Topic: Georgia-ReBORN - A Clean foobar2000 Theme (Read 174123 times) previous topic - next topic
howdin and 4 Guests are viewing this topic.
Re: Georgia-ReBORN - A Clean foobar2000 Theme
Reply #225
@handleyman,
just pushed a new commit to support lyrics when streaming, I think you might be interested.
Should work out of the box without changing anything in Lyric Show 3 preferences. Thanks goes to @zeremy for showing me
a better workaround as I previously had :-). Get it here.
Cheers
-TT
Great, thanks. Do I have to replace whole Profile folder, or can i just replace what has been changed??
Yea, just replace what has changed. You can also add my changes from Github to your javascript files.
Btw, I don't know if you changed your Lyric Show 3 preferences, but it works best if option "Search for this type of lyric" is set to Prefer synced.
This is by default if you didn't change anything.
-TT
Mmmm.. thing is, I'm not sure which bits have changed?!
Reply #226
Hi @Azemoth,
So does this happen only for that album you're playing?
Check your PM.
-TT
Reply #227
@handleyman,
sorry but a lot of things has changed since that post it was written.
You can view it here: https://github.com/TT-ReBORN/Georgia-ReBORN/commits/master
If you click on a commit, you will see what has changed and which files ( if you click on the Showing * changed files )
has changed...
I've also added playlist row hover effect plus added Option to enable/disable the playlist/library row mouse hover,
added mouse wheel scroll for manually cycling through artworks, more support for booklet artwork, auto-playlists, other options,
fixed some bugs and updated foo_ui_columns to 1.7.0 and updated config files. The radio lyric support can be found in "Commits on Nov 11, 2021".
This means, it's much faster to make a new portable install and just download the latest up to date version,
instead of adding the changes to your modified files. Copy and note all your changes somewhere and just copy it to the new files, it's much faster that way...
As I have already written, when the first public release will be published, you can then just wait for the next version when it will be released,
instead of always looking for every commit I'm pushing on Github...
-TT
Reply #228
Hi TT, thanks in advance, what a stunning theme, best ever, period. I'm getting an "Aw crashed" screen with this message:
Error: Spider Monkey Panel v1.5.2 ({04620F16-1878-47A1-8EFE-0CE0B99566CC}: Georgia-ReBORN v2.0.3 by TT)
class constructors must be invoked with 'new'
File: Common.js
Line: 515, Column: 24
Stack trace:
  assert@Common.js:515:24
  generate_first_item_to_draw@Panel_Playlist.js:3145:3
  generate_items_to_draw@Panel_Playlist.js:3045:25
  on_content_to_draw_change@Control_List.js:429:22
  on_content_to_draw_change@Panel_Playlist.js:1987:44
  update_list_h_size@Control_List.js:507:14
  on_h_size@Control_List.js:392:14
  on_size@Control_List.js:160:18
  on_size@Panel_Playlist.js:759:26
  PlaylistPanel/this.on_size@Panel_Playlist.js:297:13
  btnActionHandler@Control_Button.js:399:15
  onClick@Control_Button.js:169:3
  buttonEventHandler@Control_Button.js:92:16
  on_mouse_lbtn_up@georgia-reborn-main.js:3806:3
Reply #229
File: Common.js
Stack trace:
Hi @FoobyClass,
Over the last 4 weeks I have fixed a lot of bugs and crashes various users have reported to me, I have also tweaked a lot...
This crash has been also fixed. I recommend not only to you, but all Georgia-ReBORN users to update it to the latest state as of now.
I do think that it's very close for the first public release, as most bugs and crashes have been fixed.
I guess the release will be in the early next year. If you all can't wait, you can update it as of now, it's definitely worth it.
Download it as usual here and replace your files.
Also be sure to clear your SMP properties, first make sure disable right click is turned off ( Options > Settings > Disable right-click ).
Right click top menu or playbar > Panel properties > Clear. Click OK.
Thanks to all users who are reporting bugs!
-TT
Reply #230
Many many thanks !!!!
Reply #231
Hi, I have a question. How to synchronize red box (see pic) with blue box (see pic)? https://imgur.com/a/bCqLBZL. Any help is appreciated.
Reply #232
Hi @meongmmiuww,
first be sure that the album cover is the same as the thumbnail and it's named folder.jpg/folder.png or cover.jpg/cover.png
and it is in the same album folder.
Maybe your album folder contains more than one image ( folder/cover ) and you are not aware of the feature to manually cycle through images via mouse wheel scroll.
If that's the case you can try to move your mouse cursor over the album cover and mouse wheel scroll up or down and see if the image will change. If you don't want this feature you can also deactivate it under
top menu Options > Player controls > Cycle album artwork with mouse wheel. This feature will only work if you have more than one image in your album folder and if your mouse cursor is over the album cover.
If there is only one image, it will mouse scroll the playlist or library.
You can also check the FAQ " How do you display the disc art in Details" on Github to learn more about the supported folder structure and naming the images.
-TT
Reply #233
Hi @meongmmiuww,
-TT
Hi, thanks for the explanation. It works perfectly :)
Reply #234
Dear TT, Happy New Year!!!
Here, reporting a crash (I've installed the last version of the theme and foobar):
Aw, crashed
foo_spider_monkey_panel
File: Common.js
Stack trace:
  on_size@Panel_Playlist.js:758:26
  PlaylistPanel/this.on_size@Panel_Playlist.js:296:13
  on_mouse_lbtn_up@georgia-reborn-main.js:3858:3
Hi @meongmmiuww,
-TT
Reply #235
Hi @FoobyClass,
I have already sent you a PM, please check your inbox. Thanks!
