Refacets ( left panel ) .
          in the hope that Refacets can finally make it possible to visualize album covers and also adds dynamic colors .
          Maybe soon  :D  :D  :D
The included fonts are already installed, but some icons are not displayed as shown in the attachment.
How can I display them?
i will make an update to see this problem . a new version is coming soon.
Thank you for the update.
But the hidden icons did not change as attached. I did a clean install and it was the same. If it is because the cache is still there, how can I delete it?
PS
The image URL I entered is not reflected, so I have included it.
https://imgur.com/a/Zsh7WOq
Try
JScript Panel 3
https://github.com/jscript-panel/release/releases
FontAwesome
Air KEN, thanks!
I solved the problem by installing fontawesome-webfont!
Thanks Jul2323 for following up on things as well.
PS
In my environment, after installing JScript Panel 3, the upper and left navigations became unresponsive,
so I am reverting back to the original.
How can I hide the top bar foobar2000? Thanks!
How can I enable the Media Library? Tanks
I already solved it, the app 64 bit and theme are great. Thanks
Thanks a lot . I will make an update soon with more features
Haven't been here in awhile but wanted to say thank you for the great theme for 64bit didn't think I would find one. It having a red skin and turntable is the icing on the cake. I will be using this for awhile.
