Topic: foobar2000 v2.0 bugs (Read 137988 times) previous topic - next topic
The bugs I found so far appear to be GUI related.
  • Double clicking on a visualization doesn't go to full screen mode.
  • Double clicking with a full screen visualization doesn't exit full screen mode.
  • Exiting full screen mode with a visualization causes it to reshape to the size of the screen and not remember the size and position of where it was last at.
  • Before the open file box pops up (shortcut CTRL + O) any highlighted items in the playlist disappear completely for a brief second before reappearing.
Re: foobar2000 v2.0 bugs
Noted, thanks for reporting.
ReFacets isn't shown in the list of installed media library viewers.
Portable install: the config does't save in portable folder.
This is probably a known issue, but I didn't see it mentioned.
The built in dark color themes (in Quick Setup) have poor visibility of the "arrows" in the media library. They're often not visible unless you hover over them with the mouse pointer:
X
It looks fine if "Dark Mode" is enabled, however.
EDIT: In dark mode, the light colored themes have worse visibility:
X
Open menu shows Add files on the title, Add files shows Open on title. they work as they should.
How did you manage that? It's not optional and is installed for everyone.
If you have multiple installs of v1 and v2, check you launched the right one???
I guess he expected ReFacets to be listed there
It is.  :D
It does here. Maybe you didn't notice, but a fresh portable install now has a "profile" folder. 1.6 didn't have it.
The profile folder for portable installs was introduced with 1.6. It's always there for clean installs.
If you didn't have one, it's because you upgraded from an older version.
Beta 3.
Console UI element doesn't use color settings from "DUI->Colors and Fonts" anymore. Is this intended?
Converter's presets that use *.bat files don't work anymore.
Example of preset:
Text of bat file:
START "sox" /D "C:\Program Files\sox\" /HIGH /WAIT sox.exe %1 -n spectrogram -x 1600 -Y 1200 -o "C:\temp\foo_temp\Image.png"
mspaint.exe "C:\temp\foo_temp\Image.png"
In 1.6.12 it works as expected: creates spectrogram and opens it in MS Paint.
Re: foobar2000 v2.0 bugs/toggle album art
Is there a way to toggle album art? I used to be able to just mouse click the area and it would switch between front and back covers.
reFACET in foobar2.0 doesn't show me my folders even I choose the folder colums...
By "folder", you mean "album art"? ReFacets doesn't do that... yet. It shows folder names.
Columns UI does that. Not sure if DUI did but I've been wrong a few times today so who knows.  :P
I would be happy with a key command to toggle album art (assign to mouse button).
Layout Editing Mode
The Layout Editing Mode can't be finished completely.
After switching it off the blue splitters indeed turn to grey ...
but even locked (the new method) splitters stay movable.
In Preferences > Output, Enable smooth seeking, pause and volume changes under Fading.
And then, play a stereo track after a mono track --> Gapless playback does not work!
Play a stereo track after a stereo track --> Gapless playback works.
BUG:
When it drop a file from windows explorer to a playlist with many files and the playlist is focused on any file (the scrollbar is up or down), the scrollbar centers, losing the focus where i was.
In V1 I restore fb2k from notification bar with one click.
In VW I restore fb2k from notification bar with TWO click.
e.c.
I not know because, but now it work.
Gapless playback does not work, if you play a stereo song right after a mono song through ASIO.
Beta 3, 32-bit:
search term "IS" doesn't work.
My Autoplaylist "5 star rating"
%rating IS 5%
doesn't get any results or just music files which have been added today.
%rating HAS 5% is working.
