Topic: [fb2k v2] Last.fm Playcount Sync (Read 7941 times) previous topic - next topic
https://marc2k3.github.io/component/lastfm-playcount-sync/
While this shares the same name as the previous version available for v1.4+, no settings or data is preserved. You have to start fresh.
And the 64bit build really needs a 64bit scrobbler so it's kind of useless at this moment in time! Not even sure why I'm posting tbh.  :D
Re: [fb2k v2] Last.fm Playcount Sync
Hello thanks for the plugin.
After installed the plugin, I got crash on startup. Disable the plugin and my foobar works fine again.
here is my crash logs.
https://cdn.discordapp.com/attachments/290709370600423424/1014389824444190781/crash_reports.zip
I download the old version https://github.com/marc2k3/fb2k-component and it didn't crash.
Not sure what's going on here as I did test everything.
I may have to revert to using old methods from the previous foobar2000-SDK. I had been using the new stuff for a few days but I must be doing something wrong. There's a tiny possibility it's fb2k bugz but it's more than likely me.
Sorry for the inconvenience.  :-[
also, the love/unlove is grey out/disabled for me.
This is because you need to authorise your account.
thank you, it's working great this time.
https://github.com/marc2k3/foo_lastfm_playcount_sync/releases
This adds an extra sanity check to make sure your Media Library is fully initialised before importing loved tracks. The menu item will be greyed out if it's not ready. This in addition to being unavailable when your Media Library has not been configured or you haven't set a user name.
Sorry but I don't have the v1 source code so I can't investigate it. It was last updated in 2020 and it's the only folder missing from the old source code archive I keep for other components: https://github.com/marc2k3/fb2k-archive
I think you'll have to nuke it from orbit. Or just uninstall - whichever is easier.  :P
If you're willing to install fb2k v2 in portable mode, you can test this console spamming album total build I made (32bit only). You can play the tracks with the biggest discrepancies you get with enhanced playcount to see what last.fm says??
Ok I installed the version of the plugin you linked (in the foo_enhanced_playback thread). The console stats look accurate as far as I can tell. The only thing throwing some of them off is the arbitrary use the ` and ' character in track titles (which on my end get changed by foo_musicbrainz). Here's an example.
Raw Last.fm playback stats in CSV where artist is Coldplay and track is Don['’|t Panic.
Artist, Album, Track title, Play count, First played, Last played
Coldplay,, Don't Panic, 20, 1/24/2006  7:02:00 PM, 11/6/2013  7:43:00 AM
Coldplay, Blue Room, Don't Panic, 31, 8/24/2006  7:36:00 AM, 8/11/2014  3:53:00 PM
Coldplay, Blue Room, Don’t Panic, 6, 2/25/2018  9:02:00 AM, 4/28/2022  3:17:00 PM
Coldplay, Garden State, Don't Panic, 20, 1/24/2006  7:02:00 PM, 11/6/2013  7:43:00 AM
Coldplay, Garden State: Music from the Motion Picture, Don’t Panic, 1, 2/25/2018  9:09:00 AM, 2/25/2018  9:09:00 AM
Coldplay, Parachutes, Don't Panic, 40, 8/24/2006  7:52:00 AM, 9/8/2013  9:39:00 PM
Coldplay, Parachutes, Don’t Panic, 3, 2/25/2018  9:08:00 AM, 4/28/2022  3:32:00 PM
Overall total for Don’t Panic is 10.
Overall total for Don't Panic is 133.
I changed the title from Don’t Panic to Don't Panic and these are the results from foo_lastfm_playcount_sync in the console:
Overall total for 'Don’t Panic' by 'Coldplay': 10
Garden State: Music from the Motion Picture - 1
Parachutes - 3
The Blue Room E.P. - 6
Overall total for 'Don't Panic' by 'Coldplay': 133
<album missing> - 42
Blue Room - 31
Garden State - 20
Parachutes - 40
I guess there's a sweet spot here for how specific the matches should be by not matching for punctuation maybe? Though it's not really your problem. It should be Last.fm doing the aliasing but they don't seem to care. I'll probably switch to ListenBrainz when my fav apps have plugins for it.
foo_musicbrainz has pretty much always* had an option for replacing unicode punctuation with asciii. Picard does the same and it's always recommended, especially if scrobbling. The wider world won't be using musicbrainz so you really want your scrobbles to count towards the titles that everyone else is submitting. Too late for you now though.
*the original developer last updated it in 2012 and it was there then. I can't say for sure about the earliest versions. There might be a changelog entry for when it was added but I'm far too lazy to check that out.
Also, it would have more interesting to compare the album groupings returned against the stats by enhanced playcount that appeared way off. That was the prompt for all of this.
Sidenote: I've updated my docs to make the artist/title thing more prominent
Marc2k3, the component Cue.Fix Version 1.02 does not install on Foobar2000 v2 32 bit beta 6.
You can check?
Cardiacs
Thanks for spotting that. The DLLs inside the fb2k-component are fine so if you extract it manually and drag it over the Preferences dialog>Component it should install. 32bit is at the root, 64bit inside the x64 folder.
Something has gone wrong with my github actions script which bundles the component and automates the release. I'll look in to it / get the file replaced ASAP.
edit: file now replaced
Installed and it works
Thanks!!!
Cardiacs
For whatever reason, specifying fb2k-component as the file extension for the 7-zip command line tool (7z) causes fb2k to barf on the result. I'm too lazy to investigate other options that would probably make it work but changing to zip definitely works.
edit: presumably it creates a 7z file and renames that which fb2k can't handle whereas zip is more explicit
edit2: as expected, I'm super stupid and needed to add this: -tzip
Works as expected
slight issue though, if your privacy settings on last.fm is set to "Hide recent listening information" it will not update the playcount.
The console will throw the error
"Last.fm Playcount Sync: Login: User required to be logged in"
sounds like a simple fix since you already have to authorize your account if you want to love/unlove tracks
