i use EAC through the current version of Ubuntu under Wine
So all the commands listed below work on Windows [change path to encoder if there is path to encoder in the command line] and the settings are written here for Ubuntu [see bottom of page to install 1.0.3 on Ubuntu]
hit F5 to see compression option Box
AFTER version 1.0 b2 all Placeholders were changed
so now for flac
-8 -V -T "ARTIST=%artist%" -T "TITLE=%title%" -T "ALBUM=%albumtitle%" -T "DATE=%year%" -T "TRACKNUMBER=%tracknr%" -T "GENRE=%genre%" -T "PERFORMER=%albuminterpret%" -T "COMPOSER=%composer%" %haslyrics%--tag-from-file=LYRICS="%lyricsfile%"%haslyrics% -T "ALBUMARTIST=%albumartist%" -T "DISCNUMBER=%cdnumber%" -T "TOTALDISCS=%totalcds%" -T "TOTALTRACKS=%numtracks%" -T "COMMENT=%comment%" %source% -o %dest%
for wavpack
-hmx3 -w "Artist=%artist%" -w "Title=%title%" -w "Album=%albumtitle%" -w "Year=%year%" -w "Genre=%genre%" -w "Tracknumber=%tracknr%" -w "Performer=%albuminterpret%" -w "Composer=%composer%" %haslyrics%--tag-from-file=lyrics="%lyricsfile%"%haslyrics% -w "Albumartist=%albumartist%" -w "Discnumber=%cdnumber%" -w "Totaldiscs=%totalcds%" -w "Totaltracks=%numtracks%" -w "Comment=%comment%" -w "Logfile=@file.ext" %source% %dest%
for ape [2 routes]
Route 1
• Monkey's Audio
Note: Along with the Monkey's Audio encoder we will be using Case's Wapet to write
APEv2 tags to the Monkey's Audio files.
1 Click EAC, Compression Options.
2 Click the External Compression tab.
3 Enable the Use external program for compression option.
4 Change Parameter passing scheme to User Defined Encoder.
5 In the Use file extension text box type in .ape.
6 In the Program, including path, used for compression text box type in the location
of the WAPET.EXE file or click the Browse button to locate theWAPET.EXE file.
command line:
%dest% -t "Artist=%artist%" -t "Title=%title%" -t "Album=%albumtitle%" -t "Year=%year%" -t "Genre=%genre%" "/home/yourname/.wine/dosdevices/c:/Program Files (x86)/Monkey's Audio\MAC.exe" %source% %dest% -c3000
![](http://i52.fastpic.ru/big/2012/1229/f5/ad994bc4d1c6610704e3bd791b31a7f5.png)
Alternatively Route 2 [easier]
forget wapet and ape tags; it is also happy with ID3 tags this much simpler way
![](http://i51.fastpic.ru/big/2012/1229/03/78ed53c0ec9169ba33131845b0db6e03.png)
tta [tick add id3 tags for tagging]
-e %source% -o %dest%
![](http://i51.fastpic.ru/big/2012/1229/ea/395453e26108e66ea3773a0b715d8bea.png)
tak
Tak works in the same way as ape as it requires 2 codecs wapet.exe which writes the tags and that you already have for ape and takc.exe which you find here and in the zip
%dest% -t "Artist=%artist%" -t "Title=%title%" -t "CD artist=%albumartist%" -t "ALBUM=%albumtitle%" -t "COMPOSER=%composer%" %haslyrics%--tag-from-file=LYRICS="%lyricsfile%"%haslyrics% -t "Year=%year%" -t "Genre=%genre%" -t "TRACKNUMBER=%tracknr%" -t "TOTALTRACKS=%numtracks%" -t "COMMENT=%comment%" "C:\Program Files (x86)\Exact Audio Copy\Flac\Takc.exe" -e -p2 %source% %dest%
![](http://i52.fastpic.ru/big/2012/1229/0b/e8c31f2950b8f7f6f5208d6b9a5a6c0b.png)
Alac[Audio Lossless Advanced Codec]
--no-optimize -A -i %source% -o %dest% --artist "%artist%" --title "%title%" --album "%albumtitle%" --date "%year%" --track "%tracknr%" --genre "%genre%" --comment "%comment%"
--composer "%composer%" --track "%tracknr%"
place the entire qaac folder from here into flac folder in EAC and use qaac.exe
![](http://i53.fastpic.ru/big/2012/1227/5f/fbda71c531282f7d2feaf05df0de025f.png)
![](http://i51.fastpic.ru/big/2012/1229/63/52f0cf2b89bb03cf5ec3a16779279c63.png)
shorten is the easiest of them all
![](http://i52.fastpic.ru/big/2012/1229/b3/5ce96dc6489dcc9b003bc2b5a176d1b3.png)
mp3HD
(click for info)
is a hybrid format. it plays lossless in winamp with a plugin. It plays lossy
everywhere else but i include it as it is rather an oddity
-if %source% -of %dest% -br 320000
ensure you have regular mp3 lame encoder present too as it needs that for the lossy part
AND make absolutely sure that you have done this: right click on mp3hdEncoder open with
Wine and say Yes to agreement otherwise it will not work
![](http://i51.fastpic.ru/big/2012/1229/90/59ba91f42945c70f3903b50daa0b0090.png)
INSTALLING 1.0.3 ON UBUNTU is a bit of a performance but follow those steps and you should be there...
SO TO INSTALL EAC 1.0 beta 3 under Wine
1. INSTALL WINE
2. Download latest version of eac
then run
cd ~/.wine/dosdevices/c\:/Program\ Files\ \(x86\)/Exact\ Audio\ Copy/
regsvr32 sql*
which will give you in your terminal
~/.wine/dosdevices/c:/Program Files/Exact
> Audio Copy$ regsvr32 sql*
> Successfully registered DLL sqlceca35.dll
> DllRegisterServer not implemented in DLL sqlcecompact35.dll
> Successfully registered DLL sqlceoledb35.dll
> DllRegisterServer not implemented in DLL sqlceqp35.dll
> DllRegisterServer not implemented in DLL sqlcese35.dll
3. At this point 1.0 will appear but may not see your cd drive
to remedy that
sudo mkdir /media/cdrom0
sudo gedit /etc/fstab
Add this line at bottom on a new line
/dev/sr0 /media/cdrom0 udf,iso9660 user,noauto,exec 0 0
save
Go to:
Applications/Wine/Configure Wine/Drive/Add a new drive [ call it D or whatever is not already in use]
and do this
![](http://i52.fastpic.ru/big/2012/1229/f1/78eb9e25c7b991aee81345d4cb2ff2f1.png)
now your drive is visible![/font][/size]
