Topic: foo_run (Read 613517 times) previous topic - next topic
Re: foo_run 0.3.8
Reply #675
does anyone know how to configure for CUETools?
so that the check on the accuraterip database starts and the file is automatically saved
Re: foo_run 0.3.8
Reply #676
"c:\Portable App\CUETools\CUETools.exe" "%_path%"
did you figure out how to run the check automatically?
Re: foo_run 0.3.8
Reply #677
Hi guys,
i know the last post was a long time ago, but i think it's still the best place to ask.
1) Would anyone know the code for a search in allmusic.com combining artist + album,
2) same question for discogs, combining the codes below ?
Discogs artist
https://www.discogs.com/es/search/?q=$replace(%artist%, ,+)&type=artist
Discogs album
https://www.discogs.com/es/search/?q=$replace(%album%, ,+)&type=master
Cheers
Nico
Re: foo_run 0.3.8
Reply #678
I found the solution for discogs, on this forum:
https://www.discogs.com/search?q=$replace(%artist%+%album%, ,+)&ie=utf-8
But i'm still looking for allmusic.com. So far i tried:
http://www.allmusic.com/search?q=$replace(%artist%+%album%, ,+)
http://www.allmusic.com/search/artist/$replace(%artist%, ,+)/search/album/$replace(%album%, ,+)
But none are working.
Any help would be appreciated.
Re: foo_run 0.3.8
Reply #679
@mrnike
The spaces need to be replaced with:
%20
You may find that other characters need replacing like ( and ) etc.
When you search in your browser you'll see these when you search via your browser.
Re: foo_run 0.3.8
Reply #680
I'm not sure i understood you.
You mean i should add %20 wherever there is a space in my code ? I doubt this is the problem, as the code for discogs works perfectly wihtout the %20.
What i'm trying to archive is to combine those 2 codes
http://www.allmusic.com/search/album/$replace(%album%, ,+)
as per the discogs code, in order to get a more precise search results.
Re: foo_run 0.3.8
Reply #681
mrnike I don't know if this will help you:
http://www.allmusic.com/search/album/$replace(%artist%+ %album%, ,+)
YouTube Music
Re: foo_run 0.3.8
Reply #682
Brillant !
Thanks SergPuh.68.
Re: foo_run 0.3.8
Reply #683
When you search on the site itself it replaces whitespace with the %20. Like this: https://www.allmusic.com/search/all/one%20two
Which is URL Encoding using ASCII Encoding Reference, see here:
https://www.w3schools.com/tags/ref_urlencode.ASP
So both these work exactly the same:
http://www.allmusic.com/search/album/$replace(%artist%+%album%, ,+)
http://www.allmusic.com/search/album/$replace(%artist%+%album%, ,'%20')
Re: foo_run 0.3.8
Reply #684
MTP file transfers to my Android phone are impossibly slow so I've had to rely on pushing files through command line with Android Debug Bridge. For example: cmd adb push "folder" "phone/sd_card/folder".
I was wondering if there was a way, maybe through using foo_run, to conveniently copy files to my phone instead? (I'm a code noob!) In the same way that it's convenient to use the "File Operations" in foobar2000 to transfer files.
Re: foo_run 0.3.8
Reply #685
Nevermind, I found my answer. (Sorry I'm a novice; feel free to delete these two messages.)
adb.exe push "%path%" "sd_card"
Re: foo_run 0.3.8
Reply #686
Does anyone know how to get rid of the trailing whitespace when using?
cmd /c echo $trim(%album artist% %album%)|CLIP
This results in a carriage return on the CLIP.
Re: foo_run 0.3.8
Reply #687
Use echo|set to remove trailing newline...
Titleformat output to clipboard:
cmd /c echo|set /p=$trim(%album artist% - %album%)|CLIP
Re: foo_run 0.3.8
Reply #689
Hi could tell me how implement code in foobar ?
Re: foo_run 0.3.8
Reply #691
thank you very much.
I don't know why I don't see Run services in Tools
Re: foo_run 0.3.8
Reply #693
ok, got this, thank you!!
Re: foo_run 0.3.8
Reply #694
Is it possible to pipe the results of a Run Service into a playlist column? I'm trying to get the file checksum into a playlist column so that I can manually review for duplicates (I can't just use foo_audiomd5 for this because they're midi files and ffmpeg doesn't know how to take the audio md5 of those)
Re: foo_run 0.3.8
Reply #695
Since I didn’t find a useful CUE sheet editor, I set a AutoHotkey script that creates or appends to a file. But when I pass the current playing position (%playback_time% or %time_elapsed%), foobar2000 only sends a “?”.
Any ideas on how to send the current playing position automatically to the script?
Re: foo_run 0.3.8
Reply #696
How do I open files with different apps? Let's say Audacity.
I've been trying this: "C:\Program Files (x86)\Audacity\audacity.exe" "%_path%"
Doesn't work. Nothing comes up.
Re: foo_run 0.3.8
Reply #697
The brackets need escaping like so:
"C:\Program Files '('x86')'\Audacity\audacity.exe" "%_path%"
Re: foo_run 0.3.8
Reply #698
Awesome! It works. Many thanks!
Re: foo_run 0.3.8
Reply #699
How can I open selected files with Serato? I also have foo_run_group, but I can't find a solution.
Thanks in advance , if anyone can help.
