Topic: Toogle button (Read 1589 times) previous topic - next topic
Re: Toogle button
You can monitor the "stop after current" status like this:
#include "foobar2000/SDK/config_object_impl.h"
auto f_on_changed = [](const service_ptr_t<config_object>& conf_obj) {
  auto status = conf_obj->get_data_bool_simple(false);
  FB2K_console_formatter() << "stop after current is " << (status ? "set" : "not set");
static config_object_notify_simple_factory g_stop_after_current_monitor(standard_config_objects::bool_playlist_stop_after_current, f_on_changed);
This will write the current status of "stop after current" to the console. Depending on your project settings you might need to adjust the path for the include.
Re: Toogle button
The toolbar button monitors the status of stop after current already. I want to monitor status of Stop after album in button toolbar. I think it's impossible for DUI.
The monitoring for "stop after album" can be done by replacing standard_config_objects::bool_playlist_stop_after_current with guid_cfg_menu_stopalbum_enabled in the code above, but I don't see any possibility to visualize it in the button toolbar.
Re: Toogle button
Looks possible with the Columns UI SDK...
 * \brief Identifies the state of a button.
 * Combine multiple flags using bitwise or.
 * \see button::get_button_state
enum t_button_state {
    /** The button is enabled */
    BUTTON_STATE_ENABLED = (1 << 0),
    /** The button is in an active state */
    BUTTON_STATE_PRESSED = (1 << 1),
    /** The button displays a ToolTip */
    BUTTON_STATE_SHOW_TOOLTIP = (1 << 2),
    /** The default button state */
    BUTTON_STATE_DEFAULT = BUTTON_STATE_ENABLED | BUTTON_STATE_SHOW_TOOLTIP,