Happy new year to you all.
-TT
Reply #236
Hey TT,
First off, love the theme, cheers for making it available.
I have an issue at the moment. I'll try to upload a screenshot at the bottom.
When I choose Black, White or Reborn themes it puts a coloured area on the left side next to the album art.
I noticed it does this when in fullscreen.
The screen I screenshot from is a 1080 but it also does this on a 4k screen.
It's like it's not scaling properly.
Reply #237
Hi @CelticDog,
do you actually mean the maximize function ( double click on top menu ) ?
Because in fullscreen ( ▢ in the top right corner next to X ) and HD res the album art should be completely filled ( a bit cut off ).
The left gap is a colored filled background with primary color because the theme always wants to proportional scale the album art.
If it's not scaled proportional with the foobar player, the colored gap will fill the "hole". This also happens if you manually resize
the player in width or height and it's not proportional scaled. If that happens, you can just scale the width or height until the gap
disappears. Or just simply use the predefined player sizes in top menu Options > Player size.
If you use the maximize function, it will always fill the whole screen - taskbar and the gap will always be there because the maximize
does not care about proportions and it just wants to fill the screen.
Back then I've tried to implement proportional scaling via ui_hacks and it just not works properly, asked TheQwertiest about it and he told me that he wants to implement a proportional scaling via SMP in the future.
I can add an option to disable the color filled gap but there will be a hole, I guess this comes to individual user choice...
-TT
Reply #238
Hi TT, thank you for making the cleanest theme available on foobar love it w all my heart & have been using it for atleast 6 months now. Every time I increase the size or fullscreen my library view always reverts to 2 album covers instead of whatever I set it as before. https://ibb.co/cJJBB3L
I obsess over crisp album art & its satisfying to look at more than 3 albums in a row scrolling through my library fullscreen. I modify it usually to fit 3 by changing the thumbnail size to medium, but anytime I want my player to be bigger or fullscreen the thumbnail size auto reverts back to large, is there a way to change it permanently or until I want to modify it again? Instead of changing it back everytime I increase the size of foobar, thanks again bro u really do foobar a justice lol
Reply #239
Hi @k333p,
what resolution are you using? Never saw 2 rows like in your screenshot...
In Full HD, player size 'Small' should have 6 rows, 'Normal' has 5 rows and 'Large' or Fullscreen has 4 rows.
I think it's also the same for 4K res. You can override the auto-resize and change it manually in top menu Options > Library > Album art > Thumbnail size.
Auto changes thumbnail size automatically based on player size.
Btw any reason why you did not install all fonts correctly ( Guifx v2 Transports ) ? :)
-TT
Reply #240
@CelticDog,
I have added an option to disable the colored gap left next to the album art if player size is not proportional scaled.
It can be now found in top menu Options > Player controls > Show colored gap if player size is not proportional
This option is enabled on default, you need to deactivate it if you don't want it.
Download as usual from here and replace your existing files.
-TT
Reply #241
Hello TT,
Thank you for making this great-looking theme! Just one quick question, is there a way to auto-fill the playlist when selecting an album in the library? This feature is present in the original Georgia theme but I cannot find this setting on Reborn.
Thank you again for making this theme!
Reply #242
Hi Hotdogs02,
yea it's possible, if you go to the Library and click on the settings button icon ... ( next to the Filter button ) and then Options.
In the left top corner click on Single-click and change the behavior.
Edit: Added it, can be now found in top menu Options > Library > Single-click action
Download from here and replace your existing files...
-TT
Reply #243
@CelticDog,
-TT
Perfect solution. Thankyou very much.
Reply #244
Hi Hotdogs02,
-TT
Thank you! It works great!
Reply #245
Hi Hotdogs02,
-TT
I think I've asked this before, but I didn't really understand the reply... is there a simple way of finding out which files have changed and just replacing those? Otherwise, any changes and settings I've made just get over-written each time. Maybe when improvements are made (to an already great theme!), those 'newly changed' files could also be stored in a .zip of their own?
Reply #246
@handleyman,
If users are editing the javascript files with their own code, there is just no way to give you a satisfied answer at all.
I can't give you the changes to a stored zip file, it's not feasible. All changes are showed here:
At the moment we are at 165 commits, every commit has an ID, the current one is a91b937, named "Added new option "Single-click action" in Options > Library".
So if I do new changes there will be new commits. You can click on those new commits to see what code has been added/removed or changed. If you click on the latest commit, you will see Showing 1 changed file with 5 additions and 1 deletion.
If you click on this you will see which files have been modified. It can be also seen in the header.
You can add those changes to your modified Georgia-ReBORN but this is really not good, because soon I will be releasing an update which has ALOT of changes in MANY files and it would be too much effort to add those.
After this update, there will be the first public release of Georgia-ReBORN. And then other updates will come in the future.
So in your case it would be the best to make notes of your changes and copy those in a new file. You can readd those when new updates will be released, those updates will not be so frequently.
-TT
Reply #247
That;'s brilliant. TT. Very helpful. Thank you. It was mainly the settings in Library, playlist, etc. Great theme - and your work is most appreciated.
Reply #248
First of all thanks a ton to the creator of this theme.
I am a newbie to Foobar2000 customization, and would like to have the following as part of this theme and foobar2000.
1. Waveform seeker
2. Equalizer
Thanks a ton in advance for the help that you guys provide.
