Topic: JScript Panel script discussion/help (Read 301203 times) previous topic - next topic
Re: JScript Panel script discussion/help
Reply #850
As above, you're just missing the font.
https://github.com/FortAwesome/Font-Awesome/blob/4.x/fonts/fontawesome-webfont.ttf?raw=true
When present, it should look like this...
https://marc2k3.github.io/jscript-panel/gallery/#track-info-seekbar-buttons
If you want to change the size of the buttons/text easily, you can open the editor and add this at the start of the script..
DPI = 144; //150%
If you wanted double the size, you could use 192. You can play around with the values until you find what is best for you.
Reply #851
Sorry, I figured buttons would be graphic elements not fonts!
It's your privilege to disagree, but that doesn't make you right and me wrong.
Reply #852
Regarding JS Smooth sample, can anyone help me find where to adjust source (playlist instead of library)?
Reply #853
It's not easy. Lots of new code would have to written. Making it read playlist contents instead of  the media library when it initialises is easy enough but you want it to respond to playlist switching, items being added/removed/reordered etc. Also, the sort order is forced in Library mode but you'd want original order preserved as a playlist. Then you have the selection logic to contend with such as making your playlist viewer jump to selection etc.
Pretty sure WilB's Library Tree for SMP does it all with zillions of options not present in Smooth Browser so you should be using that.
Reply #854
ok thanks. It was listed as a feature on Falstaff's old deviant site, but no worries.
Libary Tree bogs down on my collection, while Smooth is still pretty smooth. I'm assuming it is better JSPanel performance over SMP currently.
Reply #855
Yeah it did exist previously but it was quite buggy and rather than fix the bugs, I removed it. I may consider restoring it at a later date but no promises.
As for SMP vs JSP, SMP really should be faster at everything. Not sure what is going on there??
Reply #856
This is a query about the JS Smooth Playlist Manager sample.
Right-click offers a variety of options, but not Save.  I thought I might find (and alter) the list of options in the script, but it imports a load of other stuff and has limited functionality actually within the JS Smooth Playlist Manager script.
Any pointers?
Reply #857
I assume you're talking about Smooth Playlist Manager and not Smooth Playlist?
In theory it would be possible to add a Save item to the menu but it would only be a shortcut to the main menu command which saves the active playlist only. It's not possible to make it respond to the mouse position and save whichever playlist you happen to be right clicking on.
Reply #858
Yes, sorry, have edited.
Better than nothing - how do I go about that?
Reply #859
Right click> save as... https://gist.githubusercontent.com/marc2k3/c980fe6ac21ad6bc7f532c76724a3f42/raw/9c12c335fd53e7c848da03496cc5212a8efeba8b/jsspm.js
Save it inside your foobar2000 profile folder\user-components\foo_jscript_panel\samples\smooth and overwrite the existing file.
edit: restart fb2k if it's running while you do this.
Reply #860
That's great, thank you.  I've just adjusted it to read "Save Active Playlist..." (as a reminder it doesn't necessarily mean the one under the mouse).
Reply #861
I might implement a file picker dialog in the component which would make saving the clicked on playlist possible but of course that will be on my new fangled version, not the abandoned one you're using.  :P
Reply #862
But the specific script might be translocatable?
Reply #863
Nope. The script would be calling a new method built in to the component which is written in C++. While you could look at the script changes, you can't utilise methods that don't exist in your version.
Reply #864
@marc2k3:  You helped me before with a script addition to the spectrogram seekbar sample code that would force auto-deletion of any images in its cache folder every time the script was unloaded:
function on_script_unload() {
utils.ListFiles(spectrogram_cache).toArray().forEach(function (item) {
_deleteFile(item);
Since changing from JScript Panel 2.88 to JScript Panel 3 version 3.03 I find that this addition no longer works.  I'd be most grateful if you could post an updated version of the code addition that does the same for 3.03--thanks a million!
Reply #866
utils.RemovePath(item);
Works perfectly, thank you very much!
Reply #867
I'm using spectrogramm seekbar and I want to say that png files of spectrograms take up too much disk space. There are much more efficient codecs, namely webp, jxl, avif and heic, but at least jpg. Right now there is no choice in which format the spectrogram file will be saved, but I really want it to appear.
Reply #868
ffmpeg generates a png with no choice. I guess I could the read the png, save as jpg and then delete the png. I'll look in to it as an option.
During early development of JSP3, I did toy with the idea of webp encoding but it's too expensive cpu wise. All javascript is running in the main thread and you don't want it blocking.
edit: before anyone says ffmpeg is also blocking, you know it's for a reason.  :P
edit2: or check the post above yours to clear the cache automatically when fb2k exits. Of course that means repeat scanning on every new session.
Reply #869
You're wrong, ffmpeg is able to save the spectrogram in any graphic format, just change the file extension from .png to .jpg or .jxl. Just checked, he can do it. But jpg is an old format with bad compression, jxl is much better, please use it.
If encoding seems too long for you, you can add a secondary script that would create spectrograms for each library file in the background without disturbing the user. Or, let's say the user turned on a new album, a spectrogram in png was created for its first track, when playback reaches the second track, a png spectrogram will be created for the second track, and the picture of the spectrogram of the first track in the background will be compressed into webp or jxl.
Reply #870
I'll stand corrected then. Not sure where I got the png idea from. Perhaps a hangover from using SoX on a previous version. I can't remember.
I'll probably use webp. jxl is too obscure and would require people going out of their way to find a WIC decoder thingy. webp is generally supported out of the box on 10/11 or google provides a download for 7/8/8.1 users.
edit: I've made the changes here: https://github.com/marc2k3/jscript-panel/commit/a01d7024dba35463676798010f69f7343f0a5d49
Reply #871
Whether JXL is "better" depends on your point of view.  JPG and MP3 are de facto standards and universally supported, regardless of whether they represent the pinnacle of compression ratio vs. fidelity.  JXL is obscure, and damned if I'm going to adopt it just to save a few megabytes of disk space.
Reply #872
Thank you for listening to my request. The default webp is of very low quality, you can visually see how bad the new spectrograms look. If you add the ffmpeg options "-lossless 1 -compression_level 6", you get a lossless webp, which is about 1.5 or 1.8 times more compression ratio than png (I personally checked it). But I still prefer jxl for its relentless and unbelievable compression ratio.
The biggest problem with jxl in jscript-panel is that foobar2000 simply doesn't render .jxl images. I changed .png to .jxl on line 233 of seekbar.js as you did in this commit, first a white rectangle is shown on the background of the empty bar for a few seconds, saying that the spectrogram is in the process of being created, and after that a solid black background. The .jxl file is in the folder, but the image doesn't appear in foobar2000.
It is very sad. However, you can store spectrograms on hdd, which is much cheaper and more reliable than ssd. It would be great to add the option "delete older than a month, two, three months", otherwise a week is somehow not enough.
Several megabytes for each file, about 80% of its weight, while the files themselves can be hundreds or thousands.
Reply #873
My component can display jxl files if I do this....
https://github.com/saschanaz/jxl-winthumb#how-to-install
Is there a better way?
Incidentally, ffmpeg seems to barf and not generate any file at all.
Everything is in this image.
https://i.imgur.com/ILhtdZv.png
edit: this is all moot, it's not like I'm changing it for this. I just wanted to show that any program with WIC support *should* work if the relevant codecs are installed.
Reply #874
So of course I was being an idiot trying to run that command in powerhsell without prefixing it with cmd /c. Oops.
But while the file is generated, changing the file extension is seemingly not enough...
But you can edit it to whatever you like (or ignore it).
And now it's working, it's noticeably slower. I guess that "superiority" comes with a price.
